[U-Boot] [PATCH] serial: uartlite: Support for SERIAL_MULTI
Add support for SERIAL MULTI for Microblaze. It can be used by other archs too.
Signed-off-by: Michal Simek monstr@monstr.eu --- arch/microblaze/lib/board.c | 4 + common/serial.c | 14 ++++ drivers/serial/serial_xuartlite.c | 138 +++++++++++++++++++++++++++++----- include/configs/microblaze-generic.h | 2 + include/serial.h | 9 ++- 5 files changed, 148 insertions(+), 19 deletions(-)
diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index c00d96b..3b671b8 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -31,6 +31,7 @@ #include <watchdog.h> #include <stdio_dev.h> #include <net.h> +#include <serial.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -111,6 +112,9 @@ void board_init (void)
monitor_flash_len = __end - __text_start;
+#ifdef CONFIG_SERIAL_MULTI + serial_initialize(); +#endif /* * The Malloc area is immediately below the monitor copy in DRAM * aka CONFIG_SYS_MONITOR_BASE - Note there is no need for reloc_off diff --git a/common/serial.c b/common/serial.c index 995d268..df02fa5 100644 --- a/common/serial.c +++ b/common/serial.c @@ -108,6 +108,20 @@ void serial_initialize (void) #if defined(CONFIG_SYS_BFIN_UART) serial_register_bfin_uart(); #endif +#if defined(CONFIG_XILINX_UARTLITE) +# ifdef XILINX_UARTLITE_BASEADDR + serial_register(&uartlite_serial0_device); +# endif /* XILINX_UARTLITE_BASEADDR */ +# ifdef XILINX_UARTLITE_BASEADDR1 + serial_register(&uartlite_serial1_device); +# endif /* XILINX_UARTLITE_BASEADDR1 */ +# ifdef XILINX_UARTLITE_BASEADDR2 + serial_register(&uartlite_serial2_device); +# endif /* XILINX_UARTLITE_BASEADDR2 */ +# ifdef XILINX_UARTLITE_BASEADDR3 + serial_register(&uartlite_serial3_device); +# endif /* XILINX_UARTLITE_BASEADDR3 */ +#endif /* CONFIG_XILINX_UARTLITE */ serial_assign (default_serial_console ()->name); }
diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 00d0eaa..3e83217 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -25,20 +25,76 @@ */
#include <config.h> +#include <common.h> #include <asm/io.h> - -#define RX_FIFO_OFFSET 0 /* receive FIFO, read only */ -#define TX_FIFO_OFFSET 4 /* transmit FIFO, write only */ -#define STATUS_REG_OFFSET 8 /* status register, read only */ +#include <linux/compiler.h> +#include <serial.h>
#define SR_TX_FIFO_FULL 0x08 /* transmit FIFO full */ #define SR_RX_FIFO_VALID_DATA 0x01 /* data in receive FIFO */ #define SR_RX_FIFO_FULL 0x02 /* receive FIFO full */
-#define UARTLITE_STATUS (CONFIG_SERIAL_BASE + STATUS_REG_OFFSET) -#define UARTLITE_TX_FIFO (CONFIG_SERIAL_BASE + TX_FIFO_OFFSET) -#define UARTLITE_RX_FIFO (CONFIG_SERIAL_BASE + RX_FIFO_OFFSET) +struct uartlite { + volatile u32 rx_fifo; + volatile u32 tx_fifo; + volatile u32 status; +}; + +static struct uartlite *userial_ports[4] = { +#ifdef XILINX_UARTLITE_BASEADDR + (struct uartlite *)XILINX_UARTLITE_BASEADDR, +#else + NULL, +#endif +#ifdef XILINX_UARTLITE_BASEADDR1 + (struct uartlite *)XILINX_UARTLITE_BASEADDR1, +#else + NULL, +#endif +#ifdef XILINX_UARTLITE_BASEADDR2 + (struct uartlite *)XILINX_UARTLITE_BASEADDR2, +#else + NULL, +#endif +#ifdef XILINX_UARTLITE_BASEADDR3 + (struct uartlite *)XILINX_UARTLITE_BASEADDR3 +#else + NULL +#endif +}; + +void uartlite_serial_putc(const char c, const int port) +{ + struct uartlite *regs = userial_ports[port]; + if (c == '\n') + uartlite_serial_putc('\r', port); + while (regs->status & SR_TX_FIFO_FULL) + ; + regs->tx_fifo = (unsigned char) (c & 0xff); +} + +void uartlite_serial_puts(const char * s, const int port) +{ + while (*s) { + uartlite_serial_putc(*s++, port); + } +} + +int uartlite_serial_getc(const int port) +{ + struct uartlite *regs = userial_ports[port]; + while (!(regs->status & SR_RX_FIFO_VALID_DATA)) + ; + return regs->rx_fifo & 0xff; +} + +int uartlite_serial_tstc(const int port) +{ + struct uartlite *regs = userial_ports[port]; + return regs->status & SR_RX_FIFO_VALID_DATA; +}
+#if !defined(CONFIG_SERIAL_MULTI) int serial_init(void) { /* FIXME: Nothing for now. We should initialize fifo, etc */ @@ -52,26 +108,72 @@ void serial_setbrg(void)
void serial_putc(const char c) { - if (c == '\n') - serial_putc('\r'); - while (in_be32((u32 *) UARTLITE_STATUS) & SR_TX_FIFO_FULL); - out_be32((u32 *) UARTLITE_TX_FIFO, (unsigned char) (c & 0xff)); + uartlite_serial_putc(c, 0); }
-void serial_puts(const char * s) +void serial_puts(const char *s) { - while (*s) { - serial_putc(*s++); - } + uartlite_serial_puts(s, 0); }
int serial_getc(void) { - while (!(in_be32((u32 *) UARTLITE_STATUS) & SR_RX_FIFO_VALID_DATA)); - return in_be32((u32 *) UARTLITE_RX_FIFO) & 0xff; + return uartlite_serial_getc(0); }
int serial_tstc(void) { - return (in_be32((u32 *) UARTLITE_STATUS) & SR_RX_FIFO_VALID_DATA); + return uartlite_serial_tstc(0); +} +#endif + +#if defined(CONFIG_SERIAL_MULTI) +/* Multi serial device functions */ +#define DECLARE_ESERIAL_FUNCTIONS(port) \ + int userial##port##_init (void) {return(0);}\ + void userial##port##_setbrg (void) {}\ + int userial##port##_getc (void) {return uartlite_serial_getc(port);}\ + int userial##port##_tstc (void) {return uartlite_serial_tstc(port);}\ + void userial##port##_putc (const char c) {uartlite_serial_putc(c, port);}\ + void userial##port##_puts (const char *s) {uartlite_serial_puts(s, port);} + +/* Serial device descriptor */ +#define INIT_ESERIAL_STRUCTURE(port,name) {\ + name,\ + userial##port##_init,\ + NULL,\ + userial##port##_setbrg,\ + userial##port##_getc,\ + userial##port##_tstc,\ + userial##port##_putc,\ + userial##port##_puts, } + +DECLARE_ESERIAL_FUNCTIONS(0); +struct serial_device uartlite_serial0_device = + INIT_ESERIAL_STRUCTURE(0,"ttyUL0"); +DECLARE_ESERIAL_FUNCTIONS(1); +struct serial_device uartlite_serial1_device = + INIT_ESERIAL_STRUCTURE(1,"ttyUL1"); +DECLARE_ESERIAL_FUNCTIONS(2); +struct serial_device uartlite_serial2_device = + INIT_ESERIAL_STRUCTURE(2,"ttyUL2"); +DECLARE_ESERIAL_FUNCTIONS(3); +struct serial_device uartlite_serial3_device = + INIT_ESERIAL_STRUCTURE(3,"ttyUL3"); + +__weak struct serial_device *default_serial_console(void) +{ +# ifdef XILINX_UARTLITE_BASEADDR + return &uartlite_serial0_device; +# endif /* XILINX_UARTLITE_BASEADDR */ +# ifdef XILINX_UARTLITE_BASEADDR1 + return &uartlite_serial1_device; +# endif /* XILINX_UARTLITE_BASEADDR1 */ +# ifdef XILINX_UARTLITE_BASEADDR2 + return &uartlite_serial2_device; +# endif /* XILINX_UARTLITE_BASEADDR2 */ +# ifdef XILINX_UARTLITE_BASEADDR3 + return &uartlite_serial3_device; +# endif /* XILINX_UARTLITE_BASEADDR3 */ } +#endif /* CONFIG_SERIAL_MULTI */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 0f46e62..1b60bfa 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -31,6 +31,8 @@ #define CONFIG_MICROBLAZE 1 #define MICROBLAZE_V5 1
+#define CONFIG_SERIAL_MULTI 1 + /* uart */ #ifdef XILINX_UARTLITE_BASEADDR # define CONFIG_XILINX_UARTLITE diff --git a/include/serial.h b/include/serial.h index ff1ce99..f047d2f 100644 --- a/include/serial.h +++ b/include/serial.h @@ -31,7 +31,7 @@ extern struct serial_device * default_serial_console (void); defined(CONFIG_MB86R0x) || defined(CONFIG_MPC5xxx) || \ defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || \ defined(CONFIG_MPC86xx) || defined(CONFIG_SYS_SC520) || \ - defined(CONFIG_TEGRA2) + defined(CONFIG_TEGRA2) || defined(CONFIG_MICROBLAZE) extern struct serial_device serial0_device; extern struct serial_device serial1_device; #if defined(CONFIG_SYS_NS16550_SERIAL) @@ -50,6 +50,13 @@ extern struct serial_device serial4_device; extern struct serial_device serial6_device; #endif
+#if defined(CONFIG_XILINX_UARTLITE) +extern struct serial_device uartlite_serial0_device; +extern struct serial_device uartlite_serial1_device; +extern struct serial_device uartlite_serial2_device; +extern struct serial_device uartlite_serial3_device; +#endif + #if defined(CONFIG_S3C2410) extern struct serial_device s3c24xx_serial0_device; extern struct serial_device s3c24xx_serial1_device;
Dear Michal Simek,
Checkpatch says:
total: 16 errors, 17 warnings, 231 lines checked
Please clean up and resubmit. Thanks.
Michal Simek
