[U-Boot-Users] Setting strataflash lock bit accidentally
Let's assume that, because a software bug, an application has accidentally set the lock bit of the flash sector used to store the U-Boot environment. In this case, when trying to store a new environment with the saveenv command, U-Boot would not be able to complete the operation. Is it enough to define CFG_FLASH_PROTECTION in order to handle this situation and to allow U-Boot to unlock the sector (same thing would happen in case the locked sectors fall in the memrory area devoted to store kernels or ramsisks)? If no, how do you suggest to manage this situation?
TIA, llandre
DAVE Electronics System House - R&D Department web: http://www.dave-tech.it email: r&d2@dave-tech.it
Use MTD tools under Linux to unlock the flash?
Indeed this is a possible solution but I'm looking for a general one implemented in u-boot. In fact it must work with any operating system and I must assume o.s. might not provide MTD or similar tools.
It is easy to postulate requirements. But seriously, if you are careless enough to use flash chips which can change modes or even lose data by just writing random data to sequential addresses then you must also accept the consequences. Either provide adequate recovery mechanisms in Linux or your OS of choice or in U-Boot.
I have to admit that I fail to understand what exactly your problem is: if you want to use the hardware protection features in U-Boot (including the unlocking of locked sectors) then just enable this feature in U-Boot.
llandre
