[PATCH v3 8/9] board: freescale: t2080qds: Update I2C mux config
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson stcarlso@linux.microsoft.com --- board/freescale/t208xqds/t208xqds.c | 26 +---------------------- configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + 7 files changed, 7 insertions(+), 25 deletions(-)
diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index fd3217f24d..715de106d6 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -22,6 +22,7 @@ #include <asm/fsl_serdes.h> #include <asm/fsl_liodn.h> #include <fm_eth.h> +#include "../common/i2c_mux.h"
#include "../common/qixis.h" #include "../common/vsc3316_3308.h" @@ -79,31 +80,6 @@ int checkboard(void) return 0; }
-int select_i2c_ch_pca9547(u8 ch, int bus_num) -{ - int ret; - -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - bus_num); - return ret; - } - ret = dm_i2c_write(dev, 0, &ch, 1); -#else - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); -#endif - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - int i2c_multiplexer_select_vid_channel(u8 channel) { return select_i2c_ch_pca9547(channel, 0); diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index b395bf17aa..b06117bda2 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -83,3 +83,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 53b82f789f..7c4ba2f53c 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -80,3 +80,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 4d33dc6a3a..f8f031f778 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -70,3 +70,4 @@ CONFIG_SYS_NUM_ADDR_MAP=64 CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index aa4f094cb5..2230e214d4 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -82,3 +82,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 0677053e21..9ab1cdfe8c 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -60,3 +60,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index c9d1fec300..1cbc947454 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -68,3 +68,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 +CONFIG_FSL_USE_PCA9547_MUX=y
Stephen Carlson
