[U-Boot] [PATCH v2] arm64: zynqmp: Add QSPI flash mini u-boot configuration
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint of internal memory. This configuration has only required qspi flash support and it uses DCC as serial.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- Chnages for v2: - Fixed copyright year - Fixed memory node - Removed partitions in flash node - Moved CONFIG_MP to kconfig
This patch is based on https://lists.denx.de/pipermail/u-boot/2018-July/335126.html --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynqmp-mini-qspi.dts | 79 +++++++++++++++++++++++++++++++ configs/xilinx_zynqmp_mini_qspi_defconfig | 61 ++++++++++++++++++++++++ include/configs/xilinx_zynqmp_mini_qspi.h | 21 ++++++++ 4 files changed, 162 insertions(+) create mode 100644 arch/arm/dts/zynqmp-mini-qspi.dts create mode 100644 configs/xilinx_zynqmp_mini_qspi_defconfig create mode 100644 include/configs/xilinx_zynqmp_mini_qspi.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6785fef..6bbe2a3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -152,6 +152,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-mini-emmc0.dtb \ zynqmp-mini-emmc1.dtb \ zynqmp-mini-nand.dtb \ + zynqmp-mini-qspi.dtb \ zynqmp-zcu100-revC.dtb \ zynqmp-zcu102-revA.dtb \ zynqmp-zcu102-revB.dtb \ diff --git a/arch/arm/dts/zynqmp-mini-qspi.dts b/arch/arm/dts/zynqmp-mini-qspi.dts new file mode 100644 index 0000000..c235a5f --- /dev/null +++ b/arch/arm/dts/zynqmp-mini-qspi.dts @@ -0,0 +1,79 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Xilinx ZynqMP Mini Configuration + * + * (C) Copyright 2015 - 2018, Xilinx, Inc. + * + * Siva Durga Prasad siva.durga.paladugu@xilinx.com + * Michal Simek michal.simek@xilinx.com + */ + +/dts-v1/; + +/ { + model = "ZynqMP MINI QSPI"; + compatible = "xlnx,zynqmp"; + #address-cells = <2>; + #size-cells = <1>; + + aliases { + serial0 = &dcc; + spi0 = &qspi; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@fffc0000 { + device_type = "memory"; + reg = <0x0 0xfffc0000 0x40000>; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + amba: amba { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <1>; + ranges; + + qspi: spi@ff0f0000 { + compatible = "xlnx,zynqmp-qspi-1.0"; + status = "disabled"; + clock-names = "ref_clk", "pclk"; + clocks = <&misc_clk &misc_clk>; + num-cs = <1>; + reg = <0x0 0xff0f0000 0x1000 0x0 0xc0000000 0x8000000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + misc_clk: misc_clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <125000000>; + }; + }; +}; + +&qspi { + status = "okay"; + flash@0 { + compatible = "n25q512a11"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + spi-max-frequency = <10000000>; + }; +}; + +&dcc { + status = "okay"; +}; diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig new file mode 100644 index 0000000..8b32829 --- /dev/null +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_qspi" +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +CONFIG_ZYNQMP_NO_DDR=y +# CONFIG_CMD_ZYNQMP is not set +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-qspi" +# CONFIG_IMAGE_FORMAT_LEGACY is not set +CONFIG_BOOTDELAY=-1 +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +CONFIG_SYS_PROMPT="ZynqMP> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_MISC is not set +CONFIG_MP=y +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SF_DUAL_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ZYNQMP_GQSPI=y +# CONFIG_EFI_LOADER is not set diff --git a/include/configs/xilinx_zynqmp_mini_qspi.h b/include/configs/xilinx_zynqmp_mini_qspi.h new file mode 100644 index 0000000..6fb0520 --- /dev/null +++ b/include/configs/xilinx_zynqmp_mini_qspi.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration for Xilinx ZynqMP QSPI Flash utility + * + * (C) Copyright 2018 Xilinx, Inc. + * Michal Simek michal.simek@xilinx.com + * Siva Durga Prasad Paladugu sivadur@xilinx.com + */ + +#ifndef __CONFIG_ZYNQMP_MINI_QSPI_H +#define __CONFIG_ZYNQMP_MINI_QSPI_H + +#include <configs/xilinx_zynqmp_mini.h> + +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_SIZE 1400 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x20000) +#define CONFIG_SYS_MALLOC_LEN 0x2000 + +#endif /* __CONFIG_ZYNQMP_MINI_QSPI_H */
Chnages for v2:
- Fixed memory node
- zynqmp-mini-qspi.dtb \ zynqmp-zcu100-revC.dtb \ zynqmp-zcu102-revA.dtb \ zynqmp-zcu102-revB.dtb \
- dts file for Xilinx ZynqMP Mini Configuration
- (C) Copyright 2015 - 2018, Xilinx, Inc.
- Siva Durga Prasad siva.durga.paladugu@xilinx.com
- Michal Simek michal.simek@xilinx.com
+/dts-v1/;
- model = "ZynqMP MINI QSPI";
- compatible = "xlnx,zynqmp";
- #address-cells = <2>;
- #size-cells = <1>;
- aliases {
serial0 = &dcc;
spi0 = &qspi;
- chosen {
- memory@fffc0000 {
- dcc: dcc {
- amba: amba {
#size-cells = <1>;
ranges;
num-cs = <1>;
#size-cells = <0>;
#clock-cells = <0>;
+&qspi {
- status = "okay";
- flash@0 {
#size-cells = <1>;
reg = <0x0>;
+&dcc {
- status = "okay";
- Configuration for Xilinx ZynqMP QSPI Flash utility
- (C) Copyright 2018 Xilinx, Inc.
- Siva Durga Prasad Paladugu sivadur@xilinx.com
Looks good. Will convert that ENV_SIZE myself because it touch other mini zynqmp configurations.
Applied.
Thanks, Michal
Michal Simek
