[U-Boot] [PATCH v2 0/3][Net][ARM] Davinci Ethernet driver cleanup
Hello,
The second spin of this patchset is identical to the first but has been re-based against u-boot/next. Since there were no technical objections with the first spin, I've applied this to the net/next branch.
Please let me know if there are any problems.
regards, Ben
This driver has been renamed dm644x_emac.c
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- cpu/arm926ejs/davinci/Makefile | 2 +- drivers/net/Makefile | 1 + .../davinci/ether.c => drivers/net/dm644x_emac.c | 0 3 files changed, 2 insertions(+), 1 deletions(-) rename cpu/arm926ejs/davinci/ether.c => drivers/net/dm644x_emac.c (100%)
diff --git a/cpu/arm926ejs/davinci/Makefile b/cpu/arm926ejs/davinci/Makefile index 6eaa89c..e45ad25 100644 --- a/cpu/arm926ejs/davinci/Makefile +++ b/cpu/arm926ejs/davinci/Makefile @@ -30,7 +30,7 @@ LIB = $(obj)lib$(SOC).a COBJS-y += cpu.o timer.o psc.o COBJS-$(CONFIG_SOC_DM355) += dm355.o COBJS-$(CONFIG_SOC_DM644X) += dm644x.o -COBJS-$(CONFIG_DRIVER_TI_EMAC) += ether.o lxt972.o dp83848.o +COBJS-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o
SOBJS = reset.o
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index a360a50..26f1ea6 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -64,6 +64,7 @@ COBJS-$(CONFIG_SH_ETHER) += sh_eth.o COBJS-$(CONFIG_DRIVER_SMC91111) += smc91111.o COBJS-$(CONFIG_DRIVER_SMC911X) += smc911x.o COBJS-$(CONFIG_TIGON3) += tigon3.o bcm570x_autoneg.o 5701rls.o +COBJS-$(CONFIG_DRIVER_TI_EMAC) += dm644x_emac.o COBJS-$(CONFIG_TSEC_ENET) += tsec.o COBJS-$(CONFIG_TSI108_ETH) += tsi108_eth.o COBJS-$(CONFIG_ULI526X) += uli526x.o diff --git a/cpu/arm926ejs/davinci/ether.c b/drivers/net/dm644x_emac.c similarity index 100% rename from cpu/arm926ejs/davinci/ether.c rename to drivers/net/dm644x_emac.c
Removed pointless #ifdefs Moved functions around in file in preparation for switch to newer API
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- drivers/net/dm644x_emac.c | 146 +++++++++++++++++++++------------------------ 1 files changed, 69 insertions(+), 77 deletions(-)
diff --git a/drivers/net/dm644x_emac.c b/drivers/net/dm644x_emac.c index f6f81df..f5cec05 100644 --- a/drivers/net/dm644x_emac.c +++ b/drivers/net/dm644x_emac.c @@ -42,10 +42,6 @@ #include <miiphy.h> #include <asm/arch/emac_defs.h>
-#ifdef CONFIG_DRIVER_TI_EMAC - -#ifdef CONFIG_CMD_NET - unsigned int emac_dbg = 0; #define debug_emac(fmt,args...) if (emac_dbg) printf(fmt,##args)
@@ -291,77 +287,6 @@ int davinci_eth_miiphy_initialize(bd_t *bis) } #endif
-/* - * This function initializes the emac hardware. It does NOT initialize - * EMAC modules power or pin multiplexors, that is done by board_init() - * much earlier in bootup process. Returns 1 on success, 0 otherwise. - */ -static int davinci_eth_hw_init(void) -{ - u_int32_t phy_id; - u_int16_t tmp; - int i; - - davinci_eth_mdio_enable(); - - for (i = 0; i < 256; i++) { - if (adap_mdio->ALIVE) - break; - udelay(10); - } - - if (i >= 256) { - printf("No ETH PHY detected!!!\n"); - return(0); - } - - /* Find if a PHY is connected and get it's address */ - if (!davinci_eth_phy_detect()) - return(0); - - /* Get PHY ID and initialize phy_ops for a detected PHY */ - if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR1, &tmp)) { - active_phy_addr = 0xff; - return(0); - } - - phy_id = (tmp << 16) & 0xffff0000; - - if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR2, &tmp)) { - active_phy_addr = 0xff; - return(0); - } - - phy_id |= tmp & 0x0000ffff; - - switch (phy_id) { - case PHY_LXT972: - sprintf(phy.name, "LXT972 @ 0x%02x", active_phy_addr); - phy.init = lxt972_init_phy; - phy.is_phy_connected = lxt972_is_phy_connected; - phy.get_link_speed = lxt972_get_link_speed; - phy.auto_negotiate = lxt972_auto_negotiate; - break; - case PHY_DP83848: - sprintf(phy.name, "DP83848 @ 0x%02x", active_phy_addr); - phy.init = dp83848_init_phy; - phy.is_phy_connected = dp83848_is_phy_connected; - phy.get_link_speed = dp83848_get_link_speed; - phy.auto_negotiate = dp83848_auto_negotiate; - break; - default: - sprintf(phy.name, "GENERIC @ 0x%02x", active_phy_addr); - phy.init = gen_init_phy; - phy.is_phy_connected = gen_is_phy_connected; - phy.get_link_speed = gen_get_link_speed; - phy.auto_negotiate = gen_auto_negotiate; - } - - printf("Ethernet PHY: %s\n", phy.name); - - return(1); -} -
/* Eth device open */ static int davinci_eth_open(void) @@ -650,6 +575,73 @@ static int davinci_eth_rcv_packet (void) return (0); }
-#endif /* CONFIG_CMD_NET */ +/* + * This function initializes the emac hardware. It does NOT initialize + * EMAC modules power or pin multiplexors, that is done by board_init() + * much earlier in bootup process. Returns 1 on success, 0 otherwise. + */ +static int davinci_eth_hw_init(void) +{ + u_int32_t phy_id; + u_int16_t tmp; + int i; + + davinci_eth_mdio_enable(); + + for (i = 0; i < 256; i++) { + if (adap_mdio->ALIVE) + break; + udelay(10); + } + + if (i >= 256) { + printf("No ETH PHY detected!!!\n"); + return(0); + } + + /* Find if a PHY is connected and get it's address */ + if (!davinci_eth_phy_detect()) + return(0); + + /* Get PHY ID and initialize phy_ops for a detected PHY */ + if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR1, &tmp)) { + active_phy_addr = 0xff; + return(0); + }
-#endif /* CONFIG_DRIVER_TI_EMAC */ + phy_id = (tmp << 16) & 0xffff0000; + + if (!davinci_eth_phy_read(active_phy_addr, PHY_PHYIDR2, &tmp)) { + active_phy_addr = 0xff; + return(0); + } + + phy_id |= tmp & 0x0000ffff; + + switch (phy_id) { + case PHY_LXT972: + sprintf(phy.name, "LXT972 @ 0x%02x", active_phy_addr); + phy.init = lxt972_init_phy; + phy.is_phy_connected = lxt972_is_phy_connected; + phy.get_link_speed = lxt972_get_link_speed; + phy.auto_negotiate = lxt972_auto_negotiate; + break; + case PHY_DP83848: + sprintf(phy.name, "DP83848 @ 0x%02x", active_phy_addr); + phy.init = dp83848_init_phy; + phy.is_phy_connected = dp83848_is_phy_connected; + phy.get_link_speed = dp83848_get_link_speed; + phy.auto_negotiate = dp83848_auto_negotiate; + break; + default: + sprintf(phy.name, "GENERIC @ 0x%02x", active_phy_addr); + phy.init = gen_init_phy; + phy.is_phy_connected = gen_is_phy_connected; + phy.get_link_speed = gen_get_link_speed; + phy.auto_negotiate = gen_auto_negotiate; + } + + printf("Ethernet PHY: %s\n", phy.name); + + return(1); +}
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- board/davinci/common/misc.h | 1 - board/davinci/dvevm/dvevm.c | 3 - board/davinci/schmoogie/schmoogie.c | 3 - board/davinci/sffsdr/sffsdr.c | 3 - board/davinci/sonata/sonata.c | 3 - cpu/arm926ejs/davinci/cpu.c | 12 ++++++ drivers/net/dm644x_emac.c | 70 ++++++++++++----------------------- include/configs/davinci_dvevm.h | 1 + include/configs/davinci_schmoogie.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + include/netdev.h | 1 + net/eth.c | 4 -- 13 files changed, 41 insertions(+), 63 deletions(-)
diff --git a/board/davinci/common/misc.h b/board/davinci/common/misc.h index 316159a..dc3cc41 100644 --- a/board/davinci/common/misc.h +++ b/board/davinci/common/misc.h @@ -22,7 +22,6 @@ #ifndef __MISC_H #define __MISC_H
-extern int eth_hw_init(void);
int dvevm_read_mac_address(uint8_t *buf); void dv_configure_mac_address(uint8_t *rom_enetaddr); diff --git a/board/davinci/dvevm/dvevm.c b/board/davinci/dvevm/dvevm.c index 8f38633..98937a9 100644 --- a/board/davinci/dvevm/dvevm.c +++ b/board/davinci/dvevm/dvevm.c @@ -73,9 +73,6 @@ int misc_init_r(void) if (dvevm_read_mac_address(eeprom_enetaddr)) dv_configure_mac_address(eeprom_enetaddr);
- if (!eth_hw_init()) - printf("ethernet init failed!\n"); - i2c_read(0x39, 0x00, 1, &video_mode, 1);
setenv("videostd", ((video_mode & 0x80) ? "pal" : "ntsc")); diff --git a/board/davinci/schmoogie/schmoogie.c b/board/davinci/schmoogie/schmoogie.c index 6e0f591..19c9580 100644 --- a/board/davinci/schmoogie/schmoogie.c +++ b/board/davinci/schmoogie/schmoogie.c @@ -130,8 +130,5 @@ int misc_init_r(void) forceenv("serial#", (char *)&tmp[0]); }
- if (!eth_hw_init()) - printf("ethernet init failed!\n"); - return(0); } diff --git a/board/davinci/sffsdr/sffsdr.c b/board/davinci/sffsdr/sffsdr.c index 7f4ee36..c24b9e1 100644 --- a/board/davinci/sffsdr/sffsdr.c +++ b/board/davinci/sffsdr/sffsdr.c @@ -143,8 +143,5 @@ int misc_init_r(void) if (sffsdr_read_mac_address(eeprom_enetaddr)) dv_configure_mac_address(eeprom_enetaddr);
- if (!eth_hw_init()) - printf("Ethernet init failed\n"); - return(0); } diff --git a/board/davinci/sonata/sonata.c b/board/davinci/sonata/sonata.c index a0bea05..7f9d9bb 100644 --- a/board/davinci/sonata/sonata.c +++ b/board/davinci/sonata/sonata.c @@ -70,8 +70,5 @@ int misc_init_r(void) if (dvevm_read_mac_address(eeprom_enetaddr)) dv_configure_mac_address(eeprom_enetaddr);
- if (!eth_hw_init()) - printf("ethernet init failed!\n"); - return(0); } diff --git a/cpu/arm926ejs/davinci/cpu.c b/cpu/arm926ejs/davinci/cpu.c index 29aead6..fcd1f1a 100644 --- a/cpu/arm926ejs/davinci/cpu.c +++ b/cpu/arm926ejs/davinci/cpu.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <netdev.h> #include <asm/arch/hardware.h>
@@ -129,3 +130,14 @@ int print_cpuinfo(void)
#endif
+/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int cpu_eth_init(bd_t *bis) +{ +#if defined(CONFIG_DRIVER_TI_EMAC) + dm644x_emac_initialize(); +#endif + return 0; +} diff --git a/drivers/net/dm644x_emac.c b/drivers/net/dm644x_emac.c index f5cec05..7c5dace 100644 --- a/drivers/net/dm644x_emac.c +++ b/drivers/net/dm644x_emac.c @@ -40,17 +40,12 @@ #include <command.h> #include <net.h> #include <miiphy.h> +#include <malloc.h> #include <asm/arch/emac_defs.h>
-/* Internal static functions */ -static int davinci_eth_hw_init (void); -static int davinci_eth_open (void); -static int davinci_eth_close (void); -static int davinci_eth_send_packet (volatile void *packet, int length); -static int davinci_eth_rcv_packet (void); static void davinci_eth_mdio_enable(void);
static int gen_init_phy(int phy_addr); @@ -58,38 +53,10 @@ static int gen_is_phy_connected(int phy_addr); static int gen_get_link_speed(int phy_addr); static int gen_auto_negotiate(int phy_addr);
-/* Wrappers exported to the U-Boot proper */ -int eth_hw_init(void) -{ - return(davinci_eth_hw_init()); -} - -int eth_init(bd_t * bd) -{ - return(davinci_eth_open()); -} - -void eth_halt(void) -{ - davinci_eth_close(); -} - -int eth_send(volatile void *packet, int length) -{ - return(davinci_eth_send_packet(packet, length)); -} - -int eth_rx(void) -{ - return(davinci_eth_rcv_packet()); -} - void eth_mdio_enable(void) { davinci_eth_mdio_enable(); } -/* End of wrappers */ -
static u_int8_t davinci_eth_mac_addr[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff };
@@ -279,17 +246,11 @@ static int davinci_mii_phy_write(char *devname, unsigned char addr, unsigned cha return(davinci_eth_phy_write(addr, reg, value) ? 0 : 1); }
-int davinci_eth_miiphy_initialize(bd_t *bis) -{ - miiphy_register(phy.name, davinci_mii_phy_read, davinci_mii_phy_write); - - return(1); -} #endif
/* Eth device open */ -static int davinci_eth_open(void) +static int davinci_eth_open(struct eth_device *dev, bd_t *bis) { dv_reg_p addr; u_int32_t clkdiv, cnt; @@ -441,7 +402,7 @@ static void davinci_eth_ch_teardown(int ch) }
/* Eth device close */ -static int davinci_eth_close(void) +static void davinci_eth_close(struct eth_device *dev) { debug_emac("+ emac_close\n");
@@ -453,7 +414,6 @@ static int davinci_eth_close(void) adap_ewrap->EWCTL = 0;
debug_emac("- emac_close\n"); - return(1); }
static int tx_send_loop = 0; @@ -462,7 +422,8 @@ static int tx_send_loop = 0; * This function sends a single packet on the network and returns * positive number (number of bytes transmitted) or negative for error */ -static int davinci_eth_send_packet (volatile void *packet, int length) +static int davinci_eth_send_packet (struct eth_device *dev, + volatile void *packet, int length) { int ret_status = -1;
@@ -509,7 +470,7 @@ static int davinci_eth_send_packet (volatile void *packet, int length) /* * This function handles receipt of a packet from the network */ -static int davinci_eth_rcv_packet (void) +static int davinci_eth_rcv_packet (struct eth_device *dev) { volatile emac_desc *rx_curr_desc; volatile emac_desc *curr_desc; @@ -580,11 +541,27 @@ static int davinci_eth_rcv_packet (void) * EMAC modules power or pin multiplexors, that is done by board_init() * much earlier in bootup process. Returns 1 on success, 0 otherwise. */ -static int davinci_eth_hw_init(void) +int dm644x_emac_initialize(void) { u_int32_t phy_id; u_int16_t tmp; int i; + struct eth_device *dev; + + dev = malloc(sizeof *dev); + + if (dev == NULL) + return -1; + + memset(dev, 0, sizeof *dev); + + dev->iobase = 0; + dev->init = davinci_eth_open; + dev->halt = davinci_eth_close; + dev->send = davinci_eth_send_packet; + dev->recv = davinci_eth_rcv_packet; + + eth_register(dev);
@@ -643,5 +620,6 @@ static int davinci_eth_hw_init(void)
+ miiphy_register(phy.name, davinci_mii_phy_read, davinci_mii_phy_write); return(1); } diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index 6c5d065..96b6afc 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -109,6 +109,7 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI /*=====================*/ /* Flash & Environment */ /*=====================*/ diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index 6612cb3..9cb9838 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -77,6 +77,7 @@ #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_OVERWRITE_ETHADDR_ONCE +#define CONFIG_NET_MULTI /*=====================*/ /* Flash & Environment */ /*=====================*/ diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index 6c1dc11..a47620f 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -74,6 +74,7 @@ #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_OVERWRITE_ETHADDR_ONCE +#define CONFIG_NET_MULTI /* Flash & Environment */ #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 893729c..82901b3 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -109,6 +109,7 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI /*=====================*/ /* Flash & Environment */ /*=====================*/ diff --git a/include/netdev.h b/include/netdev.h index 4f2b23a..57ffe40 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -44,6 +44,7 @@ int cpu_eth_init(bd_t *bis); int au1x00_enet_initialize(bd_t*); int bfin_EMAC_initialize(bd_t *bis); int dc21x4x_initialize(bd_t *bis); +int dm644x_emac_initialize(void); int dnet_eth_initialize(int id, void *regs, unsigned int phy_addr); int e1000_initialize(bd_t *bis); int eepro100_initialize(bd_t *bis); diff --git a/net/eth.c b/net/eth.c index 8940ebf..eb218b6 100644 --- a/net/eth.c +++ b/net/eth.c @@ -504,7 +504,6 @@ extern int at91rm9200_miiphy_initialize(bd_t *bis); extern int emac4xx_miiphy_initialize(bd_t *bis); extern int mcf52x2_miiphy_initialize(bd_t *bis); extern int ns7520_miiphy_initialize(bd_t *bis); -extern int davinci_eth_miiphy_initialize(bd_t *bis);
int eth_initialize(bd_t *bis) @@ -525,9 +524,6 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_DRIVER_NS7520_ETHERNET) ns7520_miiphy_initialize(bis); #endif -#if defined(CONFIG_DRIVER_TI_EMAC) - davinci_eth_miiphy_initialize(bis); -#endif return 0; } #endif
Ben, I believe there was a comment regrading the name of the file. The present name is dm644x_emac.c and it should be davinci_emac.c Because other floavours of DaVinci will use the same file.
IIRC in the list had the same comment. Also the patch uses "dm644x_emac_initialize" It would be better to use davinci_emac_initialize.
There are not big changes and I can send in a patch if its is ok with you.
Thanks, Sandeep
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Ben Warren Sent: Tuesday, May 26, 2009 4:07 AM To: u-boot@lists.denx.de Cc: Ben Warren Subject: [U-Boot] [PATCH v2 0/3][Net][ARM] Davinci Ethernet driver cleanup
Hello,
regards, Ben _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Sandeep,
Thanks, Sandeep
It's better for me to redo the patch set. I named them based on comments in the header of the source file.
regards, Ben
Ben Warren
Paulraj, Sandeep
