[U-Boot-Users] BDI2000 stop debug in board.c for ARM
When I debug the board SMDK2410 using the BDI2000, I got an error puzzle me a lot.
Debug in start.s is okay, when get into the file board.c following instruction in " for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) {" cycle, there is an notification appear in the ddd debugger. "Further execution is probably impossible." And then uboot go back to "monitor_flash_len = _bss_start - _armboot_start; "
I don't know why. Can anybody tell me what happen here? Thanks a lot,
Fan
....... gd = (gd_t*)(_armboot_start - CFG_MALLOC_LEN - sizeof(gd_t)); /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
memset ((void*)gd, 0, sizeof (gd_t)); gd->bd = (bd_t*)((char*)gd - sizeof(bd_t)); memset (gd->bd, 0, sizeof (bd_t));
for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { if ((*init_fnc_ptr)() != 0) { hang (); } }
Fan, Xin (GE Healthcare)
