[PATCH v2 1/3] binman: Add nxp_imx8mimage etype
Add new binman etype derived from mkimage etype which generates configuration input file for mkimage -T imx8mimage, and runs the mkimage on input data. The mkimage -T imx8mimage is used to generate combined image with SPL and DDR PHY blobs which is bootable on i.MX8M.
The configuration file generated here is equivalent of imx8mimage.cfg, which is the file passed to '$ mkimage -T imx8mimage -n imx8mimage.cfg ...' . The settings generated into the imx8mimage.cfg file are configured via supported binman DT properties, nxp,boot-from, nxp,loader-address, nxp,rom-version.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Adam Ford aford173@gmail.com Cc: Alper Nebi Yasak alpernebiyasak@gmail.com Cc: Andrejs Cainikovs andrejs.cainikovs@toradex.com Cc: Angus Ainslie angus@akkea.ca Cc: Emanuele Ghidoli emanuele.ghidoli@toradex.com Cc: Fabio Estevam festevam@gmail.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk Cc: Simon Glass sjg@chromium.org Cc: Stefan Eichenberger stefan.eichenberger@toradex.com Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Tom Rini trini@konsulko.com Cc: kernel@puri.sm Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: Fix pylint errors --- tools/binman/etype/nxp_imx8mimage.py | 74 ++++++++++++++++++++++++++++ 1 file changed, 74 insertions(+) create mode 100644 tools/binman/etype/nxp_imx8mimage.py
diff --git a/tools/binman/etype/nxp_imx8mimage.py b/tools/binman/etype/nxp_imx8mimage.py new file mode 100644 index 00000000000..3585120b79b --- /dev/null +++ b/tools/binman/etype/nxp_imx8mimage.py @@ -0,0 +1,74 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2023-2024 Marek Vasut marex@denx.de +# Written with much help from Simon Glass sjg@chromium.org +# +# Entry-type module for generating the i.MX8M mkimage -T imx8mimage +# configuration file and invocation of mkimage -T imx8mimage on the +# configuration file and input data. +# + +from collections import OrderedDict + +from binman.entry import Entry +from binman.etype.mkimage import Entry_mkimage +from binman.etype.section import Entry_section +from binman import elf +from dtoc import fdt_util +from u_boot_pylib import tools + +class Entry_nxp_imx8mimage(Entry_mkimage): + """NXP i.MX8M imx8mimage .cfg file generator and mkimage invoker + + Properties / Entry arguments: + - nxp,boot-from - device to boot from (e.g. 'sd') + - nxp,loader-address - loader address (SPL text base) + - nxp,rom-version - BootROM version ('2' for i.MX8M Nano and Plus) + """ + + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.required_props = ['nxp,boot-from', 'nxp,rom-version', 'nxp,loader-address'] + + def ReadNode(self): + super().ReadNode() + self.boot_from = fdt_util.GetString(self._node, 'nxp,boot-from') + self.loader_address = fdt_util.GetInt(self._node, 'nxp,loader-address') + self.rom_version = fdt_util.GetInt(self._node, 'nxp,rom-version') + self.ReadEntries() + + def BuildSectionData(self, required): + data, input_fname, uniq = self.collect_contents_to_file( + self._entries.values(), 'input') + # Generate mkimage configuration file similar to imx8mimage.cfg + # and pass it to mkimage to generate SPL image for us here. + cfg_fname = tools.get_output_filename('nxp.imx8mimage.cfg.%s' % uniq) + with open(cfg_fname, 'w') as outf: + print('ROM_VERSION v%d' % self.rom_version, file=outf) + print('BOOT_FROM %s' % self.boot_from, file=outf) + print('LOADER %s %#x' % (input_fname, self.loader_address), file=outf) + + output_fname = tools.get_output_filename(f'cfg-out.{uniq}') + args = ['-d', input_fname, '-n', cfg_fname, '-T', 'imx8mimage', + output_fname] + if self.mkimage.run_cmd(*args) is not None: + return tools.read_file(output_fname) + else: + # Bintool is missing; just use the input data as the output + self.record_missing_bintool(self.mkimage) + return data + + def SetImagePos(self, image_pos): + # Customized SoC specific SetImagePos which skips the mkimage etype + # implementation and removes the 0x48 offset introduced there. That + # offset is only used for uImage/fitImage, which is not the case in + # here. + upto = 0x00 + for entry in super().GetEntries().values(): + entry.SetOffsetSize(upto, None) + + # Give up if any entries lack a size + if entry.size is None: + return + upto += entry.size + + Entry_section.SetImagePos(self, image_pos)
Include imx8mq-u-boot.dtsi in the board -u-boot.dtsi to pull in binman configuration instead of duplicating it in the board -u-boot.dtsi again. Drop the duplicate binman configuration.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Adam Ford aford173@gmail.com Cc: Alper Nebi Yasak alpernebiyasak@gmail.com Cc: Andrejs Cainikovs andrejs.cainikovs@toradex.com Cc: Angus Ainslie angus@akkea.ca Cc: Emanuele Ghidoli emanuele.ghidoli@toradex.com Cc: Fabio Estevam festevam@gmail.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk Cc: Simon Glass sjg@chromium.org Cc: Stefan Eichenberger stefan.eichenberger@toradex.com Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Tom Rini trini@konsulko.com Cc: kernel@puri.sm Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: No change --- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 111 +---------------------------- 1 file changed, 1 insertion(+), 110 deletions(-)
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index e23998f5aba..819501337e9 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -3,11 +3,7 @@ * Copyright 2019 NXP */
-/ { - binman: binman { - multiple-images; - }; -}; +#include "imx8mq-u-boot.dtsi"
&pinctrl_uart1 { bootph-pre-ram; @@ -16,108 +12,3 @@ &uart1 { bootph-pre-ram; }; - -&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - ddr-1d-imem-fw { - filename = "lpddr4_pmu_train_1d_imem.bin"; - type = "blob-ext"; - align-end = <4>; - }; - - ddr-1d-dmem-fw { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - type = "blob-ext"; - align-end = <4>; - }; - - ddr-2d-imem-fw { - filename = "lpddr4_pmu_train_2d_imem.bin"; - type = "blob-ext"; - align-end = <4>; - }; - - ddr-2d-dmem-fw { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - type = "blob-ext"; - align-end = <4>; - }; - }; - - flash { - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x910000>; - entry = <0x910000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; -};
Rework the flash.bin image generation such that it uses the new binman nxp_imx8mimage etype. This way, the flash.bin is assembled in correct order using plain binman, without any workarounds or sections assembled in special DT node order.
Reviewed-By: Tim Harvey tharvey@gateworks.com Tested-By: Tim Harvey tharvey@gateworks.com # imx8mm_venice Tested-by: Fabio Estevam festevam@gmail.com # imx8mm-evk and imx8mn-evk Signed-off-by: Marek Vasut marex@denx.de --- WARNING: This is very likely to break corner case uses, so please do test this on your platform. NOTE: This also opens the implementation for proper CST signing etype, the CST signing would look similar to nxp-imx8mimage section, and it would likely wrap the whole topmost section {} in the binman node. --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Adam Ford aford173@gmail.com Cc: Alper Nebi Yasak alpernebiyasak@gmail.com Cc: Andrejs Cainikovs andrejs.cainikovs@toradex.com Cc: Angus Ainslie angus@akkea.ca Cc: Emanuele Ghidoli emanuele.ghidoli@toradex.com Cc: Fabio Estevam festevam@gmail.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk Cc: Simon Glass sjg@chromium.org Cc: Stefan Eichenberger stefan.eichenberger@toradex.com Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Tom Rini trini@konsulko.com Cc: kernel@puri.sm Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de --- V2: Add TB from Fabio/Tim and RB from Tim --- arch/arm/dts/imx8mm-u-boot.dtsi | 126 ++++++--------- .../dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 8 +- arch/arm/dts/imx8mn-u-boot.dtsi | 147 +++++++----------- arch/arm/dts/imx8mp-dhcom-u-boot.dtsi | 2 +- arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 2 +- arch/arm/dts/imx8mp-u-boot.dtsi | 96 +++++------- arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi | 15 +- arch/arm/dts/imx8mq-u-boot.dtsi | 109 +++++-------- 8 files changed, 203 insertions(+), 302 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 06f2f73a03f..6ab8f66256e 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -5,7 +5,6 @@
/ { binman: binman { - multiple-images; };
#ifdef CONFIG_OPTEE @@ -43,56 +42,61 @@ };
&binman { - u-boot-spl-ddr { - align = <4>; - align-size = <4>; - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - - u-boot-spl { - align-end = <4>; - filename = "u-boot-spl.bin"; - }; + filename = "flash.bin"; + section { + pad-byte = <0x00>;
- ddr-1d-imem-fw { - filename = "lpddr4_pmu_train_1d_imem.bin"; - align-end = <4>; +#ifdef CONFIG_FSPI_CONF_HEADER + fspi_conf_block { + filename = CONFIG_FSPI_CONF_FILE; type = "blob-ext"; + size = <0x1000>; }; +#endif
- ddr-1d-dmem-fw { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - align-end = <4>; - type = "blob-ext"; - }; + nxp-imx8mimage { + filename = "u-boot-spl-mkimage.bin"; + nxp,boot-from = "sd"; + nxp,rom-version = <1>; + nxp,loader-address = <CONFIG_SPL_TEXT_BASE>; + args; /* Needed by mkimage etype superclass */
- ddr-2d-imem-fw { - filename = "lpddr4_pmu_train_2d_imem.bin"; - align-end = <4>; - type = "blob-ext"; - }; + section { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>;
- ddr-2d-dmem-fw { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - align-end = <4>; - type = "blob-ext"; - }; - }; + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + };
- spl { - filename = "spl.bin"; + ddr-1d-imem-fw { + filename = "lpddr4_pmu_train_1d_imem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + ddr-1d-dmem-fw { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- blob { - filename = "u-boot-spl-ddr.bin"; + ddr-2d-imem-fw { + filename = "lpddr4_pmu_train_2d_imem.bin"; + align-end = <4>; + type = "blob-ext"; + }; + + ddr-2d-dmem-fw { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + align-end = <4>; + type = "blob-ext"; + }; }; }; - }; - - itb { - filename = "u-boot.itb";
fit { description = "Configuration to load ATF before U-Boot"; @@ -101,6 +105,11 @@ #endif fit,fdt-list = "of-list"; #address-cells = <1>; +#ifdef CONFIG_FSPI_CONF_HEADER + offset = <0x58C00>; +#else + offset = <0x57c00>; +#endif
images { uboot { @@ -166,43 +175,6 @@ }; }; }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - -#ifdef CONFIG_FSPI_CONF_HEADER - fspi_conf_block { - filename = CONFIG_FSPI_CONF_FILE; - type = "blob-ext"; - size = <0x1000>; - }; - - spl { - filename = "spl.bin"; - offset = <0x1000>; - type = "blob-ext"; - }; - - binman_uboot: uboot { - filename = "u-boot.itb"; - offset = <0x58C00>; - type = "blob-ext"; - }; -#else - spl { - filename = "spl.bin"; - offset = <0x0>; - type = "blob-ext"; - }; - - binman_uboot: uboot { - filename = "u-boot.itb"; - offset = <0x57c00>; - type = "blob-ext"; - }; -#endif - }; };
&clk { diff --git a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi index 8b397f535c1..90183aff8bc 100644 --- a/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi @@ -35,8 +35,12 @@ bootph-pre-ram; };
-&binman_uboot { - offset = <0x5fc00>; +&binman { + section { + fit { + offset = <0x5fc00>; + }; + }; };
&gpio1 { diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 96b1a1bc802..ba9967dbe4a 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -5,7 +5,6 @@
#ifdef CONFIG_OPTEE @@ -92,78 +91,83 @@ };
&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - filename = "u-boot-spl.bin"; + filename = "flash.bin"; + section { + pad-byte = <0x00>; + +#ifdef CONFIG_FSPI_CONF_HEADER + fspi_conf_block { + filename = CONFIG_FSPI_CONF_FILE; + type = "blob-ext"; + offset = <0x400>; }; +#endif
- ddr-1d-imem-fw { + nxp-imx8mimage { + filename = "u-boot-spl-mkimage.bin"; + nxp,boot-from = "sd"; + nxp,rom-version = <2>; + nxp,loader-address = <CONFIG_SPL_TEXT_BASE>; + args; /* Needed by mkimage etype superclass */ + + section { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + filename = "u-boot-spl.bin"; + }; + + ddr-1d-imem-fw { #ifdef CONFIG_IMX8M_LPDDR4 - filename = "lpddr4_pmu_train_1d_imem.bin"; + filename = "lpddr4_pmu_train_1d_imem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_imem_1d_201810.bin"; + filename = "ddr4_imem_1d_201810.bin"; #else - filename = "ddr3_imem_1d.bin"; + filename = "ddr3_imem_1d.bin"; #endif - type = "blob-ext"; - align-end = <4>; - }; + type = "blob-ext"; + align-end = <4>; + };
- ddr-1d-dmem-fw { + ddr-1d-dmem-fw { #ifdef CONFIG_IMX8M_LPDDR4 - filename = "lpddr4_pmu_train_1d_dmem.bin"; + filename = "lpddr4_pmu_train_1d_dmem.bin"; #elif CONFIG_IMX8M_DDR4 - filename = "ddr4_dmem_1d_201810.bin"; + filename = "ddr4_dmem_1d_201810.bin"; #else - filename = "ddr3_dmem_1d.bin"; + filename = "ddr3_dmem_1d.bin"; #endif - type = "blob-ext"; - align-end = <4>; - }; + type = "blob-ext"; + align-end = <4>; + };
#if defined(CONFIG_IMX8M_LPDDR4) || defined(CONFIG_IMX8M_DDR4) - ddr-2d-imem-fw { + ddr-2d-imem-fw { #ifdef CONFIG_IMX8M_LPDDR4 - filename = "lpddr4_pmu_train_2d_imem.bin"; + filename = "lpddr4_pmu_train_2d_imem.bin"; #else - filename = "ddr4_imem_2d_201810.bin"; + filename = "ddr4_imem_2d_201810.bin"; #endif - type = "blob-ext"; - align-end = <4>; - }; + type = "blob-ext"; + align-end = <4>; + };
- ddr-2d-dmem-fw { + ddr-2d-dmem-fw { #ifdef CONFIG_IMX8M_LPDDR4 - filename = "lpddr4_pmu_train_2d_dmem.bin"; + filename = "lpddr4_pmu_train_2d_dmem.bin"; #else - filename = "ddr4_dmem_2d_201810.bin"; + filename = "ddr4_dmem_2d_201810.bin"; #endif - type = "blob-ext"; - align-end = <4>; - }; + type = "blob-ext"; + align-end = <4>; + }; #endif - }; - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; - - blob { - filename = "u-boot-spl-ddr.bin"; }; }; - }; - - itb { - filename = "u-boot.itb";
fit { description = "Configuration to load ATF before U-Boot"; @@ -172,6 +176,11 @@ #endif fit,fdt-list = "of-list"; #address-cells = <1>; +#ifdef CONFIG_FSPI_CONF_HEADER + offset = <0x59000>; +#else + offset = <0x58000>; +#endif
images { uboot { @@ -237,42 +246,4 @@ }; }; }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - -#ifdef CONFIG_FSPI_CONF_HEADER - fspi_conf_block { - filename = CONFIG_FSPI_CONF_FILE; - type = "blob-ext"; - offset = <0x400>; - }; - - spl { - filename = "spl.bin"; - offset = <0x1000>; - type = "blob-ext"; - }; - - binman_uboot: uboot { - filename = "u-boot.itb"; - offset = <0x59000>; - type = "blob-ext"; - }; -#else - - spl { - offset = <0x0>; - filename = "spl.bin"; - type = "blob-ext"; - }; - - binman_uboot: uboot { - offset = <0x58000>; - filename = "u-boot.itb"; - type = "blob-ext"; - }; -#endif - }; }; diff --git a/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi b/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi index b05be57e71b..cb37e28f28f 100644 --- a/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi @@ -136,7 +136,7 @@ };
&binman { - itb { + section { fit { images { fdt-dto-imx8mp-dhcom-som-overlay-eth1xfast { diff --git a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi index 22171bd344e..aff5dcf615d 100644 --- a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi @@ -136,7 +136,7 @@ };
&binman { - itb { + section { fit { images { fip { diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 4fadcaea509..c4c1a177102 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -6,7 +6,6 @@
#ifdef CONFIG_OPTEE @@ -83,55 +82,52 @@ #endif
&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; + filename = "flash.bin"; + section { + pad-byte = <0x00>;
- ddr-1d-imem-fw { - filename = "lpddr4_pmu_train_1d_imem_202006.bin"; - type = "blob-ext"; - align-end = <4>; - }; + nxp-imx8mimage { + filename = "u-boot-spl-mkimage.bin"; + nxp,boot-from = "sd"; + nxp,rom-version = <2>; + nxp,loader-address = <CONFIG_SPL_TEXT_BASE>; + args; /* Needed by mkimage etype superclass */
- ddr-1d-dmem-fw { - filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; - type = "blob-ext"; - align-end = <4>; - }; + section { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>;
- ddr-2d-imem-fw { - filename = "lpddr4_pmu_train_2d_imem_202006.bin"; - type = "blob-ext"; - align-end = <4>; - }; + u-boot-spl { + align-end = <4>; + };
- ddr-2d-dmem-fw { - filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; - type = "blob-ext"; - align-end = <4>; - }; - }; + ddr-1d-imem-fw { + filename = "lpddr4_pmu_train_1d_imem_202006.bin"; + type = "blob-ext"; + align-end = <4>; + };
- spl { - filename = "spl.bin"; + ddr-1d-dmem-fw { + filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; + type = "blob-ext"; + align-end = <4>; + };
- mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x920000"; + ddr-2d-imem-fw { + filename = "lpddr4_pmu_train_2d_imem_202006.bin"; + type = "blob-ext"; + align-end = <4>; + };
- blob { - filename = "u-boot-spl-ddr.bin"; + ddr-2d-dmem-fw { + filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; + type = "blob-ext"; + align-end = <4>; + }; }; }; - }; - - itb { - filename = "u-boot.itb";
fit { description = "Configuration to load ATF before U-Boot"; @@ -140,6 +136,7 @@ #endif fit,fdt-list = "of-list"; #address-cells = <1>; + offset = <0x58000>;
images { uboot { @@ -195,21 +192,4 @@ }; }; }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl { - filename = "spl.bin"; - offset = <0x0>; - type = "blob-ext"; - }; - - binman_uboot: uboot { - filename = "u-boot.itb"; - offset = <0x58000>; - type = "blob-ext"; - }; - }; }; diff --git a/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi index e3341a46d63..1a4568dac65 100644 --- a/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi @@ -11,14 +11,13 @@ };
&binman { - /delete-node/ signed-hdmi; - - signed-hdmi { - filename = "signed_hdmi.bin"; - - signed-dp-imx8m { - filename = "signed_dp_imx8m.bin"; - type = "blob-ext"; + section { + nxp-imx8mimage { + section { + signed-hdmi-imx8m { + filename = "signed_dp_imx8m.bin"; + }; + }; }; }; }; diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 90b2274754b..48dbe94f0c4 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -5,7 +5,6 @@
}; @@ -35,65 +34,58 @@ };
- ddr-1d-imem-fw { - filename = "lpddr4_pmu_train_1d_imem.bin"; - align-end = <4>; - type = "blob-ext"; - }; + nxp-imx8mimage { + filename = "u-boot-spl-mkimage.bin"; + nxp,boot-from = "sd"; + nxp,rom-version = <1>; + nxp,loader-address = <CONFIG_SPL_TEXT_BASE>; + args; /* Needed by mkimage etype superclass */
- ddr-1d-dmem-fw { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - align-end = <4>; - type = "blob-ext"; - }; - - ddr-2d-imem-fw { - filename = "lpddr4_pmu_train_2d_imem.bin"; - align-end = <4>; - type = "blob-ext"; - }; + section { + align = <4>; + align-size = <4>; + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>;
- signed-hdmi { - filename = "signed_hdmi.bin"; + ddr-1d-imem-fw { + filename = "lpddr4_pmu_train_1d_imem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- signed-hdmi-imx8m { - filename = "signed_hdmi_imx8m.bin"; - type = "blob-ext"; - }; - }; + ddr-1d-dmem-fw { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- spl { - filename = "spl.bin"; + ddr-2d-imem-fw { + filename = "lpddr4_pmu_train_2d_imem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + ddr-2d-dmem-fw { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + align-end = <4>; + type = "blob-ext"; + };
- blob { - filename = "u-boot-spl-ddr.bin"; + signed-hdmi-imx8m { + filename = "signed_hdmi_imx8m.bin"; + type = "blob-ext"; + }; }; }; - }; - - itb { - filename = "u-boot.itb";
fit { description = "Configuration to load ATF before U-Boot"; @@ -158,21 +150,4 @@ }; }; }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl { - filename = "spl.bin"; - offset = <0x0>; - type = "blob-ext"; - }; - - binman_uboot: uboot { - filename = "u-boot.itb"; - offset = <0x57c00>; - type = "blob-ext"; - }; - }; };
Applied all, thanks.
Fabio Estevam
