[PATCH v4 0/5] android_ab: introduce bcb ab_dump command and provide several bcb fixes
The patch series include changes: - move ab_select_slot() documentation to @ notation - move ab_select command to bcb subcommands - introduce the ab_dump command to print the content of the BCB block; it's useful for debugging A/B logic on supported boards - fix the slot suffix format in the ABC block to align with official Android BCB specifications - add a test for the ab_dump command to verify the accuracy of each field within the ABC data displayed, it's also useful for testing slot_suffix problem code paths
Changes v3 since v2 at [2]: - return "Legend" block for bcb command - additionally, verify the CONFIG_ANDROID_AB configuration alongside CONFIG_CMD_BCB to ensure that the A/B scheme is used for the designated board.
Changes v2 since v1 at [1]: - move ab_select_slot() documentation to @ notation - move ab_select command to bcb subcommands per Simon and Mattijs suggestions - redesign ab_dump as bcb subcommand - use spaces instead of tabs in the ab_dump command output - print hex values in the lowercase - add RvB tags
Links: [1] https://lore.kernel.org/all/20240725194716.32232-1-ddrokosov@salutedevices.c... [2] https://lore.kernel.org/all/20240911214945.15873-1-ddrokosov@salutedevices.c...
Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- Changes in v4: - add #ifdefs for CONFIG_ANDROID_AB in cmd/bcb.c to allow the usage of the bcb command without A/B enabled - run the savedefconfig command for all defconfigs that include the CMD_BCB configuration - resolve merge conflicts with latest master - provide additional trailers from the previous version (excluding changed patches) - Link to v3: https://lore.kernel.org/r/20241008-android_ab_master-v3-0-f292c45a33e4@salut...
--- Dmitry Rokosov (5): include/android_ab: move ab_select_slot() documentation to @ notation treewide: bcb: move ab_select command to bcb subcommands cmd: bcb: change strcmp() usage style in the do_bcb_ab_select() cmd: bcb: introduce 'ab_dump' command to print BCB block content common: android_ab: fix slot suffix for abc block
MAINTAINERS | 1 - boot/android_ab.c | 116 ++++++++++++++++++++++++------ cmd/Kconfig | 14 ---- cmd/Makefile | 1 - cmd/ab_select.c | 66 ----------------- cmd/bcb.c | 110 ++++++++++++++++++++++++++++ configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/khadas-vim3_android_ab_defconfig | 1 - configs/khadas-vim3l_android_ab_defconfig | 1 - configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 1 - doc/android/ab.rst | 12 ++-- include/android_ab.h | 17 ++++- include/configs/khadas-vim3_android.h | 2 +- include/configs/khadas-vim3l_android.h | 2 +- include/configs/meson64_android.h | 4 +- include/configs/ti_omap5_common.h | 4 +- test/py/tests/test_android/test_ab.py | 31 ++++++-- 20 files changed, 260 insertions(+), 128 deletions(-) --- base-commit: 5d899fc58c44fe5623e31524da2205d8597a53d1 change-id: 20241008-android_ab_master-d86d71c839ae
There are new function documentation requirements in U-Boot, so apply these changes for android_ab.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- boot/android_ab.c | 43 ++++++++++++++++++++++++------------------- include/android_ab.h | 7 ++++--- 2 files changed, 28 insertions(+), 22 deletions(-)
diff --git a/boot/android_ab.c b/boot/android_ab.c index 1196a189ed5349ca5c088e3b6ef1796b11c69a84..0045c8133a8e164f1fdd4c0f9b683de0f13f26e0 100644 --- a/boot/android_ab.c +++ b/boot/android_ab.c @@ -13,13 +13,13 @@ #include <u-boot/crc.h>
/** - * Compute the CRC-32 of the bootloader control struct. + * ab_control_compute_crc() - Compute the CRC32 of the bootloader control. + * + * @abc: Bootloader control block * * Only the bytes up to the crc32_le field are considered for the CRC-32 * calculation. * - * @param[in] abc bootloader control block - * * Return: crc32 sum */ static uint32_t ab_control_compute_crc(struct bootloader_control *abc) @@ -28,14 +28,14 @@ static uint32_t ab_control_compute_crc(struct bootloader_control *abc) }
/** - * Initialize bootloader_control to the default value. + * ab_control_default() - Initialize bootloader_control to the default value. + * + * @abc: Bootloader control block * * It allows us to boot all slots in order from the first one. This value * should be used when the bootloader message is corrupted, but not when * a valid message indicates that all slots are unbootable. * - * @param[in] abc bootloader control block - * * Return: 0 on success and a negative on error */ static int ab_control_default(struct bootloader_control *abc) @@ -67,7 +67,13 @@ static int ab_control_default(struct bootloader_control *abc) }
/** - * Load the boot_control struct from disk into newly allocated memory. + * ab_control_create_from_disk() - Load the boot_control from disk into memory. + * + * @dev_desc: Device where to read the boot_control struct from + * @part_info: Partition in 'dev_desc' where to read from, normally + * the "misc" partition should be used + * @abc: pointer to pointer to bootloader_control data + * @offset: boot_control struct offset * * This function allocates and returns an integer number of disk blocks, * based on the block size of the passed device to help performing a @@ -75,10 +81,6 @@ static int ab_control_default(struct bootloader_control *abc) * The boot_control struct offset (2 KiB) must be a multiple of the device * block size, for simplicity. * - * @param[in] dev_desc Device where to read the boot_control struct from - * @param[in] part_info Partition in 'dev_desc' where to read from, normally - * the "misc" partition should be used - * @param[out] pointer to pointer to bootloader_control data * Return: 0 on success and a negative on error */ static int ab_control_create_from_disk(struct blk_desc *dev_desc, @@ -122,15 +124,17 @@ static int ab_control_create_from_disk(struct blk_desc *dev_desc, }
/** - * Store the loaded boot_control block. + * ab_control_store() - Store the loaded boot_control block. + * + * @dev_desc: Device where we should write the boot_control struct + * @part_info: Partition on the 'dev_desc' where to write + * @abc Pointer to the boot control struct and the extra bytes after + * it up to the nearest block boundary + * @offset: boot_control struct offset * * Store back to the same location it was read from with * ab_control_create_from_misc(). * - * @param[in] dev_desc Device where we should write the boot_control struct - * @param[in] part_info Partition on the 'dev_desc' where to write - * @param[in] abc Pointer to the boot control struct and the extra bytes after - * it up to the nearest block boundary * Return: 0 on success and a negative on error */ static int ab_control_store(struct blk_desc *dev_desc, @@ -160,12 +164,13 @@ static int ab_control_store(struct blk_desc *dev_desc, }
/** - * Compare two slots. + * ab_compare_slots() - Compare two slots. + * + * @a: The first bootable slot metadata + * @b: The second bootable slot metadata * * The function determines slot which is should we boot from among the two. * - * @param[in] a The first bootable slot metadata - * @param[in] b The second bootable slot metadata * Return: Negative if the slot "a" is better, positive of the slot "b" is * better or 0 if they are equally good. */ diff --git a/include/android_ab.h b/include/android_ab.h index dbf20343da62447a237ec845e216517d34455ad3..1e53879a25f145a9d18ac0a6553d8c217123aa6f 100644 --- a/include/android_ab.h +++ b/include/android_ab.h @@ -18,7 +18,10 @@ struct disk_partition; #define NUM_SLOTS 2
/** - * Select the slot where to boot from. + * ab_select_slot() - Select the slot where to boot from. + * + * @dev_desc: Place to store the device description pointer + * @part_info: Place to store the partition information * * On Android devices with more than one boot slot (multiple copies of the * kernel and system images) selects which slot should be used to boot from and @@ -28,8 +31,6 @@ struct disk_partition; * registered before returning from this function so it isn't selected * indefinitely. * - * @param[in] dev_desc Place to store the device description pointer - * @param[in] part_info Place to store the partition information * Return: The slot number (>= 0) on success, or a negative on error */ int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info,
To enhance code organization, it is beneficial to consolidate all A/B BCB management routines into a single super-command. The 'bcb' command is an excellent candidate for this purpose.
This patch integrates the separate 'ab_select' command into the 'bcb' group as the 'ab_select' subcommand, maintaining the same parameter list for consistency.
Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- MAINTAINERS | 1 - cmd/Kconfig | 14 ------ cmd/Makefile | 1 - cmd/ab_select.c | 66 --------------------------- cmd/bcb.c | 75 +++++++++++++++++++++++++++++++ configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/khadas-vim3_android_ab_defconfig | 1 - configs/khadas-vim3l_android_ab_defconfig | 1 - configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 1 - doc/android/ab.rst | 12 ++--- include/configs/khadas-vim3_android.h | 2 +- include/configs/khadas-vim3l_android.h | 2 +- include/configs/meson64_android.h | 4 +- include/configs/ti_omap5_common.h | 4 +- test/py/tests/test_android/test_ab.py | 8 ++-- 18 files changed, 93 insertions(+), 104 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 7aefda93d017f07d616f0f6d191129914fbeb484..668ccec9ae6df47192b1af668e3fdbeb1dfa15ea 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -65,7 +65,6 @@ R: Sam Protsenko semen.protsenko@linaro.org S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-dfu.git F: boot/android_ab.c -F: cmd/ab_select.c F: doc/android/ab.rst F: include/android_ab.h F: test/py/tests/test_android/test_ab.py diff --git a/cmd/Kconfig b/cmd/Kconfig index 37894eb80d66f98bb5a3b3745d207ddbf7af088d..e1a4a97b042db2491d55398ea1e879ce5a83930e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1774,20 +1774,6 @@ config CMD_XXD
endmenu
-menu "Android support commands" - -config CMD_AB_SELECT - bool "ab_select" - depends on ANDROID_AB - help - On Android devices with more than one boot slot (multiple copies of - the kernel and system images) this provides a command to select which - slot should be used to boot from and register the boot attempt. This - is used by the new A/B update model where one slot is updated in the - background while running from the other slot. - -endmenu - if NET
menuconfig CMD_NET diff --git a/cmd/Makefile b/cmd/Makefile index 91227f1249cbda5f7b383e8865c8cc23f3ad5f44..0fd7da3c0de91822c4299cc7034193c497d622b1 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -17,7 +17,6 @@ obj-$(CONFIG_CMD_2048) += 2048.o obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_AES) += aes.o -obj-$(CONFIG_CMD_AB_SELECT) += ab_select.o obj-$(CONFIG_CMD_ADC) += adc.o obj-$(CONFIG_CMD_ARMFLASH) += armflash.o obj-$(CONFIG_BLK) += blk_common.o diff --git a/cmd/ab_select.c b/cmd/ab_select.c deleted file mode 100644 index 7c178c728ca4c8b5bcba02a04eef2d6a7c86afb6..0000000000000000000000000000000000000000 --- a/cmd/ab_select.c +++ /dev/null @@ -1,66 +0,0 @@ -// SPDX-License-Identifier: BSD-2-Clause -/* - * Copyright (C) 2017 The Android Open Source Project - */ - -#include <android_ab.h> -#include <command.h> -#include <env.h> -#include <part.h> - -static int do_ab_select(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - int ret; - struct blk_desc *dev_desc; - struct disk_partition part_info; - char slot[2]; - bool dec_tries = true; - - if (argc < 4) - return CMD_RET_USAGE; - - for (int i = 4; i < argc; i++) { - if (strcmp(argv[i], "--no-dec") == 0) { - dec_tries = false; - } else { - return CMD_RET_USAGE; - } - } - - /* Lookup the "misc" partition from argv[2] and argv[3] */ - if (part_get_info_by_dev_and_name_or_num(argv[2], argv[3], - &dev_desc, &part_info, - false) < 0) { - return CMD_RET_FAILURE; - } - - ret = ab_select_slot(dev_desc, &part_info, dec_tries); - if (ret < 0) { - printf("Android boot failed, error %d.\n", ret); - return CMD_RET_FAILURE; - } - - /* Android standard slot names are 'a', 'b', ... */ - slot[0] = BOOT_SLOT_NAME(ret); - slot[1] = '\0'; - env_set(argv[1], slot); - printf("ANDROID: Booting slot: %s\n", slot); - return CMD_RET_SUCCESS; -} - -U_BOOT_CMD(ab_select, 5, 0, do_ab_select, - "Select the slot used to boot from and register the boot attempt.", - "<slot_var_name> <interface> <dev[:part|#part_name]> [--no-dec]\n" - " - Load the slot metadata from the partition 'part' on\n" - " device type 'interface' instance 'dev' and store the active\n" - " slot in the 'slot_var_name' variable. This also updates the\n" - " Android slot metadata with a boot attempt, which can cause\n" - " successive calls to this function to return a different result\n" - " if the returned slot runs out of boot attempts.\n" - " - If 'part_name' is passed, preceded with a # instead of :, the\n" - " partition name whose label is 'part_name' will be looked up in\n" - " the partition table. This is commonly the "misc" partition.\n" - " - If '--no-dec' is set, the number of tries remaining will not\n" - " decremented for the selected boot slot\n" -); diff --git a/cmd/bcb.c b/cmd/bcb.c index 97a96c009641cc094645607ef833575f3c03fe4b..bf28726da91134fa287ca8aada884ed74ecc8f2b 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -8,6 +8,7 @@ #include <android_bootloader_message.h> #include <bcb.h> #include <command.h> +#include <android_ab.h> #include <display_options.h> #include <log.h> #include <part.h> @@ -23,6 +24,9 @@ enum bcb_cmd { BCB_CMD_FIELD_TEST, BCB_CMD_FIELD_DUMP, BCB_CMD_STORE, +#ifdef CONFIG_ANDROID_AB + BCB_CMD_AB_SELECT, +#endif };
static const char * const fields[] = { @@ -52,6 +56,10 @@ static int bcb_cmd_get(char *cmd) return BCB_CMD_STORE; if (!strcmp(cmd, "dump")) return BCB_CMD_FIELD_DUMP; +#ifdef CONFIG_ANDROID_AB + if (!strcmp(cmd, "ab_select")) + return BCB_CMD_AB_SELECT; +#endif else return -1; } @@ -85,6 +93,12 @@ static int bcb_is_misused(int argc, char *const argv[]) if (argc != 2) goto err; break; +#ifdef CONFIG_ANDROID_AB + case BCB_CMD_AB_SELECT: + if (argc != 4 && argc != 5) + goto err; + return 0; +#endif default: printf("Error: 'bcb %s' not supported\n", argv[0]); return -1; @@ -414,6 +428,46 @@ void bcb_reset(void) __bcb_reset(); }
+#ifdef CONFIG_ANDROID_AB +static int do_bcb_ab_select(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret; + struct blk_desc *dev_desc; + struct disk_partition part_info; + char slot[2]; + bool dec_tries = true; + + for (int i = 4; i < argc; i++) { + if (strcmp(argv[i], "--no-dec") == 0) + dec_tries = false; + else + return CMD_RET_USAGE; + } + + /* Lookup the "misc" partition from argv[2] and argv[3] */ + if (part_get_info_by_dev_and_name_or_num(argv[2], argv[3], + &dev_desc, &part_info, + false) < 0) { + return CMD_RET_FAILURE; + } + + ret = ab_select_slot(dev_desc, &part_info, dec_tries); + if (ret < 0) { + printf("Android boot failed, error %d.\n", ret); + return CMD_RET_FAILURE; + } + + /* Android standard slot names are 'a', 'b', ... */ + slot[0] = BOOT_SLOT_NAME(ret); + slot[1] = '\0'; + env_set(argv[1], slot); + printf("ANDROID: Booting slot: %s\n", slot); + + return CMD_RET_SUCCESS; +} +#endif + static struct cmd_tbl cmd_bcb_sub[] = { U_BOOT_CMD_MKENT(load, CONFIG_SYS_MAXARGS, 1, do_bcb_load, "", ""), U_BOOT_CMD_MKENT(set, CONFIG_SYS_MAXARGS, 1, do_bcb_set, "", ""), @@ -421,6 +475,10 @@ static struct cmd_tbl cmd_bcb_sub[] = { U_BOOT_CMD_MKENT(test, CONFIG_SYS_MAXARGS, 1, do_bcb_test, "", ""), U_BOOT_CMD_MKENT(dump, CONFIG_SYS_MAXARGS, 1, do_bcb_dump, "", ""), U_BOOT_CMD_MKENT(store, CONFIG_SYS_MAXARGS, 1, do_bcb_store, "", ""), +#ifdef CONFIG_ANDROID_AB + U_BOOT_CMD_MKENT(ab_select, CONFIG_SYS_MAXARGS, 1, + do_bcb_ab_select, "", ""), +#endif };
static int do_bcb(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -460,6 +518,23 @@ U_BOOT_CMD( "bcb dump <field> - dump BCB <field>\n" "bcb store - store BCB back to <interface>\n" "\n" +#ifdef CONFIG_ANDROID_AB + "bcb ab_select -\n" + " Select the slot used to boot from and register the boot attempt.\n" + " <slot_var_name> <interface> <dev[:part|#part_name]> [--no-dec]\n" + " - Load the slot metadata from the partition 'part' on\n" + " device type 'interface' instance 'dev' and store the active\n" + " slot in the 'slot_var_name' variable. This also updates the\n" + " Android slot metadata with a boot attempt, which can cause\n" + " successive calls to this function to return a different result\n" + " if the returned slot runs out of boot attempts.\n" + " - If 'part_name' is passed, preceded with a # instead of :, the\n" + " partition name whose label is 'part_name' will be looked up in\n" + " the partition table. This is commonly the "misc" partition.\n" + " - If '--no-dec' is set, the number of tries remaining will not\n" + " decremented for the selected boot slot\n" + "\n" +#endif "Legend:\n" "<interface> - storage device interface (virtio, mmc, etc)\n" "<dev> - storage device index containing the BCB partition\n" diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index efc154eda043ff3ea08194288e33792ce48282f9..b793f00babe474ea3f15292fb4015a7120401238 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -48,7 +48,6 @@ CONFIG_CMD_SPL=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_CMD_BCB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_AB_SELECT=y CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 0f8533e15dbd7c0186a513b27b46a0407b6f79f1..5cacd7f9cc53d338d52120186b16684add93fd21 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_ADTIMG=y CONFIG_CMD_ABOOTIMG=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_CMD_BCB=y -CONFIG_CMD_AB_SELECT=y CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 81a938339d5934605cb7defa04ea92f76468b21a..2d8068ecdc79c01c1281ab3873fc892aa4c96be7 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_ADTIMG=y CONFIG_CMD_ABOOTIMG=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_CMD_BCB=y -CONFIG_CMD_AB_SELECT=y CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y diff --git a/configs/khadas-vim3_android_ab_defconfig b/configs/khadas-vim3_android_ab_defconfig index 510fe4f8928fe39a040a615636fa550b3e0dc5db..de5357c45cbfe4742d9491a29386850570acc235 100644 --- a/configs/khadas-vim3_android_ab_defconfig +++ b/configs/khadas-vim3_android_ab_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_AB_SELECT=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y diff --git a/configs/khadas-vim3l_android_ab_defconfig b/configs/khadas-vim3l_android_ab_defconfig index d2da8ff2a69b209b8fb22a48be537bd4dd17a3bb..4d7b90f23002e464d7dc40516bcd3161b0f59439 100644 --- a/configs/khadas-vim3l_android_ab_defconfig +++ b/configs/khadas-vim3l_android_ab_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_AB_SELECT=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 1b3b8c6e788cd6845b61e62a06b730da28831edc..b5f80b8572ad32b2a92d4fe82c9068c453c11dfd 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -27,6 +27,7 @@ CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x6000 CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ANDROID_AB=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y CONFIG_CMD_BOOTZ=y @@ -46,6 +47,7 @@ CONFIG_CMD_MD5SUM=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_MX_CYCLIC=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_BCB=y CONFIG_CMD_CLK=y CONFIG_CMD_DEMO=y CONFIG_CMD_GPIO=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f31ecef4f58ee201f93c61cd072d6f688b091c3b..749f53559f708ee52fb7c9c638aedcbcb2f23b72 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -103,7 +103,6 @@ CONFIG_CMD_AXI=y CONFIG_CMD_CAT=y CONFIG_CMD_SETEXPR_FMT=y CONFIG_CMD_XXD=y -CONFIG_CMD_AB_SELECT=y CONFIG_CMD_DHCP6=y CONFIG_BOOTP_DNS2=y CONFIG_CMD_PCAP=y diff --git a/doc/android/ab.rst b/doc/android/ab.rst index 2adf88781d60b61d1b3c74efe976a684b590c813..7fd4aeb6a724b839de9be5e9a8843ade2ad3667e 100644 --- a/doc/android/ab.rst +++ b/doc/android/ab.rst @@ -18,7 +18,7 @@ The A/B updates support can be activated by specifying next options in your board configuration file::
CONFIG_ANDROID_AB=y - CONFIG_CMD_AB_SELECT=y + CONFIG_CMD_BCB=y
The disk space on target device must be partitioned in a way so that each partition which needs to be updated has two or more instances. The name of @@ -26,8 +26,8 @@ each instance must be formed by adding suffixes: ``_a``, ``_b``, ``_c``, etc. For example: ``boot_a``, ``boot_b``, ``system_a``, ``system_b``, ``vendor_a``, ``vendor_b``.
-As a result you can use ``ab_select`` command to ensure A/B boot process in your -boot script. This command analyzes and processes A/B metadata stored on a +As a result you can use ``bcb ab_select`` command to ensure A/B boot process in +your boot script. This command analyzes and processes A/B metadata stored on a special partition (e.g. ``misc``) and determines which slot should be used for booting up.
@@ -42,15 +42,15 @@ Command usage
.. code-block:: none
- ab_select <slot_var_name> <interface> <dev[:part_number|#part_name]> + bcb ab_select <slot_var_name> <interface> <dev[:part_number|#part_name]>
for example::
- => ab_select slot_name mmc 1:4 + => bcb ab_select slot_name mmc 1:4
or::
- => ab_select slot_name mmc 1#misc + => bcb ab_select slot_name mmc 1#misc
Result::
diff --git a/include/configs/khadas-vim3_android.h b/include/configs/khadas-vim3_android.h index da6adf6c413add03413f40987959a24ad0d41e62..5468ac5878b34b82a70db84c209bab9f3a9dd79f 100644 --- a/include/configs/khadas-vim3_android.h +++ b/include/configs/khadas-vim3_android.h @@ -12,7 +12,7 @@ #define LOGO_UUID "43a3305d-150f-4cc9-bd3b-38fca8693846;" #define ROOT_UUID "ddb8c3f6-d94d-4394-b633-3134139cc2e0;"
-#if defined(CONFIG_CMD_AB_SELECT) +#if defined(CONFIG_CMD_BCB) && defined(CONFIG_ANDROID_AB) #define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=logo,start=512K,size=2M,uuid=" LOGO_UUID \ diff --git a/include/configs/khadas-vim3l_android.h b/include/configs/khadas-vim3l_android.h index b1768e2d821176452254fb07f2e3747402b9b4fd..32821b942109feae5ade9f7fd02924bca34cf58b 100644 --- a/include/configs/khadas-vim3l_android.h +++ b/include/configs/khadas-vim3l_android.h @@ -12,7 +12,7 @@ #define LOGO_UUID "43a3305d-150f-4cc9-bd3b-38fca8693846;" #define ROOT_UUID "ddb8c3f6-d94d-4394-b633-3134139cc2e0;"
-#if defined(CONFIG_CMD_AB_SELECT) +#if defined(CONFIG_CMD_BCB) && defined(CONFIG_ANDROID_AB) #define PARTS_DEFAULT \ "uuid_disk=${uuid_gpt_disk};" \ "name=logo,start=512K,size=2M,uuid=" LOGO_UUID \ diff --git a/include/configs/meson64_android.h b/include/configs/meson64_android.h index c0e977abb01fb9efb7a462906a0073c84c800897..cc626dbf02418a49b367c8386797ce6ffc28c85b 100644 --- a/include/configs/meson64_android.h +++ b/include/configs/meson64_android.h @@ -47,13 +47,13 @@ #define AVB_VERIFY_CMD "" #endif
-#if defined(CONFIG_CMD_AB_SELECT) +#if defined(CONFIG_CMD_BCB) && defined(CONFIG_ANDROID_AB) #define ANDROIDBOOT_GET_CURRENT_SLOT_CMD "get_current_slot=" \ "if part number mmc ${mmcdev} " CONTROL_PARTITION " control_part_number; " \ "then " \ "echo " CONTROL_PARTITION \ " partition number:${control_part_number};" \ - "ab_select current_slot mmc ${mmcdev}:${control_part_number};" \ + "bcb ab_select current_slot mmc ${mmcdev}:${control_part_number};" \ "else " \ "echo " CONTROL_PARTITION " partition not found;" \ "fi;\0" diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 26494ae980108ad84eb173a0deaa7b701a5309d4..26b6c1cd188c05371c6455cd6247f07a1773d885 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -93,13 +93,13 @@
#define CONTROL_PARTITION "misc"
-#if defined(CONFIG_CMD_AB_SELECT) +#if defined(CONFIG_CMD_BCB) && defined(CONFIG_ANDROID_AB) #define AB_SELECT_SLOT \ "if part number mmc 1 " CONTROL_PARTITION " control_part_number; " \ "then " \ "echo " CONTROL_PARTITION \ " partition number:${control_part_number};" \ - "ab_select slot_name mmc ${mmcdev}:${control_part_number};" \ + "bcb ab_select slot_name mmc ${mmcdev}:${control_part_number};" \ "else " \ "echo " CONTROL_PARTITION " partition not found;" \ "exit;" \ diff --git a/test/py/tests/test_android/test_ab.py b/test/py/tests/test_android/test_ab.py index c79cb07fda35dfeb608ac7345cd3f22744e2e491..0d7b7995a9fab6e3daad748721818b9e4cfac452 100644 --- a/test/py/tests/test_android/test_ab.py +++ b/test/py/tests/test_android/test_ab.py @@ -56,20 +56,20 @@ def ab_disk_image(u_boot_console):
@pytest.mark.boardspec('sandbox') @pytest.mark.buildconfigspec('android_ab') -@pytest.mark.buildconfigspec('cmd_ab_select') +@pytest.mark.buildconfigspec('cmd_bcb') @pytest.mark.requiredtool('sgdisk') def test_ab(ab_disk_image, u_boot_console): - """Test the 'ab_select' command.""" + """Test the 'bcb ab_select' command."""
u_boot_console.run_command('host bind 0 ' + ab_disk_image.path)
- output = u_boot_console.run_command('ab_select slot_name host 0#misc') + output = u_boot_console.run_command('bcb ab_select slot_name host 0#misc') assert 're-initializing A/B metadata' in output assert 'Attempting slot a, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=a' in output
- output = u_boot_console.run_command('ab_select slot_name host 0:1') + output = u_boot_console.run_command('bcb ab_select slot_name host 0:1') assert 'Attempting slot b, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=b' in output
Hi Dmitry,
Thank you for the patch.
On mar., oct. 15, 2024 at 00:06, Dmitry Rokosov ddrokosov@salutedevices.com wrote:
endmenu
- bool "ab_select"
- help
-endmenu
if NET
- Copyright (C) 2017 The Android Open Source Project
char *const argv[])
- int ret;
- char slot[2];
- if (argc < 4)
dec_tries = false;
} else {
false) < 0) {
- if (ret < 0) {
- slot[1] = '\0';
" the partition table. This is commonly the \"misc\" partition.\n"
- BCB_CMD_AB_SELECT,
+#endif };
- if (!strcmp(cmd, "ab_select"))
- case BCB_CMD_AB_SELECT:
goto err;
As discussed in https://lore.kernel.org/r/all/87ikttzhwd.fsf@baylibre.com/, let's try to use CONFIG_IS_ENABLED.
Let's continue the discussion in https://lore.kernel.org/r/all/87ikttzhwd.fsf@baylibre.com/
- int ret;
- char slot[2];
dec_tries = false;
else
false) < 0) {
- if (ret < 0) {
- slot[1] = '\0';
+} +#endif
- U_BOOT_CMD_MKENT(ab_select, CONFIG_SYS_MAXARGS, 1,
+#endif };
- "bcb ab_select -\n"
- " Select the slot used to boot from and register the boot attempt.\n"
- " <slot_var_name> <interface> <dev[:part|#part_name]> [--no-dec]\n"
- "\n"
CONFIG_ANDROID_AB=y
- CONFIG_CMD_BCB=y
- bcb ab_select <slot_var_name> <interface> <dev[:part_number|#part_name]>
for example::
- => bcb ab_select slot_name mmc 1:4
or::
- => bcb ab_select slot_name mmc 1#misc
Result::
"else " \ "echo " CONTROL_PARTITION " partition not found;" \ "fi;\0""bcb ab_select current_slot mmc ${mmcdev}:${control_part_number};" \
"else " \ "echo " CONTROL_PARTITION " partition not found;" \ "exit;" \"bcb ab_select slot_name mmc ${mmcdev}:${control_part_number};" \
- output = u_boot_console.run_command('bcb ab_select slot_name host 0#misc') assert 're-initializing A/B metadata' in output assert 'Attempting slot a, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=a' in output
- output = u_boot_console.run_command('bcb ab_select slot_name host 0:1') assert 'Attempting slot b, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=b' in output
-- 2.43.0
In the entire cmd/bcb.c file, the return value of strcmp() is not directly compared to 0. Therefore, it would be better to maintain this style in the new do_bcb_ab_select() function as well.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- cmd/bcb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/bcb.c b/cmd/bcb.c index bf28726da91134fa287ca8aada884ed74ecc8f2b..3935b7f8d535e87593020b91a6b37d7c5ef02a83 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -439,7 +439,7 @@ static int do_bcb_ab_select(struct cmd_tbl *cmdtp, int flag, int argc, bool dec_tries = true;
for (int i = 4; i < argc; i++) { - if (strcmp(argv[i], "--no-dec") == 0) + if (!strcmp(argv[i], "--no-dec")) dec_tries = false; else return CMD_RET_USAGE;
It's really helpful to have the ability to dump BCB block for debugging A/B logic on the board supported this partition schema.
Command 'bcb ab_dump' prints all fields of bootloader_control struct including slot_metadata for all presented slots.
Output example: =====
board# bcb ab_dump ubi 0#misc Read 512 bytes from volume misc to 000000000bf07580 Read 512 bytes from volume misc to 000000000bf42f40 Bootloader Control: [misc] Active Slot: _a Magic Number: 0x42414342 Version: 1 Number of Slots: 2 Recovery Tries Remaining: 0 CRC: 0x2c8b50bc (Valid)
Slot[0] Metadata:
- Priority: 15
- Tries Remaining: 0
- Successful Boot: 1
- Verity Corrupted: 0
Slot[1] Metadata:
- Priority: 14
- Tries Remaining: 7
- Successful Boot: 0
The ab_dump command allows you to display ABC data directly on the U-Boot console. During an A/B test execution, this test verifies the accuracy of each field within the ABC data.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- boot/android_ab.c | 68 +++++++++++++++++++++++++++++++++++ cmd/bcb.c | 35 ++++++++++++++++++ include/android_ab.h | 10 ++++++ test/py/tests/test_android/test_ab.py | 23 ++++++++++++ 4 files changed, 136 insertions(+)
diff --git a/boot/android_ab.c b/boot/android_ab.c index 0045c8133a8e164f1fdd4c0f9b683de0f13f26e0..c93e51541019d0fe793303c4b3d5286df061906f 100644 --- a/boot/android_ab.c +++ b/boot/android_ab.c @@ -372,3 +372,71 @@ int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info,
return slot; } + +int ab_dump_abc(struct blk_desc *dev_desc, struct disk_partition *part_info) +{ + struct bootloader_control *abc; + u32 crc32_le; + int i, ret; + struct slot_metadata *slot; + + if (!dev_desc || !part_info) { + log_err("ANDROID: Empty device descriptor or partition info\n"); + return -EINVAL; + } + + ret = ab_control_create_from_disk(dev_desc, part_info, &abc, 0); + if (ret < 0) { + log_err("ANDROID: Cannot create bcb from disk %d\n", ret); + return ret; + } + + if (abc->magic != BOOT_CTRL_MAGIC) { + log_err("ANDROID: Unknown A/B metadata: %.8x\n", abc->magic); + ret = -ENODATA; + goto error; + } + + if (abc->version > BOOT_CTRL_VERSION) { + log_err("ANDROID: Unsupported A/B metadata version: %.8x\n", + abc->version); + ret = -ENODATA; + goto error; + } + + if (abc->nb_slot > ARRAY_SIZE(abc->slot_info)) { + log_err("ANDROID: Wrong number of slots %u, expected %zu\n", + abc->nb_slot, ARRAY_SIZE(abc->slot_info)); + ret = -ENODATA; + goto error; + } + + printf("Bootloader Control: [%s]\n", part_info->name); + printf("Active Slot: %s\n", abc->slot_suffix); + printf("Magic Number: 0x%x\n", abc->magic); + printf("Version: %u\n", abc->version); + printf("Number of Slots: %u\n", abc->nb_slot); + printf("Recovery Tries Remaining: %u\n", abc->recovery_tries_remaining); + + printf("CRC: 0x%.8x", abc->crc32_le); + + crc32_le = ab_control_compute_crc(abc); + if (abc->crc32_le != crc32_le) + printf(" (Invalid, Expected: 0x%.8x)\n", crc32_le); + else + printf(" (Valid)\n"); + + for (i = 0; i < abc->nb_slot; ++i) { + slot = &abc->slot_info[i]; + printf("\nSlot[%d] Metadata:\n", i); + printf("\t- Priority: %u\n", slot->priority); + printf("\t- Tries Remaining: %u\n", slot->tries_remaining); + printf("\t- Successful Boot: %u\n", slot->successful_boot); + printf("\t- Verity Corrupted: %u\n", slot->verity_corrupted); + } + +error: + free(abc); + + return ret; +} diff --git a/cmd/bcb.c b/cmd/bcb.c index 3935b7f8d535e87593020b91a6b37d7c5ef02a83..a0eff55c2ed4230e3964297a937c95f9eec3ec85 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -26,6 +26,7 @@ enum bcb_cmd { BCB_CMD_STORE, #ifdef CONFIG_ANDROID_AB BCB_CMD_AB_SELECT, + BCB_CMD_AB_DUMP, #endif };
@@ -59,6 +60,8 @@ static int bcb_cmd_get(char *cmd) #ifdef CONFIG_ANDROID_AB if (!strcmp(cmd, "ab_select")) return BCB_CMD_AB_SELECT; + if (!strcmp(cmd, "ab_dump")) + return BCB_CMD_AB_DUMP; #endif else return -1; @@ -98,6 +101,10 @@ static int bcb_is_misused(int argc, char *const argv[]) if (argc != 4 && argc != 5) goto err; return 0; + case BCB_CMD_AB_DUMP: + if (argc != 3) + goto err; + return 0; #endif default: printf("Error: 'bcb %s' not supported\n", argv[0]); @@ -466,6 +473,28 @@ static int do_bcb_ab_select(struct cmd_tbl *cmdtp, int flag, int argc,
return CMD_RET_SUCCESS; } + +static int do_bcb_ab_dump(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + int ret; + struct blk_desc *dev_desc; + struct disk_partition part_info; + + if (part_get_info_by_dev_and_name_or_num(argv[1], argv[2], + &dev_desc, &part_info, + false) < 0) { + return CMD_RET_FAILURE; + } + + ret = ab_dump_abc(dev_desc, &part_info); + if (ret < 0) { + printf("Cannot dump ABC data, error %d.\n", ret); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} #endif
static struct cmd_tbl cmd_bcb_sub[] = { @@ -478,6 +507,8 @@ static struct cmd_tbl cmd_bcb_sub[] = { #ifdef CONFIG_ANDROID_AB U_BOOT_CMD_MKENT(ab_select, CONFIG_SYS_MAXARGS, 1, do_bcb_ab_select, "", ""), + U_BOOT_CMD_MKENT(ab_dump, CONFIG_SYS_MAXARGS, 1, + do_bcb_ab_dump, "", ""), #endif };
@@ -534,6 +565,10 @@ U_BOOT_CMD( " - If '--no-dec' is set, the number of tries remaining will not\n" " decremented for the selected boot slot\n" "\n" + "bcb ab_dump -\n" + " Dump boot_control information from specific partition.\n" + " <interface> <dev[:part|#part_name]>\n" + "\n" #endif "Legend:\n" "<interface> - storage device interface (virtio, mmc, etc)\n" diff --git a/include/android_ab.h b/include/android_ab.h index 1e53879a25f145a9d18ac0a6553d8c217123aa6f..838230e06f8cbf7a5d79d9d84d9ebe9f96aca10d 100644 --- a/include/android_ab.h +++ b/include/android_ab.h @@ -36,4 +36,14 @@ struct disk_partition; int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info, bool dec_tries);
+/** + * ab_dump_abc() - Dump ABC information for specific partition. + * + * @dev_desc: Device description pointer + * @part_info: Partition information + * + * Return: 0 on success, or a negative on error + */ +int ab_dump_abc(struct blk_desc *dev_desc, struct disk_partition *part_info); + #endif /* __ANDROID_AB_H */ diff --git a/test/py/tests/test_android/test_ab.py b/test/py/tests/test_android/test_ab.py index 0d7b7995a9fab6e3daad748721818b9e4cfac452..9bf1a0eb00a6ae1edebf62f07fd162b9c8c02e49 100644 --- a/test/py/tests/test_android/test_ab.py +++ b/test/py/tests/test_android/test_ab.py @@ -54,6 +54,27 @@ def ab_disk_image(u_boot_console): di = ABTestDiskImage(u_boot_console) return di
+def ab_dump(u_boot_console, slot_num, crc): + output = u_boot_console.run_command('bcb ab_dump host 0#misc') + header, slot0, slot1 = output.split('\r\r\n\r\r\n') + slots = [slot0, slot1] + slot_suffixes = ['_a', '_b'] + + header = dict(map(lambda x: map(str.strip, x.split(':')), header.split('\r\r\n'))) + assert header['Bootloader Control'] == '[misc]' + assert header['Active Slot'] == slot_suffixes[slot_num] + assert header['Magic Number'] == '0x42414342' + assert header['Version'] == '1' + assert header['Number of Slots'] == '2' + assert header['Recovery Tries Remaining'] == '0' + assert header['CRC'] == '{} (Valid)'.format(crc) + + slot = dict(map(lambda x: map(str.strip, x.split(':')), slots[slot_num].split('\r\r\n\t- ')[1:])) + assert slot['Priority'] == '15' + assert slot['Tries Remaining'] == '6' + assert slot['Successful Boot'] == '0' + assert slot['Verity Corrupted'] == '0' + @pytest.mark.boardspec('sandbox') @pytest.mark.buildconfigspec('android_ab') @pytest.mark.buildconfigspec('cmd_bcb') @@ -68,8 +89,10 @@ def test_ab(ab_disk_image, u_boot_console): assert 'Attempting slot a, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=a' in output + ab_dump(u_boot_console, 0, '0xd438d1b9')
output = u_boot_console.run_command('bcb ab_select slot_name host 0:1') assert 'Attempting slot b, tries remaining 7' in output output = u_boot_console.run_command('printenv slot_name') assert 'slot_name=b' in output + ab_dump(u_boot_console, 1, '0x011ec016')
To align with the official Android BCB (Bootloader Control Block) specifications, it's important to note that the slot_suffix should start with an underscore symbol.
For a comprehensive understanding of the expected slot_suffix format in userspace, please refer to the provided reference [1].
Links: [1] - https://source.android.com/docs/core/architecture/bootloader/updating#slots
Based-on: https://android-review.googlesource.com/c/platform/external/u-boot/+/1446439 Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Guillaume La Roque glaroque@baylibre.com Signed-off-by: Dmitry Rokosov ddrokosov@salutedevices.com --- boot/android_ab.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/boot/android_ab.c b/boot/android_ab.c index c93e51541019d0fe793303c4b3d5286df061906f..a287eac04fe88ad08bdcf1b1b1d6e564d503d800 100644 --- a/boot/android_ab.c +++ b/boot/android_ab.c @@ -52,7 +52,7 @@ static int ab_control_default(struct bootloader_control *abc) if (!abc) return -EFAULT;
- memcpy(abc->slot_suffix, "a\0\0\0", 4); + memcpy(abc->slot_suffix, "_a\0\0", 4); abc->magic = BOOT_CTRL_MAGIC; abc->version = BOOT_CTRL_VERSION; abc->nb_slot = NUM_SLOTS; @@ -328,7 +328,8 @@ int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info, * or the device tree. */ memset(slot_suffix, 0, sizeof(slot_suffix)); - slot_suffix[0] = BOOT_SLOT_NAME(slot); + slot_suffix[0] = '_'; + slot_suffix[1] = BOOT_SLOT_NAME(slot); if (memcmp(abc->slot_suffix, slot_suffix, sizeof(slot_suffix))) { memcpy(abc->slot_suffix, slot_suffix,
Dmitry Rokosov
Mattijs Korpershoek
