[PATCH] ARM: rmobile: Remove default bootargs
The bootargs in all those boards are a copy of initial example bootargs, just remove those as they make little sense in most configurations.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/hihope_rzg2_defconfig | 1 - configs/r8a77970_eagle_defconfig | 1 - configs/r8a77980_condor_defconfig | 1 - configs/r8a77990_ebisu_defconfig | 1 - configs/r8a77995_draak_defconfig | 1 - configs/rcar3_salvator-x_defconfig | 1 - configs/rcar3_ulcb_defconfig | 1 - 7 files changed, 7 deletions(-)
diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index be71ebb6a2..800481326d 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -12,7 +12,6 @@ CONFIG_TARGET_HIHOPE_RZG2=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a774a1-hihope-rzg2m.dtb" # CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 2e5fb60f1a..2532154978 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -14,7 +14,6 @@ CONFIG_TARGET_EAGLE=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77970-eagle.dtb" CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index 1b9948bcbb..02f008ad35 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -14,7 +14,6 @@ CONFIG_TARGET_CONDOR=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77980-condor.dtb" # CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_HUSH_PARSER=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 69297fef66..e5cab47f9f 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -13,7 +13,6 @@ CONFIG_TARGET_EBISU=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77990-ebisu.dtb" # CONFIG_BOARD_EARLY_INIT_F is not set CONFIG_UPDATE_TFTP=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 562b80b996..acae38a6c0 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -13,7 +13,6 @@ CONFIG_TARGET_DRAAK=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77995-draak.dtb" CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index 150db3bff5..bb0bcfefe2 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -12,7 +12,6 @@ CONFIG_TARGET_SALVATOR_X=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77950-salvator-x.dtb" CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index a6f806c3c3..e0d72d940d 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -13,7 +13,6 @@ CONFIG_TARGET_ULCB=y CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_DEFAULT_FDT_FILE="r8a77950-ulcb.dtb" CONFIG_UPDATE_TFTP=y CONFIG_HUSH_PARSER=y
