[U-Boot] [PATCH 1/2] spi: cf_qspi: Use DIV_ROUND_UP at appropriate place
This change slightly improves readability.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/cf_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/cf_qspi.c b/drivers/spi/cf_qspi.c index a37ac4e..06bcf91 100644 --- a/drivers/spi/cf_qspi.c +++ b/drivers/spi/cf_qspi.c @@ -171,7 +171,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, volatile qspi_t *qspi = dev->regs; u8 *txbuf = (u8 *)dout; u8 *rxbuf = (u8 *)din; - u32 count = ((bitlen / 8) + (bitlen % 8 ? 1 : 0)); + u32 count = DIV_ROUND_UP(bitlen, 8); u32 n, i = 0;
/* Sanitize arguments */
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/spi/mxc_spi.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 5bed858..2ea3228 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -224,7 +224,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, const u8 *dout, u8 *din, unsigned long flags) { struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); - int nbytes = (bitlen + 7) / 8; + int nbytes = DIV_ROUND_UP(bitlen, 8); u32 data, cnt, i; struct cspi_regs *regs = (struct cspi_regs *)mxcs->base;
@@ -294,7 +294,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, /* Transfer completed, clear any pending request */ reg_write(®s->stat, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF);
- nbytes = (bitlen + 7) / 8; + nbytes = DIV_ROUND_UP(bitlen, 8);
cnt = nbytes % 32;
@@ -330,7 +330,7 @@ int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { - int n_bytes = (bitlen + 7) / 8; + int n_bytes = DIV_ROUND_UP(bitlen, 8); int n_bits; int ret; u32 blk_size;
- int nbytes = DIV_ROUND_UP(bitlen, 8); u32 data, cnt, i; struct cspi_regs *regs = (struct cspi_regs *)mxcs->base;
cnt = nbytes % 32;
- int n_bytes = DIV_ROUND_UP(bitlen, 8); int n_bits; int ret; u32 blk_size;
Reviewed-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
-- Thanks, Jagan.
cnt = nbytes % 32;
Applied to u-boot-spi/master
-- Thanks, Jagan.
Signed-off-by: Axel Linaxel.lin@ingics.com
ACK. Thanks for the cleanup.
Signed-off-by: Richard Retanubunrichardretanubun@ruggedcom.com
-- Thanks, Jagan.
-- Thanks, Jagan.
Axel Lin
Jagan Teki
Richard Retanubun
