[U-Boot] [PATCH V5 RESEND 0/3] mtd/NAND: Support for FSMC controller
This patchset adds support for ST's FSMC controller. In the current u-boot, a SPEAr specific driver exists for FSMC controller. This patchset adds a full fledged driver that can be used across multiple platforms and removes the obsolete SPEAr specific driver.
V4 -> V5 - Dropped the patch that defined change_bit as wrapper over __change_bit and, instead, defined logic to correct bit errors without using __change_bit
V3 -> V4 - Removed local_irq_save and local_irq_restore calls from change_bit wrapper - Report the total bit flips, including that of ECC, to the upper layers - Replace change_bit calls for err_idx's 0th and 1st bit with "^= 3" operation
V2 -> V3 - Implemented timeout during hardware ecc read - Used __attribute__ ((aligned(2))) instead of using array of U16 - Removed unnecessary enum
V1 -> V2 - Defined CONFIG_SYS_NAND_SELF_INIT and did the related changes - Modified the error index calculation process - Modified newly erased page read algorithm - Initialized the badblockbits index to 7 - Improved fsmc_bch8_correct_data() implementation
Vipin KUMAR (3): mtd/NAND: Add FSMC driver support SPEAr: Configure FSMC driver for NAND interface mtd/NAND: Remove obsolete SPEAr specific NAND drivers
arch/arm/include/asm/arch-spear/hardware.h | 8 +- arch/arm/include/asm/arch-spear/spr_nand.h | 57 ---- board/spear/spear300/spear300.c | 14 +- board/spear/spear310/spear310.c | 14 +- board/spear/spear320/spear320.c | 13 +- board/spear/spear600/spear600.c | 14 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsmc_nand.c | 487 ++++++++++++++++++++++++++++ drivers/mtd/nand/spr_nand.c | 124 ------- include/configs/spear-common.h | 3 +- include/configs/spear3xx.h | 4 + include/configs/spear6xx.h | 3 + include/linux/mtd/fsmc_nand.h | 101 ++++++ 13 files changed, 638 insertions(+), 205 deletions(-) delete mode 100644 arch/arm/include/asm/arch-spear/spr_nand.h create mode 100644 drivers/mtd/nand/fsmc_nand.c delete mode 100644 drivers/mtd/nand/spr_nand.c create mode 100644 include/linux/mtd/fsmc_nand.h
Flexible static memory controller is a peripheral provided by ST, which controls the access to NAND chips along with many other memory device chips eg NOR, SRAM.
This patch adds the driver support for FSMC controller interfacing with NAND memory.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsmc_nand.c | 487 +++++++++++++++++++++++++++++++++++++++++ include/linux/mtd/fsmc_nand.h | 101 +++++++++ 3 files changed, 589 insertions(+), 0 deletions(-) create mode 100644 drivers/mtd/nand/fsmc_nand.c create mode 100644 include/linux/mtd/fsmc_nand.h
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 1d1b628..29dc20e 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -49,6 +49,7 @@ COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o +COBJS-$(CONFIG_NAND_FSMC) += fsmc_nand.o COBJS-$(CONFIG_NAND_JZ4740) += jz4740_nand.o COBJS-$(CONFIG_NAND_KB9202) += kb9202_nand.o COBJS-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o diff --git a/drivers/mtd/nand/fsmc_nand.c b/drivers/mtd/nand/fsmc_nand.c new file mode 100644 index 0000000..292fa8c --- /dev/null +++ b/drivers/mtd/nand/fsmc_nand.c @@ -0,0 +1,487 @@ +/* + * (C) Copyright 2010 + * Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com. + * + * (C) Copyright 2012 + * Amit Virdi, ST Micoelectronics, amit.virdi@st.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/err.h> +#include <linux/mtd/nand_ecc.h> +#include <linux/mtd/fsmc_nand.h> +#include <asm/arch/hardware.h> + +static u32 fsmc_version; +static struct fsmc_regs *const fsmc_regs_p = (struct fsmc_regs *) + CONFIG_SYS_FSMC_BASE; + +/* + * ECC4 and ECC1 have 13 bytes and 3 bytes of ecc respectively for 512 bytes of + * data. ECC4 can correct up to 8 bits in 512 bytes of data while ECC1 can + * correct 1 bit in 512 bytes + */ + +static struct nand_ecclayout fsmc_ecc4_lp_layout = { + .eccbytes = 104, + .eccpos = { 2, 3, 4, 5, 6, 7, 8, + 9, 10, 11, 12, 13, 14, + 18, 19, 20, 21, 22, 23, 24, + 25, 26, 27, 28, 29, 30, + 34, 35, 36, 37, 38, 39, 40, + 41, 42, 43, 44, 45, 46, + 50, 51, 52, 53, 54, 55, 56, + 57, 58, 59, 60, 61, 62, + 66, 67, 68, 69, 70, 71, 72, + 73, 74, 75, 76, 77, 78, + 82, 83, 84, 85, 86, 87, 88, + 89, 90, 91, 92, 93, 94, + 98, 99, 100, 101, 102, 103, 104, + 105, 106, 107, 108, 109, 110, + 114, 115, 116, 117, 118, 119, 120, + 121, 122, 123, 124, 125, 126 + }, + .oobfree = { + {.offset = 15, .length = 3}, + {.offset = 31, .length = 3}, + {.offset = 47, .length = 3}, + {.offset = 63, .length = 3}, + {.offset = 79, .length = 3}, + {.offset = 95, .length = 3}, + {.offset = 111, .length = 3}, + {.offset = 127, .length = 1} + } +}; + +/* + * ECC4 layout for NAND of pagesize 4096 bytes & OOBsize 224 bytes. 13*8 bytes + * of OOB size is reserved for ECC, Byte no. 0 & 1 reserved for bad block & 118 + * bytes are free for use. + */ +static struct nand_ecclayout fsmc_ecc4_224_layout = { + .eccbytes = 104, + .eccpos = { 2, 3, 4, 5, 6, 7, 8, + 9, 10, 11, 12, 13, 14, + 18, 19, 20, 21, 22, 23, 24, + 25, 26, 27, 28, 29, 30, + 34, 35, 36, 37, 38, 39, 40, + 41, 42, 43, 44, 45, 46, + 50, 51, 52, 53, 54, 55, 56, + 57, 58, 59, 60, 61, 62, + 66, 67, 68, 69, 70, 71, 72, + 73, 74, 75, 76, 77, 78, + 82, 83, 84, 85, 86, 87, 88, + 89, 90, 91, 92, 93, 94, + 98, 99, 100, 101, 102, 103, 104, + 105, 106, 107, 108, 109, 110, + 114, 115, 116, 117, 118, 119, 120, + 121, 122, 123, 124, 125, 126 + }, + .oobfree = { + {.offset = 15, .length = 3}, + {.offset = 31, .length = 3}, + {.offset = 47, .length = 3}, + {.offset = 63, .length = 3}, + {.offset = 79, .length = 3}, + {.offset = 95, .length = 3}, + {.offset = 111, .length = 3}, + {.offset = 127, .length = 97} + } +}; + +/* + * ECC placement definitions in oobfree type format + * There are 13 bytes of ecc for every 512 byte block and it has to be read + * consecutively and immediately after the 512 byte data block for hardware to + * generate the error bit offsets in 512 byte data + * Managing the ecc bytes in the following way makes it easier for software to + * read ecc bytes consecutive to data bytes. This way is similar to + * oobfree structure maintained already in u-boot nand driver + */ +static struct fsmc_eccplace fsmc_eccpl_lp = { + .eccplace = { + {.offset = 2, .length = 13}, + {.offset = 18, .length = 13}, + {.offset = 34, .length = 13}, + {.offset = 50, .length = 13}, + {.offset = 66, .length = 13}, + {.offset = 82, .length = 13}, + {.offset = 98, .length = 13}, + {.offset = 114, .length = 13} + } +}; + +static struct nand_ecclayout fsmc_ecc4_sp_layout = { + .eccbytes = 13, + .eccpos = { 0, 1, 2, 3, 6, 7, 8, + 9, 10, 11, 12, 13, 14 + }, + .oobfree = { + {.offset = 15, .length = 1}, + } +}; + +static struct fsmc_eccplace fsmc_eccpl_sp = { + .eccplace = { + {.offset = 0, .length = 4}, + {.offset = 6, .length = 9} + } +}; + +static struct nand_ecclayout fsmc_ecc1_layout = { + .eccbytes = 24, + .eccpos = {2, 3, 4, 18, 19, 20, 34, 35, 36, 50, 51, 52, + 66, 67, 68, 82, 83, 84, 98, 99, 100, 114, 115, 116}, + .oobfree = { + {.offset = 8, .length = 8}, + {.offset = 24, .length = 8}, + {.offset = 40, .length = 8}, + {.offset = 56, .length = 8}, + {.offset = 72, .length = 8}, + {.offset = 88, .length = 8}, + {.offset = 104, .length = 8}, + {.offset = 120, .length = 8} + } +}; + +/* Count the number of 0's in buff upto a max of max_bits */ +static int count_written_bits(uint8_t *buff, int size, int max_bits) +{ + int k, written_bits = 0; + + for (k = 0; k < size; k++) { + written_bits += hweight8(~buff[k]); + if (written_bits > max_bits) + break; + } + + return written_bits; +} + +static void fsmc_nand_hwcontrol(struct mtd_info *mtd, int cmd, uint ctrl) +{ + struct nand_chip *this = mtd->priv; + ulong IO_ADDR_W; + + if (ctrl & NAND_CTRL_CHANGE) { + IO_ADDR_W = (ulong)this->IO_ADDR_W; + + IO_ADDR_W &= ~(CONFIG_SYS_NAND_CLE | CONFIG_SYS_NAND_ALE); + if (ctrl & NAND_CLE) + IO_ADDR_W |= CONFIG_SYS_NAND_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= CONFIG_SYS_NAND_ALE; + + if (ctrl & NAND_NCE) { + writel(readl(&fsmc_regs_p->pc) | + FSMC_ENABLE, &fsmc_regs_p->pc); + } else { + writel(readl(&fsmc_regs_p->pc) & + ~FSMC_ENABLE, &fsmc_regs_p->pc); + } + this->IO_ADDR_W = (void *)IO_ADDR_W; + } + + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); +} + +static int fsmc_bch8_correct_data(struct mtd_info *mtd, u_char *dat, + u_char *read_ecc, u_char *calc_ecc) +{ + /* The calculated ecc is actually the correction index in data */ + u32 err_idx[8]; + u32 num_err, i; + u32 ecc1, ecc2, ecc3, ecc4; + + num_err = (readl(&fsmc_regs_p->sts) >> 10) & 0xF; + + if (likely(num_err == 0)) + return 0; + + if (unlikely(num_err > 8)) { + /* + * This is a temporary erase check. A newly erased page read + * would result in an ecc error because the oob data is also + * erased to FF and the calculated ecc for an FF data is not + * FF..FF. + * This is a workaround to skip performing correction in case + * data is FF..FF + * + * Logic: + * For every page, each bit written as 0 is counted until these + * number of bits are greater than 8 (the maximum correction + * capability of FSMC for each 512 + 13 bytes) + */ + + int bits_ecc = count_written_bits(read_ecc, 13, 8); + int bits_data = count_written_bits(dat, 512, 8); + + if ((bits_ecc + bits_data) <= 8) { + if (bits_data) + memset(dat, 0xff, 512); + return bits_data + bits_ecc; + } + + return -EBADMSG; + } + + ecc1 = readl(&fsmc_regs_p->ecc1); + ecc2 = readl(&fsmc_regs_p->ecc2); + ecc3 = readl(&fsmc_regs_p->ecc3); + ecc4 = readl(&fsmc_regs_p->sts); + + err_idx[0] = (ecc1 >> 0) & 0x1FFF; + err_idx[1] = (ecc1 >> 13) & 0x1FFF; + err_idx[2] = (((ecc2 >> 0) & 0x7F) << 6) | ((ecc1 >> 26) & 0x3F); + err_idx[3] = (ecc2 >> 7) & 0x1FFF; + err_idx[4] = (((ecc3 >> 0) & 0x1) << 12) | ((ecc2 >> 20) & 0xFFF); + err_idx[5] = (ecc3 >> 1) & 0x1FFF; + err_idx[6] = (ecc3 >> 14) & 0x1FFF; + err_idx[7] = (((ecc4 >> 16) & 0xFF) << 5) | ((ecc3 >> 27) & 0x1F); + + i = 0; + while (i < num_err) { + err_idx[i] ^= 3; + + if (err_idx[i] < 512 * 8) { + u8 *p = dat + err_idx[i] / 8; + *p = *p ^ (1 << (err_idx[i] % 8)); + } + i++; + } + + return num_err; +} + +static int fsmc_read_hwecc(struct mtd_info *mtd, + const u_char *data, u_char *ecc) +{ + u_int ecc_tmp; + int timeout = CONFIG_SYS_HZ; + ulong start; + + switch (fsmc_version) { + case FSMC_VER8: + start = get_timer(0); + while (get_timer(start) < timeout) { + /* + * Busy waiting for ecc computation + * to finish for 512 bytes + */ + if (readl(&fsmc_regs_p->sts) & FSMC_CODE_RDY) + break; + } + + ecc_tmp = readl(&fsmc_regs_p->ecc1); + ecc[0] = (u_char) (ecc_tmp >> 0); + ecc[1] = (u_char) (ecc_tmp >> 8); + ecc[2] = (u_char) (ecc_tmp >> 16); + ecc[3] = (u_char) (ecc_tmp >> 24); + + ecc_tmp = readl(&fsmc_regs_p->ecc2); + ecc[4] = (u_char) (ecc_tmp >> 0); + ecc[5] = (u_char) (ecc_tmp >> 8); + ecc[6] = (u_char) (ecc_tmp >> 16); + ecc[7] = (u_char) (ecc_tmp >> 24); + + ecc_tmp = readl(&fsmc_regs_p->ecc3); + ecc[8] = (u_char) (ecc_tmp >> 0); + ecc[9] = (u_char) (ecc_tmp >> 8); + ecc[10] = (u_char) (ecc_tmp >> 16); + ecc[11] = (u_char) (ecc_tmp >> 24); + + ecc_tmp = readl(&fsmc_regs_p->sts); + ecc[12] = (u_char) (ecc_tmp >> 16); + break; + + default: + ecc_tmp = readl(&fsmc_regs_p->ecc1); + ecc[0] = (u_char) (ecc_tmp >> 0); + ecc[1] = (u_char) (ecc_tmp >> 8); + ecc[2] = (u_char) (ecc_tmp >> 16); + break; + } + + return 0; +} + +void fsmc_enable_hwecc(struct mtd_info *mtd, int mode) +{ + writel(readl(&fsmc_regs_p->pc) & ~FSMC_ECCPLEN_256, + &fsmc_regs_p->pc); + writel(readl(&fsmc_regs_p->pc) & ~FSMC_ECCEN, + &fsmc_regs_p->pc); + writel(readl(&fsmc_regs_p->pc) | FSMC_ECCEN, + &fsmc_regs_p->pc); +} + +/* + * fsmc_read_page_hwecc + * @mtd: mtd info structure + * @chip: nand chip info structure + * @buf: buffer to store read data + * @page: page number to read + * + * This routine is needed for fsmc verison 8 as reading from NAND chip has to be + * performed in a strict sequence as follows: + * data(512 byte) -> ecc(13 byte) + * After this read, fsmc hardware generates and reports error data bits(upto a + * max of 8 bits) + */ +static int fsmc_read_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int page) +{ + struct fsmc_eccplace *fsmc_eccpl; + int i, j, s, stat, eccsize = chip->ecc.size; + int eccbytes = chip->ecc.bytes; + int eccsteps = chip->ecc.steps; + uint8_t *p = buf; + uint8_t *ecc_calc = chip->buffers->ecccalc; + uint8_t *ecc_code = chip->buffers->ecccode; + int off, len, group = 0; + uint8_t oob[13] __attribute__((aligned(2))); + + /* Differentiate between small and large page ecc place definitions */ + if (mtd->writesize == 512) + fsmc_eccpl = &fsmc_eccpl_sp; + else + fsmc_eccpl = &fsmc_eccpl_lp; + + for (i = 0, s = 0; s < eccsteps; s++, i += eccbytes, p += eccsize) { + + chip->cmdfunc(mtd, NAND_CMD_READ0, s * eccsize, page); + chip->ecc.hwctl(mtd, NAND_ECC_READ); + chip->read_buf(mtd, p, eccsize); + + for (j = 0; j < eccbytes;) { + off = fsmc_eccpl->eccplace[group].offset; + len = fsmc_eccpl->eccplace[group].length; + group++; + + /* + * length is intentionally kept a higher multiple of 2 + * to read at least 13 bytes even in case of 16 bit NAND + * devices + */ + if (chip->options & NAND_BUSWIDTH_16) + len = roundup(len, 2); + chip->cmdfunc(mtd, NAND_CMD_READOOB, off, page); + chip->read_buf(mtd, oob + j, len); + j += len; + } + + memcpy(&ecc_code[i], oob, 13); + chip->ecc.calculate(mtd, p, &ecc_calc[i]); + + stat = chip->ecc.correct(mtd, p, &ecc_code[i], + &ecc_calc[i]); + if (stat < 0) + mtd->ecc_stats.failed++; + else + mtd->ecc_stats.corrected += stat; + } + + return 0; +} + +int fsmc_nand_init(struct nand_chip *nand) +{ + static int chip_nr; + struct mtd_info *mtd; + int i; + u32 peripid2 = readl(&fsmc_regs_p->peripid2); + + fsmc_version = (peripid2 >> FSMC_REVISION_SHFT) & + FSMC_REVISION_MSK; + + writel(readl(&fsmc_regs_p->ctrl) | FSMC_WP, &fsmc_regs_p->ctrl); + +#if defined(CONFIG_SYS_FSMC_NAND_16BIT) + writel(FSMC_DEVWID_16 | FSMC_DEVTYPE_NAND | FSMC_ENABLE | FSMC_WAITON, + &fsmc_regs_p->pc); +#elif defined(CONFIG_SYS_FSMC_NAND_8BIT) + writel(FSMC_DEVWID_8 | FSMC_DEVTYPE_NAND | FSMC_ENABLE | FSMC_WAITON, + &fsmc_regs_p->pc); +#else +#error Please define CONFIG_SYS_FSMC_NAND_16BIT or CONFIG_SYS_FSMC_NAND_8BIT +#endif + writel(readl(&fsmc_regs_p->pc) | FSMC_TCLR_1 | FSMC_TAR_1, + &fsmc_regs_p->pc); + writel(FSMC_THIZ_1 | FSMC_THOLD_4 | FSMC_TWAIT_6 | FSMC_TSET_0, + &fsmc_regs_p->comm); + writel(FSMC_THIZ_1 | FSMC_THOLD_4 | FSMC_TWAIT_6 | FSMC_TSET_0, + &fsmc_regs_p->attrib); + + nand->options = 0; +#if defined(CONFIG_SYS_FSMC_NAND_16BIT) + nand->options |= NAND_BUSWIDTH_16; +#endif + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = 512; + nand->ecc.calculate = fsmc_read_hwecc; + nand->ecc.hwctl = fsmc_enable_hwecc; + nand->cmd_ctrl = fsmc_nand_hwcontrol; + nand->IO_ADDR_R = nand->IO_ADDR_W = + (void __iomem *)CONFIG_SYS_NAND_BASE; + nand->badblockbits = 7; + + mtd = &nand_info[chip_nr++]; + mtd->priv = nand; + + switch (fsmc_version) { + case FSMC_VER8: + nand->ecc.bytes = 13; + nand->ecc.correct = fsmc_bch8_correct_data; + nand->ecc.read_page = fsmc_read_page_hwecc; + if (mtd->writesize == 512) + nand->ecc.layout = &fsmc_ecc4_sp_layout; + else { + if (mtd->oobsize == 224) + nand->ecc.layout = &fsmc_ecc4_224_layout; + else + nand->ecc.layout = &fsmc_ecc4_lp_layout; + } + + break; + default: + nand->ecc.bytes = 3; + nand->ecc.layout = &fsmc_ecc1_layout; + nand->ecc.correct = nand_correct_data; + break; + } + + /* Detect NAND chips */ + if (nand_scan_ident(mtd, CONFIG_SYS_MAX_NAND_DEVICE, NULL)) + return -ENXIO; + + if (nand_scan_tail(mtd)) + return -ENXIO; + + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + if (nand_register(i)) + return -ENXIO; + + return 0; +} diff --git a/include/linux/mtd/fsmc_nand.h b/include/linux/mtd/fsmc_nand.h new file mode 100644 index 0000000..3a61cea --- /dev/null +++ b/include/linux/mtd/fsmc_nand.h @@ -0,0 +1,101 @@ +/* + * (C) Copyright 2010 + * Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSMC_NAND_H__ +#define __FSMC_NAND_H__ + +#include <linux/mtd/nand.h> + +struct fsmc_regs { + u32 ctrl; /* 0x00 */ + u8 reserved_1[0x40 - 0x04]; + u32 pc; /* 0x40 */ + u32 sts; /* 0x44 */ + u32 comm; /* 0x48 */ + u32 attrib; /* 0x4c */ + u32 ioata; /* 0x50 */ + u32 ecc1; /* 0x54 */ + u32 ecc2; /* 0x58 */ + u32 ecc3; /* 0x5c */ + u8 reserved_2[0xfe0 - 0x60]; + u32 peripid0; /* 0xfe0 */ + u32 peripid1; /* 0xfe4 */ + u32 peripid2; /* 0xfe8 */ + u32 peripid3; /* 0xfec */ + u32 pcellid0; /* 0xff0 */ + u32 pcellid1; /* 0xff4 */ + u32 pcellid2; /* 0xff8 */ + u32 pcellid3; /* 0xffc */ +}; + +/* ctrl register definitions */ +#define FSMC_WP (1 << 7) + +/* pc register definitions */ +#define FSMC_RESET (1 << 0) +#define FSMC_WAITON (1 << 1) +#define FSMC_ENABLE (1 << 2) +#define FSMC_DEVTYPE_NAND (1 << 3) +#define FSMC_DEVWID_8 (0 << 4) +#define FSMC_DEVWID_16 (1 << 4) +#define FSMC_ECCEN (1 << 6) +#define FSMC_ECCPLEN_512 (0 << 7) +#define FSMC_ECCPLEN_256 (1 << 7) +#define FSMC_TCLR_1 (1 << 9) +#define FSMC_TAR_1 (1 << 13) + +/* sts register definitions */ +#define FSMC_CODE_RDY (1 << 15) + +/* comm register definitions */ +#define FSMC_TSET_0 (0 << 0) +#define FSMC_TWAIT_6 (6 << 8) +#define FSMC_THOLD_4 (4 << 16) +#define FSMC_THIZ_1 (1 << 24) + +/* peripid2 register definitions */ +#define FSMC_REVISION_MSK (0xf) +#define FSMC_REVISION_SHFT (0x4) + +#define FSMC_VER8 0x8 + +/* + * There are 13 bytes of ecc for every 512 byte block and it has to be read + * consecutively and immediately after the 512 byte data block for hardware to + * generate the error bit offsets + * Managing the ecc bytes in the following way is easier. This way is similar to + * oobfree structure maintained already in u-boot nand driver + */ +#define FSMC_MAX_ECCPLACE_ENTRIES 32 + +struct fsmc_nand_eccplace { + u32 offset; + u32 length; +}; + +struct fsmc_eccplace { + struct fsmc_nand_eccplace eccplace[FSMC_MAX_ECCPLACE_ENTRIES]; +}; + +extern int fsmc_nand_init(struct nand_chip *nand); +#endif
Signed-off-by: Vipin Kumarvipin.kumar@st.com Signed-off-by: Amit Virdiamit.virdi@st.com
- (C) Copyright 2010
- Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com.
- (C) Copyright 2012
- Amit Virdi, ST Micoelectronics, amit.virdi@st.com.
Fix the typo please. In all the copyright headers.
~Vikram
Scott,
If you're fine with this patchset, while pushing the patches upstream, could you please change Micoelectronics to Microelectronics at both the places?
Thanks Amit Virdi
Since FSMC is a standard IP and it supports different memory interfaces, it is supported independent of spear platform and spear is configured to use that driver for interfacing with the NAND device
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- arch/arm/include/asm/arch-spear/hardware.h | 8 ++++---- board/spear/spear300/spear300.c | 14 +++++++++----- board/spear/spear310/spear310.c | 14 +++++++++----- board/spear/spear320/spear320.c | 13 +++++++++---- board/spear/spear600/spear600.c | 14 +++++++++----- include/configs/spear-common.h | 3 ++- include/configs/spear3xx.h | 4 ++++ include/configs/spear6xx.h | 3 +++ 8 files changed, 49 insertions(+), 24 deletions(-)
diff --git a/arch/arm/include/asm/arch-spear/hardware.h b/arch/arm/include/asm/arch-spear/hardware.h index 818f36c..a6517b2 100644 --- a/arch/arm/include/asm/arch-spear/hardware.h +++ b/arch/arm/include/asm/arch-spear/hardware.h @@ -37,15 +37,15 @@
#if defined(CONFIG_SPEAR600) #define CONFIG_SYS_I2C_BASE (0xD0200000) -#define CONFIG_SPEAR_FSMCBASE (0xD1800000) +#define CONFIG_SYS_FSMC_BASE (0xD1800000)
#elif defined(CONFIG_SPEAR300) #define CONFIG_SYS_I2C_BASE (0xD0180000) -#define CONFIG_SPEAR_FSMCBASE (0x94000000) +#define CONFIG_SYS_FSMC_BASE (0x94000000)
#elif defined(CONFIG_SPEAR310) #define CONFIG_SYS_I2C_BASE (0xD0180000) -#define CONFIG_SPEAR_FSMCBASE (0x44000000) +#define CONFIG_SYS_FSMC_BASE (0x44000000)
#undef CONFIG_SYS_NAND_CLE #undef CONFIG_SYS_NAND_ALE @@ -57,7 +57,7 @@
#elif defined(CONFIG_SPEAR320) #define CONFIG_SYS_I2C_BASE (0xD0180000) -#define CONFIG_SPEAR_FSMCBASE (0x4C000000) +#define CONFIG_SYS_FSMC_BASE (0x4C000000)
#define CONFIG_SPEAR_EMIBASE (0x40000000) #define CONFIG_SPEAR_RASBASE (0xB3000000) diff --git a/board/spear/spear300/spear300.c b/board/spear/spear300/spear300.c index 60ee544..72a3631 100644 --- a/board/spear/spear300/spear300.c +++ b/board/spear/spear300/spear300.c @@ -24,10 +24,12 @@ #include <common.h> #include <nand.h> #include <asm/io.h> +#include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_defs.h> #include <asm/arch/spr_misc.h> -#include <asm/arch/spr_nand.h> + +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE];
int board_init(void) { @@ -41,18 +43,20 @@ int board_init(void) * Called by nand_init_chip to initialize the board specific functions */
-int board_nand_init(struct nand_chip *nand) +void board_nand_init() { struct misc_regs *const misc_regs_p = (struct misc_regs *)CONFIG_SPEAR_MISCBASE; + struct nand_chip *nand = &nand_chip[0];
+#if defined(CONFIG_NAND_FSMC) if (((readl(&misc_regs_p->auto_cfg_reg) & MISC_SOCCFGMSK) == MISC_SOCCFG30) || ((readl(&misc_regs_p->auto_cfg_reg) & MISC_SOCCFGMSK) == MISC_SOCCFG31)) {
- return spear_nand_init(nand); + fsmc_nand_init(nand); } - - return -1; +#endif + return; } diff --git a/board/spear/spear310/spear310.c b/board/spear/spear310/spear310.c index 03dfe16..14e666d 100644 --- a/board/spear/spear310/spear310.c +++ b/board/spear/spear310/spear310.c @@ -25,10 +25,12 @@ #include <common.h> #include <nand.h> #include <asm/io.h> +#include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_defs.h> #include <asm/arch/spr_misc.h> -#include <asm/arch/spr_nand.h> + +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE];
int board_init(void) { @@ -42,18 +44,20 @@ int board_init(void) * Called by nand_init_chip to initialize the board specific functions */
- return spear_nand_init(nand); + fsmc_nand_init(nand); } - - return -1; +#endif + return; } diff --git a/board/spear/spear320/spear320.c b/board/spear/spear320/spear320.c index 2ba2dbb..994eb2b 100644 --- a/board/spear/spear320/spear320.c +++ b/board/spear/spear320/spear320.c @@ -25,10 +25,12 @@ #include <common.h> #include <nand.h> #include <asm/io.h> +#include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_defs.h> #include <asm/arch/spr_misc.h> -#include <asm/arch/spr_nand.h> + +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE];
int board_init(void) { @@ -42,18 +44,21 @@ int board_init(void) * Called by nand_init_chip to initialize the board specific functions */
- return spear_nand_init(nand); + fsmc_nand_init(nand); } +#endif
- return -1; + return; } diff --git a/board/spear/spear600/spear600.c b/board/spear/spear600/spear600.c index eef9a37..ab0f760 100644 --- a/board/spear/spear600/spear600.c +++ b/board/spear/spear600/spear600.c @@ -24,10 +24,12 @@ #include <common.h> #include <nand.h> #include <asm/io.h> +#include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h> #include <asm/arch/spr_defs.h> #include <asm/arch/spr_misc.h> -#include <asm/arch/spr_nand.h> + +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE];
int board_init(void) { @@ -41,13 +43,15 @@ int board_init(void) * Called by nand_init_chip to initialize the board specific functions */
+#if defined(CONFIG_NAND_FSMC) if (!(readl(&misc_regs_p->auto_cfg_reg) & MISC_NANDDIS)) - return spear_nand_init(nand); - - return -1; + fsmc_nand_init(nand); +#endif + return; } diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index fa71590..14011af 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -88,9 +88,10 @@ #define CONFIG_SYS_LOADS_BAUD_CHANGE
/* NAND FLASH Configuration */ +#define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS -#define CONFIG_NAND_SPEAR 1 +#define CONFIG_NAND_FSMC #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE 1
diff --git a/include/configs/spear3xx.h b/include/configs/spear3xx.h index 37bdebb..2a86c21 100644 --- a/include/configs/spear3xx.h +++ b/include/configs/spear3xx.h @@ -117,6 +117,10 @@
#endif
+/* NAND flash configuration */ +#define CONFIG_SYS_FSMC_NAND_SP +#define CONFIG_SYS_FSMC_NAND_8BIT + #if defined(CONFIG_SPEAR300) #define CONFIG_SYS_NAND_BASE (0x80000000)
diff --git a/include/configs/spear6xx.h b/include/configs/spear6xx.h index 2ad5beb..c5bcc30 100644 --- a/include/configs/spear6xx.h +++ b/include/configs/spear6xx.h @@ -38,6 +38,9 @@ #define CONFIG_PL01x_PORTS { (void *)CONFIG_SYS_SERIAL0, \ (void *)CONFIG_SYS_SERIAL1 }
+/* NAND flash configuration */ +#define CONFIG_SYS_FSMC_NAND_SP +#define CONFIG_SYS_FSMC_NAND_8BIT #define CONFIG_SYS_NAND_BASE (0xD2000000)
#endif /* __CONFIG_H */
Since, SPEAr platform uses generic FSMC driver now, so spear specific files drivers/mtd/nand/spr_nand.c, arch/arm/include/asm/arch-spear/spr_nand.h are removed
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- arch/arm/include/asm/arch-spear/spr_nand.h | 57 ------------- drivers/mtd/nand/spr_nand.c | 124 ---------------------------- 2 files changed, 0 insertions(+), 181 deletions(-) delete mode 100644 arch/arm/include/asm/arch-spear/spr_nand.h delete mode 100644 drivers/mtd/nand/spr_nand.c
diff --git a/arch/arm/include/asm/arch-spear/spr_nand.h b/arch/arm/include/asm/arch-spear/spr_nand.h deleted file mode 100644 index 2b63dc7..0000000 --- a/arch/arm/include/asm/arch-spear/spr_nand.h +++ /dev/null @@ -1,57 +0,0 @@ -/* - * (C) Copyright 2009 - * Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __SPR_NAND_H__ -#define __SPR_NAND_H__ - -struct fsmc_regs { - u32 reserved_1[0x10]; - u32 genmemctrl_pc; - u32 reserved_2; - u32 genmemctrl_comm; - u32 genmemctrl_attrib; - u32 reserved_3; - u32 genmemctrl_ecc; -}; - -/* genmemctrl_pc register definitions */ -#define FSMC_RESET (1 << 0) -#define FSMC_WAITON (1 << 1) -#define FSMC_ENABLE (1 << 2) -#define FSMC_DEVTYPE_NAND (1 << 3) -#define FSMC_DEVWID_8 (0 << 4) -#define FSMC_DEVWID_16 (1 << 4) -#define FSMC_ECCEN (1 << 6) -#define FSMC_ECCPLEN_512 (0 << 7) -#define FSMC_ECCPLEN_256 (1 << 7) -#define FSMC_TCLR_1 (1 << 9) -#define FSMC_TAR_1 (1 << 13) - -/* genmemctrl_comm register definitions */ -#define FSMC_TSET_0 (0 << 0) -#define FSMC_TWAIT_6 (6 << 8) -#define FSMC_THOLD_4 (4 << 16) -#define FSMC_THIZ_1 (1 << 24) - -extern int spear_nand_init(struct nand_chip *nand); -#endif diff --git a/drivers/mtd/nand/spr_nand.c b/drivers/mtd/nand/spr_nand.c deleted file mode 100644 index 097d0c6..0000000 --- a/drivers/mtd/nand/spr_nand.c +++ /dev/null @@ -1,124 +0,0 @@ -/* - * (C) Copyright 2009 - * Vipin Kumar, ST Micoelectronics, vipin.kumar@st.com. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <nand.h> -#include <linux/mtd/nand_ecc.h> -#include <asm/io.h> -#include <asm/arch/hardware.h> -#include <asm/arch/spr_nand.h> - -static struct fsmc_regs *const fsmc_regs_p = - (struct fsmc_regs *)CONFIG_SPEAR_FSMCBASE; - -static struct nand_ecclayout spear_nand_ecclayout = { - .eccbytes = 24, - .eccpos = {2, 3, 4, 18, 19, 20, 34, 35, 36, 50, 51, 52, - 66, 67, 68, 82, 83, 84, 98, 99, 100, 114, 115, 116}, - .oobfree = { - {.offset = 8, .length = 8}, - {.offset = 24, .length = 8}, - {.offset = 40, .length = 8}, - {.offset = 56, .length = 8}, - {.offset = 72, .length = 8}, - {.offset = 88, .length = 8}, - {.offset = 104, .length = 8}, - {.offset = 120, .length = 8} - } -}; - -static void spear_nand_hwcontrol(struct mtd_info *mtd, int cmd, uint ctrl) -{ - struct nand_chip *this = mtd->priv; - ulong IO_ADDR_W; - - if (ctrl & NAND_CTRL_CHANGE) { - IO_ADDR_W = (ulong)this->IO_ADDR_W; - - IO_ADDR_W &= ~(CONFIG_SYS_NAND_CLE | CONFIG_SYS_NAND_ALE); - if (ctrl & NAND_CLE) - IO_ADDR_W |= CONFIG_SYS_NAND_CLE; - if (ctrl & NAND_ALE) - IO_ADDR_W |= CONFIG_SYS_NAND_ALE; - - if (ctrl & NAND_NCE) { - writel(readl(&fsmc_regs_p->genmemctrl_pc) | - FSMC_ENABLE, &fsmc_regs_p->genmemctrl_pc); - } else { - writel(readl(&fsmc_regs_p->genmemctrl_pc) & - ~FSMC_ENABLE, &fsmc_regs_p->genmemctrl_pc); - } - this->IO_ADDR_W = (void *)IO_ADDR_W; - } - - if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -} - -static int spear_read_hwecc(struct mtd_info *mtd, - const u_char *data, u_char ecc[3]) -{ - u_int ecc_tmp; - - /* read the h/w ECC */ - ecc_tmp = readl(&fsmc_regs_p->genmemctrl_ecc); - - ecc[0] = (u_char) (ecc_tmp & 0xFF); - ecc[1] = (u_char) ((ecc_tmp & 0xFF00) >> 8); - ecc[2] = (u_char) ((ecc_tmp & 0xFF0000) >> 16); - - return 0; -} - -void spear_enable_hwecc(struct mtd_info *mtd, int mode) -{ - writel(readl(&fsmc_regs_p->genmemctrl_pc) & ~0x80, - &fsmc_regs_p->genmemctrl_pc); - writel(readl(&fsmc_regs_p->genmemctrl_pc) & ~FSMC_ECCEN, - &fsmc_regs_p->genmemctrl_pc); - writel(readl(&fsmc_regs_p->genmemctrl_pc) | FSMC_ECCEN, - &fsmc_regs_p->genmemctrl_pc); -} - -int spear_nand_init(struct nand_chip *nand) -{ - writel(FSMC_DEVWID_8 | FSMC_DEVTYPE_NAND | FSMC_ENABLE | FSMC_WAITON, - &fsmc_regs_p->genmemctrl_pc); - writel(readl(&fsmc_regs_p->genmemctrl_pc) | FSMC_TCLR_1 | FSMC_TAR_1, - &fsmc_regs_p->genmemctrl_pc); - writel(FSMC_THIZ_1 | FSMC_THOLD_4 | FSMC_TWAIT_6 | FSMC_TSET_0, - &fsmc_regs_p->genmemctrl_comm); - writel(FSMC_THIZ_1 | FSMC_THOLD_4 | FSMC_TWAIT_6 | FSMC_TSET_0, - &fsmc_regs_p->genmemctrl_attrib); - - nand->options = 0; - nand->ecc.mode = NAND_ECC_HW; - nand->ecc.layout = &spear_nand_ecclayout; - nand->ecc.size = 512; - nand->ecc.bytes = 3; - nand->ecc.calculate = spear_read_hwecc; - nand->ecc.hwctl = spear_enable_hwecc; - nand->ecc.correct = nand_correct_data; - nand->cmd_ctrl = spear_nand_hwcontrol; - return 0; -}
Hi Scott,
Are you okay with this patchset version? If yes, please go ahead and push it upstream via your repository. There are some other SPEAr related patches depending on this set that I would like to push.
Thanks, Stefan
Hi Scott,
Ping.
Thanks, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
On 05/31/2012 02:04 AM, Stefan Roese wrote:
Hi Scott,
Ping.
Acked-by: Scott Wood scottwood@freescale.com
If you have other things to put on top of them, go ahead and take these patches with them.
-Scott
Hi Scott,
Ping.
Acked-by: Scott Woodscottwood@freescale.com
Thanks Scott.
Stefan, if you're going to apply these patches could you please fix Micoelectronics -> Microelectronics in fsmc_nand.c?
Regards Amit Virdi
Will do.
Thanks, Stefan
Okay, will do.
Thanks, Stefan
participants (5)
Amit Virdi
Scott Wood
Stefan Roese
stefan@roese.nl
Vikram Narayanan
