[U-Boot] [PATCH] mmc: fsl_esdhc: Fix hang after 'save' command
Since commit 48e0b2bd (powerpc/esdhc: Correct judgement for DATA PIO mode) we see mx6 systems to hang after doing a 'save' command.
Revert this commit since the original 'ifdef' logic from 7b43db92 (drivers/mmc/fsl_esdhc.c: fix compiler warnings) was the correct one.
Reported-by: Tapani Utriainen tapani@technexion.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- drivers/mmc/fsl_esdhc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 861f4b9..ec01795 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -178,7 +178,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) int timeout; struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; -#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO +#ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO uint wml_value;
wml_value = data->blocksize/4;
On Tue, May 28, 2013 at 3:09 PM, Fabio Estevam fabio.estevam@freescale.comwrote:
This seem to affect 'master' branch, not 'imx' tree. Is that correct?
On Tue, May 28, 2013 at 3:31 PM, Otavio Salvador otavio@ossystems.com.br wrote:
Yes, the offending commit is in master, but not on u-boot-imx branch.
My apologies. I misread that patch. I found it hard to believe that Wolfgang had broken the logic, and that it had been broken for 2 years, but somehow my brain insisted that was the case. I now agree with your assessment, and will apply your patch.
Haijun, please investigate the problem you were trying to solve with this patch, and determine what the actual cause was, and then submit a new patch to fix it.
Andy
Hi, Fleming and Fabio
Sorry to reply to you so late.
As our manual described.
In the eSDHC, the data buffer can hold up to 128 words (32-bit).
The watermark levels for both write and read can be configured for CPU polling mode. The watermark level can be from 1 word to the maximum of 128 words.
For both DMA read and write, the burst length, can be configured from 1 to the maximum of 16.
The host driver may configure watermark level and burst length value according to the system situation and requirement in the watermark level register (WML).
So if we define CONFIG_SYS_FSL_ESDHC_USE_PIO, this should be needed for CPU Polling mode. My patch works well on my board both for DMA mod and CPU Polling mode.
Fabio, Did you boot up from sdcard? If so save command will write to SD card. In this case write command will be failed. I'm not familiar with mx6 system. I don't know if there are some difference in Watermark Level Register (eSDHC_WML).
Regards Haijun.
-----Original Message----- From: Fleming Andy-AFLEMING Sent: Wednesday, May 29, 2013 3:52 AM To: Estevam Fabio-R49496 Cc: Zhang Haijun-B42677; wd@denx.de; u-boot@lists.denx.de; sbabic@denx.de; tapani@technexion.com Subject: Re: [PATCH] mmc: fsl_esdhc: Fix hang after 'save' command
Andy
On Thu, Jun 27, 2013 at 4:50 AM, Zhang Haijun-B42677 B42677@freescale.comwrote:
I think you may have misunderstood the WML register. My read of the manual indicates it is most definitely necessary for DMA. I think it is also necessary for polling mode, and WML configuration was not added properly when polling mode support was added to the driver. The solution may be to set up WML for both modes, but the manual is a bit unclear (it sometimes likes to refer to polling mode as "External DMA").
Andy
On Thu, Jun 27, 2013 at 6:50 AM, Zhang Haijun-B42677 B42677@freescale.com wrote:
Yes, I boot from sd card.
Can you try removing CONFIG_SYS_FSL_ESDHC_USE_PIO from your board file?
Applied, thanks.
Andy
participants (7)
Andy Fleming
Andy Fleming
Fabio Estevam
Fabio Estevam
Otavio Salvador
Zhang Haijun-B42677
