Re: [U-Boot-Users] sam9263ek not booting uboot dataflash
Ok E Robertson wrote:
Can you send me your diff?
The diff I'm using is attached. Thanks.
I'm talking about your adding code. Don't use the mailing list for send code.
Regards Michael
Oops. It bounce back anyway.
Regards Michael
I've narrowed down the problem to the compiler. I have several gcc3.4 and gcc4.1 based compilers and the gcc3.4 compiled u-boot binary worked. I've been using the arm-gcc4.1-uclibc20061004 compiler with always breaks because "uses hardware FP" whereas u-boot "uses software FP". I've used arm-gcc3.4-uclibc0.9.28 compiler to build u-boot 1.2.0 which worked.
E Robertson
michael
