[U-Boot] [PATCH] ARM: EXYNOS: fixed compiler warning message
Removed [-Wuninitialized] warning message. The fout_sel is assigned to "-1" by default. And start, gpio_func is initialized to 0.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 3 +++ arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- 2 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index fc0ed5e..672598f 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -173,6 +173,9 @@ static unsigned long exynos5_get_pll_clk(int pllreg) fout_sel = (pll_div2_sel >> BPLL_FOUT_SEL_SHIFT) & BPLL_FOUT_SEL_MASK; break; + default: + fout_sel = -1; + break; }
if (fout_sel == 0) diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 822410e..0e91a6c 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -66,7 +66,7 @@ static int exynos5_mmc_config(int peripheral, int flags) struct exynos5_gpio_part1 *gpio1 = (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); struct s5p_gpio_bank *bank, *bank_ext; - int i, start, gpio_func; + int i, start = 0, gpio_func = 0;
switch (peripheral) { case PERIPH_ID_SDMMC0:
Hi Jaehoon Chung,
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com
Thanks and Regards, Rajeshwari Shinde.
On Tue, Jul 10, 2012 at 12:50 PM, Jaehoon Chung jh80.chung@samsung.com wrote:
default:
fout_sel = -1;
break; } if (fout_sel == 0)
int i, start = 0, gpio_func = 0; switch (peripheral) { case PERIPH_ID_SDMMC0:
On 11 July 2012 13:17, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Jaehoon Chung,
applied to u-boot-samsung.
Thanks. Minkyu Kang.
Jaehoon Chung
Minkyu Kang
Rajeshwari Birje
