[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 3f97af5302ee15530411232b464d255eb2ff2ffb:
ot1200: add sata support (2014-10-23 10:04:26 +0200)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 0b23780ff02bdbec46fac1fe4151e2ebf1eae881:
arm: mx6: cm_fx6: detect 1GB DRAM correctly on solo (2014-11-05 17:18:01 +0100)
---------------------------------------------------------------- Anatolij Gustschin (1): arm: imx6: fix typos in CCM_ANALOG_PLL_VIDEO_DENOM register name
Christian Gmeiner (3): ot1200: add feature pads ot1200: add support for usdhc4 ot1200: rework card detect for eMMC
Fabio Estevam (2): mx6sabresd: Add Seiko WVGA panel support novena: Add MAINTAINERS file
Heiko Schocher (1): arm, imx, spi: detect spi flash again on aristainetos board
Jeroen Hofstee (1): board: wandboard: add usb storage
Marek Vasut (3): ARM: mx6: Add support for Kosagi Novena mtd: nand: mxs: Add ECC geometry for 2048b/112b NAND arm: mxs: Define bootscript env variable on m28evk
Markus Niebel (2): tqma6: fix sf detection tqma6: fix typo in header guard define
Nikita Kiryanov (2): arm: mx6: cm_fx6: change issd gpio order arm: mx6: cm_fx6: detect 1GB DRAM correctly on solo
Nikolay Dimitrov (1): novena: Fix ethernet PHY reset sequence
Soeren Moch (1): arm: arch-mx6: typo fixes in crm_regs.h
Ye.Li (9): imximage: Fix the bootdata.size calculation imx: gpt: Add High frequency clock source support for GPT imx: mx6sl: Add perclk_clk_sel bit define in CCM imx: mx6: Change the get_ipg_per_clk for OSC 24Mhz source imx: mx6sl: Set the preclk clock source to OSC 24Mhz imx: mx6: Enable high frequency clock source for GPT imx: mx6sl: Add IOMUX setting for USDHC1-3 imx: mx6slevk: Add support for USDHC1 and USDHC3 slots imx: mx6 sabreauto: Add board support for USB EHCI
arch/arm/Kconfig | 4 + arch/arm/cpu/armv7/mx6/clock.c | 4 + arch/arm/cpu/armv7/mx6/soc.c | 17 + arch/arm/imx-common/iomux-v3.c | 15 + arch/arm/imx-common/timer.c | 75 +++- arch/arm/include/asm/arch-mx6/crm_regs.h | 12 +- arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 19 + arch/arm/include/asm/imx-common/iomux-v3.h | 5 + board/aristainetos/aristainetos.c | 6 + board/bachmann/ot1200/ot1200.c | 70 ++- board/compulab/cm_fx6/cm_fx6.c | 2 +- board/compulab/cm_fx6/spl.c | 7 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 93 ++++ board/freescale/mx6sabresd/mx6sabresd.c | 61 +++ board/freescale/mx6slevk/mx6slevk.c | 105 ++++- board/kosagi/novena/Kconfig | 18 + board/kosagi/novena/MAINTAINERS | 6 + board/kosagi/novena/Makefile | 11 + board/kosagi/novena/novena.c | 340 +++++++++++++++ board/kosagi/novena/novena_spl.c | 584 ++++++++++++++++++++++++++ board/kosagi/novena/setup.cfg | 47 +++ board/tqc/tqma6/tqma6.c | 10 +- board/tqc/tqma6/tqma6_bb.h | 2 +- configs/novena_defconfig | 4 + drivers/mtd/nand/mxs_nand.c | 9 +- include/configs/aristainetos.h | 2 +- include/configs/imx6_spl.h | 2 +- include/configs/m28evk.h | 1 + include/configs/mx6_common.h | 1 + include/configs/mx6qsabreauto.h | 3 + include/configs/mx6slevk.h | 6 +- include/configs/novena.h | 298 +++++++++++++ include/configs/tqma6.h | 19 +- include/configs/wandboard.h | 9 + tools/imximage.c | 2 +- 35 files changed, 1829 insertions(+), 40 deletions(-) create mode 100644 board/kosagi/novena/Kconfig create mode 100644 board/kosagi/novena/MAINTAINERS create mode 100644 board/kosagi/novena/Makefile create mode 100644 board/kosagi/novena/novena.c create mode 100644 board/kosagi/novena/novena_spl.c create mode 100644 board/kosagi/novena/setup.cfg create mode 100644 configs/novena_defconfig create mode 100644 include/configs/novena.h
Regards, Stefano
On Wed, Nov 05, 2014 at 06:01:04PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
