[U-Boot] [PATCH 1/2] board: cm_fx6: Enable DM support for video, fix build error
Enable driver model for Video to remove the following compile warning on CM-FX6 SOM based target:
===================== WARNING ====================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. ====================================================
This change introduced build error as shown:
LD u-boot drivers/built-in.o: In function ipu_displays_init' arm-linux-ld.bfd: BFD (GNU Binutils) 2.29.1 assertion fail elf32-arm.c:9509 Makefile:1621: recipe for target 'u-boot' failed make: *** [u-boot] Error 1
The DM converted video driver calls ipu_displays_init in its probe, which inturn calls relevant board_video_skip. Defining ipu_displays_init in the board file fixes build error. Target was compile tested, build was clean.
Signed-off-by: Suniel Mahesh sunil.m@techveda.org --- board/compulab/cm_fx6/cm_fx6.c | 5 +++++ configs/cm_fx6_defconfig | 1 + 2 files changed, 6 insertions(+)
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index feb7a71..38dca2e 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -146,6 +146,11 @@ int board_video_skip(void) static inline void cm_fx6_setup_display(void) {} #endif /* CONFIG_VIDEO_IPUV3 */
+int ipu_displays_init(void) +{ + return board_video_skip(); +} + #ifdef CONFIG_DWC_AHSATA static int cm_fx6_issd_gpios[] = { /* The order of the GPIOs in the array is important! */ diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index a27cdd7..8288095 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -86,4 +86,5 @@ CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_VIDEO_IPUV3=y CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_FDT_FIXUP_PARTITIONS=y
Enable CONFIG_DM_ETH to remove compile warning on CM-FX6 SOM based target:
===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. ====================================================
Signed-off-by: Suniel Mahesh sunil.m@techveda.org --- configs/cm_fx6_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 8288095..1eb288b 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -80,6 +80,7 @@ CONFIG_DM_REGULATOR=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y +CONFIG_DM_ETH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y
From: Suniel Mahesh sunil.m@techveda.org Enable CONFIG_DM_ETH to remove compile warning on CM-FX6 SOM based target: ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. ==================================================== Signed-off-by: Suniel Mahesh sunil.m@techveda.org
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
From: Suniel Mahesh sunil.m@techveda.org Enable driver model for Video to remove the following compile warning on CM-FX6 SOM based target: ===================== WARNING ====================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. ==================================================== This change introduced build error as shown: LD u-boot drivers/built-in.o: In function ipu_displays_init' arm-linux-ld.bfd: BFD (GNU Binutils) 2.29.1 assertion fail elf32-arm.c:9509 Makefile:1621: recipe for target 'u-boot' failed make: *** [u-boot] Error 1 The DM converted video driver calls ipu_displays_init in its probe, which inturn calls relevant board_video_skip. Defining ipu_displays_init in the board file fixes build error. Target was compile tested, build was clean. Signed-off-by: Suniel Mahesh sunil.m@techveda.org
sbabic@denx.de
