[U-Boot] [PATCH] mmc:sdhci:fix: Change default interrupts enabled at SDHCI initialization
This patch changes sdhci_init()'s behavior to NOT enable all interrupt sources by default. Moreover interrupt signaling has been disabled.
This patch do not enable interrupts which aren't served in u-boot (they are defined at sdhci.h but NOT used elsewhere): - SDHCI_INT_CARD_INSERT, SDHCI_INT_CARD_REMOVE, SDHCI_BUS_POWER, SDHCI_INT_CARD_REMOVE, SDHCI_INT_CARD_INT
Special care shall be put on SDHCI_INT_CARD_INT, which indicates interrupt generated by SD card. According to "SD Host Controller Simplified Spec. ver 3.00" when bit 8 (Card Interrupt Status Enable) at "Normal Interrupt Status Enable Register" (offset 0x34) is set, the card interrupt detection is started. Then eMMC card may cause the SD controller to set this bit and then this interrupt is passed to booted OS and might cause kernel crash.
To sum up: - Only enable interrupts, which are served at u-boot - This cleanup as a side effect fixes SDHCI's CARD INTERRUPT problem at Linux kernel (versions 3.6+, sdhci controller) - Keep masked bits at "Normal Interrupt Signal Enable Register" (0x38h)
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Lei Wen leiwen@marvell.com Cc: Andy Fleming afleming@freescale.com --- drivers/mmc/sdhci.c | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 0fd1337..76c14fb 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -412,9 +412,11 @@ int sdhci_init(struct mmc *mmc) status = sdhci_readl(host, SDHCI_PRESENT_STATE); }
- /* Eable all state */ - sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_ENABLE); - sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_SIGNAL_ENABLE); + /* Enable only interrupts served by the SD controller */ + sdhci_writel(host, SDHCI_INT_DATA_MASK | SDHCI_INT_CMD_MASK + , SDHCI_INT_ENABLE); + /* Mask all sdhci interrupt sources */ + sdhci_writel(host, 0x0, SDHCI_SIGNAL_ENABLE);
return 0; }
Dear All,
Any feedback about this patch?
To sum up:
Register" (0x38h)
It looks good to me.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
On 01/29/2013 11:47 PM, Lukasz Majewski wrote:
Dear All,
To sum up:
Register" (0x38h)
Dear All,
It has been on the list for quite long time.....
Dear All,
To sum up:
Register" (0x38h)
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 02/11/2013 03:50 AM, Lukasz Majewski wrote:
Dear All,
This is one of the patches that I really want Andy to chime in on.
- -- Tom
Dear All,
I'd like to kindly ask for any feedback on this patch.
It is now more than month on the u-boot mailing list...
Dear All,
Dear All,
To sum up:
Register" (0x38h)
- /* Enable only interrupts served by the SD controller */
- sdhci_writel(host, SDHCI_INT_DATA_MASK |
SDHCI_INT_CMD_MASK
On 02/21/2013 12:21 PM, Lukasz Majewski wrote:
Dear All,
OK, sorry, the generic name of the driver threw me for a minute. I'm fine with this change going up u-boot-samsung -> u-boot-arm -> master since it's a samsung-only driver right now. Does this work for you?
Dear All,
Dear All,
return 0; }
- -- Tom
Hi Tom,
Dear All,
I think that this driver didn't use samsung-only. going up u-boot-samsung? I'm not sure that.
Best Regards, Jaehoon Chung
Dear All,
Dear All,
return 0; }
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJRJl0zAAoJENk4IS6UOR1WU68P/RTyQMDciU5rlgA0NfcSt2/y T55Q+R43eaRABLqEdLu5rQXJgKcLIQZEr4Czfu3LqWDfUylJiXkUc+ngSQ/uJR9p v1IN+rrIOs3ZQcFy9d3oDROtkz16Mc0T+32WI8g/NfL7X9IKYqSEeBUGmc0O54Ro kdmH9fqzCX3wbaY//+vG1uMA3s61Ekx+3Gbf5BcyoVMHrf1fNz4L1kZ7ZB/MBzdp HOQIoButM7/BGteF5o5LPHCNw7LtnAz5basRwaGQmrGVzeA2GCKFOrYEx3oa/ghC mK/PNTW6RCzRFBckbA2No9C1Tj1i7EMy8K/B8sub9FmJWF9XfDf4YhbacXOse5RA +mSwZiWuJP7K/0YaDUh7itQE2Wec2iA2LNlgb0Ujwnm4DsxnP805Cbz/JJuT9mCu 8LYw7crg4DwU9X0g0MEojKXupQ2mHMBHHrYRuUdIaYxHkkkf7j4mSIzPR75FzAjF 8l54TL4bEKHyUd7HmTaEkafyhziC8Kit4SEQqjTJW9S720nVOaM/pMmrji3mxUXH wHUpTTVS0TIAzhdAtxxpPxbRsMnnEgobOFGDbF8wzjGMQWWudZGLXqCm0kv+5B2K 3o6IlxPQ/TlokPe+A63NHTbJTJ0z/ylLX0UyNifzPzsoTiskO4qqSdHdrGTcA3f+ Tqq0rAM0CXj2oMMkkOFb =nGWo -----END PGP SIGNATURE----- _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 02/21/2013 06:33 PM, Jaehoon Chung wrote:
Hi Tom,
On 02/22/2013 02:45 AM, Tom Rini wrote: On 02/21/2013 12:21 PM, Lukasz Majewski wrote:
Dear All,
Unless the context got very wrong, it touches drivers/mmc/sdhci.c which is controlled by CONFIG_SDHCI which is only turned on in what look like samsung platforms to me.
- -- Tom
Hi Tom,
Hi Tom,
Dear All,
There is a /asm/arch-pantheon/config.h file which sets the CONFIG_SDHCI flag. It was added by Lei Wen (who is CC'ed to this thread) and looks like ARM926EJS (Marwell Semiconductor) processor based system.
Other systems are indeed samsung based processors.
I don't mind if this patch would go via u-boot-samsung tree.
Moreover, since this change "touches" Lei system, I think that he should have expressed his opinion. Sadly this didn't happened....
iQIcBAEBAgAGBQJRJrESAAoJENk4IS6UOR1WKeYP/2FBhDgWjyf5Sh8m0Q1bdhRm EvNMWLuexHUbxOu0AMsKyurPAGHnkfsWtNBnQXe804XXY29chFTsLlJUh4EGUBHm KiSJPU9LAlDt/aMmv6ncFcgJ9I7jyu8bETBLbJszDSleO0DqpUBu+R7isVv0N7n3 Uozo89zHpCvGrN2VLlQetMrTTJKquThn4CT9SIm02Z2OM5l3vBLUg+QMk1MCjDUd znIsFtUG5F+8T0uqzFN698RYACagPl5Y10HMylWHZgpgV2wGxQWrXspx78wHRSvy cwDPd2SVQbO3o3s9ixlppxeO2kpva8NouzsCJn4nH5ivrHumFCm8SI2ka4YE6du5 2b6Hol1Ie9jxq8B6cCNdEsHeHru3r+r19GzTNE0VfbrArpM8jO7FHcLruyzRjlaC QyzDgdLXzV21113U+UlyAk5yWZ4he4xVHV4oFoN+QhIbQdNZP3gWkzLUQLLr9ry6 iIgeLx8GDONVxv7hGfNvAaxhQMgvANUOEtPP0CV+K0b60IDXyrFyP1xt5NRN77iR v1rfcqitudFUyF6zqbDDLC2a5EW45UVyQR0WdZK999TWHS/U+5pTcDHhls1F16VD wGZ+k+RmJQVWVdLImOsyWewPeZtzt02qlNom9LF8sKq8T4Uyf8uLhKksOyfxMCR7 AvZ53JHQoAAvhgPVn4KF =7Oz4 -----END PGP SIGNATURE-----
Hi All,
On 02/22/2013 04:11 PM, Lukasz Majewski wrote:
Hi Tom,
Hi Tom,
Dear All,
I don't mind, too. I think this patch would not affect the other SoC. But I think that need to accept or review by somebody. I was already posted "acked-by" for this patch.
Dear All,
Hi Tom,
Hi Tom,
Dear All,
Any feedback? If not, please pull this patch to u-boot mainline.
Today it is 2 months since this patch has been posted on ML. No reply from interested people.
Dear Lukasz,
On 11/03/13 17:22, Lukasz Majewski wrote:
Dear All,
Hi Tom,
Hi Tom,
> Dear All, > > I'd like to kindly ask for any feedback on this patch. > > It is now more than month on the u-boot mailing list...
Since Andy seems absent, applied to u-boot-samsung.
Thanks, Minkyu Kang.
Jaehoon Chung
Lukasz Majewski
Minkyu Kang
