[PATCH] efi_loader: Avoid underflow when calculating remaining var store size
The efi_var_mem_free() function calculates the available size for a new EFI variable by subtracting the occupied buffer size and the overhead for a new variable from the maximum buffer size set in Kconfig. This is then returned as QueryVariableInfo()'s RemainingVariableStorageSize output.
This can underflow as the calculation is done in and processed as unsigned integer types. Check for underflow before doing the subtraction and return zero if there's no space.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
lib/efi_loader/efi_var_mem.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/lib/efi_loader/efi_var_mem.c b/lib/efi_loader/efi_var_mem.c index d6b65aed12ea..5fa7dcb8d3ed 100644 --- a/lib/efi_loader/efi_var_mem.c +++ b/lib/efi_loader/efi_var_mem.c @@ -177,6 +177,10 @@ efi_status_t __efi_runtime efi_var_mem_ins(
u64 __efi_runtime efi_var_mem_free(void) { + if (efi_var_buf->length + sizeof(struct efi_var_entry) >= + EFI_VAR_BUF_SIZE) + return 0; + return EFI_VAR_BUF_SIZE - efi_var_buf->length - sizeof(struct efi_var_entry); }
Alper Nebi Yasak
