[PATCH] Revert "spi: spi-uclass: Add support to manually relocate spi memory ops"
This reverts commit 346df7d4fa62afc578d820b3a18815eec765074f.
This patch broke booting Rockchip systems from U-Boot residing on SPI flash, for at least the Pinebook Pro and Rockpro64, and also confirmed with the not yet upstream Helios64.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: T Karthik Reddy t.karthik.reddy@xilinx.com Cc: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Cc: Michal Simek michal.simek@xilinx.com Cc: Pratyush Yadav p.yadav@ti.com --- drivers/spi/spi-uclass.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index d867b27806..ec7f4652b3 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -11,7 +11,6 @@ #include <log.h> #include <malloc.h> #include <spi.h> -#include <spi-mem.h> #include <dm/device_compat.h> #include <asm/global_data.h> #include <dm/device-internal.h> @@ -200,16 +199,6 @@ static int spi_post_probe(struct udevice *bus) ops->set_mode += gd->reloc_off; if (ops->cs_info) ops->cs_info += gd->reloc_off; - if (ops->mem_ops) { - struct spi_controller_mem_ops *mem_ops = - (struct spi_controller_mem_ops *)ops->mem_ops; - if (mem_ops->adjust_op_size) - mem_ops->adjust_op_size += gd->reloc_off; - if (mem_ops->supports_op) - mem_ops->supports_op += gd->reloc_off; - if (mem_ops->exec_op) - mem_ops->exec_op += gd->reloc_off; - } reloc_done++; } #endif
if (ops->mem_ops) {
reloc_done++; }}
#endif
This is protected by CONFIG_NEEDS_MANUAL_RELOC which is only enable for m68k and microblaze. I expect rockchip is arm and you should never have this code in your binary. That's why please double check it.
Thanks, Michal
if (ops->mem_ops) {
reloc_done++; }}
#endif
Yes, this really doesn't make sense. Try also just removing spi-mem.h from the file and see if that causes things to work again. If so, time to dig in to that header file to figure out what could be going wrong.
removing the header is not sufficient to have the boards booting from SPI.
U-Boot TPL 2021.07-00768-g49373a3334-dirty (Jul 23 2021 - 20:42:57) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM...
U-Boot SPL 2021.07-00768-g49373a3334-dirty (Jul 23 2021 - 20:42:57 -0500) Trying to boot from SPI
At this point u-boot hangs, with the patch reverted I get the following U-Boot TPL 2021.07-00769-g4af8bd872c-dirty (Jul 23 2021 - 21:20:51) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM...
U-Boot SPL 2021.07-00769-g4af8bd872c-dirty (Jul 23 2021 - 21:20:51 -0500) Trying to boot from SPI
U-Boot 2021.07-00769-g4af8bd872c-dirty (Jul 23 2021 - 21:20:51 -0500)
SoC: Rockchip rk3399 Reset cause: RST Model: Kobol Helios64 Revision: 0.0 - Unknown DRAM: 3.9 GiB PMIC: RK808 MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from SPIFlash... SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment
In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Kobol Helios64 Revision: UNKNOWN Net: dw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found.
starting USB... Bus usb@fe900000: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe900000 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device ** No partition table - mmc 0 ** Couldn't find partition mmc 0:1 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Scanning disk mmc@fe320000.blk... Scanning disk mmc@fe330000.blk... ** Unrecognized filesystem type ** Found 5 disks dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busLoading Boot0000 'Fedora' failed EFI boot manager: Cannot load any image Found EFI removable media binary efi/boot/bootaa64.efi
if (ops->mem_ops) {
}} reloc_done++;
#endif
-- Tom
Is LTO on, on these platforms? That code in question really should not be enabled, at all. Like, if you toss an #error in that section of code, it should still build. It does, right?
It does still build if I put a #error in the middle of it
$ grep LTO .config CONFIG_ARCH_SUPPORTS_LTO=y # CONFIG_LTO is not set
LTO is not on
-- Tom
LTO is not on
OK, so progress. What toolchain are you using here? And can you easily re-test with one of the kernel.org ones, or if using one already 9.2.0 (or 11.1.0) ?
LTO is not on
I have been using gcc 10.2.1, I will test with 11.1.1
Dennis
-- Tom
LTO is not on
Did you have a chance to further investigate this?
Dennis Gilmore
Michal Simek
Peter Robinson
