[PATCH v2 1/1] acpi: cannot have RSDT above 4 GiB
The field RsdtAddress has only 32 bit. The RSDT table cannot be located beyond 4 GiB.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: Avoid superfluous 0 assignment. RSDP is already zeroed out. Use constants form linux/sizes.h --- lib/acpi/base.c | 23 ++++++++++++++++------- 1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/lib/acpi/base.c b/lib/acpi/base.c index 2057bd2bef..26bf0cb8d3 100644 --- a/lib/acpi/base.c +++ b/lib/acpi/base.c @@ -12,6 +12,7 @@ #include <dm/acpi.h> #include <mapmem.h> #include <tables_csum.h> +#include <linux/sizes.h>
void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, struct acpi_xsdt *xsdt) @@ -21,10 +22,13 @@ void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, memcpy(rsdp->signature, RSDP_SIG, 8); memcpy(rsdp->oem_id, OEM_ID, 6);
- rsdp->length = sizeof(struct acpi_rsdp); - rsdp->rsdt_address = map_to_sysmem(rsdt); + if (rsdt) + rsdp->rsdt_address = map_to_sysmem(rsdt); + + if (xsdt) + rsdp->xsdt_address = map_to_sysmem(xsdt);
- rsdp->xsdt_address = map_to_sysmem(xsdt); + rsdp->length = sizeof(struct acpi_rsdp); rsdp->revision = ACPI_RSDP_REV_ACPI_2_0;
/* Calculate checksums */ @@ -68,11 +72,15 @@ static void acpi_write_xsdt(struct acpi_xsdt *xsdt) static int acpi_write_base(struct acpi_ctx *ctx, const struct acpi_writer *entry) { - /* We need at least an RSDP and an RSDT Table */ + /* We need at least an RSDP and an XSDT Table */ ctx->rsdp = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); - ctx->rsdt = ctx->current; - acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); + if (map_to_sysmem(ctx->current) < SZ_4G - SZ_64K) { + ctx->rsdt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); + } else { + ctx->rsdt = 0; + } ctx->xsdt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_xsdt));
@@ -80,7 +88,8 @@ static int acpi_write_base(struct acpi_ctx *ctx, memset(ctx->base, '\0', ctx->current - ctx->base);
acpi_write_rsdp(ctx->rsdp, ctx->rsdt, ctx->xsdt); - acpi_write_rsdt(ctx->rsdt); + if (ctx->rsdt) + acpi_write_rsdt(ctx->rsdt); acpi_write_xsdt(ctx->xsdt);
On Sun, 12 Nov 2023 at 16:54, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Applied to u-boot-dm/next, thanks!
