[U-Boot] [PATCH v3 1/2] net: introduce packet capture support
Add support for capturing ethernet packets and storing them in memory in PCAP(2.4) format, later to be analyzed by any PCAP viewer software (IE. Wireshark)
This feature greatly assist debugging network issues such as detecting dropped packets, packet corruption etc.
Signed-off-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Alex Marginean alexm.osslist@gmail.com Tested-by: Alex Marginean alexm.osslist@gmail.com --- v2: Fix type assignmnet to header.ts_sec v3: Several suggestion changes by Bin and Alex: * Change to implementation to command based. * Added counters for incoming/outgoing packets. * Support clearing the capture for multiple captures. * Added documentation (separate patch).
cmd/Kconfig | 7 +++ cmd/net.c | 63 +++++++++++++++++++++ include/net.h | 56 +++++++++++++++++++ net/Makefile | 1 + net/net.c | 8 +++ net/pcap.c | 152 ++++++++++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 287 insertions(+) create mode 100644 net/pcap.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0badcb3fe0..638f979f28 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1239,6 +1239,13 @@ config BOOTP_NTPSERVER bool "Request & store 'ntpserverip' from BOOTP/DHCP server" depends on CMD_BOOTP
+config CMD_PCAP + bool "pcap capture" + help + Selecting this will allow capturing all Ethernet packets and store + them in physical memory in a PCAP formated file, + later to be analyzed by PCAP reader application (IE. WireShark). + config BOOTP_PXE bool "Send PXE client arch to BOOTP/DHCP server" default y diff --git a/cmd/net.c b/cmd/net.c index 89721b8f8b..5022f1dbcc 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -457,3 +457,66 @@ U_BOOT_CMD( );
#endif /* CONFIG_CMD_LINK_LOCAL */ + +#if defined(CONFIG_CMD_PCAP) +static int do_pcap_init(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + phys_addr_t addr; + unsigned int size; + + if (argc != 3) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[1], NULL, 16); + size = simple_strtoul(argv[2], NULL, 10); + + return pcap_init(addr, size) ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static int do_pcap_start(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return pcap_start_stop(true) ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static int do_pcap_stop(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return pcap_start_stop(false) ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static int do_pcap_status(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return pcap_print_status() ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static int do_pcap_clear(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return pcap_clear() ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static char pcap_help_text[] = + "- network packet capture\n\n" + "pcap\n" + "pcap init\t\t\t<addr> <max_size>\n" + "pcap start\t\t\tstart capture\n" + "pcap stop\t\t\tstop capture\n" + "pcap status\t\t\tprint status\n" + "pcap clear\t\t\tclear capture buffer\n" + "\n" + "With:\n" + "\t<addr>: user address to which pcap will be stored (hexedcimal)\n" + "\t<max_size>: Maximum size of pcap file (decimal)\n" + "\n"; + +U_BOOT_CMD_WITH_SUBCMDS(pcap, "pcap", pcap_help_text, + U_BOOT_SUBCMD_MKENT(init, 3, 0, do_pcap_init), + U_BOOT_SUBCMD_MKENT(start, 1, 0, do_pcap_start), + U_BOOT_SUBCMD_MKENT(stop, 1, 0, do_pcap_stop), + U_BOOT_SUBCMD_MKENT(status, 1, 0, do_pcap_status), + U_BOOT_SUBCMD_MKENT(clear, 1, 0, do_pcap_clear), +); +#endif /* CONFIG_CMD_PCAP */ diff --git a/include/net.h b/include/net.h index 44b32385c4..f0289c3cde 100644 --- a/include/net.h +++ b/include/net.h @@ -630,6 +630,58 @@ bool arp_is_waiting(void); /* Waiting for ARP reply? */ void net_set_icmp_handler(rxhand_icmp_f *f); /* Set ICMP RX handler */ void net_set_timeout_handler(ulong, thand_f *);/* Set timeout handler */
+/* PCAP extension */ + +/** + * pcap_init() - Initialize PCAP memory buffer + * + * @paddr physicaly memory address to store buffer + * @size maximum size of capture file in memory + * + * @return 0 on success, -ERROR on error + */ +int pcap_init(phys_addr_t paddr, unsigned long size); + +/** + * pcap_start_stop() - start / stop pcap capture + * + * @start if true, start capture if false stop capture + * + * @return 0 on success, -ERROR on error + */ +int pcap_start_stop(bool start); + +/** + * pcap_clear() - clear pcap capture buffer and statistics + * + * @return 0 on success, -ERROR on error + */ +int pcap_clear(void); + +/** + * pcap_print_status() - print status of pcap capture + * + * @return 0 on success, -ERROR on error + */ +int pcap_print_status(void); + +/** + * pcap_active() - check if pcap is enabled + * + * @return TRUE if active, FALSE if not. + */ +bool pcap_active(void); + +/** + * pcap_post() - Post a packet to PCAP file + * + * @packet: packet to post + * @len: packet length in bytes + * @outgoing packet direction (outgoing/incoming) + * @return 0 on success, -ERROR on error + */ +int pcap_post(const void *packet, size_t len, bool outgoing); + /* Network loop state */ enum net_loop_state { NETLOOP_CONTINUE, @@ -658,6 +710,10 @@ static inline void net_send_packet(uchar *pkt, int len) { /* Currently no way to return errors from eth_send() */ (void) eth_send(pkt, len); + +#if defined(CONFIG_CMD_PCAP) + pcap_post(pkt, len, true); +#endif }
/* diff --git a/net/Makefile b/net/Makefile index ce36362168..d70a7c6834 100644 --- a/net/Makefile +++ b/net/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_CMD_LINK_LOCAL) += link_local.o obj-$(CONFIG_NET) += net.o obj-$(CONFIG_CMD_NFS) += nfs.o obj-$(CONFIG_CMD_PING) += ping.o +obj-$(CONFIG_CMD_PCAP) += pcap.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o diff --git a/net/net.c b/net/net.c index 58b0417cbe..b6b5a49153 100644 --- a/net/net.c +++ b/net/net.c @@ -671,6 +671,11 @@ done: net_set_icmp_handler(NULL); #endif net_set_state(prev_net_state); + +#if defined(CONFIG_CMD_PCAP) + if (pcap_active()) + pcap_print_status(); +#endif return ret; }
@@ -1083,6 +1088,9 @@ void net_process_received_packet(uchar *in_packet, int len)
debug_cond(DEBUG_NET_PKT, "packet received\n");
+#if defined(CONFIG_CMD_PCAP) + pcap_post(in_packet, len, false); +#endif net_rx_packet = in_packet; net_rx_packet_len = len; et = (struct ethernet_hdr *)in_packet; diff --git a/net/pcap.c b/net/pcap.c new file mode 100644 index 0000000000..071bfeb510 --- /dev/null +++ b/net/pcap.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2019 Ramon Fried rfried.dev@gmail.com + */ + +#include <common.h> +#include <net.h> +#include <time.h> +#include <asm/io.h> + +#define LINKTYPE_ETHERNET 1 + +static bool initialized; +static bool running; +static bool buffer_full; +static void *buf; +static unsigned int max_size; +static unsigned int pos; + +static unsigned long incoming_count; +static unsigned long outgoing_count; + +struct pcap_header { + u32 magic; + u16 version_major; + u16 version_minor; + s32 thiszone; + u32 sigfigs; + u32 snaplen; + u32 network; +}; + +struct pcap_packet_header { + u32 ts_sec; + u32 ts_usec; + u32 incl_len; + u32 orig_len; +}; + +static struct pcap_header file_header = { + .magic = 0xa1b2c3d4, + .version_major = 2, + .version_minor = 4, + .snaplen = 65535, + .network = LINKTYPE_ETHERNET, +}; + +int pcap_init(phys_addr_t paddr, unsigned long size) +{ + buf = map_physmem(paddr, size, 0); + if (!buf) { + printf("Failed mapping PCAP memory\n"); + return -ENOMEM; + } + + printf("PCAP capture initialized: addr: 0x%lx max length: %lu\n", + (unsigned long)buf, size); + + memcpy(buf, &file_header, sizeof(file_header)); + pos = sizeof(file_header); + max_size = size; + initialized = true; + running = false; + buffer_full = false; + incoming_count = 0; + outgoing_count = 0; + return 0; +} + +int pcap_start_stop(bool start) +{ + if (!initialized) { + printf("error: pcap was not initialized\n"); + return -ENODEV; + } + + running = start; + + return 0; +} + +int pcap_clear(void) +{ + if (!initialized) { + printf("error: pcap was not initialized\n"); + return -ENODEV; + } + + pos = sizeof(file_header); + incoming_count = 0; + outgoing_count = 0; + buffer_full = false; + + printf("pcap capture cleared\n"); + return 0; +} + +int pcap_post(const void *packet, size_t len, bool outgoing) +{ + struct pcap_packet_header header; + u64 cur_time = timer_get_us(); + + if (!initialized || !running || !buf) + return -ENODEV; + + if ((pos + len + sizeof(header)) >= max_size) { + buffer_full = true; + return -ENOMEM; + } + + header.ts_sec = cur_time / 1000000; + header.ts_usec = cur_time % 1000000; + header.incl_len = len; + header.orig_len = len; + + memcpy(buf + pos, &header, sizeof(header)); + pos += sizeof(header); + memcpy(buf + pos, packet, len); + pos += len; + + if (outgoing) + outgoing_count++; + else + incoming_count++; + + return 0; +} + +int pcap_print_status(void) +{ + if (!initialized) { + printf("pcap was not initialized\n"); + return -ENODEV; + } + printf("PCAP status:\n"); + printf("\tInitialized addr: 0x%lx\tmax length: %u\n", + (unsigned long)buf, max_size); + printf("\tStatus: %s.\t file size: %u\n", running ? "Active" : "Idle", + pos); + printf("\tIncoming packets: %lu Outgoing packets: %lu\n", + incoming_count, outgoing_count); + + if (buffer_full) + printf("\t!!! Buffer is full, consider increasing buffer size !!!\n"); + + return 0; +} + +bool pcap_active(void) +{ + return running; +}
Add documentation for new "pcap" command.
Signed-off-by: Ramon Fried rfried.dev@gmail.com --- doc/README.pcap | 61 +++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 61 insertions(+) create mode 100644 doc/README.pcap
diff --git a/doc/README.pcap b/doc/README.pcap new file mode 100644 index 0000000000..25c85ae271 --- /dev/null +++ b/doc/README.pcap @@ -0,0 +1,61 @@ +PCAP: + +U-boot supports live ethernet packet capture in PCAP(2.4) format. +This is enabled by CONFIG_CMD_PCAP. + +The capture is stored on physical memory, and should be copied to +a machine capabale of parsing and displaying PCAP files (IE. wireshark) +If networking works properly one can copy the capture file from physical memory +using tftpput, or save it to local storage with (sf write, mmc write, fatwrite, etc) + +the pcap capturing requires maximum buffer size. +when the buffer is full, packets will silently drop. +check the status using "pcap status" to see if the buffer is full, +if so, consider increasing the buffer size. + +Usage example: + +# Initialize pcap capture to physical address (0x100000) with maximum size of 100000. +# Start capture +pcap start + +# Initialize network activity +env set ipaddr 10.0.2.15; env set serverip 10.0.2.2; tftp uImage64 + +# Stop capture +pcap stop + +# pcap init 0x100000 100000 +PCAP capture initialized: addr: 0xffffffff80100000 max length: 100000 + +# pcap start +# env set ipaddr 10.0.2.15; env set serverip 10.0.2.2; tftp uImage64 +eth0@10000000: PHY present at 0 +eth0@10000000: link up, 1000Mbps full-duplex (lpa: 0x7c00) +Using eth0@10000000 device +TFTP from server 10.0.2.2; our IP address is 10.0.2.15 +Filename 'uImage64'. +Load address: 0xffffffff88000000 +Loading: ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + ################################################################# + # + 18.2 MiB/s +done +Bytes transferred = 8359376 (7f8dd0 hex) +PCAP status: + Initialized addr: 0xffffffff80100000 max length: 100000 + Status: Active. file size: 99991 + Incoming packets: 66 Outgoing packets: 67 + !!! Buffer is full, consider increasing buffer size !!! + + +# pcap stop +# tftpput 0xffffffff80100000 100000 10.0.2.2:capture.pcap +
- Change to implementation to command based.
- Added counters for incoming/outgoing packets.
- Support clearing the capture for multiple captures.
- Added documentation (separate patch).
+config CMD_PCAP
bool "pcap capture"
help
Please just move this to a separate cmd/pcap.c instead of this ifdef.
phys_addr_t addr;
unsigned int size;
if (argc != 3)
"pcap\n"
"\n"
"With:\n"
"\n";
Please put this stuff in include/net/pcap.h
- pcap_init() - Initialize PCAP memory buffer
- @paddr physicaly memory address to store buffer
- @size maximum size of capture file in memory
- @return 0 on success, -ERROR on error
- pcap_start_stop() - start / stop pcap capture
- @start if true, start capture if false stop capture
- pcap_clear() - clear pcap capture buffer and statistics
- pcap_print_status() - print status of pcap capture
- pcap_active() - check if pcap is enabled
- @return TRUE if active, FALSE if not.
- pcap_post() - Post a packet to PCAP file
- @packet: packet to post
- @len: packet length in bytes
- @outgoing packet direction (outgoing/incoming)
Maybe move this call inside of eth_send().
+#endif }
Please maintain alpha order.
if (pcap_active())
- Copyright 2019 Ramon Fried rfried.dev@gmail.com
u32 magic;
u16 version_major;
u16 version_minor;
s32 thiszone;
u32 sigfigs;
u32 snaplen;
u32 network;
u32 ts_sec;
u32 ts_usec;
u32 incl_len;
u32 orig_len;
.version_major = 2,
.version_minor = 4,
.snaplen = 65535,
if (!buf) {
return -ENOMEM;
max_size = size;
initialized = true;
running = false;
incoming_count = 0;
outgoing_count = 0;
if (!initialized) {
return -ENODEV;
running = start;
if (!initialized) {
return -ENODEV;
incoming_count = 0;
outgoing_count = 0;
return -ENODEV;
buffer_full = true;
return -ENOMEM;
It seems like an error should be printed the first time the limit is hit, not just wait until a status is requested.
pos += len;
You should also provide an env variable of the size so that users can use that to write to a file.
Something like: env_set_hex("pcapsize", pos);
if (outgoing)
outgoing_count++;
else
incoming_count++;
if (!initialized) {
return -ENODEV;
pos);
if (buffer_full)
return running;
2.22.0
On Fri, Jul 12, 2019 at 12:18 AM Joe Hershberger joe.hershberger@ni.com wrote:
+config CMD_PCAP
bool "pcap capture"
help
NP
phys_addr_t addr;
unsigned int size;
if (argc != 3)
"pcap\n"
"\n"
"With:\n"
"\n";
NP
NP
+#endif }
NP
if (pcap_active())
u32 magic;
u16 version_major;
u16 version_minor;
s32 thiszone;
u32 sigfigs;
u32 snaplen;
u32 network;
u32 ts_sec;
u32 ts_usec;
u32 incl_len;
u32 orig_len;
.version_major = 2,
.version_minor = 4,
.snaplen = 65535,
if (!buf) {
return -ENOMEM;
max_size = size;
initialized = true;
running = false;
incoming_count = 0;
outgoing_count = 0;
if (!initialized) {
return -ENODEV;
running = start;
if (!initialized) {
return -ENODEV;
incoming_count = 0;
outgoing_count = 0;
return -ENODEV;
buffer_full = true;
return -ENOMEM;
Printing error on the first time was my initial implementation. problem is that it's printed along with other ####### that tftp uses. This doesn't look nice. what do you think ?
pos += len;
That's really nice, didn't think about it.
if (outgoing)
outgoing_count++;
else
incoming_count++;
if (!initialized) {
return -ENODEV;
pos);
if (buffer_full)
return running;
2.22.0
I think this should be an uncommon enough of an issue that it's OK to break up the #####.
pos += len;
This is a nice feature to have. We need a unit test for it, though. Please add it to a sandbox test and exercise it, then have the test try to load the resulting file with tshark to ensure a valid format. There are potentially other things in the header that is printed that can be used for further validation.
Thanks for this feature. -Joe
Hi Joe, I fixed all your notes regarding the patches, except the test. I thought I'll find some net framework to start with, but I didn't find any tests under u-boot/tests/* that actually transfer a file between the host and u-boot sandbox. Did I miss anything ? I did find something interesting under u-boot/api/api_net.c that can perhaps be leveraged to something like that. Do you know how to begin with a test you described above ? Meanwhile, I posted the updated patches (without the test) so they can be reviewed by you.
Thanks, Ramon.
I'm not sure if it's appropriate but maybe a sandbox test like test/dm/eth.c.
Probably not, but maybe if you elaborate a bit more about what you have in mind.
Thanks, Ramon.
Joe Hershberger
Ramon Fried
