[U-Boot] [PATCH V2] common: Simplify get_clocks() #ifdef
get_clocks is wrapped by CONFIG_FSL_CLK and CONFIG_M68K in seperate piece code. They can be merged into one snippet.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Alexey Brodkin abrodkin@synopsys.com Cc: "angelo@sysam.it" angelo@sysam.it Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Stephen Warren swarren@nvidia.com Cc: "Andreas Bießmann" andreas.devel@googlemail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes V2: Refine patch subject as Simon suggested. Add Simon's Reviewed-by
common/board_f.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 486e828..7bc05b1 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -806,10 +806,7 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_BOARD_POSTCLK_INIT) board_postclk_init, #endif -#ifdef CONFIG_FSL_CLK - get_clocks, -#endif -#ifdef CONFIG_M68K +#if defined(CONFIG_FSL_CLK) || defined(CONFIG_M68K) get_clocks, #endif env_init, /* initialize environment */
Hi Peng,
- get_clocks,
change is ok for me.
Acked-by: Angelo Dureghello angelo@sysam.it
Signed-off-by: Peng Fan Peng.Fan@freescale.com Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Alexey Brodkin abrodkin@synopsys.com Cc: "angelo@sysam.it" angelo@sysam.it Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Stephen Warren swarren@nvidia.com Cc: "Andreas Bießmann" andreas.devel@googlemail.com Reviewed-by: Simon Glass sjg@chromium.org Acked-by: Angelo Dureghello angelo@sysam.it
Angelo Dureghello
Peng Fan
