[U-Boot] Using sspi for hardware detection?
Hello,
I'm working on a modular socfpga based system with several optional boards. Each optional board contain a board ID that can be read through a SPI bus.
Since we want just read the board ID, we used manually the sspi command, something like:
=> sspi 1:1.0 8 0 42
But it seems that the sspi command can't be used in a uboot script. sspi seems only used to manually test spi drivers.
If we compare with i2c command, we have a i2c read to memory:
i2c read chip address[.0, .1, .2] length memaddress - read to memory
Why there is no such feature for spi ? Is there an interest to evolve the sspi command to add a read to memory?
sspi <bus id>: <chip select>.<mode> <bit length> <data> <memaddress>
By looking at existing code, it seems that hardware detection in uboot is handled by architecture/board specific code to set custom environment variable like "fpgatype" [1] or "unit_ident" "unit_serial" [2] (misc_init_r).
What do you recommend? Implement a custom misc_init_r() for hardware detection?
[1] https://gitlab.denx.de/u-boot/u-boot/blob/master/arch/arm/mach-socfpga/misc_... [2] https://gitlab.denx.de/u-boot/u-boot/blob/master/board/softing/vining_fpga/s...
Best regards, Romain
On Wed, Nov 27, 2019 at 1:58 PM Romain Naour romain.naour@smile.fr wrote:
Hello,
Probably because noone has needed it so far.
If you need it and provide a decent patch, I could probable get accepted...
How is that related? How does reading to memory help you with knowing the hw type in scripts?
Anyway, I think board_late_init is a better fit than misc_init_r, which is rather meant to be a platform thing and vining can only use it because socfpga doesn't need it otherwise.
Best regards, Romain _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hello,
Ok I'll take a look how to implement this.
Sorry, actually this is another possibility.
The first possibility is evolve the sspi command to add <memaddress>. This allow to use a script working on memory containing the data received from the spi bus. For my use case, it would allow to get the board ID in memory and use an uboot script analyze which board ID has been read.
The second possibility is to use misc_init_r (or as you suggest board_late_init) in a board specific code (board/<customer>/<board_name>/socfpga.c) to access the spi bus and set custom environment variable. These environment variable are later used by uboot script.
I would like an advice on the best implementation. I believe modifying sspi command can be the way to go since it can be used for other use case.
Thanks for your feed back!
Hello,
Yes, looks to me like that might be a handy thing to have in that command. Of course that comes at the expand of size increasement when this command is compiled in, so I can't judge if it's ok to add.
Romain Naour
Simon Goldschmidt
