[U-Boot] [PATCH] net: move bootfile/ipaddr init into eth_initialize
All arches init these variables the same way, so move the logic into the core net code to avoid duplicating it everywhere else.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/arm/lib/board.c | 11 ----------- arch/avr32/lib/board.c | 5 ----- arch/blackfin/lib/board.c | 9 +-------- arch/m68k/lib/board.c | 14 -------------- arch/microblaze/lib/board.c | 7 ------- arch/mips/lib/board.c | 11 ----------- arch/nds32/lib/board.c | 9 --------- arch/nios2/lib/board.c | 2 -- arch/powerpc/lib/board.c | 11 ----------- arch/sandbox/lib/board.c | 3 --- arch/sh/lib/board.c | 22 ++-------------------- arch/sparc/lib/board.c | 7 ------- arch/x86/lib/board.c | 12 ------------ net/eth.c | 12 ++++++++++++ 14 files changed, 15 insertions(+), 120 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 3d78274..2c4276b 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -536,9 +536,6 @@ void board_init_r(gd_t *id, ulong dest_addr) arm_pci_init(); #endif
- /* IP Address */ - gd->bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - stdio_init(); /* get the devices list going. */
jumptable_init(); @@ -576,14 +573,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); -#if defined(CONFIG_CMD_NET) - { - char *s = getenv("bootfile"); - - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - } -#endif
#ifdef CONFIG_BOARD_LATE_INIT board_late_init(); diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 63fe297..4bc3c8a 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -304,8 +304,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) /* initialize environment */ env_relocate();
- bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); - stdio_init(); jumptable_init(); console_init_r(); @@ -317,9 +315,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s) - copy_filename(BootFile, s, sizeof(BootFile)); puts("Net: "); eth_initialize(gd->bd); #endif diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index e3ee4cd..4310fef 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -294,15 +294,8 @@ static void board_net_init_r(bd_t *bd) bb_miiphy_init(); #endif #ifdef CONFIG_CMD_NET - char *s; - - if ((s = getenv("bootfile")) != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - printf("Net: "); - eth_initialize(gd->bd); + eth_initialize(bd); #endif }
diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index 259b71c..b3dca77 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -507,15 +507,6 @@ void board_init_r (gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate ();
- /* - * Fill in missing fields of bd_info. - * We do this here, where we have "normal" access to the - * environment; we used to do this still running from ROM, - * where had to use getenv_f(), which can be pretty slow when - * the environment is in EEPROM. - */ - bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); - WATCHDOG_RESET ();
#if defined(CONFIG_PCI) @@ -568,11 +559,6 @@ void board_init_r (gd_t *id, ulong dest_addr)
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); -#if defined(CONFIG_CMD_NET) - if ((s = getenv ("bootfile")) != NULL) { - copy_filename (BootFile, s, sizeof (BootFile)); - } -#endif
WATCHDOG_RESET ();
diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index 9828b76..f3679d5 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -176,19 +176,12 @@ void board_init (void) load_addr = getenv_ulong("loadaddr", 16, load_addr);
#if defined(CONFIG_CMD_NET) - /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - printf("Net: "); eth_initialize(gd->bd);
uchar enetaddr[6]; eth_getenv_enetaddr("ethaddr", enetaddr); printf("MAC: %pM\n", enetaddr); - - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); #endif
/* main_loop */ diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index d998f0e..6b36a98 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -316,9 +316,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate();
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - #if defined(CONFIG_PCI) /* * Do pci configuration @@ -338,14 +335,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
#ifdef CONFIG_CMD_SPI puts("SPI: "); diff --git a/arch/nds32/lib/board.c b/arch/nds32/lib/board.c index 66e4537..446e0fd 100644 --- a/arch/nds32/lib/board.c +++ b/arch/nds32/lib/board.c @@ -368,9 +368,6 @@ void board_init_r(gd_t *id, ulong dest_addr) nds32_pci_init(); #endif
jumptable_init(); @@ -401,12 +398,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
-#if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); -#endif - #ifdef BOARD_LATE_INIT board_late_init(); #endif diff --git a/arch/nios2/lib/board.c b/arch/nios2/lib/board.c index 65de26e..ca8a3e5 100644 --- a/arch/nios2/lib/board.c +++ b/arch/nios2/lib/board.c @@ -143,8 +143,6 @@ void board_init (void) WATCHDOG_RESET (); env_relocate();
- bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); - WATCHDOG_RESET (); stdio_init(); jumptable_init(); diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index ff5888e..931b098 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -877,9 +877,6 @@ void board_init_r(gd_t *id, ulong dest_addr) #endif #endif /* CONFIG_CMD_NET */
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - WATCHDOG_RESET();
#if defined(CONFIG_PCI) && !defined(CONFIG_SYS_EARLY_PCI_INIT) @@ -935,14 +932,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
diff --git a/arch/sandbox/lib/board.c b/arch/sandbox/lib/board.c index b7997e9..a71b1ba 100644 --- a/arch/sandbox/lib/board.c +++ b/arch/sandbox/lib/board.c @@ -226,9 +226,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* initialize environment */ env_relocate();
jumptable_init(); diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index d9c0c22..e1a5739 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -99,14 +99,6 @@ static int sh_mem_env_init(void) return 0; }
-#if defined(CONFIG_CMD_NET) -static int sh_net_init(void) -{ - gd->bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - return 0; -} -#endif - #if defined(CONFIG_CMD_MMC) static int sh_mmc_init(void) { @@ -144,9 +136,6 @@ init_fnc_t *init_sequence[] = #ifdef CONFIG_BOARD_LATE_INIT board_late_init, #endif -#if defined(CONFIG_CMD_NET) - sh_net_init, /* SH specific eth init */ -#endif #if defined(CONFIG_CMD_MMC) sh_mmc_init, #endif @@ -200,15 +189,8 @@ void sh_generic_init(void) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - { - char *s; - puts("Net: "); - eth_initialize(gd->bd); - - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - } + puts("Net: "); + eth_initialize(gd->bd); #endif /* CONFIG_CMD_NET */
while (1) { diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index 519a4fb..a36f165 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -333,8 +333,6 @@ void board_init_f(ulong bootflag) mac_read_from_eeprom(); #endif
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); #if defined(CONFIG_PCI) /* * Do pci configuration @@ -359,11 +357,6 @@ void board_init_f(ulong bootflag)
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); -#if defined(CONFIG_CMD_NET) - if ((s = getenv("bootfile")) != NULL) { - copy_filename(BootFile, s, sizeof(BootFile)); - } -#endif /* CONFIG_CMD_NET */
WATCHDOG_RESET();
diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index d742fec..595b3c9 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -321,12 +321,6 @@ void board_init_r(gd_t *id, ulong dest_addr) env_relocate(); show_boot_progress(0x26);
- -#ifdef CONFIG_CMD_NET - /* IP Address */ - bd_data.bi_ip_addr = getenv_IPaddr("ipaddr"); -#endif - #if defined(CONFIG_PCI) /* * Do pci configuration @@ -373,12 +367,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); -#if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); -#endif
WATCHDOG_RESET();
diff --git a/net/eth.c b/net/eth.c index f3a55ba..c5daee1 100644 --- a/net/eth.c +++ b/net/eth.c @@ -224,6 +224,16 @@ int eth_register(struct eth_device *dev) return 0; }
+static void eth_env_init(bd_t *bis) +{ + const char *s; + + if ((s = getenv("bootfile")) != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); + + bis->bi_ip_addr = getenv_IPaddr("ipaddr"); +} + int eth_initialize(bd_t *bis) { int num_devices = 0; @@ -239,6 +249,8 @@ int eth_initialize(bd_t *bis) phy_init(); #endif
+ eth_env_init(bis); + /* * If board-specific initialization exists, call it. * If not, call a CPU-specific one
Hi Mike,
Signed-off-by: Mike Frysingervapier@gentoo.org
Tested on nios2 boards.
Tested-by: Thomas Chou thomas@wytron.com.tw
Best regards, Thomas
Dear Mike Frysinger,
This is the wrong approach.
There are many more ieces of code in arch/*/lib/board.c which are duplicated across some or all architectures. Instread of ripping these apart and fixing a bit here and a bit thre we should combine efforts and merge all arch/*/lib/board.c into a common file.
Additionally, your patch potentially breaks a number of boards.
- /* IP Address */
The code which you remove here does NOT depend on CONFIG_CMD_NET; note that this is intentional.
When moving this into net/eth.c, it will be missing for all oards that do not have CONFIG_CMD_NET defined.
So NAK.
or, if we add bit by bit, we have an easily testable solution rather than one giant leap
arm_pci_init();
#endif
- /* IP Address */
i noticed that, however, i'm not sure it matters. i can't find any place in u- boot that actually reads this variable.
arch/*/include/asm/u-boot.h: bi_ip_addr is declared as part of bd_t arch/*/lib/board.c: bi_ip_addr gets initialized based on env common/cmd_bdinfo.c: the value of bi_ip_addr gets displayed common/cmd_nvedit.c: bi_ip_addr gets written when user does "setenv ipaddr" board/esd/cpci405/cpci405.c: bi_ip_addr is written via the env net/net.c: bi_ip_addr gets written as part of global env sync
is there any reason i shouldn't just rip out all bi_ip_addr handling ? -mike
For example, the "bdinfo" command prints it; see common/cmd_bdinfo.c
which i documented as the *only* place where the member gets read: common/cmd_bdinfo.c: the value of bi_ip_addr gets displayed
and that would be absolutely trivial to replace with getenv("ipaddr") -mike
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/arm/include/asm/u-boot.h | 1 - arch/arm/lib/board.c | 3 --- arch/avr32/include/asm/u-boot.h | 1 - arch/avr32/lib/board.c | 2 -- arch/blackfin/include/asm/u-boot.h | 1 - arch/blackfin/lib/board.c | 3 --- arch/m68k/include/asm/u-boot.h | 1 - arch/m68k/lib/board.c | 9 --------- arch/microblaze/include/asm/u-boot.h | 1 - arch/microblaze/lib/board.c | 3 --- arch/mips/include/asm/u-boot.h | 1 - arch/mips/lib/board.c | 3 --- arch/nds32/include/asm/u-boot.h | 1 - arch/nds32/lib/board.c | 3 --- arch/nios2/include/asm/u-boot.h | 1 - arch/nios2/lib/board.c | 2 -- arch/openrisc/include/asm/u-boot.h | 1 - arch/powerpc/include/asm/u-boot.h | 1 - arch/powerpc/lib/board.c | 3 --- arch/sandbox/include/asm/u-boot.h | 1 - arch/sandbox/lib/board.c | 3 --- arch/sh/include/asm/u-boot.h | 1 - arch/sh/lib/board.c | 11 ----------- arch/sparc/include/asm/u-boot.h | 1 - arch/sparc/lib/board.c | 2 -- arch/x86/include/asm/u-boot.h | 1 - arch/x86/lib/board.c | 6 ------ board/esd/cpci405/cpci405.c | 9 ++++----- common/cmd_bdinfo.c | 28 ++++++++++++++-------------- common/cmd_nvedit.c | 16 +--------------- net/net.c | 2 -- 31 files changed, 19 insertions(+), 103 deletions(-)
diff --git a/arch/arm/include/asm/u-boot.h b/arch/arm/include/asm/u-boot.h index f30b9fc..e6b3e46 100644 --- a/arch/arm/include/asm/u-boot.h +++ b/arch/arm/include/asm/u-boot.h @@ -38,7 +38,6 @@
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ ulong bi_arch_number; /* unique id for this board */ ulong bi_boot_params; /* where this board expects params */ struct /* RAM configuration */ diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 3d78274..e611ada 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -536,9 +536,6 @@ void board_init_r(gd_t *id, ulong dest_addr) arm_pci_init(); #endif
jumptable_init(); diff --git a/arch/avr32/include/asm/u-boot.h b/arch/avr32/include/asm/u-boot.h index ff1ed23..1d2959a 100644 --- a/arch/avr32/include/asm/u-boot.h +++ b/arch/avr32/include/asm/u-boot.h @@ -24,7 +24,6 @@
typedef struct bd_info { unsigned long bi_baudrate; - unsigned long bi_ip_addr; unsigned char bi_phy_id[4]; unsigned long bi_board_number; void *bi_boot_params; diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 63fe297..be5da90 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -304,8 +304,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) /* initialize environment */ env_relocate();
- bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); - stdio_init(); jumptable_init(); console_init_r(); diff --git a/arch/blackfin/include/asm/u-boot.h b/arch/blackfin/include/asm/u-boot.h index 9712fc0..df81183 100644 --- a/arch/blackfin/include/asm/u-boot.h +++ b/arch/blackfin/include/asm/u-boot.h @@ -30,7 +30,6 @@
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_boot_params; /* where this board expects params */ unsigned long bi_memstart; /* start of DRAM memory */ phys_size_t bi_memsize; /* size of DRAM memory in bytes */ diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index e3ee4cd..5d9d448 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -86,7 +86,6 @@ static void display_global_data(void) printf(" |-jt(%p): %p\n", gd->jt, *(gd->jt)); printf(" \-bd: %p\n", gd->bd); printf(" |-bi_baudrate: %x\n", bd->bi_baudrate); - printf(" |-bi_ip_addr: %lx\n", bd->bi_ip_addr); printf(" |-bi_boot_params: %lx\n", bd->bi_boot_params); printf(" |-bi_memstart: %lx\n", bd->bi_memstart); printf(" |-bi_memsize: %lx\n", bd->bi_memsize); @@ -299,8 +298,6 @@ static void board_net_init_r(bd_t *bd) if ((s = getenv("bootfile")) != NULL) copy_filename(BootFile, s, sizeof(BootFile));
- bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - printf("Net: "); eth_initialize(gd->bd); #endif diff --git a/arch/m68k/include/asm/u-boot.h b/arch/m68k/include/asm/u-boot.h index 0a48bbd..973c9ee 100644 --- a/arch/m68k/include/asm/u-boot.h +++ b/arch/m68k/include/asm/u-boot.h @@ -47,7 +47,6 @@ typedef struct bd_info { unsigned long bi_mbar_base; /* base of internal registers */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ unsigned long bi_boot_params; /* where this board expects params */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index 259b71c..e80d853 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -507,15 +507,6 @@ void board_init_r (gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate ();
#if defined(CONFIG_PCI) diff --git a/arch/microblaze/include/asm/u-boot.h b/arch/microblaze/include/asm/u-boot.h index 21c72d5..a0b1dbf 100644 --- a/arch/microblaze/include/asm/u-boot.h +++ b/arch/microblaze/include/asm/u-boot.h @@ -40,7 +40,6 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_baudrate; /* Console Baudrate */ } bd_t;
diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index 9828b76..beb406d 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -176,9 +176,6 @@ void board_init (void) load_addr = getenv_ulong("loadaddr", 16, load_addr);
diff --git a/arch/mips/include/asm/u-boot.h b/arch/mips/include/asm/u-boot.h index edb87bb..590649a 100644 --- a/arch/mips/include/asm/u-boot.h +++ b/arch/mips/include/asm/u-boot.h @@ -33,7 +33,6 @@
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_arch_number; /* unique id for this board */ unsigned long bi_boot_params; /* where this board expects params */ unsigned long bi_memstart; /* start of DRAM memory */ diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index d998f0e..2f45562 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -316,9 +316,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate();
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - #if defined(CONFIG_PCI) /* * Do pci configuration diff --git a/arch/nds32/include/asm/u-boot.h b/arch/nds32/include/asm/u-boot.h index 9a69750..eabbf38 100644 --- a/arch/nds32/include/asm/u-boot.h +++ b/arch/nds32/include/asm/u-boot.h @@ -40,7 +40,6 @@
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned char bi_enetaddr[6]; /* Ethernet adress */ unsigned long bi_arch_number; /* unique id for this board */ unsigned long bi_boot_params; /* where this board expects params */ diff --git a/arch/nds32/lib/board.c b/arch/nds32/lib/board.c index 66e4537..46f022a 100644 --- a/arch/nds32/lib/board.c +++ b/arch/nds32/lib/board.c @@ -368,9 +368,6 @@ void board_init_r(gd_t *id, ulong dest_addr) nds32_pci_init(); #endif
jumptable_init(); diff --git a/arch/nios2/include/asm/u-boot.h b/arch/nios2/include/asm/u-boot.h index f7c70ff..315ef8b 100644 --- a/arch/nios2/include/asm/u-boot.h +++ b/arch/nios2/include/asm/u-boot.h @@ -39,7 +39,6 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_baudrate; /* Console Baudrate */ } bd_t;
- bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); - WATCHDOG_RESET (); stdio_init(); jumptable_init(); diff --git a/arch/openrisc/include/asm/u-boot.h b/arch/openrisc/include/asm/u-boot.h index 2913994..76b8132 100644 --- a/arch/openrisc/include/asm/u-boot.h +++ b/arch/openrisc/include/asm/u-boot.h @@ -33,7 +33,6 @@
typedef struct bd_info { unsigned long bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_arch_number; /* unique id for this board */ unsigned long bi_boot_params; /* where this board expects params */ unsigned long bi_memstart; /* start of DRAM memory */ diff --git a/arch/powerpc/include/asm/u-boot.h b/arch/powerpc/include/asm/u-boot.h index b2fa2b5..1552054 100644 --- a/arch/powerpc/include/asm/u-boot.h +++ b/arch/powerpc/include/asm/u-boot.h @@ -63,7 +63,6 @@ typedef struct bd_info { unsigned long bi_vcofreq; /* VCO Freq, in MHz */ #endif unsigned long bi_bootflags; /* boot / reboot flag (Unused) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned char bi_enetaddr[6]; /* OLD: see README.enetaddr */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index ff5888e..d4cbb4d 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -877,9 +877,6 @@ void board_init_r(gd_t *id, ulong dest_addr) #endif #endif /* CONFIG_CMD_NET */
#if defined(CONFIG_PCI) && !defined(CONFIG_SYS_EARLY_PCI_INIT) diff --git a/arch/sandbox/include/asm/u-boot.h b/arch/sandbox/include/asm/u-boot.h index 166ef14..de8120a 100644 --- a/arch/sandbox/include/asm/u-boot.h +++ b/arch/sandbox/include/asm/u-boot.h @@ -45,7 +45,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/sandbox/lib/board.c b/arch/sandbox/lib/board.c index b7997e9..a71b1ba 100644 --- a/arch/sandbox/lib/board.c +++ b/arch/sandbox/lib/board.c @@ -226,9 +226,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* initialize environment */ env_relocate();
jumptable_init(); diff --git a/arch/sh/include/asm/u-boot.h b/arch/sh/include/asm/u-boot.h index 4574512..6c04daf 100644 --- a/arch/sh/include/asm/u-boot.h +++ b/arch/sh/include/asm/u-boot.h @@ -33,7 +33,6 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_baudrate; /* Console Baudrate */ unsigned long bi_boot_params; /* where this board expects params */ } bd_t; diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index d9c0c22..cb34c0b 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -99,14 +99,6 @@ static int sh_mem_env_init(void) return 0; }
-#if defined(CONFIG_CMD_NET) -static int sh_net_init(void) -{ - gd->bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - return 0; -} -#endif - #if defined(CONFIG_CMD_MMC) static int sh_mmc_init(void) { @@ -144,9 +136,6 @@ init_fnc_t *init_sequence[] = #ifdef CONFIG_BOARD_LATE_INIT board_late_init, #endif -#if defined(CONFIG_CMD_NET) - sh_net_init, /* SH specific eth init */ -#endif #if defined(CONFIG_CMD_MMC) sh_mmc_init, #endif diff --git a/arch/sparc/include/asm/u-boot.h b/arch/sparc/include/asm/u-boot.h index 1d94087..8d01118 100644 --- a/arch/sparc/include/asm/u-boot.h +++ b/arch/sparc/include/asm/u-boot.h @@ -51,7 +51,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index 519a4fb..cd5cd52 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -333,8 +333,6 @@ void board_init_f(ulong bootflag) mac_read_from_eeprom(); #endif
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); #if defined(CONFIG_PCI) /* * Do pci configuration diff --git a/arch/x86/include/asm/u-boot.h b/arch/x86/include/asm/u-boot.h index 26450eb..da667c5 100644 --- a/arch/x86/include/asm/u-boot.h +++ b/arch/x86/include/asm/u-boot.h @@ -45,7 +45,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index d742fec..a0c22b1 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -321,12 +321,6 @@ void board_init_r(gd_t *id, ulong dest_addr) env_relocate(); show_boot_progress(0x26);
- -#ifdef CONFIG_CMD_NET - /* IP Address */ - bd_data.bi_ip_addr = getenv_IPaddr("ipaddr"); -#endif - #if defined(CONFIG_PCI) /* * Do pci configuration diff --git a/board/esd/cpci405/cpci405.c b/board/esd/cpci405/cpci405.c index 41b5ba0..1441b10 100644 --- a/board/esd/cpci405/cpci405.c +++ b/board/esd/cpci405/cpci405.c @@ -730,12 +730,11 @@ int do_get_bpip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* * Update whole ip-addr */ - bd->bi_ip_addr = ipaddr; sprintf(str, "%ld.%ld.%ld.%ld", - (bd->bi_ip_addr & 0xff000000) >> 24, - (bd->bi_ip_addr & 0x00ff0000) >> 16, - (bd->bi_ip_addr & 0x0000ff00) >> 8, - (bd->bi_ip_addr & 0x000000ff)); + (ipaddr & 0xff000000) >> 24, + (ipaddr & 0x00ff0000) >> 16, + (ipaddr & 0x0000ff00) >> 8, + (ipaddr & 0x000000ff)); setenv("ipaddr", str); printf("Updated ip_addr from bp_eeprom to %s!\n", str); } diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 97f2945..71a7337 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -139,7 +139,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_HERMES print_mhz("ethspeed", bd->bi_ethspeed); #endif - printf("IP addr = %pI4\n", &bd->bi_ip_addr); + printf("IP addr = %s\n", getenv("ipaddr")); printf("baudrate = %6ld bps\n", bd->bi_baudrate); print_num("relocaddr", gd->relocaddr); return 0; @@ -164,7 +164,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif
printf("baudrate = %ld bps\n", bd->bi_baudrate); @@ -188,7 +188,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); return 0; @@ -221,7 +221,7 @@ int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %6ld bps\n", bd->bi_baudrate); return 0; @@ -267,7 +267,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_eth(3); #endif
- printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %ld bps\n", bd->bi_baudrate);
@@ -295,7 +295,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_num("flashoffset", (ulong)bd->bi_flashoffset);
print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); printf("baudrate = %d bps\n", bd->bi_baudrate);
return 0; @@ -315,7 +315,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_num("flashoffset", (ulong)bd->bi_flashoffset);
return 0; @@ -335,7 +335,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_num("flashoffset", (ulong)bd->bi_flashoffset);
print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); printf("baudrate = %lu bps\n", bd->bi_baudrate);
return 0; @@ -359,7 +359,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %d bps\n", bd->bi_baudrate); #if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) @@ -386,7 +386,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); return 0; @@ -419,7 +419,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); print_mhz("ethspeed", bd->bi_ethspeed); #endif printf("baudrate = %d bps\n", bd->bi_baudrate); @@ -444,7 +444,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif print_num("FB base ", gd->fb_base); return 0; @@ -468,7 +468,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
@@ -489,7 +489,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
printf("baudrate = %ld bps\n", bd->bi_baudrate); diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 63afc82..ca7d8e4 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -341,21 +341,7 @@ int _do_env_set(int flag, int argc, char * const argv[]) * Some variables should be updated when the corresponding * entry in the environment is changed */ - if (strcmp(name, "ipaddr") == 0) { - char *s = argv[2]; /* always use only one arg */ - char *e; - unsigned long addr; - bd->bi_ip_addr = 0; - for (addr = 0, i = 0; i < 4; ++i) { - ulong val = s ? simple_strtoul(s, &e, 10) : 0; - addr <<= 8; - addr |= val & 0xFF; - if (s) - s = *e ? e + 1 : e; - } - bd->bi_ip_addr = htonl(addr); - return 0; - } else if (strcmp(argv[1], "loadaddr") == 0) { + if (strcmp(argv[1], "loadaddr") == 0) { load_addr = simple_strtoul(argv[2], NULL, 16); return 0; } diff --git a/net/net.c b/net/net.c index 045405b..3f08669 100644 --- a/net/net.c +++ b/net/net.c @@ -342,13 +342,11 @@ void net_auto_load(void) static void NetInitLoop(enum proto_t protocol) { static int env_changed_id; - bd_t *bd = gd->bd; int env_id = get_env_id();
/* update only when the environment has changed */ if (env_changed_id != env_id) { NetOurIP = getenv_IPaddr("ipaddr"); - NetCopyIP(&bd->bi_ip_addr, &NetOurIP); NetOurGatewayIP = getenv_IPaddr("gatewayip"); NetOurSubnetMask = getenv_IPaddr("netmask"); NetServerIP = getenv_IPaddr("serverip");
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/arm/lib/board.c | 8 -------- arch/avr32/lib/board.c | 3 --- arch/blackfin/lib/board.c | 7 +------ arch/m68k/lib/board.c | 5 ----- arch/microblaze/lib/board.c | 4 ---- arch/mips/lib/board.c | 8 -------- arch/nds32/lib/board.c | 6 ------ arch/powerpc/lib/board.c | 8 -------- arch/sh/lib/board.c | 11 ++--------- arch/sparc/lib/board.c | 5 ----- arch/x86/lib/board.c | 6 ------ net/eth.c | 10 ++++++++++ 12 files changed, 13 insertions(+), 68 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index e611ada..2c4276b 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -573,14 +573,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
#ifdef CONFIG_BOARD_LATE_INIT board_late_init(); diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index be5da90..4bc3c8a 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -315,9 +315,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s) - copy_filename(BootFile, s, sizeof(BootFile)); puts("Net: "); eth_initialize(gd->bd); #endif diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index 5d9d448..1ee7e22 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -293,13 +293,8 @@ static void board_net_init_r(bd_t *bd) bb_miiphy_init(); #endif #ifdef CONFIG_CMD_NET - char *s; - - if ((s = getenv("bootfile")) != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - printf("Net: "); - eth_initialize(gd->bd); + eth_initialize(bd); #endif }
diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index e80d853..b3dca77 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -559,11 +559,6 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET ();
diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index beb406d..f3679d5 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -182,10 +182,6 @@ void board_init (void) uchar enetaddr[6]; eth_getenv_enetaddr("ethaddr", enetaddr); printf("MAC: %pM\n", enetaddr); - - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); #endif
/* main_loop */ diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index 2f45562..6b36a98 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -335,14 +335,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
#ifdef CONFIG_CMD_SPI puts("SPI: "); diff --git a/arch/nds32/lib/board.c b/arch/nds32/lib/board.c index 46f022a..446e0fd 100644 --- a/arch/nds32/lib/board.c +++ b/arch/nds32/lib/board.c @@ -398,12 +398,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
-#if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); -#endif - #ifdef BOARD_LATE_INIT board_late_init(); #endif diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index d4cbb4d..931b098 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -932,14 +932,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index cb34c0b..e1a5739 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -189,15 +189,8 @@ void sh_generic_init(void) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - { - char *s; - puts("Net: "); - eth_initialize(gd->bd); - - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - } + puts("Net: "); + eth_initialize(gd->bd); #endif /* CONFIG_CMD_NET */
while (1) { diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index cd5cd52..a36f165 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -357,11 +357,6 @@ void board_init_f(ulong bootflag)
WATCHDOG_RESET();
diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index a0c22b1..595b3c9 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -367,12 +367,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
diff --git a/net/eth.c b/net/eth.c index f3a55ba..83ad814 100644 --- a/net/eth.c +++ b/net/eth.c @@ -224,6 +224,14 @@ int eth_register(struct eth_device *dev) return 0; }
+static void eth_env_init(bd_t *bis) +{ + const char *s; + + if ((s = getenv("bootfile")) != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); +} + int eth_initialize(bd_t *bis) { int num_devices = 0; @@ -239,6 +247,8 @@ int eth_initialize(bd_t *bis) phy_init(); #endif
Hi Mike,
Please rebase.
Thanks, -Joe
Hi Mike,
Please rebase.
Thanks, -Joe
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - rebased onto mainline
arch/arm/include/asm/u-boot.h | 1 - arch/arm/lib/board.c | 3 --- arch/avr32/include/asm/u-boot.h | 1 - arch/avr32/lib/board.c | 2 -- arch/blackfin/include/asm/u-boot.h | 1 - arch/blackfin/lib/board.c | 3 --- arch/m68k/include/asm/u-boot.h | 1 - arch/m68k/lib/board.c | 9 --------- arch/microblaze/include/asm/u-boot.h | 1 - arch/microblaze/lib/board.c | 3 --- arch/mips/include/asm/u-boot.h | 1 - arch/mips/lib/board.c | 3 --- arch/nds32/include/asm/u-boot.h | 1 - arch/nds32/lib/board.c | 3 --- arch/nios2/include/asm/u-boot.h | 1 - arch/nios2/lib/board.c | 2 -- arch/openrisc/include/asm/u-boot.h | 1 - arch/powerpc/include/asm/u-boot.h | 1 - arch/powerpc/lib/board.c | 3 --- arch/sandbox/include/asm/u-boot.h | 1 - arch/sandbox/lib/board.c | 3 --- arch/sh/include/asm/u-boot.h | 1 - arch/sh/lib/board.c | 11 ----------- arch/sparc/include/asm/u-boot.h | 1 - arch/sparc/lib/board.c | 2 -- arch/x86/include/asm/init_helpers.h | 1 - arch/x86/include/asm/u-boot.h | 1 - arch/x86/lib/board.c | 3 --- arch/x86/lib/init_helpers.c | 8 -------- board/esd/cpci405/cpci405.c | 9 ++++----- common/cmd_bdinfo.c | 28 ++++++++++++++-------------- common/cmd_nvedit.c | 16 +--------------- net/net.c | 2 -- 33 files changed, 19 insertions(+), 109 deletions(-)
diff --git a/arch/arm/include/asm/u-boot.h b/arch/arm/include/asm/u-boot.h index 20e1653..eac3800 100644 --- a/arch/arm/include/asm/u-boot.h +++ b/arch/arm/include/asm/u-boot.h @@ -38,7 +38,6 @@
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ ulong bi_arch_number; /* unique id for this board */ ulong bi_boot_params; /* where this board expects params */ unsigned long bi_arm_freq; /* arm frequency */ diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 5270c11..66dfb13 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -555,9 +555,6 @@ void board_init_r(gd_t *id, ulong dest_addr) arm_pci_init(); #endif
typedef struct bd_info { unsigned long bi_baudrate; - unsigned long bi_ip_addr; unsigned char bi_phy_id[4]; unsigned long bi_board_number; void *bi_boot_params; diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index d626c29..3c2d0fb 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -316,8 +316,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) /* initialize environment */ env_relocate();
- bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - printf("Net: "); eth_initialize(gd->bd); #endif diff --git a/arch/m68k/include/asm/u-boot.h b/arch/m68k/include/asm/u-boot.h index 0a48bbd..973c9ee 100644 --- a/arch/m68k/include/asm/u-boot.h +++ b/arch/m68k/include/asm/u-boot.h @@ -47,7 +47,6 @@ typedef struct bd_info { unsigned long bi_mbar_base; /* base of internal registers */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ unsigned long bi_boot_params; /* where this board expects params */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index 1526967..ffd91a8 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -507,15 +507,6 @@ void board_init_r (gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate ();
typedef struct bd_info { int bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned char bi_enetaddr[6]; /* Ethernet adress */ unsigned long bi_arch_number; /* unique id for this board */ unsigned long bi_boot_params; /* where this board expects params */ diff --git a/arch/nds32/lib/board.c b/arch/nds32/lib/board.c index 074aabf..50ea30d 100644 --- a/arch/nds32/lib/board.c +++ b/arch/nds32/lib/board.c @@ -369,9 +369,6 @@ void board_init_r(gd_t *id, ulong dest_addr) nds32_pci_init(); #endif
typedef struct bd_info { unsigned long bi_baudrate; /* serial console baudrate */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_arch_number; /* unique id for this board */ unsigned long bi_boot_params; /* where this board expects params */ unsigned long bi_memstart; /* start of DRAM memory */ diff --git a/arch/powerpc/include/asm/u-boot.h b/arch/powerpc/include/asm/u-boot.h index b2fa2b5..1552054 100644 --- a/arch/powerpc/include/asm/u-boot.h +++ b/arch/powerpc/include/asm/u-boot.h @@ -63,7 +63,6 @@ typedef struct bd_info { unsigned long bi_vcofreq; /* VCO Freq, in MHz */ #endif unsigned long bi_bootflags; /* boot / reboot flag (Unused) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned char bi_enetaddr[6]; /* OLD: see README.enetaddr */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index d5b75e5..7daffce 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -877,9 +877,6 @@ void board_init_r(gd_t *id, ulong dest_addr) #endif #endif /* CONFIG_CMD_NET */
#if defined(CONFIG_PCI) && !defined(CONFIG_SYS_EARLY_PCI_INIT) diff --git a/arch/sandbox/include/asm/u-boot.h b/arch/sandbox/include/asm/u-boot.h index 166ef14..de8120a 100644 --- a/arch/sandbox/include/asm/u-boot.h +++ b/arch/sandbox/include/asm/u-boot.h @@ -45,7 +45,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/sandbox/lib/board.c b/arch/sandbox/lib/board.c index 306d1ec..c173bf9 100644 --- a/arch/sandbox/lib/board.c +++ b/arch/sandbox/lib/board.c @@ -235,9 +235,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* initialize environment */ env_relocate();
jumptable_init(); diff --git a/arch/sh/include/asm/u-boot.h b/arch/sh/include/asm/u-boot.h index 4574512..6c04daf 100644 --- a/arch/sh/include/asm/u-boot.h +++ b/arch/sh/include/asm/u-boot.h @@ -33,7 +33,6 @@ typedef struct bd_info { unsigned long bi_flashoffset; /* reserved area for startup monitor */ unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ - unsigned long bi_ip_addr; /* IP Address */ unsigned long bi_baudrate; /* Console Baudrate */ unsigned long bi_boot_params; /* where this board expects params */ } bd_t; diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index eb021e8..d71cca4 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -100,14 +100,6 @@ static int sh_mem_env_init(void) return 0; }
-#if defined(CONFIG_CMD_NET) -static int sh_net_init(void) -{ - gd->bd->bi_ip_addr = getenv_IPaddr("ipaddr"); - return 0; -} -#endif - #if defined(CONFIG_CMD_MMC) static int sh_mmc_init(void) { @@ -145,9 +137,6 @@ init_fnc_t *init_sequence[] = #ifdef CONFIG_BOARD_LATE_INIT board_late_init, #endif -#if defined(CONFIG_CMD_NET) - sh_net_init, /* SH specific eth init */ -#endif #if defined(CONFIG_CMD_MMC) sh_mmc_init, #endif diff --git a/arch/sparc/include/asm/u-boot.h b/arch/sparc/include/asm/u-boot.h index 1d94087..8d01118 100644 --- a/arch/sparc/include/asm/u-boot.h +++ b/arch/sparc/include/asm/u-boot.h @@ -51,7 +51,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index c0d2608..9faf88b 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -333,8 +333,6 @@ void board_init_f(ulong bootflag) mac_read_from_eeprom(); #endif
- /* IP Address */ - bd->bi_ip_addr = getenv_IPaddr("ipaddr"); #if defined(CONFIG_PCI) /* * Do pci configuration diff --git a/arch/x86/include/asm/init_helpers.h b/arch/x86/include/asm/init_helpers.h index 192f18e..8d2e0ba 100644 --- a/arch/x86/include/asm/init_helpers.h +++ b/arch/x86/include/asm/init_helpers.h @@ -36,7 +36,6 @@ int set_reloc_flag_r(void); int mem_malloc_init_r(void); int init_bd_struct_r(void); int flash_init_r(void); -int init_ip_address_r(void); int status_led_set_r(void); int set_bootfile_r(void); int set_load_addr_r(void); diff --git a/arch/x86/include/asm/u-boot.h b/arch/x86/include/asm/u-boot.h index 26450eb..da667c5 100644 --- a/arch/x86/include/asm/u-boot.h +++ b/arch/x86/include/asm/u-boot.h @@ -45,7 +45,6 @@ typedef struct bd_info { unsigned long bi_sramstart; /* start of SRAM memory */ unsigned long bi_sramsize; /* size of SRAM memory */ unsigned long bi_bootflags; /* boot / reboot flag (for LynxOS) */ - unsigned long bi_ip_addr; /* IP Address */ unsigned short bi_ethspeed; /* Ethernet speed in Mbps */ unsigned long bi_intfreq; /* Internal Freq, in MHz */ unsigned long bi_busfreq; /* Bus Freq, in MHz */ diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index 5f0b62c..15b4ae2 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -157,9 +157,6 @@ init_fnc_t *init_sequence_r[] = { flash_init_r, #endif env_relocate_r, -#ifdef CONFIG_CMD_NET - init_ip_address_r, -#endif #ifdef CONFIG_PCI pci_init_r, #endif diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index 9f4dee0..a8741d0 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -179,14 +179,6 @@ int flash_init_r(void) } #endif
-int init_ip_address_r(void) -{ - /* IP Address */ - bd_data.bi_ip_addr = getenv_IPaddr("ipaddr"); - - return 0; -} - #ifdef CONFIG_STATUS_LED int status_led_set_r(void) { diff --git a/board/esd/cpci405/cpci405.c b/board/esd/cpci405/cpci405.c index 41b5ba0..1441b10 100644 --- a/board/esd/cpci405/cpci405.c +++ b/board/esd/cpci405/cpci405.c @@ -730,12 +730,11 @@ int do_get_bpip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* * Update whole ip-addr */ - bd->bi_ip_addr = ipaddr; sprintf(str, "%ld.%ld.%ld.%ld", - (bd->bi_ip_addr & 0xff000000) >> 24, - (bd->bi_ip_addr & 0x00ff0000) >> 16, - (bd->bi_ip_addr & 0x0000ff00) >> 8, - (bd->bi_ip_addr & 0x000000ff)); + (ipaddr & 0xff000000) >> 24, + (ipaddr & 0x00ff0000) >> 16, + (ipaddr & 0x0000ff00) >> 8, + (ipaddr & 0x000000ff)); setenv("ipaddr", str); printf("Updated ip_addr from bp_eeprom to %s!\n", str); } diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 5359a47..802b510 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -139,7 +139,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_HERMES print_mhz("ethspeed", bd->bi_ethspeed); #endif - printf("IP addr = %pI4\n", &bd->bi_ip_addr); + printf("IP addr = %s\n", getenv("ipaddr")); printf("baudrate = %6ld bps\n", bd->bi_baudrate); print_num("relocaddr", gd->relocaddr); return 0; @@ -164,7 +164,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %d bps\n", bd->bi_baudrate); #if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) @@ -395,7 +395,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif printf("baudrate = %ld bps\n", (ulong)bd->bi_baudrate); return 0; @@ -428,7 +428,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); print_mhz("ethspeed", bd->bi_ethspeed); #endif printf("baudrate = %d bps\n", bd->bi_baudrate); @@ -453,7 +453,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
#if defined(CONFIG_CMD_NET) print_eth(0); - printf("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf("ip_addr = %s\n", getenv("ipaddr")); #endif print_num("FB base ", gd->fb_base); return 0; @@ -477,7 +477,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
@@ -498,7 +498,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
printf("baudrate = %ld bps\n", bd->bi_baudrate); diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index b1494dc..5d772e4 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -342,21 +342,7 @@ int _do_env_set(int flag, int argc, char * const argv[]) * Some variables should be updated when the corresponding * entry in the environment is changed */ - if (strcmp(name, "ipaddr") == 0) { - char *s = argv[2]; /* always use only one arg */ - char *e; - unsigned long addr; - bd->bi_ip_addr = 0; - for (addr = 0, i = 0; i < 4; ++i) { - ulong val = s ? simple_strtoul(s, &e, 10) : 0; - addr <<= 8; - addr |= val & 0xFF; - if (s) - s = *e ? e + 1 : e; - } - bd->bi_ip_addr = htonl(addr); - return 0; - } else if (strcmp(argv[1], "loadaddr") == 0) { + if (strcmp(argv[1], "loadaddr") == 0) { load_addr = simple_strtoul(argv[2], NULL, 16); return 0; } diff --git a/net/net.c b/net/net.c index c5acf8f..73d23eb 100644 --- a/net/net.c +++ b/net/net.c @@ -342,13 +342,11 @@ void net_auto_load(void) static void NetInitLoop(enum proto_t protocol) { static int env_changed_id; - bd_t *bd = gd->bd; int env_id = get_env_id();
arch/arm/lib/board.c | 8 -------- arch/avr32/lib/board.c | 3 --- arch/blackfin/lib/board.c | 7 +------ arch/m68k/lib/board.c | 5 ----- arch/microblaze/lib/board.c | 4 ---- arch/mips/lib/board.c | 8 -------- arch/nds32/lib/board.c | 6 ------ arch/powerpc/lib/board.c | 8 -------- arch/sh/lib/board.c | 11 ++--------- arch/sparc/lib/board.c | 5 ----- arch/x86/include/asm/init_helpers.h | 1 - arch/x86/lib/board.c | 3 --- arch/x86/lib/init_helpers.c | 12 ------------ net/eth.c | 10 ++++++++++ 14 files changed, 13 insertions(+), 78 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 66dfb13..024646c 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -592,14 +592,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
#ifdef CONFIG_BOARD_LATE_INIT board_late_init(); diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index 3c2d0fb..b390a6c 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -327,9 +327,6 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s) - copy_filename(BootFile, s, sizeof(BootFile)); puts("Net: "); eth_initialize(gd->bd); #endif diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index 5d9d448..1ee7e22 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -293,13 +293,8 @@ static void board_net_init_r(bd_t *bd) bb_miiphy_init(); #endif #ifdef CONFIG_CMD_NET - char *s; - - if ((s = getenv("bootfile")) != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - printf("Net: "); - eth_initialize(gd->bd); + eth_initialize(bd); #endif }
diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index ffd91a8..65a8595 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -559,11 +559,6 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET ();
#ifdef CONFIG_CMD_SPI puts("SPI: "); diff --git a/arch/nds32/lib/board.c b/arch/nds32/lib/board.c index 50ea30d..7121313 100644 --- a/arch/nds32/lib/board.c +++ b/arch/nds32/lib/board.c @@ -399,12 +399,6 @@ void board_init_r(gd_t *id, ulong dest_addr) /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
-#if defined(CONFIG_CMD_NET) - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); -#endif - #ifdef BOARD_LATE_INIT board_late_init(); #endif diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 7daffce..fea310e 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -932,14 +932,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index d71cca4..34d7881 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -190,15 +190,8 @@ void sh_generic_init(void) bb_miiphy_init(); #endif #if defined(CONFIG_CMD_NET) - { - char *s; - puts("Net: "); - eth_initialize(gd->bd); - - s = getenv("bootfile"); - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - } + puts("Net: "); + eth_initialize(gd->bd); #endif /* CONFIG_CMD_NET */
while (1) { diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index 9faf88b..7e48775 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -357,11 +357,6 @@ void board_init_f(ulong bootflag)
WATCHDOG_RESET();
diff --git a/arch/x86/include/asm/init_helpers.h b/arch/x86/include/asm/init_helpers.h index 8d2e0ba..8afb443 100644 --- a/arch/x86/include/asm/init_helpers.h +++ b/arch/x86/include/asm/init_helpers.h @@ -37,7 +37,6 @@ int mem_malloc_init_r(void); int init_bd_struct_r(void); int flash_init_r(void); int status_led_set_r(void); -int set_bootfile_r(void); int set_load_addr_r(void);
#endif /* !_INIT_HELPERS_H_ */ diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index 15b4ae2..90cf7fc 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -177,9 +177,6 @@ init_fnc_t *init_sequence_r[] = { status_led_set_r, #endif set_load_addr_r, -#if defined(CONFIG_CMD_NET) - set_bootfile_r, -#endif #if defined(CONFIG_CMD_IDE) ide_init_r, #endif diff --git a/arch/x86/lib/init_helpers.c b/arch/x86/lib/init_helpers.c index a8741d0..9ec34ff 100644 --- a/arch/x86/lib/init_helpers.c +++ b/arch/x86/lib/init_helpers.c @@ -188,18 +188,6 @@ int status_led_set_r(void) } #endif
-int set_bootfile_r(void) -{ - char *s; - - s = getenv("bootfile"); - - if (s != NULL) - copy_filename(BootFile, s, sizeof(BootFile)); - - return 0; -} - int set_load_addr_r(void) { /* Initialize from environment */ diff --git a/net/eth.c b/net/eth.c index aabb343..0a55a7b 100644 --- a/net/eth.c +++ b/net/eth.c @@ -250,6 +250,14 @@ int eth_unregister(struct eth_device *dev) return 0; }
+static void eth_env_init(bd_t *bis) +{ + const char *s; + + if ((s = getenv("bootfile")) != NULL) + copy_filename(BootFile, s, sizeof(BootFile)); +} + int eth_initialize(bd_t *bis) { int num_devices = 0; @@ -265,6 +273,8 @@ int eth_initialize(bd_t *bis) phy_init(); #endif
Hi Mike,
Applied... thanks.
-Joe
Hi Mike,
Applied... thanks.
-Joe
Commit 50a47d0 "net: punt bd->bi_ip_addr" introduced a build warning. Fix it.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Mike Frysinger vapier@gentoo.org --- common/cmd_nvedit.c | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 5999cb8..2712002 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -204,7 +204,6 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag, */ int _do_env_set(int flag, int argc, char * const argv[]) { - bd_t *bd = gd->bd; int i, len; int console = -1; char *name, *value, *s;
Applied, thanks.
-Joe
Dear Joe Hershberger,
In message CANr=Z=bVYVDM_qoUngpEUz0x4S1P4bZYPbypU_P2grzvARnKXQ@mail.gmail.com you wrote:
Applied, thanks.
Umm... how comes?
This falls not into your bailiwick...
Applied, thanks.
Umm... how comes?
Only because the break came through me.
-Joe
In message CANr=Z=aDCq+E2yeDpPXLxtoRyN3G3tOs7v0h=q4_of_ybkH8Hw@mail.gmail.com you wrote:
Applied, thanks.
Umm... how comes?
This is a common file that is unrelated with network code. It shuld not go through the net repo. [If you want to go ahead, you can pull it into the stagiung repo, and send a pull reqest fot that - but for a single patch that makes little sense.]
Hi Wolfgang,
Applied, thanks.
Umm... how comes?
Sounds good... I'll drop it. You can apply it directly.
Thanks, -Joe
Hi Mike,
unfortunately this patch breaks compatibility with older v2.4 kernels. bd_t struct passed to the kernel has different offsets of the fields after bi_ip_addr. As a result older powerpc kernels setup wrong bus clock configurations and serial console baudrate. If the kernel still boots somehow, mounting nfs rootfs doesn't seem to work, etc. We need to fix the offsets at least.
Thanks, Anatolij
participants (5)
Anatolij Gustschin
Joe Hershberger
Mike Frysinger
Thomas Chou
