[U-Boot] [PATCH] mmc: sdhci: Add the programmable clock mode support
Add the programmable clock mode for the clock generator.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
drivers/mmc/sdhci.c | 49 +++++++++++++++++++++++++++++++++++++++---------- include/sdhci.h | 15 +++++++++++++++ 2 files changed, 54 insertions(+), 10 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 5c71ab8..ee6d4a1 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -286,7 +286,7 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) { struct sdhci_host *host = mmc->priv; - unsigned int div, clk, timeout, reg; + unsigned int div, clk = 0, timeout, reg;
/* Wait max 20 ms */ timeout = 200; @@ -310,14 +310,35 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) return 0;
if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) { - /* Version 3.00 divisors must be a multiple of 2. */ - if (mmc->cfg->f_max <= clock) - div = 1; - else { - for (div = 2; div < SDHCI_MAX_DIV_SPEC_300; div += 2) { - if ((mmc->cfg->f_max / div) <= clock) + /* + * Check if the Host Controller supports Programmable Clock + * Mode. + */ + if (host->clk_mul) { + for (div = 1; div <= 1024; div++) { + if ((mmc->cfg->f_max * host->clk_mul / div) + <= clock) break; } + + /* + * Set Programmable Clock Mode in the Clock + * Control register. + */ + clk = SDHCI_PROG_CLOCK_MODE; + div--; + } else { + /* Version 3.00 divisors must be a multiple of 2. */ + if (mmc->cfg->f_max <= clock) { + div = 1; + } else { + for (div = 2; + div < SDHCI_MAX_DIV_SPEC_300; div += 2) { + if ((mmc->cfg->f_max / div) <= clock) + break; + } + } + div >>= 1; } } else { /* Version 2.00 divisors must be a power of 2. */ @@ -325,13 +346,13 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if ((mmc->cfg->f_max / div) <= clock) break; } + div >>= 1; } - div >>= 1;
if (host->set_clock) host->set_clock(host->index, div);
- clk = (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT; + clk |= (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT; clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN) << SDHCI_DIVIDER_HI_SHIFT; clk |= SDHCI_CLOCK_INT_EN; @@ -480,7 +501,7 @@ static const struct mmc_ops sdhci_ops = {
int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) { - unsigned int caps; + unsigned int caps, caps_1;
host->cfg.name = host->name; host->cfg.ops = &sdhci_ops; @@ -546,6 +567,14 @@ int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk)
host->cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
+ /* + * In case of Host Controller v3.00, find out whether clock + * multiplier is supported. + */ + caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1); + host->clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> + SDHCI_CLOCK_MUL_SHIFT; + sdhci_reset(host, SDHCI_RESET_ALL);
host->mmc = mmc_create(&host->cfg, host); diff --git a/include/sdhci.h b/include/sdhci.h index e0f6667..5abe0a2 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -97,6 +97,7 @@ #define SDHCI_DIV_MASK 0xFF #define SDHCI_DIV_MASK_LEN 8 #define SDHCI_DIV_HI_MASK 0x300 +#define SDHCI_PROG_CLOCK_MODE 0x0020 #define SDHCI_CLOCK_CARD_EN 0x0004 #define SDHCI_CLOCK_INT_STABLE 0x0002 #define SDHCI_CLOCK_INT_EN 0x0001 @@ -166,6 +167,19 @@ #define SDHCI_CAN_64BIT 0x10000000
#define SDHCI_CAPABILITIES_1 0x44 +#define SDHCI_SUPPORT_SDR50 0x00000001 +#define SDHCI_SUPPORT_SDR104 0x00000002 +#define SDHCI_SUPPORT_DDR50 0x00000004 +#define SDHCI_DRIVER_TYPE_A 0x00000010 +#define SDHCI_DRIVER_TYPE_C 0x00000020 +#define SDHCI_DRIVER_TYPE_D 0x00000040 +#define SDHCI_RETUNING_TIMER_COUNT_MASK 0x00000F00 +#define SDHCI_RETUNING_TIMER_COUNT_SHIFT 8 +#define SDHCI_USE_SDR50_TUNING 0x00002000 +#define SDHCI_RETUNING_MODE_MASK 0x0000C000 +#define SDHCI_RETUNING_MODE_SHIFT 14 +#define SDHCI_CLOCK_MUL_MASK 0x00FF0000 +#define SDHCI_CLOCK_MUL_SHIFT 16
#define SDHCI_MAX_CURRENT 0x48
@@ -240,6 +254,7 @@ struct sdhci_host { unsigned int quirks; unsigned int host_caps; unsigned int version; + unsigned int clk_mul; /* Clock Muliplier value */ unsigned int clock; struct mmc *mmc; const struct sdhci_ops *ops;
Dear Pantelis,
this one is delegated to me, but I think it is out of my scope. Could you please have a look?
Andreas
div = 1;
else {
* Mode.
<= clock) break; }
* Control register.
div--;
} else {
div = 1;
} else {
for (div = 2;
break;
} } else { /* Version 2.00 divisors must be a power of 2. */div >>= 1;
}div >>= 1;
div >>= 1;
- clk |= (div & SDHCI_DIV_MASK) << SDHCI_DIVIDER_SHIFT; clk |= ((div & SDHCI_DIV_HI_MASK) >> SDHCI_DIV_MASK_LEN) << SDHCI_DIVIDER_HI_SHIFT; clk |= SDHCI_CLOCK_INT_EN;
- unsigned int clk_mul; /* Clock Muliplier value */ unsigned int clock; struct mmc *mmc; const struct sdhci_ops *ops;
Hi Andreas,
On 08/15/2016 01:17 AM, Andreas Bießmann wrote:
Dear Pantelis,
I will be delegated to me. I will check this patch.
Thanks.
Best Regards, Jaehoon Chung
Andreas
div = 1;
else {
* Mode.
<= clock) break; }
* Control register.
div--;
} else {
div = 1;
} else {
for (div = 2;
break;
}div >>= 1;
div >>= 1;
Hi Wenyou,
On 08/16/2016 10:02 AM, Jaehoon Chung wrote:
Hi Andreas,
Dear Pantelis,
Sorry for reviewing too late. First, this patch needs to rebase on latest u-boot-mmc. Then I will check this patch on my boards..
Thanks.
Andreas
div = 1;
else {
* Mode.
<= clock) break; }
* Control register.
div--;
} else {
div = 1;
} else {
for (div = 2;
break;
}div >>= 1;
div >>= 1;
s/Muliplier/Multiplier
Andreas Bießmann
Jaehoon Chung
Wenyou Yang
