[PATCH 1/2] Revert "buildman: Correct CROSS_COMPILE output for sandbox"
This reverts commit bd0a548ad4a155fec29473d4cc8e135832926973.
tools/buildman/toolchain.py | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 8f9130bdcdf..688f2e26872 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -156,8 +156,9 @@ class Toolchain: Returns: Value of that environment variable or arguments """ + wrapper = self.GetWrapper() if which == VAR_CROSS_COMPILE: - return self.GetWrapper() + self.cross + return wrapper + os.path.join(self.path, self.cross) elif which == VAR_PATH: return self.path elif which == VAR_ARCH:
The previous attempt at fixing this broke the normal usage of the -A flag.
At present, 'buildman -A sandbox' adds the path containing the toolchain. We can assume that this is in the path and we don't want to set CROSS_COMPILE=/bin/
Change this to align with what MakeEnvironment() does, but only for sandbox boards.
tools/buildman/toolchain.py | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 688f2e26872..241e8e69307 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -156,9 +156,10 @@ class Toolchain: Returns: Value of that environment variable or arguments """ - wrapper = self.GetWrapper() if which == VAR_CROSS_COMPILE: - return wrapper + os.path.join(self.path, self.cross) + wrapper = self.GetWrapper() + base = '' if self.arch == 'sandbox' else self.path + return wrapper + os.path.join(base, self.cross) elif which == VAR_PATH: return self.path elif which == VAR_ARCH:
Applied to u-boot-dm/next, thanks!
