[U-Boot-Users] qe: add ability to upload QE firmware
Define the layout of a binary blob that contains a QE firmware and instructions on how to upload it. Add function qe_upload_firmware() to parse the blob and perform the actual upload. Add command-line command "qe fw" to take a firmware blob in memory and upload it. Fully define 'struct rsp' in immap_qe.h to include the actual RISC Special Registers.
Signed-off-by: Timur Tabi timur@freescale.com ---
This patch applies to Kim's mpc83xx branch on u-boot-mpc83xx.git at denx.de.
doc/README.qe_firmware | 295 ++++++++++++++++++++++++++++++++++++++++++++ drivers/qe/qe.c | 213 ++++++++++++++++++++++++++++++++ drivers/qe/qe.h | 56 +++++++++ include/asm-ppc/immap_qe.h | 35 +++++- 4 files changed, 596 insertions(+), 3 deletions(-) create mode 100644 doc/README.qe_firmware
diff --git a/doc/README.qe_firmware b/doc/README.qe_firmware new file mode 100644 index 0000000..8962664 --- /dev/null +++ b/doc/README.qe_firmware @@ -0,0 +1,295 @@ + Freescale QUICC Engine Firmware Uploading + ----------------------------------------- + +(c) 2007 Timur Tabi <timur at freescale.com>, + Freescale Semiconductor + +Table of Contents +================= + + I - Software License for Firmware + + II - Microcode Availability + + III - Description and Terminology + + IV - Microcode Programming Details + + V - Firmware Structure Layout + + VI - Sample Code for Creating Firmware Files + +Revision Information +==================== + +November 30, 2007: Rev 1.0 - Initial version + +I - Software License for Firmware +================================= + +Each firmware file comes with its own software license. For information on +the particular license, please see the license text that is distributed with +the firmware. + +II - Microcode Availability +=========================== + +Firmware files are distributed through various channels. Some are available on +http://opensource.freescale.com. For other firmware files, please contact +your Freescale representative or your operating system vendor. + +III - Description and Terminology +================================ + +In this document, the term 'microcode' refers to the sequence of 32-bit +integers that compose the actual QE microcode. + +The term 'firmware' refers to a binary blob that contains the microcode as +well as other data that + + 1) describes the microcode's purpose + 2) describes how and where to upload the microcode + 3) specifies the values of various registers + 4) includes additional data for use by specific device drivers + +Firmware files are binary files that contain only a firmware. + +IV - Microcode Programming Details +=================================== + +The QE architecture allows for only one microcode present in I-RAM for each +RISC processor. To replace any current microcode, a full QE reset (which +disables the microcode) must be performed first. + +QE microcode is uploaded using the following procedure: + +1) The microcode is placed into I-RAM at a specific location, using the + IRAM.IADD and IRAM.IDATA registers. + +2) The CERCR.CIR bit is set to 0 or 1, depending on whether the firmware + needs split I-RAM. Split I-RAM is only meaningful for SOCs that have + QEs with multiple RISC processors, such as the 8360. Splitting the I-RAM + allows each processor to run a different microcode, effectively creating an + asymmetric multiprocessing (AMP) system. + +3) The TIBCR trap registers are loaded with the addresses of the trap handlers + in the microcode. + +4) The RSP.ECCR register is programmed with the value provided. + +5) If necessary, device drivers that need the virtual traps and extended mode + data will use them. + +Virtual Microcode Traps + +These virtual traps are conditional branches in the microcode. These are +"soft" provisional introduced in the ROMcode in order to enable higher +flexibility and save h/w traps If new features are activated or an issue is +being fixed in the RAM package utilizing they should be activated. This data +structure signals the microcode which of these virtual traps is active. + +This structure contains 6 words that the application should copy to some +specific been defined. This table describes the structure. + + --------------------------------------------------------------- + | Offset in | | Destination Offset | Size of | + | array | Protocol | within PRAM | Operand | + --------------------------------------------------------------| + | 0 | Ethernet | 0xF8 | 4 bytes | + | | interworking | | | + --------------------------------------------------------------- + | 4 | ATM | 0xF8 | 4 bytes | + | | interworking | | | + --------------------------------------------------------------- + | 8 | PPP | 0xF8 | 4 bytes | + | | interworking | | | + --------------------------------------------------------------- + | 12 | Ethernet RX | 0x22 | 1 byte | + | | Distributor Page | | | + --------------------------------------------------------------- + | 16 | ATM Globtal | 0x28 | 1 byte | + | | Params Table | | | + --------------------------------------------------------------- + | 20 | Insert Frame | 0xF8 | 4 bytes | + --------------------------------------------------------------- + + +Extended Modes + +This is a double word bit array (64 bits) that defines special functionality +which has an impact on the softwarew drivers. Each bit has its own impact +and has special instructions for the s/w associated with it. This structure is +described in this table: + + ----------------------------------------------------------------------- + | Bit # | Name | Description | + ----------------------------------------------------------------------- + | 0 | General | Indicates that prior to each host command | + | | push command | given by the application, the software must | + | | | assert a special host command (push command)| + | | | CECDR = 0x00800000. | + | | | CECR = 0x01c1000f. | + ----------------------------------------------------------------------- + | 1 | UCC ATM | Indicates that after issuing ATM RX INIT | + | | RX INIT | command, the host must issue another special| + | | push command | command (push command) and immediately | + | | | following that re-issue the ATM RX INIT | + | | | command. (This makes the sequence of | + | | | initializing the ATM receiver a sequence of | + | | | three host commands) | + | | | CECDR = 0x00800000. | + | | | CECR = 0x01c1000f. | + ----------------------------------------------------------------------- + | 2 | Add/remove | Indicates that following the specific host | + | | command | command: "Add/Remove entry in Hash Lookup | + | | validation | Table" used in Interworking setup, the user | + | | | must issue another command. | + | | | CECDR = 0xce000003. | + | | | CECR = 0x01c10f58. | + ----------------------------------------------------------------------- + | 3 | General push | Indicates that the s/w has to initialize | + | | command | some pointers in the Ethernet thread pages | + | | | which are used when Header Compression is | + | | | activated. The full details of these | + | | | pointers is located in the software drivers.| + ----------------------------------------------------------------------- + | 4 | General push | Indicates that after issuing Ethernet TX | + | | command | INIT command, user must issue this command | + | | | for each SNUM of Ethernet TX thread. | + | | | CECDR = 0x00800003. | + | | | CECR = 0x7'b{0}, 8'b{Enet TX thread SNUM}, | + | | | 1'b{1}, 12'b{0}, 4'b{1} | + ----------------------------------------------------------------------- + | 5 - 31 | N/A | Reserved, set to zero. | + ----------------------------------------------------------------------- + +V - Firmware Structure Layout +============================== + +QE microcode from Freescale is typically provided as a header file. This +header file contains macros that define the microcode binary itself as well as +some other data used in uploading that microcode. The format of these files +do not lend themselves to simple inclusion into other code. Hence, +the need for a more portable format. This section defines that format. + +Instead of distributing a header file, the microcode and related data are +embedded into a binary blob. This blob is passed to the qe_upload_firmware() +function, which parses the blob and performs everything necessary to upload +the microcode. + +All integers are big-endian. See the comments for function +qe_upload_firmware() for up-to-date implementation information. + +This structure supports versioning, where the version of the structure is +embedded into the structure itself. To ensure forward and backwards +compatibility, all versions of the structure must use the same 'qe_header' +structure at the beginning. + +'header' (type: struct qe_header): + The 'length' field is the size, in bytes, of the entire structure, + including all the microcode embedded in it, as well as the CRC (if + present). + + The 'magic' field is an array of three bytes that contains the letters + 'Q', 'E', and 'F'. This is an identifier that indicates that this + structure is a QE Firmware structure. + + The 'version' field is a single byte that indicates the version of this + structure. If the layout of the structure should ever need to be + changed to add support for additional types of microcode, then the + version number should also be changed. + +The 'id' field is a null-terminated string(suitable for printing) that +identifies the firmware. + +The 'count' field indicates the number of 'microcode' structures. There +must be one and only one 'microcode' structure for each RISC processor. +Therefore, this field also represents the number of RISC processors for this +SOC. + +The 'soc' structure contains the SOC numbers and revisions used to match +the microcode to the SOC itself. Normally, the microcode loader should +check the data in this structure with the SOC number and revisions, and +only upload the microcode if there's a match. However, this check is not +made on all platforms. + +Although it is not recommended, you can specify '0' in the soc.model +field to skip matching SOCs altogether. + +The 'model' field is a 16-bit number that matches the actual SOC. The +'major' and 'minor' fields are the major and minor revision numbrs, +respectively, of the SOC. + +For example, to match the 8323, revision 1.0: + soc.model = 8323 + soc.major = 1 + soc.minor = 0 + +'padding' is neccessary for structure alignment. This field ensures that the +'extended_modes' field is aligned on a 64-bit boundary. + +'extended_modes' is a bitfield that defines special functionality which has an +impact on the device drivers. Each bit has its own impact and has special +instructions for the driver associated with it. This field is stored in +the QE library and available to any driver that calles qe_get_firmware_info(). + +'vtraps' is an array of 8 words that contain virtual trap values for each +virtual traps. As with 'extended_modes', this field is stored in the QE +library and available to any driver that calles qe_get_firmware_info(). + +'microcode' (type: struct qe_microcode): + For each RISC processor there is one 'microcode' structure. The first + 'microcode' structure is for the first RISC, and so on. + + The 'id' field is a null-terminated string suitable for printing that + identifies this particular microcode. + + 'traps' is an array of 16 words that contain hardware trap values + for each of the 16 traps. If trap[i] is 0, then this particular + trap is to be ignored (i.e. not written to TIBCR[i]). The entire value + is written as-is to the TIBCR[i] register, so be sure to set the EN + and T_IBP bits if necessary. + + 'eccr' is the value to program into the ECCR register. + + 'iram_offset' is the offset into IRAM to start writing the + microcode. + + 'count' is the number of 32-bit words in the microcode. + + 'code_offset' is the offset, in bytes, from the beginning of this + structure where the microcode itself can be found. The first + microcode binary should be located immediately after the 'microcode' + array. + + 'major', 'minor', and 'revision' are the major, minor, and revision + version numbers, respectively, of the microcode. If all values are 0, + then these fields are ignored. + + 'reserved' is necessary for structure alignment. Since 'microcode' + is an array, the 64-bit 'extended_modes' field needs to be aligned + on a 64-bit boundary, and this can only happen if the size of + 'microcode' is a multiple of 8 bytes. To ensure that, we add + 'reserved'. + +After the last microcode is a 32-bit CRC. It can be calculated using +this algorithm: + +u32 crc32(const u8 *p, unsigned int len) +{ + unsigned int i; + u32 crc = 0; + + while (len--) { + crc ^= *p++; + for (i = 0; i < 8; i++) + crc = (crc >> 1) ^ ((crc & 1) ? 0xedb88320 : 0); + } + return crc; +} + +VI - Sample Code for Creating Firmware Files +============================================ + +A Python program that creates firmware binaries from the header files normally +distributed by Freescale can be found on http://opensource.freescale.com. diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 7559e92..04e81f9 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -21,6 +21,7 @@ */
#include "common.h" +#include <command.h> #include "asm/errno.h" #include "asm/io.h" #include "asm/immap_qe.h" @@ -248,4 +249,216 @@ int qe_set_mii_clk_src(int ucc_num) return 0; }
+/* The maximum number of RISCs we support */ +#define MAX_QE_RISC 2 + +/* Firmware information stored here for qe_get_firmware_info() */ +static struct qe_firmware_info qe_firmware_info; + +/* + * Upload a QE microcode + * + * This function is a worker function for qe_upload_firmware(). It does + * the actual uploading of the microcode. + */ +static void qe_upload_microcode(const void *base, + const struct qe_microcode *ucode) +{ + const u32 *code = base + be32_to_cpu(ucode->code_offset); + unsigned int i; + + if (ucode->major || ucode->minor || ucode->revision) + printf("QE: uploading microcode '%s' version %u.%u.%u\n", + ucode->id, ucode->major, ucode->minor, ucode->revision); + else + printf("QE: uploading microcode '%s'\n", ucode->id); + + /* Use auto-increment */ + out_be32(&qe_immr->iram.iadd, be32_to_cpu(ucode->iram_offset) | + QE_IRAM_IADD_AIE | QE_IRAM_IADD_BADDR); + + for (i = 0; i < be32_to_cpu(ucode->count); i++) + out_be32(&qe_immr->iram.idata, be32_to_cpu(code[i])); +} + +/* + * Upload a microcode to the I-RAM at a specific address. + * + * See Documentation/powerpc/qe-firmware.txt for information on QE microcode + * uploading. + * + * Currently, only version 1 is supported, so the 'version' field must be + * set to 1. + * + * The SOC model and revision are not validated, they are only displayed for + * informational purposes. + * + * 'calc_size' is the calculated size, in bytes, of the firmware structure and + * all of the microcode structures, minus the CRC. + * + * 'length' is the size that the structure says it is, including the CRC. + */ +int qe_upload_firmware(const struct qe_firmware *firmware) +{ + unsigned int i; + unsigned int j; + u32 crc; + size_t calc_size = sizeof(struct qe_firmware); + size_t length; + const struct qe_header *hdr; + + if (!firmware) { + printf("Invalid address\n"); + return -EINVAL; + } + + hdr = &firmware->header; + length = be32_to_cpu(hdr->length); + + /* Check the magic */ + if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || + (hdr->magic[2] != 'F')) { + printf("Not a microcode\n"); + return -EPERM; + } + + /* Check the version */ + if (hdr->version != 1) { + printf("Unsupported version\n"); + return -EPERM; + } + + /* Validate some of the fields */ + if ((firmware->count < 1) || (firmware->count >= MAX_QE_RISC)) { + printf("Invalid data\n"); + return -EINVAL; + } + + /* Validate the length and check if there's a CRC */ + calc_size += (firmware->count - 1) * sizeof(struct qe_microcode); + + for (i = 0; i < firmware->count; i++) + /* + * For situations where the second RISC uses the same microcode + * as the first, the 'code_offset' and 'count' fields will be + * zero, so it's okay to add those. + */ + calc_size += sizeof(u32) * + be32_to_cpu(firmware->microcode[i].count); + + /* Validate the length */ + if (length != calc_size + sizeof(u32)) { + printf("Invalid length\n"); + return -EPERM; + } + + /* + * Validate the CRC. We would normally call crc32_no_comp(), but that + * function isn't available unless you turn on JFFS support. + */ + crc = be32_to_cpu(*(u32 *)((void *)firmware + calc_size)); + if (crc != (crc32(-1, (const void *) firmware, calc_size) ^ -1)) { + printf("Firmware CRC is invalid\n"); + return -EIO; + } + + /* + * If the microcode calls for it, split the I-RAM. + */ + if (!firmware->split) { + out_be16(&qe_immr->cp.cercr, + in_be16(&qe_immr->cp.cercr) | QE_CP_CERCR_CIR); + } + + if (firmware->soc.model) + printf("Firmware '%s' for %u V%u.%u\n", + firmware->id, be16_to_cpu(firmware->soc.model), + firmware->soc.major, firmware->soc.minor); + else + printf("Firmware '%s'\n", firmware->id); + + /* + * The QE only supports one microcode per RISC, so clear out all the + * saved microcode information and put in the new. + */ + memset(&qe_firmware_info, 0, sizeof(qe_firmware_info)); + strcpy(qe_firmware_info.id, firmware->id); + qe_firmware_info.extended_modes = firmware->extended_modes; + memcpy(qe_firmware_info.vtraps, firmware->vtraps, + sizeof(firmware->vtraps)); + + /* Loop through each microcode. */ + for (i = 0; i < firmware->count; i++) { + const struct qe_microcode *ucode = &firmware->microcode[i]; + + /* Upload a microcode if it's present */ + if (ucode->code_offset) + qe_upload_microcode(firmware, ucode); + + /* Program the traps for this processor */ + for (j = 0; j < 16; j++) { + u32 trap = be32_to_cpu(ucode->traps[j]); + + if (trap) + out_be32(&qe_immr->rsp[i].tibcr[j], trap); + } + + /* Enable traps */ + out_be32(&qe_immr->rsp[i].eccr, be32_to_cpu(ucode->eccr)); + } + + return 0; +} + +struct qe_firmware_info *qe_get_firmware_info(void) +{ + return &qe_firmware_info; +} + +static int qe_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong addr; + + if (argc < 3) { + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + if (strcmp(argv[1], "fw") == 0) { + addr = simple_strtoul(argv[2], NULL, 16); + + if (!addr) { + printf("Invalid address\n"); + return -EINVAL; + } + + /* + * If a length was supplied, compare that with the 'length' + * field. + */ + + if (argc >= 3) { + ulong length = simple_strtoul(argv[3], NULL, 16); + struct qe_firmware *firmware = (void *) addr; + + if (length != be32_to_cpu(firmware->header.length)) { + printf("Invalid length\n"); + return -EINVAL; + } + } + + return qe_upload_firmware((const struct qe_firmware *) addr); + } + + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; +} + +U_BOOT_CMD( + qe, 4, 0, qe_cmd, + "qe - QUICC Engine commands\n", + "fw <addr> [<length>] - Upload firmware at address <addr>,\n" + "with optional length <length>\n" + ); + #endif /* CONFIG_QE */ diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index 400b1a6..4c96c67 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -222,6 +222,60 @@ typedef enum qe_clock {
#define QE_SDEBCR_BA_MASK 0x01FFFFFF
+/* Communication Processor */ +#define QE_CP_CERCR_MEE 0x8000 /* Multi-user RAM ECC enable */ +#define QE_CP_CERCR_IEE 0x4000 /* Instruction RAM ECC enable */ +#define QE_CP_CERCR_CIR 0x0800 /* Common instruction RAM */ + +/* I-RAM */ +#define QE_IRAM_IADD_AIE 0x80000000 /* Auto Increment Enable */ +#define QE_IRAM_IADD_BADDR 0x00080000 /* Base Address */ + +/* Structure that defines QE firmware binary files. + * + * See doc/README.qe_firmware for a description of these fields. + */ +struct qe_firmware { + struct qe_header { + u32 length; /* Length of the entire structure, in bytes */ + u8 magic[3]; /* Set to { 'Q', 'E', 'F' } */ + u8 version; /* Version of this layout. First ver is '1' */ + } header; + u8 id[62]; /* Null-terminated identifier string */ + u8 split; /* 0 = shared I-RAM, 1 = split I-RAM */ + u8 count; /* Number of microcode[] structures */ + struct { + u16 model; /* The SOC model */ + u8 major; /* The SOC revision major */ + u8 minor; /* The SOC revision minor */ + } __attribute__ ((packed)) soc; + u8 padding[4]; /* Reserved, for alignment */ + u64 extended_modes; /* Extended modes */ + u32 vtraps[8]; /* Virtual trap addresses */ + u8 reserved[4]; /* Reserved, for future expansion */ + struct qe_microcode { + u8 id[32]; /* Null-terminated identifier */ + u32 traps[16]; /* Trap addresses, 0 == ignore */ + u32 eccr; /* The value for the ECCR register */ + u32 iram_offset; /* Offset into I-RAM for the code */ + u32 count; /* Number of 32-bit words of the code */ + u32 code_offset; /* Offset of the actual microcode */ + u8 major; /* The microcode version major */ + u8 minor; /* The microcode version minor */ + u8 revision; /* The microcode version revision */ + u8 padding; /* Reserved, for alignment */ + u8 reserved[4]; /* Reserved, for future expansion */ + } __attribute__ ((packed)) microcode[1]; + /* All microcode binaries should be located here */ + /* CRC32 should be located here, after the microcode binaries */ +} __attribute__ ((packed)); + +struct qe_firmware_info { + char id[64]; /* Firmware name */ + u32 vtraps[8]; /* Virtual trap addresses */ + u64 extended_modes; /* Extended modes */ +}; + void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign); void qe_issue_cmd(uint cmd, uint sbc, u8 mcn, u32 cmd_data); uint qe_muram_alloc(uint size, uint align); @@ -233,5 +287,7 @@ void qe_reset(void); void qe_assign_page(uint snum, uint para_ram_base); int qe_set_brg(uint brg, uint rate); int qe_set_mii_clk_src(int ucc_num); +int qe_upload_firmware(const struct qe_firmware *firmware); +struct qe_firmware_info *qe_get_firmware_info(void);
#endif /* __QE_H__ */ diff --git a/include/asm-ppc/immap_qe.h b/include/asm-ppc/immap_qe.h index a16a6d3..bec54aa 100644 --- a/include/asm-ppc/immap_qe.h +++ b/include/asm-ppc/immap_qe.h @@ -513,10 +513,39 @@ typedef struct dbg { u8 res2[0x48]; } __attribute__ ((packed)) dbg_t;
-/* RISC Special Registers (Trap and Breakpoint) -*/ +/* + * RISC Special Registers (Trap and Breakpoint). These are described in + * the QE Developer's Handbook. + */ typedef struct rsp { - u8 fixme[0x100]; + u32 tibcr[16]; /* Trap/instruction breakpoint control regs */ + u8 res0[64]; + u32 ibcr0; + u32 ibs0; + u32 ibcnr0; + u8 res1[4]; + u32 ibcr1; + u32 ibs1; + u32 ibcnr1; + u32 npcr; + u32 dbcr; + u32 dbar; + u32 dbamr; + u32 dbsr; + u32 dbcnr; + u8 res2[12]; + u32 dbdr_h; + u32 dbdr_l; + u32 dbdmr_h; + u32 dbdmr_l; + u32 bsr; + u32 bor; + u32 bior; + u8 res3[4]; + u32 iatr[4]; + u32 eccr; /* Exception control configuration register */ + u32 eicr; + u8 res4[0x100-0xf8]; } __attribute__ ((packed)) rsp_t;
typedef struct qe_immap {
doc/README.qe_firmware | 295 +++++++++++++++++++++++++++++++++++ +++++++++ drivers/qe/qe.c | 213 ++++++++++++++++++++++++++++++++ drivers/qe/qe.h | 56 +++++++++ include/asm-ppc/immap_qe.h | 35 +++++- 4 files changed, 596 insertions(+), 3 deletions(-) create mode 100644 doc/README.qe_firmware
- ulong addr;
- if (argc < 3) {
return 1;
- if (strcmp(argv[1], "fw") == 0) {
if (!addr) {
return -EINVAL;
'length'
* field.
if (argc >= 3) {
return -EINVAL;
- printf ("Usage:\n%s\n", cmdtp->usage);
- return 1;
+U_BOOT_CMD(
- qe, 4, 0, qe_cmd,
- "qe - QUICC Engine commands\n",
- "fw <addr> [<length>] - Upload firmware at address <addr>,\n"
I'm at a loss, why have length at all? You seem to always take it from firmware->header.length.
Also can we be more explicit in the help with 'Upload firmware'.. to 'Upload microcode firmware to QE' or something like that.
- k
Kumar Gala wrote:
+U_BOOT_CMD(
- qe, 4, 0, qe_cmd,
It's optional. If you specify the length, it will validate that against header.length. That's so that you can do this:
tftp $loadaddr $firmware qe fw $loadaddr $filesize
If the length doesn't match, then it doesn't bother trying to parse the rest of the image.
The Linux version of this code does the same thing, but it's probably more useful since drivers will use request_firmware() which returns a length.
Granted, the CRC check is more bullet-proof.
Sure. New patch coming.
On Nov 30, 2007, at 4:34 PM, Timur Tabi wrote:
Kumar Gala wrote:
+U_BOOT_CMD(
- qe, 4, 0, qe_cmd,
It seems like a silly check if there is already a CRC check.
- k
Kumar Gala
Timur Tabi
