[PATCH] drivers: usb: Fix config indentation
The indentation was messing up with the scripts/build-whitelist.sh that was marking SYS_USB_EVENT_POLL_VIA_INT_QUEUE (and probably also the other indented options) erroneously as ad-hoc configure option with the following error:
``` Error: You must add new CONFIG options using Kconfig The following new ad-hoc CONFIG options were detected: CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE ``` --- drivers/usb/Kconfig | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 756a4ec402..34881a12b8 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -113,14 +113,14 @@ choice ---help--- Enable a polling mechanism for USB keyboard.
- config SYS_USB_EVENT_POLL - bool "Interrupt polling" +config SYS_USB_EVENT_POLL + bool "Interrupt polling"
- config SYS_USB_EVENT_POLL_VIA_INT_QUEUE - bool "Poll via interrupt queue" +config SYS_USB_EVENT_POLL_VIA_INT_QUEUE + bool "Poll via interrupt queue"
- config SYS_USB_EVENT_POLL_VIA_CONTROL_EP - bool "Poll via control EP" +config SYS_USB_EVENT_POLL_VIA_CONTROL_EP + bool "Poll via control EP"
endchoice
Ruben Di Battista
