[U-Boot] [PATCH 1/3] powerpc/85xx: Enable eSPI controller & SPI bootsupport on P2020DS
Signed-off-by: Jerry Huang Chang-Ming.Huang@freescale.com Signed-off-by: Zhao Chenhui b35336@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- boards.cfg | 1 + include/configs/P2020DS.h | 28 ++++++++++++++++++++++++++++ 2 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/boards.cfg b/boards.cfg index be5f83d..39f15f6 100644 --- a/boards.cfg +++ b/boards.cfg @@ -537,6 +537,7 @@ P2020DS powerpc mpc85xx p2020ds freesca P2020DS_36BIT powerpc mpc85xx p2020ds freescale - P2020DS:36BIT P2020DS_DDR2 powerpc mpc85xx p2020ds freescale - P2020DS:DDR2 P2020DS_SDCARD powerpc mpc85xx p2020ds freescale - P2020DS:SDCARD +P2020DS_SPIFLASH powerpc mpc85xx p2020ds freescale - P2020DS:SPIFLASH P2020RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB P2020RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT P2020RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT,SDCARD diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 47f1f18..cee9fd4 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -40,6 +40,13 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xf8fffffc #endif
+#ifdef CONFIG_SPIFLASH +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_SYS_TEXT_BASE 0xf8f80000 +#define CONFIG_RESET_VECTOR_ADDRESS 0xf8fffffc +#endif + /* High Level Configuration Options */ #define CONFIG_BOOKE 1 /* BOOKE */ #define CONFIG_E500 1 /* BOOKE e500 family */ @@ -418,6 +425,18 @@ #define CONFIG_SYS_EEPROM_BUS_NUM 0
/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI + +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION + +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + +/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ @@ -594,6 +613,15 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_SPIFLASH) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 #else #define CONFIG_ENV_IS_IN_FLASH 1 #if CONFIG_SYS_MONITOR_BASE > 0xfff80000
Also added support to save env to spi flash in case of SPIBOOT.
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/P1_P2_RDB.h | 18 ++++++++++++++++-- 1 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 449329a..9249e37 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -411,6 +411,15 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_RTC_DS1337 #define CONFIG_SYS_RTC_DS1337_NOOSC #define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/* eSPI - Enhanced SPI */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + /* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. @@ -527,8 +536,13 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #elif defined(CONFIG_RAMBOOT_SPIFLASH) - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) + #define CONFIG_ENV_IS_IN_SPI_FLASH + #define CONFIG_ENV_SPI_BUS 0 + #define CONFIG_ENV_SPI_CS 0 + #define CONFIG_ENV_SPI_MAX_HZ 10000000 + #define CONFIG_ENV_SPI_MODE 0 + #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ + #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 #endif #else
Signed-off-by: Jiang Yutang b14898@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/p1022ds/p1022ds.c | 3 +++ include/configs/P1022DS.h | 15 +++++++++++++++ 2 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 73a1021..8ef627f 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -46,6 +46,9 @@ int board_early_init_f(void) /* Set the pin muxing to enable ETSEC2. */ clrbits_be32(&gur->pmuxcr2, 0x001F8000);
+ /* Enable the SPI */ + clrsetbits_8(&pixis->brdcfg0, PIXIS_ELBC_SPI_MASK, PIXIS_SPI); + return 0; }
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index fb2a41c..593efd5 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -170,6 +170,8 @@ #define PIXIS_LBMAP_SWITCH 7 #define PIXIS_LBMAP_MASK 0xF0 #define PIXIS_LBMAP_ALTBANK 0x20 +#define PIXIS_ELBC_SPI_MASK 0xc0 +#define PIXIS_SPI 0x80
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ @@ -267,6 +269,19 @@ #define CONFIG_SYS_EEPROM_BUS_NUM 1
/* + * eSPI - Enhanced SPI + */ +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION + +#define CONFIG_HARD_SPI +#define CONFIG_FSL_ESPI + +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */
applied to 85xx
- k
applied to 85xx
- k
On Thu, 21 Apr 2011 13:54:01 -0500 Kumar Gala galak@kernel.crashing.org wrote:
36BIT+SPIFLASH?
If it's not working, perhaps a comment about it?
-Scott
applied to 85xx
- k
Kumar Gala
Scott Wood
