[PATCH 0/2 V2] RGXX3: Set boot order for mmc0 first
Set the rgxx3 device to boot from mmc0 first. This serves as a fallback to allow us to recover from a bad U-Boot (or later) stage in a worst case scenario. The code for an ADC button appears to have broke some board revisions; this solution is much simpler and allows users to continue to program the adc button as they see fit.
Changes from V1: - Removed sdmmc1, as long as we have sdmmc0 we should be safe. - Clarified that the expectation is that we can prevent a bad U-Boot stage with a valid FIT signature by looking at removable storage first.
Chris Morgan (2): Revert "board: rockchip: Add early ADC button detect for RGxx3" board: rockchip: rgxx3: Use sdmmc0 as first device
.../arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 2 +- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 64 ------------------- 2 files changed, 1 insertion(+), 65 deletions(-)
This reverts commit 41a60d0e5cef54a59596a58940fa7c9cf071034b.
On some of the supported devices the adc detect code always returns that the button has been pushed, and as a result the device will not boot normally.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 64 ---------------------- 1 file changed, 64 deletions(-)
diff --git a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c index 099eea60c3..5c57b902d1 100644 --- a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c +++ b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c @@ -6,14 +6,12 @@ #include <abuf.h> #include <adc.h> #include <asm/io.h> -#include <command.h> #include <display.h> #include <dm.h> #include <dm/lists.h> #include <env.h> #include <fdt_support.h> #include <linux/delay.h> -#include <linux/iopoll.h> #include <mipi_dsi.h> #include <mmc.h> #include <panel.h> @@ -21,8 +19,6 @@ #include <stdlib.h> #include <video_bridge.h>
-#define BOOT_BROM_DOWNLOAD 0xef08a53c - #define GPIO0_BASE 0xfdd60000 #define GPIO4_BASE 0xfe770000 #define GPIO_SWPORT_DR_L 0x0000 @@ -36,14 +32,6 @@
#define GPIO_WRITEMASK(bits) ((bits) << 16)
-#define SARADC_BASE 0xfe720000 -#define SARADC_DATA 0x0000 -#define SARADC_STAS 0x0004 -#define SARADC_ADC_STATUS BIT(0) -#define SARADC_CTRL 0x0008 -#define SARADC_INPUT_SRC_MSK 0x7 -#define SARADC_POWER_CTRL BIT(3) - #define DTB_DIR "rockchip/"
struct rg3xx_model { @@ -169,64 +157,12 @@ static const struct rg353_panel rg353_panel_details[] = { }, };
-/* - * The device has internal eMMC, and while some devices have an exposed - * clk pin you can ground to force a bypass not all devices do. As a - * result it may be possible for some devices to become a perma-brick - * if a corrupted TPL or SPL stage with a valid header is flashed to - * the internal eMMC. Add functionality to read ADC channel 0 (the func - * button) as early as possible in the boot process to provide some - * protection against this. If we ever get an open TPL stage, we should - * consider moving this function there. - */ -void read_func_button(void) -{ - int ret; - u32 reg; - - /* Turn off SARADC to reset it. */ - writel(0, (SARADC_BASE + SARADC_CTRL)); - - /* Enable channel 0 and power on SARADC. */ - writel(((0 & SARADC_INPUT_SRC_MSK) | SARADC_POWER_CTRL), - (SARADC_BASE + SARADC_CTRL)); - - /* - * Wait for data to be ready. Use timeout of 20000us from - * rockchip_saradc driver. - */ - ret = readl_poll_timeout((SARADC_BASE + SARADC_STAS), reg, - !(reg & SARADC_ADC_STATUS), 20000); - if (ret) { - printf("ADC Timeout"); - return; - } - - /* Read the data from the SARADC. */ - reg = readl((SARADC_BASE + SARADC_DATA)); - - /* Turn the SARADC back off so it's ready to be used again. */ - writel(0, (SARADC_BASE + SARADC_CTRL)); - - /* - * If the value is less than 30 the button is being pressed. - * Reset the device back into Rockchip download mode. - */ - if (reg <= 30) { - printf("download key pressed, entering download mode..."); - writel(BOOT_BROM_DOWNLOAD, CONFIG_ROCKCHIP_BOOT_MODE_REG); - do_reset(NULL, 0, 0, NULL); - } -}; - /* * Start LED very early so user knows device is on. Set color * to red. */ void spl_board_init(void) { - read_func_button(); - /* Set GPIO0_C5, GPIO0_C6, and GPIO0_C7 to output. */ writel(GPIO_WRITEMASK(GPIO_C7 | GPIO_C6 | GPIO_C5) | \ (GPIO_C7 | GPIO_C6 | GPIO_C5),
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
@@ -36,14 +32,6 @@
- The device has internal eMMC, and while some devices have an exposed
- clk pin you can ground to force a bypass not all devices do. As a
- result it may be possible for some devices to become a perma-brick
- if a corrupted TPL or SPL stage with a valid header is flashed to
- the internal eMMC. Add functionality to read ADC channel 0 (the func
- button) as early as possible in the boot process to provide some
- protection against this. If we ever get an open TPL stage, we should
- consider moving this function there.
- int ret;
- u32 reg;
- if (ret) {
return;
- if (reg <= 30) {
- Start LED very early so user knows device is on. Set color
- to red.
Have you check the key input voltage with voltameter which can identify is hardware issue or software issue.
Thanks,
- Kever
Signed-off-by: Chris Morganmacromorgan@hotmail.com
@@ -36,14 +32,6 @@
- int ret;
- u32 reg;
- if (ret) {
return;
- if (reg <= 30) {
- to red.
It's a software issue. I confirmed I actually could have fixed it by using the ADC driver (which sets up the interrupt registers correctly). However, there is something to be said of keeping things simple. I should have taken your advice from the get-go and just done that.
Thank you. Chris
Thanks,
- Kever
diff --git a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c index 099eea60c3..5c57b902d1 100644 --- a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c +++ b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c @@ -6,14 +6,12 @@ #include <abuf.h> #include <adc.h> #include <asm/io.h> -#include <command.h> #include <display.h> #include <dm.h> #include <dm/lists.h> #include <env.h> #include <fdt_support.h> #include <linux/delay.h> -#include <linux/iopoll.h> #include <mipi_dsi.h> #include <mmc.h> #include <panel.h> @@ -21,8 +19,6 @@ #include <stdlib.h> #include <video_bridge.h> -#define BOOT_BROM_DOWNLOAD 0xef08a53c
@@ -36,14 +32,6 @@ #define GPIO_WRITEMASK(bits) ((bits) << 16) -#define SARADC_BASE 0xfe720000 -#define SARADC_DATA 0x0000 -#define SARADC_STAS 0x0004 -#define SARADC_ADC_STATUS BIT(0) -#define SARADC_CTRL 0x0008 -#define SARADC_INPUT_SRC_MSK 0x7 -#define SARADC_POWER_CTRL BIT(3)
- #define DTB_DIR "rockchip/" struct rg3xx_model {
@@ -169,64 +157,12 @@ static const struct rg353_panel rg353_panel_details[] = { }, }; -/*
- int ret;
- u32 reg;
- if (ret) {
return;
- if (reg <= 30) {
- to red.
Some of the rgxx3 devices do not have a way to recover from a poor flash of a bootloader to eMMC. Set the device to always attempt to boot from sdmmc0 first which ensures that we can override the boot from emmc if we have a card present with a valid fit signature. The expectation is that this will protect from the very unlikely chance we have a valid FIT signature on the eMMC but the U-Boot stage fails for some other reason.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi index 793ed4ae8a..c7e849816a 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi +++ b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi @@ -4,7 +4,7 @@
/ { chosen { - u-boot,spl-boot-order = "same-as-spl", &sdmmc1, &sdmmc0; + u-boot,spl-boot-order = &sdmmc0, &sdhci; }; };
Thanks, - Kever
/ { chosen {
}; };u-boot,spl-boot-order = &sdmmc0, &sdhci;
Chris Morgan
Chris Morgan
Kever Yang
