[U-Boot] [PATCH][v2] fsl/usb: Limit phy_type comparison to first four characters
Use first four characters for phy_type comparison. Strcmp() should not be used to check the phy_type string which maybe parsed by hwconfig_subarg(). Hwconfig_subarg() returns part of hwconfig string starting from phy_type value till the end of the string. Since phy_type could be either "utmi" or "ulpi", strncmp() should be used so that a comparison of "utmi;fsl_ddr:bank_intlv=auto" with "utmi" will succeed.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Nikhil Badola nikhil.badola@freescale.com --- Changes for v2: - Changed patch heading - Changed patch commit message
drivers/usb/host/ehci-fsl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 45e5d6a..1ca7cf5 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -86,7 +86,7 @@ int ehci_hcd_init(int index, enum usb_init_type init, #endif }
- if (!strcmp(phy_type, "utmi")) { + if (!strncmp(phy_type, "utmi", 4)) { #if defined(CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY) setbits_be32(&ehci->control, PHY_CLK_SEL_UTMI); setbits_be32(&ehci->control, UTMI_PHY_EN);
Changes for v2:
Applied to u-boot-mpc85xx/master. Thanks.
York
Nikhil Badola
York Sun
