[PATCH] arm64: xilinx: dts: Add dma properties to fix dtbs_check warnings
Update dma name and add #dma-cells properties to fix dtbs_check warnings.
Signed-off-by: Shravya Kumbham shravya.kumbham@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp.dtsi | 48 ++++++++++++++++++++++++++-------------- 1 file changed, 32 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 1331cec36f34..755a4ed2e515 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -265,7 +265,7 @@ };
/* GDMA */ - fpd_dma_chan1: dma@fd500000 { + fpd_dma_chan1: dma-controller@fd500000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd500000 0x0 0x1000>; @@ -276,9 +276,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14e8>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan2: dma@fd510000 { + fpd_dma_chan2: dma-controller@fd510000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd510000 0x0 0x1000>; @@ -289,9 +290,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14e9>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan3: dma@fd520000 { + fpd_dma_chan3: dma-controller@fd520000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd520000 0x0 0x1000>; @@ -302,9 +304,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14ea>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan4: dma@fd530000 { + fpd_dma_chan4: dma-controller@fd530000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd530000 0x0 0x1000>; @@ -315,9 +318,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14eb>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan5: dma@fd540000 { + fpd_dma_chan5: dma-controller@fd540000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd540000 0x0 0x1000>; @@ -328,9 +332,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14ec>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan6: dma@fd550000 { + fpd_dma_chan6: dma-controller@fd550000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd550000 0x0 0x1000>; @@ -341,9 +346,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14ed>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan7: dma@fd560000 { + fpd_dma_chan7: dma-controller@fd560000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd560000 0x0 0x1000>; @@ -354,9 +360,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14ee>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
- fpd_dma_chan8: dma@fd570000 { + fpd_dma_chan8: dma-controller@fd570000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xfd570000 0x0 0x1000>; @@ -367,6 +374,7 @@ #stream-id-cells = <1>; iommus = <&smmu 0x14ef>; power-domains = <&zynqmp_firmware PD_GDMA>; + #dma-cells = <1>; };
gic: interrupt-controller@f9010000 { @@ -396,7 +404,7 @@ * These dma channels, Users should ensure that these dma * Channels are allowed for non secure access. */ - lpd_dma_chan1: dma@ffa80000 { + lpd_dma_chan1: dma-controller@ffa80000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffa80000 0x0 0x1000>; @@ -407,9 +415,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x868>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan2: dma@ffa90000 { + lpd_dma_chan2: dma-controller@ffa90000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffa90000 0x0 0x1000>; @@ -420,9 +429,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x869>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan3: dma@ffaa0000 { + lpd_dma_chan3: dma-controller@ffaa0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffaa0000 0x0 0x1000>; @@ -433,9 +443,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86a>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan4: dma@ffab0000 { + lpd_dma_chan4: dma-controller@ffab0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffab0000 0x0 0x1000>; @@ -446,9 +457,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86b>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan5: dma@ffac0000 { + lpd_dma_chan5: dma-controller@ffac0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffac0000 0x0 0x1000>; @@ -459,9 +471,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86c>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan6: dma@ffad0000 { + lpd_dma_chan6: dma-controller@ffad0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffad0000 0x0 0x1000>; @@ -472,9 +485,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86d>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan7: dma@ffae0000 { + lpd_dma_chan7: dma-controller@ffae0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffae0000 0x0 0x1000>; @@ -485,9 +499,10 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86e>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
- lpd_dma_chan8: dma@ffaf0000 { + lpd_dma_chan8: dma-controller@ffaf0000 { status = "disabled"; compatible = "xlnx,zynqmp-dma-1.0"; reg = <0x0 0xffaf0000 0x0 0x1000>; @@ -498,6 +513,7 @@ #stream-id-cells = <1>; iommus = <&smmu 0x86f>; power-domains = <&zynqmp_firmware PD_ADMA>; + #dma-cells = <1>; };
mc: memory-controller@fd070000 {
pá 14. 1. 2022 v 12:44 odesílatel Michal Simek michal.simek@xilinx.com napsal:
/* GDMA */
#dma-cells = <1>; }; gic: interrupt-controller@f9010000 {
#dma-cells = <1>; }; mc: memory-controller@fd070000 {
-- 2.34.1
Applied. M
Michal Simek
Michal Simek
