[U-Boot] [PATCH] ATMEL (AT91): Fix compile errors for at91sam9m10g45 Eval Kit
Subject: [PATCH] ATMEL: Fix compile errors for at91sam9m10g45 Eval Kit
This patch fixes numerous compile errors for the at91sam9m10g45 Eval Kit. Also implements some dummy functions for the timer code to allow final linking. Finally, this patch also adds this board to the boards.cfg file.
Signed-off-by: Alex Waterman awaterman@dawning.com --- .../cpu/arm926ejs/at91/at91sam9m10g45_devices.c | 26 +++--- arch/arm/cpu/arm926ejs/at91/clock.c | 2 +- arch/arm/cpu/arm926ejs/at91/timer.c | 13 +++ .../arm/include/asm/arch-at91/at91sam9g45_matrix.h | 84 ++++++++++---------- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 58 ++++++++------ board/atmel/at91sam9m10g45ek/led.c | 6 +- boards.cfg | 1 + include/configs/at91sam9m10g45ek.h | 39 ++++++--- 8 files changed, 134 insertions(+), 95 deletions(-)
It looks like recent patch submissions probably have a lot of overlapping fixes with this patch. Those patches (Asen Chavdarov Dimov's reworks for instance) seem more generic though. Since this board is scheduled or deletion I would really like to at least get this board back to non-deletion status but ideally I would want to wait for those generic patches to go through before I submit a real patch to fix this board. If those generic patches are not committed before release, can this board be put on hold for deletion?
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c index 4ad9b1f..08b961f 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9m10g45_devices.c @@ -26,42 +26,42 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> +#include <asm/io.h>
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 19, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTB, 18, 0); /* RXD0 */ - writel(1 << AT91SAM9G45_ID_US0, &pmc->pcer); + writel(1 << ATMEL_ID_USART0, &pmc->pcer); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 5, 0); /* RXD1 */ - writel(1 << AT91SAM9G45_ID_US1, &pmc->pcer); + writel(1 << ATMEL_ID_USART1, &pmc->pcer); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 6, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 7, 0); /* RXD2 */ - writel(1 << AT91SAM9G45_ID_US2, &pmc->pcer); + writel(1 << ATMEL_ID_USART2, &pmc->pcer); }
void at91_serial3_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTB, 13, 1); /* DTXD */ - writel(1 << AT91_ID_SYS, &pmc->pcer); + writel(1 << ATMEL_ID_SYS, &pmc->pcer); }
void at91_serial_hw_init(void) @@ -86,14 +86,14 @@ void at91_serial_hw_init(void) #ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 0, 0); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* SPI0_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI0, &pmc->pcer); + writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 3, 0); @@ -123,14 +123,14 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 15, 0); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 16, 0); /* SPI1_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9G45_ID_SPI1, &pmc->pcer); + writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 17, 0); diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index 608af2c..0081ed7 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -57,7 +57,7 @@ static unsigned long at91_css_to_rate(unsigned long css) { switch (css) { case AT91_PMC_MCKR_CSS_SLOW: - return CONFIG_SYS_AT91_SLOW_CLOCK; + return AT91_SLOW_CLOCK; case AT91_PMC_MCKR_CSS_MAIN: return gd->main_clk_rate_hz; case AT91_PMC_MCKR_CSS_PLLA: diff --git a/arch/arm/cpu/arm926ejs/at91/timer.c b/arch/arm/cpu/arm926ejs/at91/timer.c index a087687..89a01ea 100644 --- a/arch/arm/cpu/arm926ejs/at91/timer.c +++ b/arch/arm/cpu/arm926ejs/at91/timer.c @@ -134,3 +134,16 @@ ulong get_tbclk(void) { return gd->timer_rate_hz; } + +/* + * Reset the timer. + */ +void reset_timer(void) +{ + /* TODO: write this code. */ +} + +void reset_timer_masked(void) +{ + /* TODO: write this code. */ +} diff --git a/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h b/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h index 1620e1b..9808e38 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h +++ b/arch/arm/include/asm/arch-at91/at91sam9g45_matrix.h @@ -15,18 +15,18 @@ #ifndef AT91SAM9G45_MATRIX_H #define AT91SAM9G45_MATRIX_H
-#define AT91_MATRIX_MCFG0 (AT91_MATRIX + 0x00) /* Master Configuration Register 0 */ -#define AT91_MATRIX_MCFG1 (AT91_MATRIX + 0x04) /* Master Configuration Register 1 */ -#define AT91_MATRIX_MCFG2 (AT91_MATRIX + 0x08) /* Master Configuration Register 2 */ -#define AT91_MATRIX_MCFG3 (AT91_MATRIX + 0x0C) /* Master Configuration Register 3 */ -#define AT91_MATRIX_MCFG4 (AT91_MATRIX + 0x10) /* Master Configuration Register 4 */ -#define AT91_MATRIX_MCFG5 (AT91_MATRIX + 0x14) /* Master Configuration Register 5 */ -#define AT91_MATRIX_MCFG6 (AT91_MATRIX + 0x18) /* Master Configuration Register 6 */ -#define AT91_MATRIX_MCFG7 (AT91_MATRIX + 0x1C) /* Master Configuration Register 7 */ -#define AT91_MATRIX_MCFG8 (AT91_MATRIX + 0x20) /* Master Configuration Register 8 */ -#define AT91_MATRIX_MCFG9 (AT91_MATRIX + 0x24) /* Master Configuration Register 9 */ -#define AT91_MATRIX_MCFG10 (AT91_MATRIX + 0x28) /* Master Configuration Register 10 */ -#define AT91_MATRIX_MCFG11 (AT91_MATRIX + 0x2C) /* Master Configuration Register 11 */ +#define AT91_MATRIX_MCFG0 (ATMEL_BASE_MATRIX + 0x00) /* Master Configuration Register 0 */ +#define AT91_MATRIX_MCFG1 (ATMEL_BASE_MATRIX + 0x04) /* Master Configuration Register 1 */ +#define AT91_MATRIX_MCFG2 (ATMEL_BASE_MATRIX + 0x08) /* Master Configuration Register 2 */ +#define AT91_MATRIX_MCFG3 (ATMEL_BASE_MATRIX + 0x0C) /* Master Configuration Register 3 */ +#define AT91_MATRIX_MCFG4 (ATMEL_BASE_MATRIX + 0x10) /* Master Configuration Register 4 */ +#define AT91_MATRIX_MCFG5 (ATMEL_BASE_MATRIX + 0x14) /* Master Configuration Register 5 */ +#define AT91_MATRIX_MCFG6 (ATMEL_BASE_MATRIX + 0x18) /* Master Configuration Register 6 */ +#define AT91_MATRIX_MCFG7 (ATMEL_BASE_MATRIX + 0x1C) /* Master Configuration Register 7 */ +#define AT91_MATRIX_MCFG8 (ATMEL_BASE_MATRIX + 0x20) /* Master Configuration Register 8 */ +#define AT91_MATRIX_MCFG9 (ATMEL_BASE_MATRIX + 0x24) /* Master Configuration Register 9 */ +#define AT91_MATRIX_MCFG10 (ATMEL_BASE_MATRIX + 0x28) /* Master Configuration Register 10 */ +#define AT91_MATRIX_MCFG11 (ATMEL_BASE_MATRIX + 0x2C) /* Master Configuration Register 11 */ #define AT91_MATRIX_ULBT (7 << 0) /* Undefined Length Burst Type */ #define AT91_MATRIX_ULBT_INFINITE (0 << 0) #define AT91_MATRIX_ULBT_SINGLE (1 << 0) @@ -37,14 +37,14 @@ #define AT91_MATRIX_ULBT_SIXTYFOUR (6 << 0) #define AT91_MATRIX_ULBT_128 (7 << 0)
-#define AT91_MATRIX_SCFG0 (AT91_MATRIX + 0x40) /* Slave Configuration Register 0 */ -#define AT91_MATRIX_SCFG1 (AT91_MATRIX + 0x44) /* Slave Configuration Register 1 */ -#define AT91_MATRIX_SCFG2 (AT91_MATRIX + 0x48) /* Slave Configuration Register 2 */ -#define AT91_MATRIX_SCFG3 (AT91_MATRIX + 0x4C) /* Slave Configuration Register 3 */ -#define AT91_MATRIX_SCFG4 (AT91_MATRIX + 0x50) /* Slave Configuration Register 4 */ -#define AT91_MATRIX_SCFG5 (AT91_MATRIX + 0x54) /* Slave Configuration Register 5 */ -#define AT91_MATRIX_SCFG6 (AT91_MATRIX + 0x58) /* Slave Configuration Register 6 */ -#define AT91_MATRIX_SCFG7 (AT91_MATRIX + 0x5C) /* Slave Configuration Register 7 */ +#define AT91_MATRIX_SCFG0 (ATMEL_BASE_MATRIX + 0x40) /* Slave Configuration Register 0 */ +#define AT91_MATRIX_SCFG1 (ATMEL_BASE_MATRIX + 0x44) /* Slave Configuration Register 1 */ +#define AT91_MATRIX_SCFG2 (ATMEL_BASE_MATRIX + 0x48) /* Slave Configuration Register 2 */ +#define AT91_MATRIX_SCFG3 (ATMEL_BASE_MATRIX + 0x4C) /* Slave Configuration Register 3 */ +#define AT91_MATRIX_SCFG4 (ATMEL_BASE_MATRIX + 0x50) /* Slave Configuration Register 4 */ +#define AT91_MATRIX_SCFG5 (ATMEL_BASE_MATRIX + 0x54) /* Slave Configuration Register 5 */ +#define AT91_MATRIX_SCFG6 (ATMEL_BASE_MATRIX + 0x58) /* Slave Configuration Register 6 */ +#define AT91_MATRIX_SCFG7 (ATMEL_BASE_MATRIX + 0x5C) /* Slave Configuration Register 7 */ #define AT91_MATRIX_SLOT_CYCLE (0x1ff << 0) /* Maximum Number of Allowed Cycles for a Burst */ #define AT91_MATRIX_DEFMSTR_TYPE (3 << 16) /* Default Master Type */ #define AT91_MATRIX_DEFMSTR_TYPE_NONE (0 << 16) @@ -52,22 +52,22 @@ #define AT91_MATRIX_DEFMSTR_TYPE_FIXED (2 << 16) #define AT91_MATRIX_FIXED_DEFMSTR (0xf << 18) /* Fixed Index of Default Master */
-#define AT91_MATRIX_PRAS0 (AT91_MATRIX + 0x80) /* Priority Register A for Slave 0 */ -#define AT91_MATRIX_PRBS0 (AT91_MATRIX + 0x84) /* Priority Register B for Slave 0 */ -#define AT91_MATRIX_PRAS1 (AT91_MATRIX + 0x88) /* Priority Register A for Slave 1 */ -#define AT91_MATRIX_PRBS1 (AT91_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ -#define AT91_MATRIX_PRAS2 (AT91_MATRIX + 0x90) /* Priority Register A for Slave 2 */ -#define AT91_MATRIX_PRBS2 (AT91_MATRIX + 0x94) /* Priority Register B for Slave 2 */ -#define AT91_MATRIX_PRAS3 (AT91_MATRIX + 0x98) /* Priority Register A for Slave 3 */ -#define AT91_MATRIX_PRBS3 (AT91_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ -#define AT91_MATRIX_PRAS4 (AT91_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ -#define AT91_MATRIX_PRBS4 (AT91_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ -#define AT91_MATRIX_PRAS5 (AT91_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ -#define AT91_MATRIX_PRBS5 (AT91_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ -#define AT91_MATRIX_PRAS6 (AT91_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ -#define AT91_MATRIX_PRBS6 (AT91_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ -#define AT91_MATRIX_PRAS7 (AT91_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ -#define AT91_MATRIX_PRBS7 (AT91_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ +#define AT91_MATRIX_PRAS0 (ATMEL_BASE_MATRIX + 0x80) /* Priority Register A for Slave 0 */ +#define AT91_MATRIX_PRBS0 (ATMEL_BASE_MATRIX + 0x84) /* Priority Register B for Slave 0 */ +#define AT91_MATRIX_PRAS1 (ATMEL_BASE_MATRIX + 0x88) /* Priority Register A for Slave 1 */ +#define AT91_MATRIX_PRBS1 (ATMEL_BASE_MATRIX + 0x8C) /* Priority Register B for Slave 1 */ +#define AT91_MATRIX_PRAS2 (ATMEL_BASE_MATRIX + 0x90) /* Priority Register A for Slave 2 */ +#define AT91_MATRIX_PRBS2 (ATMEL_BASE_MATRIX + 0x94) /* Priority Register B for Slave 2 */ +#define AT91_MATRIX_PRAS3 (ATMEL_BASE_MATRIX + 0x98) /* Priority Register A for Slave 3 */ +#define AT91_MATRIX_PRBS3 (ATMEL_BASE_MATRIX + 0x9C) /* Priority Register B for Slave 3 */ +#define AT91_MATRIX_PRAS4 (ATMEL_BASE_MATRIX + 0xA0) /* Priority Register A for Slave 4 */ +#define AT91_MATRIX_PRBS4 (ATMEL_BASE_MATRIX + 0xA4) /* Priority Register B for Slave 4 */ +#define AT91_MATRIX_PRAS5 (ATMEL_BASE_MATRIX + 0xA8) /* Priority Register A for Slave 5 */ +#define AT91_MATRIX_PRBS5 (ATMEL_BASE_MATRIX + 0xAC) /* Priority Register B for Slave 5 */ +#define AT91_MATRIX_PRAS6 (ATMEL_BASE_MATRIX + 0xB0) /* Priority Register A for Slave 6 */ +#define AT91_MATRIX_PRBS6 (ATMEL_BASE_MATRIX + 0xB4) /* Priority Register B for Slave 6 */ +#define AT91_MATRIX_PRAS7 (ATMEL_BASE_MATRIX + 0xB8) /* Priority Register A for Slave 7 */ +#define AT91_MATRIX_PRBS7 (ATMEL_BASE_MATRIX + 0xBC) /* Priority Register B for Slave 7 */ #define AT91_MATRIX_M0PR (3 << 0) /* Master 0 Priority */ #define AT91_MATRIX_M1PR (3 << 4) /* Master 1 Priority */ #define AT91_MATRIX_M2PR (3 << 8) /* Master 2 Priority */ @@ -81,7 +81,7 @@ #define AT91_MATRIX_M10PR (3 << 8) /* Master 10 Priority (in Register B) */ #define AT91_MATRIX_M11PR (3 << 12) /* Master 11 Priority (in Register B) */
-#define AT91_MATRIX_MRCR (AT91_MATRIX + 0x100) /* Master Remap Control Register */ +#define AT91_MATRIX_MRCR (ATMEL_BASE_MATRIX + 0x100) /* Master Remap Control Register */ #define AT91_MATRIX_RCB0 (1 << 0) /* Remap Command for AHB Master 0 (ARM926EJ-S Instruction Master) */ #define AT91_MATRIX_RCB1 (1 << 1) /* Remap Command for AHB Master 1 (ARM926EJ-S Data Master) */ #define AT91_MATRIX_RCB2 (1 << 2) @@ -95,7 +95,7 @@ #define AT91_MATRIX_RCB10 (1 << 10) #define AT91_MATRIX_RCB11 (1 << 11)
-#define AT91_MATRIX_TCMR (AT91_MATRIX + 0x110) /* TCM Configuration Register */ +#define AT91_MATRIX_TCMR (ATMEL_BASE_MATRIX + 0x110) /* TCM Configuration Register */ #define AT91_MATRIX_ITCM_SIZE (0xf << 0) /* Size of ITCM enabled memory block */ #define AT91_MATRIX_ITCM_0 (0 << 0) #define AT91_MATRIX_ITCM_32 (6 << 0) @@ -107,12 +107,12 @@ #define AT91_MATRIX_TCM_NO_WS (0x0 << 11) #define AT91_MATRIX_TCM_ONE_WS (0x1 << 11)
-#define AT91_MATRIX_VIDEO (AT91_MATRIX + 0x118) /* Video Mode Configuration Register */ +#define AT91_MATRIX_VIDEO (ATMEL_BASE_MATRIX + 0x118) /* Video Mode Configuration Register */ #define AT91C_VDEC_SEL (0x1 << 0) /* Video Mode Selection */ #define AT91C_VDEC_SEL_OFF (0 << 0) #define AT91C_VDEC_SEL_ON (1 << 0)
-#define AT91_MATRIX_EBICSA (AT91_MATRIX + 0x128) /* EBI Chip Select Assignment Register */ +#define AT91_MATRIX_EBICSA (ATMEL_BASE_MATRIX + 0x128) /* EBI Chip Select Assignment Register */ #define AT91_MATRIX_EBI_CS1A (1 << 1) /* Chip Select 1 Assignment */ #define AT91_MATRIX_EBI_CS1A_SMC (0 << 1) #define AT91_MATRIX_EBI_CS1A_SDRAMC (1 << 1) @@ -138,13 +138,13 @@ #define AT91_MATRIX_EBI_DDR_IOSR_REDUCED (0 << 18) #define AT91_MATRIX_EBI_DDR_IOSR_NORMAL (1 << 18)
-#define AT91_MATRIX_WPMR (AT91_MATRIX + 0x1E4) /* Write Protect Mode Register */ +#define AT91_MATRIX_WPMR (ATMEL_BASE_MATRIX + 0x1E4) /* Write Protect Mode Register */ #define AT91_MATRIX_WPMR_WPEN (1 << 0) /* Write Protect ENable */ #define AT91_MATRIX_WPMR_WP_WPDIS (0 << 0) #define AT91_MATRIX_WPMR_WP_WPEN (1 << 0) #define AT91_MATRIX_WPMR_WPKEY (0xFFFFFF << 8) /* Write Protect KEY */
-#define AT91_MATRIX_WPSR (AT91_MATRIX + 0x1E8) /* Write Protect Status Register */ +#define AT91_MATRIX_WPSR (ATMEL_BASE_MATRIX + 0x1E8) /* Write Protect Status Register */ #define AT91_MATRIX_WPSR_WPVS (1 << 0) /* Write Protect Violation Status */ #define AT91_MATRIX_WPSR_NO_WPV (0 << 0) #define AT91_MATRIX_WPSR_WPV (1 << 0) diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index f92b20f..6319a9b 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -23,6 +23,7 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/sizes.h> #include <asm/arch/at91sam9g45.h> #include <asm/arch/at91sam9_matrix.h> @@ -32,7 +33,6 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> #include <asm/arch/hardware.h> #include <lcd.h> #include <atmel_lcdc.h> @@ -41,6 +41,14 @@ #endif #include <netdev.h>
+/* + * arch/arm/include/asm/arch-at91/at91sam9g45.h defines ATMEL_BASE_SCM; + * however, other code still wants AT91_SMC instead. Likewise for the AT91_PMC + * definition. + */ +#define AT91_SMC ATMEL_BASE_SMC +#define AT91_PMC ATMEL_BASE_PMC + DECLARE_GLOBAL_DATA_PTR;
/* ------------------------------------------------------------------------- */ @@ -54,20 +62,20 @@ static void at91sam9m10g45ek_nand_hw_init(void) unsigned long csa;
/* Enable CS3 */ - csa = at91_sys_read(AT91_MATRIX_EBICSA); - at91_sys_write(AT91_MATRIX_EBICSA, + csa = readl(AT91_MATRIX_EBICSA); + writel(AT91_MATRIX_EBICSA, csa | AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA);
/* Configure SMC CS3 for NAND/SmartMedia */ - at91_sys_write(AT91_SMC_SETUP(3), + writel(AT91_SMC_SETUP(3), AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), + writel(AT91_SMC_PULSE(3), AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(3) | AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(2)); - at91_sys_write(AT91_SMC_CYCLE(3), + writel(AT91_SMC_CYCLE(3), AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(4)); - at91_sys_write(AT91_SMC_MODE(3), + writel(AT91_SMC_MODE(3), AT91_SMC_READMODE | AT91_SMC_WRITEMODE | AT91_SMC_EXNWMODE_DISABLE | #ifdef CONFIG_SYS_NAND_DBW_16 @@ -77,7 +85,7 @@ static void at91sam9m10g45ek_nand_hw_init(void) #endif AT91_SMC_TDF_(3));
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIOC); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_PIOC);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -90,7 +98,7 @@ static void at91sam9m10g45ek_nand_hw_init(void) #ifdef CONFIG_CMD_USB static void at91sam9m10g45ek_usb_hw_init(void) { - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIODE); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_PIODE);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); @@ -100,10 +108,12 @@ static void at91sam9m10g45ek_usb_hw_init(void) #ifdef CONFIG_MACB static void at91sam9m10g45ek_macb_hw_init(void) { - unsigned long rstc; + unsigned long rstc_mr; + struct at91_rstc *volatile rstc_mem = + (struct at91_rstc *volatile)ATMEL_BASE_RSTC;
/* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_EMAC); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_EMAC);
/* * Disable pull-up on: @@ -118,22 +128,20 @@ static void at91sam9m10g45ek_macb_hw_init(void) pin_to_mask(AT91_PIN_PA13), pin_to_controller(AT91_PIN_PA0) + PIO_PUDR);
- rstc = at91_sys_read(AT91_RSTC_MR); + rstc_mr = rstc_mem->mr;
/* Need to reset PHY -> 500ms reset */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (AT91_RSTC_ERSTL & (0x0D << 8)) | - AT91_RSTC_URSTEN); - - at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + rstc_mem->mr = rstc_mr | (AT91_RSTC_KEY | + AT91_RSTC_MR_ERSTL(0x0D) | + AT91_RSTC_MR_URSTEN); + rstc_mem->cr = AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST;
/* Wait for end hardware reset */ - while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + while (!(rstc_mem->sr & AT91_RSTC_SR_NRSTL)) + ;
/* Restore NRST value */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (rstc) | - AT91_RSTC_URSTEN); + rstc_mem->mr = AT91_RSTC_KEY | (rstc_mr) | AT91_RSTC_MR_URSTEN;
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA15) | @@ -161,7 +169,7 @@ vidinfo_t panel_info = { vl_vsync_len: 1, vl_upper_margin:40, vl_lower_margin:1, - mmio: AT91SAM9G45_LCDC_BASE, + mmio : ATMEL_BASE_LCDC, };
@@ -208,7 +216,7 @@ static void at91sam9m10g45ek_lcd_hw_init(void) at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_LCDC); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_LCDC);
gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; } @@ -227,7 +235,7 @@ void lcd_show_board_info(void) lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", - CONFIG_SYS_AT91_CPU_NAME, + ATMEL_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; @@ -298,7 +306,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9G45_BASE_EMAC, 0x00); + rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); #endif return rc; } diff --git a/board/atmel/at91sam9m10g45ek/led.c b/board/atmel/at91sam9m10g45ek/led.c index ff59a2d..b939c5b 100644 --- a/board/atmel/at91sam9m10g45ek/led.c +++ b/board/atmel/at91sam9m10g45ek/led.c @@ -23,15 +23,17 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/arch/at91sam9g45.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> -#include <asm/arch/io.h> + +#define AT91_PMC ATMEL_BASE_PMC
void coloured_LED_init(void) { /* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9G45_ID_PIODE); + writel(AT91_PMC_PCER, 1 << ATMEL_ID_PIODE);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1); diff --git a/boards.cfg b/boards.cfg index d2cacc8..d90ac24 100644 --- a/boards.cfg +++ b/boards.cfg @@ -72,6 +72,7 @@ netstar arm arm925t voiceblue arm arm925t omap1510inn arm arm925t - ti aspenite arm arm926ejs - Marvell armada100 +at91sam9m10g45ek arm arm926ejs at91sam9m10g45ek atmel at91 afeb9260 arm arm926ejs - - at91 at91cap9adk arm arm926ejs - atmel at91 snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index de74dcf..9c1b647 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -28,17 +28,15 @@ #define __CONFIG_H
#define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY
/* ARM asynchronous clock */ -#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ +#define AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_HZ 1000
-#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ -#ifdef CONFIG_AT91SAM9M10G45EK -#define CONFIG_AT91SAM9M10G45 1 /* It's an Atmel AT91SAM9M10G45 SoC*/ -#else -#define CONFIG_AT91SAM9G45 1 /* It's an Atmel AT91SAM9G45 SoC*/ -#endif +#define CONFIG_AT91SAM9M10G45 +#define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
@@ -48,6 +46,9 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
+#define ATMEL_PIO_PORTS 5 /* 5 PIO ports. */ +#define CONFIG_SYS_SDRAM_BASE 0x70000000 + /* * Hardware drivers */ @@ -57,6 +58,19 @@ #undef CONFIG_USART1 #undef CONFIG_USART2 #define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART_BASE ATMEL_BASE_USART3 +#define CONFIG_USART_ID 3 + +/* + * This needs to be defined for the OHCI code to work but it is defined as + * ATMEL_ID_UHPHS in the CPU specific header files. + */ +#define ATMEL_ID_UHP ATMEL_ID_UHPHS + +/* + * Specify the clock enable bit in the PMC_SCER register. + */ +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* LCD */ #define CONFIG_LCD 1 @@ -156,13 +170,13 @@ #define CONFIG_USB_ATMEL #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91SAM9G45_UHP_OHCI_BASE */ -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g45" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE 1
-#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM #define CONFIG_SYS_MEMTEST_END 0x23e00000 @@ -216,7 +230,8 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) - +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - \ + GENERATED_GBL_DATA_SIZE) #define CONFIG_STACKSIZE (32*1024) /* regular stack */
#ifdef CONFIG_USE_IRQ
Alex Waterman
