[U-Boot] [PATCH 0/4] dm: i2c: Add I2C support for i.CoreM6
This series add I2C support for i.CoreM6 and it is on top of [1] with u-boot-imx/master branch.
[1] [PATCH v7 00/21] imx6: Add Engicam i.CoreM6 QDL support
Jagan Teki (4): i2c: Kconfig: Add SYS_I2C_MXC entry i2c: mxc: Print hex instead of decimal for bus address i2c: mxc: Make 'no gpio pinctrl state' print as debug imx6: icorem6: Add I2C support
arch/arm/cpu/armv7/mx6/Kconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 2 ++ configs/imx6qdl_icore_nand_defconfig | 2 ++ drivers/i2c/Kconfig | 8 ++++++++ drivers/i2c/mxc_i2c.c | 2 +- 5 files changed, 14 insertions(+), 1 deletion(-)
Added kconfig for SYS_I2C_MXC driver.
Cc: Stefano Babic sbabic@denx.de Cc: Heiko Schocher hs@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/i2c/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 1537b67..051f911 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -109,6 +109,14 @@ config SYS_I2C_INTEL the I2C API meaning that any I2C operations will immediately fail for now.
+config SYS_I2C_MXC + bool "NXP i.MX I2C driver" + depends on MX6 + help + Add support for the NXP i.MX I2C driver. This supports upto for bus + channels and operating on standard mode upto 100 kbits/s and fast + mode upto 400 kbits/s. + config SYS_I2C_ROCKCHIP bool "Rockchip I2C driver" depends on DM_I2C
Better to print the hex value for bus address instead of decimal, for more readbility on bus addressing.
Before: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 35274752, no gpio pinctrl state.
After: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 0x21a4000, no gpio pinctrl state.
Cc: Simon Glass sjg@chromium.org Cc: Heiko Schocher hs@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/i2c/mxc_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index a26f44e..838b344 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -775,7 +775,7 @@ static int mxc_i2c_probe(struct udevice *bus) */ ret = fdt_find_string(fdt, node, "pinctrl-names", "gpio"); if (ret < 0) { - dev_info(dev, "i2c bus %d at %lu, no gpio pinctrl state.\n", bus->seq, i2c_bus->base); + dev_info(dev, "i2c bus %d at 0x%2lx, no gpio pinctrl state.\n", bus->seq, i2c_bus->base); } else { ret = gpio_request_by_name_nodev(fdt, node, "scl-gpios", 0, &i2c_bus->scl_gpio,
Some I2C bus devicetree nodes, doesn't require to have gpio pinctrl so replace the dev_info to debug so the print never comes on the console and for bus that uses gpio pinctrl anyway have dev_err.
Before: ------ U-Boot> i2c dev 1 Setting bus to 1 i2c bus 1 at 0x21a4000, no gpio pinctrl state.
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 838b344..3429054 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -775,7 +775,7 @@ static int mxc_i2c_probe(struct udevice *bus) */ ret = fdt_find_string(fdt, node, "pinctrl-names", "gpio"); if (ret < 0) { - dev_info(dev, "i2c bus %d at 0x%2lx, no gpio pinctrl state.\n", bus->seq, i2c_bus->base); + debug("i2c bus %d at 0x%2lx, no gpio pinctrl state.\n", bus->seq, i2c_bus->base); } else { ret = gpio_request_by_name_nodev(fdt, node, "scl-gpios", 0, &i2c_bus->scl_gpio,
Add I2C support for Engicam i.CoreM6 qdl board.
icorem6qdl> i2c bus Bus 0: i2c@021a0000 Bus 1: i2c@021a4000 Bus 2: i2c@021a8000 icorem6qdl> i2c dev 2 Setting bus to 2 icorem6qdl> i2c speed 100000 Setting bus speed to 100000 Hz icorem6qdl> i2c probe Valid chip addresses: 2C icorem6qdl> i2c md 2C 0xff 00ff: 00 00 00 00 0f f0 01 64 ff ff 00 00 00 00 00 00 .......d........
Cc: Stefano Babic sbabic@denx.de Cc: Heiko Schocher hs@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 2 ++ configs/imx6qdl_icore_nand_defconfig | 2 ++ 3 files changed, 5 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 8456b0e..c04536c 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -102,6 +102,7 @@ config TARGET_MX6Q_ICORE select DM select DM_ETH select DM_GPIO + select DM_I2C select DM_MMC select DM_THERMAL select SUPPORT_SPL diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index bcf999d..d102a40 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_MAXARGS=32 CONFIG_CMD_BMP=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MEMTEST=y @@ -32,6 +33,7 @@ CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_SYS_I2C_MXC=y CONFIG_VIDEO_IPUV3=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index b424c15..83fc428 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_MAXARGS=32 CONFIG_CMD_BMP=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_MEMTEST=y @@ -28,6 +29,7 @@ CONFIG_NAND_MXS=y CONFIG_IMX_THERMAL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_SYS_I2C_MXC=y CONFIG_VIDEO_IPUV3=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y
Jagan Teki
