[PATCH 08/30] mtd: spi-nor: Update block protection flags for flash parts
From: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com
The block protection flags for Gigadevice, Spansion, and ISSI flash memory have been modified. Additionally, new flags for SPI_NOR_OCTAL_DTR_READ and octal DTR page programming have been introduced for Micron OSPI flashes. Furthermore, the flashes mt35xu01g and mt35xu02g have been incorporated into the CONFIG_SPI_FLASH_MT35XU configuration, so that in driver mt35xu512aba_fixups will be applied.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Signed-off-by: Tejas Bhumkar tejas.arvind.bhumkar@amd.com --- drivers/mtd/spi/spi-nor-ids.c | 34 ++++++++++++++++++++-------------- 1 file changed, 20 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 3cb132dcff..cb39c99fa8 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -122,9 +122,9 @@ const struct flash_info spi_nor_ids[] = { {INFO("gd25b256", 0xc84019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES) }, {INFO("gd25b512", 0xc8471A, 0, 64 * 1024, 1024, SECT_4K | - SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES)}, + SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES | SPI_NOR_HAS_TB)}, {INFO("gd55b01g", 0xc8471B, 0, 64 * 1024, 2048, SECT_4K | - SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES)}, + SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES | SPI_NOR_HAS_TB)}, {INFO("gd55b02g", 0xc8471C, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES)}, {INFO("gd25f64", 0xc84317, 0, 64 * 1024, 128, SECT_4K | @@ -191,7 +191,8 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_4B_OPCODES)}, { INFO("gd25lx256e", 0xc86819, 0, 64 * 1024, 512, - SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) + SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, /* adding these 1.8V OSPI flash parts */ {INFO("gd25lx512", 0xc8681A, 0, 64 * 1024, 1024, SECT_4K | @@ -212,11 +213,11 @@ const struct flash_info spi_nor_ids[] = { { INFO("is25lp128", 0x9d6018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ) }, { INFO("is25lp256", 0x9d6019, 0, 64 * 1024, 512, - SECT_4K | SPI_NOR_DUAL_READ) }, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_HAS_TB) }, { INFO("is25lp512", 0x9d601a, 0, 64 * 1024, 1024, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_TB) }, { INFO("is25lp01g", 0x9d601b, 0, 64 * 1024, 2048, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_TB) }, { INFO("is25wp008", 0x9d7014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) }, { INFO("is25wp016", 0x9d7015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, @@ -233,7 +234,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("is25wp01g", 0x9d701b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wx256", 0x9d5b19, 0, 128 * 1024, 256, - SECT_4K | USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, + SECT_4K | USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | + SPI_NOR_HAS_TB) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */ @@ -312,11 +314,15 @@ const struct flash_info spi_nor_ids[] = { { INFO("mt25qu02g", 0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, { INFO("mt25ql02g", 0x20ba22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE | SPI_NOR_4B_OPCODES) }, #ifdef CONFIG_SPI_FLASH_MT35XU - { INFO("mt35xl512aba", 0x2c5a1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, - { INFO("mt35xu512aba", 0x2c5b1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, + { INFO("mt35xl512aba", 0x2c5a1a, 0, 128 * 1024, 512, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_OCTAL_DTR_PP) }, + { INFO("mt35xu512aba", 0x2c5b1a, 0, 128 * 1024, 512, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_OCTAL_DTR_PP) }, + { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_OCTAL_DTR_PP) }, + { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_OCTAL_DTR_PP) }, #endif /* CONFIG_SPI_FLASH_MT35XU */ - { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, - { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ /* Spansion/Cypress -- single (large) sector size only, at least @@ -325,8 +331,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25sl032p", 0x010215, 0x4d00, 64 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25sl064p", 0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25fl256s0", 0x010219, 0x4d00, 256 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { INFO6("s25fl512s", 0x010220, 0x4d0080, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_HAS_TB) }, + { INFO6("s25fl512s", 0x010220, 0x4d0080, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_HAS_TB) }, { INFO6("s25fs512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, @@ -334,7 +340,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s70fs01gs_256k", 0x010221, 0x4d00, 256 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25sl12800", 0x012018, 0x0300, 256 * 1024, 64, 0) }, { INFO("s25sl12801", 0x012018, 0x0301, 64 * 1024, 256, 0) }, - { INFO6("s25fl128s", 0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fl128s", 0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_HAS_TB) }, { INFO("s25fl129p0", 0x012018, 0x4d00, 256 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl129p1", 0x012018, 0x4d01, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25sl008a", 0x010213, 0, 64 * 1024, 16, 0) },
Tejas Bhumkar
