[U-Boot] [PATCH v3] spi/arm-pl022: Add support for ARM PL022 spi controller
This patch adds the support for the ARM PL022 SPI controller for the standard variant (0x00041022), which has a 16bit wide and 8 locations deep TX/RX FIFO.
Signed-off-by: Armando Visconti armando.visconti@st.com Signed-off-by: Vipin Kumar vipin.kumar@st.com --- Changes in v3 Added void to spi_init arguments Used readl/writel in place of u16 accessors Fix: Provided address of register in place of value to readl/writel IO accessors
Tested with spear1340-evb
Stefan, I have not added your Acked-by because the patch has changed after you acked it.
drivers/spi/Makefile | 1 + drivers/spi/pl022_spi.c | 310 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 311 insertions(+) create mode 100644 drivers/spi/pl022_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 824d357..3a4e4b0 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -42,6 +42,7 @@ COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o COBJS-$(CONFIG_MXS_SPI) += mxs_spi.o COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o +COBJS-$(CONFIG_PL022_SPI) += pl022_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o diff --git a/drivers/spi/pl022_spi.c b/drivers/spi/pl022_spi.c new file mode 100644 index 0000000..86d65ae --- /dev/null +++ b/drivers/spi/pl022_spi.c @@ -0,0 +1,310 @@ +/* + * (C) Copyright 2012 + * Armando Visconti, ST Microelectronics, armando.visconti@st.com. + * + * Driver for ARM PL022 SPI Controller. Based on atmel_spi.c + * by Atmel Corporation. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* SSP registers mapping */ +struct pl022 { + u32 ssp_cr0; /* 0x000 */ + u32 ssp_cr1; /* 0x004 */ + u32 ssp_dr; /* 0x008 */ + u32 ssp_sr; /* 0x00c */ + u32 ssp_cpsr; /* 0x010 */ + u32 ssp_imsc; /* 0x014 */ + u32 ssp_ris; /* 0x018 */ + u32 ssp_mis; /* 0x01c */ + u32 ssp_icr; /* 0x020 */ + u32 ssp_dmacr; /* 0x024 */ + u8 reserved_1[0x080 - 0x028]; + u32 ssp_itcr; /* 0x080 */ + u32 ssp_itip; /* 0x084 */ + u32 ssp_itop; /* 0x088 */ + u32 ssp_tdr; /* 0x08c */ + u8 reserved_2[0xFE0 - 0x090]; + u32 ssp_pid0; /* 0xfe0 */ + u32 ssp_pid1; /* 0xfe4 */ + u32 ssp_pid2; /* 0xfe8 */ + u32 ssp_pid3; /* 0xfec */ + u32 ssp_cid0; /* 0xff0 */ + u32 ssp_cid1; /* 0xff4 */ + u32 ssp_cid2; /* 0xff8 */ + u32 ssp_cid3; /* 0xffc */ +}; + +/* SSP Control Register 0 - SSP_CR0 */ +#define SSP_CR0_SPO (0x1 << 6) +#define SSP_CR0_SPH (0x1 << 7) +#define SSP_CR0_8BIT_MODE (0x07) +#define SSP_SCR_MAX (0xFF) +#define SSP_SCR_SHFT 8 + +/* SSP Control Register 0 - SSP_CR1 */ +#define SSP_CR1_MASK_SSE (0x1 << 1) + +#define SSP_CPSR_MAX (0xFE) + +/* SSP Status Register - SSP_SR */ +#define SSP_SR_MASK_TFE (0x1 << 0) /* Transmit FIFO empty */ +#define SSP_SR_MASK_TNF (0x1 << 1) /* Transmit FIFO not full */ +#define SSP_SR_MASK_RNE (0x1 << 2) /* Receive FIFO not empty */ +#define SSP_SR_MASK_RFF (0x1 << 3) /* Receive FIFO full */ +#define SSP_SR_MASK_BSY (0x1 << 4) /* Busy Flag */ + +struct pl022_spi_slave { + struct spi_slave slave; + void *regs; + unsigned int freq; +}; + +static inline struct pl022_spi_slave *to_pl022_spi(struct spi_slave *slave) +{ + return container_of(slave, struct pl022_spi_slave, slave); +} + +/* + * Following three functions should be provided by the + * board support package. + */ +int __weak spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void __weak spi_cs_activate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void __weak spi_cs_deactivate(struct spi_slave *slave) +{ + /* do nothing */ +} + +void spi_init(void) +{ + /* do nothing */ +} + +/* + * ARM PL022 exists in different 'flavors'. + * This drivers currently support the standard variant (0x00041022), that has a + * 16bit wide and 8 locations deep TX/RX FIFO. + */ +static int pl022_is_supported(struct pl022_spi_slave *ps) +{ + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* PL022 version is 0x00041022 */ + if ((readl(&pl022->ssp_pid0) == 0x22) && + (readl(&pl022->ssp_pid1) == 0x10) && + ((readl(&pl022->ssp_pid2) & 0xf) == 0x04) && + (readl(&pl022->ssp_pid3) == 0x00)) + return 1; + + return 0; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct pl022_spi_slave *ps; + struct pl022 *pl022; + u16 scr = 1, prescaler, cr0 = 0, cpsr = 0; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ps = malloc(sizeof(*ps)); + if (!ps) + return NULL; + + ps->slave.bus = bus; + ps->slave.cs = cs; + ps->freq = max_hz; + + switch (bus) { + case 0: + ps->regs = (void *)CONFIG_SYS_SPI_BASE; + break; +#ifdef CONFIG_SYS_SPI_BASE1 + case 1: + ps->regs = (void *)CONFIG_SYS_SPI_BASE1; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE2 + case 2: + ps->regs = (void *)CONFIG_SYS_SPI_BASE2; + break; +#endif +#ifdef CONFIG_SYS_SPI_BASE3 + case 3: + ps->regs = (void *)CONFIG_SYS_SPI_BASE3; + break; +#endif + default: + free(ps); + return NULL; + } + + pl022 = (struct pl022 *)ps->regs; + + /* Check the PL022 version */ + if (!pl022_is_supported(ps)) { + free(ps); + return NULL; + } + + /* Set requested polarity and 8bit mode */ + cr0 = SSP_CR0_8BIT_MODE; + cr0 |= (mode & SPI_CPHA) ? SSP_CR0_SPH : 0; + cr0 |= (mode & SPI_CPOL) ? SSP_CR0_SPO : 0; + + writel(cr0, &pl022->ssp_cr0); + + /* Program the SSPClk frequency */ + prescaler = CONFIG_SYS_SPI_CLK / ps->freq; + + if (prescaler <= 0xFF) + cpsr = prescaler; + else { + for (scr = 1; scr <= SSP_SCR_MAX; scr++) { + if (!(prescaler % scr)) { + cpsr = prescaler / scr; + if (cpsr <= SSP_CPSR_MAX) + break; + } + } + + if (scr > SSP_SCR_MAX) { + scr = SSP_SCR_MAX; + cpsr = prescaler / scr; + cpsr &= SSP_CPSR_MAX; + } + } + + if (cpsr & 0x1) + cpsr++; + + writel(cpsr, &pl022->ssp_cpsr); + cr0 = readl(&pl022->ssp_cr0); + writel(cr0 | (scr - 1) << SSP_SCR_SHFT, &pl022->ssp_cr0); + + return &ps->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + + free(ps); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* Enable the SPI hardware */ + setbits_le32(&pl022->ssp_cr1, SSP_CR1_MASK_SSE); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + + /* Disable the SPI hardware */ + writel(0x0, &pl022->ssp_cr1); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct pl022_spi_slave *ps = to_pl022_spi(slave); + struct pl022 *pl022 = (struct pl022 *)ps->regs; + u32 len_tx = 0, len_rx = 0, len; + u32 ret = 0; + const u8 *txp = dout; + u8 *rxp = din, value; + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + goto out; + + /* + * TODO: The controller can do non-multiple-of-8 bit + * transfers, but this driver currently doesn't support it. + * + * It's also not clear how such transfers are supposed to be + * represented as a stream of bytes...this is a limitation of + * the current SPI interface. + */ + if (bitlen % 8) { + ret = -1; + + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + goto out; + } + + len = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + while (len_tx < len) { + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_TNF) { + value = (txp != NULL) ? *txp++ : 0; + writel(value, &pl022->ssp_dr); + len_tx++; + } + + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_RNE) { + value = readl(&pl022->ssp_dr); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + + while (len_rx < len_tx) { + if (readl(&pl022->ssp_sr) & SSP_SR_MASK_RNE) { + value = readl(&pl022->ssp_dr); + if (rxp) + *rxp++ = value; + len_rx++; + } + } + +out: + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
Okay.
Looks still good, so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Signed-off-by: Armando Viscontiarmando.visconti@st.com Signed-off-by: Vipin Kumarvipin.kumar@st.com
I recall now that SPI variant is same also on the new SoC (I2C cell is different).
So no need to test over it. SPEAr1340 is enough.
Ciao, Arm
Does this tested on hw, please re-base the tree and send the next version patch. Let me know if it ok to review under current tree.
-- Thanks, Jagan.
On Thu, Dec 13, 2012 at 7:31 PM, Armando Visconti armando.visconti@st.com wrote:
Ciao, Arm
Armando Visconti
Jagan Teki
Stefan Roese
Vipin Kumar
