[U-Boot] EABI version error when building u-boot
Hello,
I'm trying to build my u-boot but in the building proccess I get an error which I cannot solve myself. The error prompt I get is:
drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a board/freescale/mx31guf/libmx31guf.a --end-group -L /home/sick/cross/arm-2007q3/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.1 -lgcc -Map u-boot.map -o u-boot arm-none-linux-gnueabi-ld: ERROR: Source object /home/sick/cross/arm-2007q3/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.1/libgcc.a(_lshrdi3.o) has EABI version 5, but target u-boot has EABI version 0 arm-none-linux-gnueabi-ld: failed to merge target specific data of file /home/sick/cross/arm-2007q3/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.1/libgcc.a(_lshrdi3.o) make: *** [/tmp/mybuild/u-boot] Fehler 1
I don't get this when I'm building other boards like the PDK Board. So I think it's a problem in my code. Does anybody of you have an idea?
Thanks a lot in advance.
Best Regards Ulrich Gerster
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Ulrich Gerster Sent: Tuesday, July 07, 2009 3:45 PM To: u-boot@lists.denx.de Subject: [U-Boot] EABI version error when building u-boot
Hello,
drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a board/freescale/mx31guf/libmx31guf.a --end-group -L /home/sick/cross/arm-2007q3/bin/../lib/gcc/arm-none-linux-gnue abi/4.2.1 -lgcc -Map u-boot.map -o u-boot arm-none-linux-gnueabi-ld: ERROR: Source object /home/sick/cross/arm-2007q3/bin/../lib/gcc/arm-none-linux-gnue
Hi Ulrich
I faced similar problem Following reference may help you
http://lists.denx.de/pipermail/u-boot/2009-June/055064.html
Regards.. Prafulla . .
Hello,
Hi Ulrich
An additional reason to try to fix this tool chain dependency issue in mainline as soon as possible.
Jean-Christophe: Do you mind sending an updated patch fixing the issue mentioned in
http://lists.denx.de/pipermail/u-boot/2009-July/055469.html
Best regards
Dirk
Dirk Behme
Prafulla Wadaskar
Ulrich Gerster
