[U-Boot] [PATCH] RISC-V: Align boot image header with Linux.
The release linux boot image header in v5.3 is different from the one present in U-boot. Align the header with the new version. The changes in Linux are backward compatible. Previous u-boot releases with older header will continue to work as well. As v5.3 kernel is the first one to support image header, there is no compatibility issue between new U-boot (with this patch) and older kernel.
Signed-off-by: Atish Patra atish.patra@wdc.com --- arch/riscv/lib/image.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/riscv/lib/image.c b/arch/riscv/lib/image.c index d063beb7dfbe..41fca5939020 100644 --- a/arch/riscv/lib/image.c +++ b/arch/riscv/lib/image.c @@ -14,20 +14,21 @@
DECLARE_GLOBAL_DATA_PTR;
-/* ASCII version of "RISCV" defined in Linux kernel */ -#define LINUX_RISCV_IMAGE_MAGIC 0x5643534952 +/* ASCII version of "RSC\0x5" defined in Linux kernel */ +#define LINUX_RISCV_IMAGE_MAGIC 0x05435352
struct linux_image_h { uint32_t code0; /* Executable code */ uint32_t code1; /* Executable code */ uint64_t text_offset; /* Image load offset */ uint64_t image_size; /* Effective Image size */ - uint64_t res1; /* reserved */ + uint64_t flags; /* kernel flags(little endian) */ + uint32_t version; /* version of the header */ + uint32_t res1; /* reserved */ uint64_t res2; /* reserved */ uint64_t res3; /* reserved */ - uint64_t magic; /* Magic number */ + uint32_t magic; /* Magic number */ uint32_t res4; /* reserved */ - uint32_t res5; /* reserved */ };
int booti_setup(ulong image, ulong *relocated_addr, ulong *size,
On Wed, Oct 9, 2019 at 9:15 AM Atish Patra atish.patra@wdc.com wrote:
nits: please remove the ending period in the commit summary
nits: Linux
nits: U-Boot
nits: U-Boot
nits: U-Boot
need have a space before (little endian)
Regards, Bin
nits: Linux
nits: U-Boot
nits: U-Boot
nits: U-Boot
Sorry for not following U-Boot naming conventionl. Fixed all the comments and sent a v2.
endian) */
Regards, Bin
Atish Patra
Atish Patra
Bin Meng
