[GIT PULL] Please pull u-boot-dfu-next-20231124
Hi Tom,
Here are some developments for next including:
- Make dfu entity name size configurable in KConfig - Implement start-stop for UMS (graceful shutdown via eject) - Improve help messages for cmd/bind - Improve help message for udc bind failures
The CI job is at https://source.denx.de/u-boot/custodians/u-boot-dfu/-/pipelines/18704
Thanks, Mattijs
The following changes since commit dca7a8958f8d0dbd53072caa4353353e062d80ca:
Merge tag 'v2024.01-rc3' into next (2023-11-20 09:19:50 -0500)
https://source.denx.de/u-boot/custodians/u-boot-dfu.git tags/u-boot-dfu-next-20231124
for you to fetch changes up to 8a0d07807abb5370fe879321c7f1d22fdda3255f:
usb: udc: Try to clarify an error message (2023-11-21 15:48:38 +0100)
---------------------------------------------------------------- u-boot-dfu-next-20231124
---------------------------------------------------------------- Jaehoon Chung (1): dfu: add CONFIG_DFU_NAME_MAX_SIZE configuration
Marek Vasut (1): usb: gadget: f_mass_storage: Stop ums on START-STOP UNIT SCSI command
Miquel Raynal (3): cmd: Change the dependencies between CMD_BIND and USB_GADGET cmd: bind: Try to improve the (un)bind help usb: udc: Try to clarify an error message
cmd/Kconfig | 2 +- cmd/bind.c | 4 ++++ drivers/dfu/Kconfig | 9 +++++++++ drivers/usb/gadget/Kconfig | 1 + drivers/usb/gadget/f_mass_storage.c | 7 +++++++ drivers/usb/gadget/udc/udc-core.c | 13 ++++++++++++- include/dfu.h | 5 +++++ 7 files changed, 39 insertions(+), 2 deletions(-)
On Fri, Nov 24, 2023 at 11:44:14AM +0100, Mattijs Korpershoek wrote:
Hi Tom,
Thanks, Mattijs
Mattijs Korpershoek
