[U-Boot] [PATCH 5/5 v3] ARM:OMAP3:SDP3430: initial support
---- Sandeep pointed me to: http://lists.denx.de/pipermail/u-boot/2009-October/062086.html so the v3 of patch with size fixes ---- Start of support of Texas Instruments Software Development Platform(SDP) for OMAP3430 - SDP3430
Highlights of this platform are: Flash Memory devices: Sibley NOR, Micron 8bit NAND and OneNAND Connectivity: 3 UARTs and expanded 4 UART ports + IrDA Ethernet, USB Other peripherals: TWL5030 PMIC+Audio+Keypad VGA display Expansion ports: Memory devices plugin boards (PISMO) Connectivity board for GPS,WLAN etc.. Completely configurable boot sequence and device mapping etc.. For more details, please refer: http://focus.ti.com/general/docs/wtbu/wtbugencontent.tsp?templateId=6123&...
Support default jumpering and: - UART1/ttyS0 console(legacy sdp3430 u-boot) - UART3/ttyS2 console (matching other boards, and SDP HW docs) - Ethernet - mmc0 - NOR boot
TODO: - mmc1 - NAND (boot or 128M storage) - OneNAND (boot or 256M storage) - Fix NOR env variable load - Review SDRC timing configuration/DPLL configuration - Dynamically read FPGA dip switch settings and map NOR/NAND/ONENAND devices to right chipselects
Currently the UART1 is enabled by default. for compatibility with other OMAP3 u-boot platforms, enable the #define of CONSOLE_J9.
Signed-off-by: David Brownell david-b@pacbell.net Signed-off-by: Nishanth Menon nm@ti.com Cc: Vikram Pandita vikram.pandita@ti.com Cc: Richard Woodruff r-woodruff2@ti.com Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Tom Rix tom.rix@windriver.com Cc: Dirk Behme dirk.behme@googlemail.com --- MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/ti/sdp3430/Makefile | 49 +++++ board/ti/sdp3430/config.mk | 33 +++ board/ti/sdp3430/sdp.c | 204 +++++++++++++++++++ board/ti/sdp3430/sdp.h | 417 +++++++++++++++++++++++++++++++++++++++ include/configs/omap3_sdp3430.h | 369 ++++++++++++++++++++++++++++++++++ 8 files changed, 1077 insertions(+), 0 deletions(-) create mode 100644 board/ti/sdp3430/Makefile create mode 100644 board/ti/sdp3430/config.mk create mode 100644 board/ti/sdp3430/sdp.c create mode 100644 board/ti/sdp3430/sdp.h create mode 100644 include/configs/omap3_sdp3430.h
diff --git a/MAINTAINERS b/MAINTAINERS index 2297651..5742782 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -628,6 +628,7 @@ Guennadi Liakhovetski g.liakhovetski@gmx.de
+ omap3_sdp3430 ARM CORTEX-A8 (OMAP3xx SoC) omap3_zoom1 ARM CORTEX-A8 (OMAP3xx SoC)
David Müller d.mueller@elsoft.ch diff --git a/MAKEALL b/MAKEALL index 38cd076..9bf75e8 100755 --- a/MAKEALL +++ b/MAKEALL @@ -603,6 +603,7 @@ LIST_ARM_CORTEX_A8=" \ omap3_overo \ omap3_evm \ omap3_pandora \ + omap3_sdp3430 \ omap3_zoom1 \ omap3_zoom2 \ " diff --git a/Makefile b/Makefile index 9637643..8dbe552 100644 --- a/Makefile +++ b/Makefile @@ -3144,6 +3144,9 @@ omap3_zoom1_config : unconfig omap3_zoom2_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 zoom2 logicpd omap3
+omap3_sdp3430_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 sdp3430 ti omap3 + ######################################################################### ## XScale Systems ######################################################################### diff --git a/board/ti/sdp3430/Makefile b/board/ti/sdp3430/Makefile new file mode 100644 index 0000000..2554c7b --- /dev/null +++ b/board/ti/sdp3430/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := sdp.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/ti/sdp3430/config.mk b/board/ti/sdp3430/config.mk new file mode 100644 index 0000000..18e4761 --- /dev/null +++ b/board/ti/sdp3430/config.mk @@ -0,0 +1,33 @@ +# +# (C) Copyright 2006-2009 +# Texas Instruments Incorporated, <www.ti.com> +# +# OMAP 3430 SDP uses OMAP3 (ARM-CortexA8) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# Physical Address: +# 8000'0000 (bank0) +# A000/0000 (bank1) +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80e80000 diff --git a/board/ti/sdp3430/sdp.c b/board/ti/sdp3430/sdp.c new file mode 100644 index 0000000..40cf26f --- /dev/null +++ b/board/ti/sdp3430/sdp.c @@ -0,0 +1,204 @@ +/* + * (C) Copyright 2004-2009 + * Texas Instruments Incorporated, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <twl4030.h> +#include <asm/io.h> +#include <asm/arch/mux.h> +#include <asm/arch/mem.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-types.h> +#include "sdp.h" + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "OMAP3 SDP3430 board", +#if defined(CONFIG_ENV_IS_IN_ONENAND) + "OneNAND", +#elif defined(CONFIG_ENV_IS_IN_NAND) + "NAND", +#else + "NOR", +#endif +}; + +/* Timing definitions for GPMC controller for Sibley NOR */ +static const u32 gpmc_sdp_nor[] = { + SDP3430_NOR_GPMC_CONF1, + SDP3430_NOR_GPMC_CONF2, + SDP3430_NOR_GPMC_CONF3, + SDP3430_NOR_GPMC_CONF4, + SDP3430_NOR_GPMC_CONF5, + SDP3430_NOR_GPMC_CONF6, + /*CONF7- computed as params */ +}; + +/* + * Timing definitions for GPMC controller for Debug Board + * Debug board contains access to ethernet and DIP Switch setting + * information etc. + */ +static const u32 gpmc_sdp_debug[] = { + SDP3430_DEBUG_GPMC_CONF1, + SDP3430_DEBUG_GPMC_CONF2, + SDP3430_DEBUG_GPMC_CONF3, + SDP3430_DEBUG_GPMC_CONF4, + SDP3430_DEBUG_GPMC_CONF5, + SDP3430_DEBUG_GPMC_CONF6, + /*CONF7- computed as params */ +}; + +/* Timing defintions for GPMC OneNAND */ +static const u32 gpmc_sdp_onenand[] = { + SDP3430_ONENAND_GPMC_CONF1, + SDP3430_ONENAND_GPMC_CONF2, + SDP3430_ONENAND_GPMC_CONF3, + SDP3430_ONENAND_GPMC_CONF4, + SDP3430_ONENAND_GPMC_CONF5, + SDP3430_ONENAND_GPMC_CONF6, + /*CONF7- computed as params */ +}; + +/* GPMC definitions for GPMC NAND */ +static const u32 gpmc_sdp_nand[] = { + SDP3430_NAND_GPMC_CONF1, + SDP3430_NAND_GPMC_CONF2, + SDP3430_NAND_GPMC_CONF3, + SDP3430_NAND_GPMC_CONF4, + SDP3430_NAND_GPMC_CONF5, + SDP3430_NAND_GPMC_CONF6, + /*CONF7- computed as params */ +}; + +/* gpmc_cfg is initialized by gpmc_init and we use it here */ +extern struct gpmc *gpmc_cfg; + +/** + * @brief board_init - gpmc and basic setup as phase1 of boot sequence + * + * @return 0 + */ +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* TODO: Dynamically pop out CS mapping and program accordingly */ + /* Configure devices for default ON ON ON settings */ + enable_gpmc_cs_config(gpmc_sdp_nor, &gpmc_cfg->cs[0], + CONFIG_SYS_FLASH_BASE, GPMC_SIZE_128M); + enable_gpmc_cs_config(gpmc_sdp_nand, &gpmc_cfg->cs[1], 0x28000000, + GPMC_SIZE_16M); + enable_gpmc_cs_config(gpmc_sdp_onenand, &gpmc_cfg->cs[2], 0x20000000, + GPMC_SIZE_16M); + enable_gpmc_cs_config(gpmc_sdp_debug, &gpmc_cfg->cs[3], DEBUG_BASE, + GPMC_SIZE_16M); + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_OMAP_3430SDP; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +#define LAN_RESET_REGISTER (CONFIG_LAN91C96_BASE + 0x01c) +#define ETH_CONTROL_REG (CONFIG_LAN91C96_BASE + 0x30b) + +/** + * @brief ether_init Take the Ethernet controller out of reset and wait + * for the EEPROM load to complete. + */ +static void ether_init(void) +{ +#ifdef CONFIG_DRIVER_LAN91C96 + int cnt = 20; + + writew(0x0, LAN_RESET_REGISTER); + do { + writew(0x1, LAN_RESET_REGISTER); + udelay(100); + if (cnt == 0) + goto reset_err_out; + --cnt; + } while (readw(LAN_RESET_REGISTER) != 0x1); + + cnt = 20; + + do { + writew(0x0, LAN_RESET_REGISTER); + udelay(100); + if (cnt == 0) + goto reset_err_out; + --cnt; + } while (readw(LAN_RESET_REGISTER) != 0x0000); + udelay(1000); + + writeb(readb(ETH_CONTROL_REG) & ~0x1, ETH_CONTROL_REG); + udelay(1000); +reset_err_out: + return; + +#endif +} + +/** + * @brief misc_init_r - Configure SDP board specific configurations + * such as power configurations, ethernet initialization as phase2 of + * boot sequence + * + * @return 0 + */ +int misc_init_r(void) +{ + /* Partial setup: + * VAUX3 - 2.8V for DVI + * VPLL1 - 1.8V + * VDAC - 1.8V + * and turns on LEDA/LEDB (not needed ... NOP?) + */ + twl4030_power_init(); + + /* FIXME finish setup: + * VAUX1 - 2.8V for mainboard I/O + * VAUX2 - 2.8V for camera + * VAUX4 - 1.8V for OMAP3 CSI + * VMMC1 - 3.15V (init, variable) for MMC1 + * VMMC2 - 1.85V for MMC2 + * VSIM - off (init, variable) for MMC1.DAT[3..7], SIM + * VPLL2 - 1.8V + */ + ether_init(); + + return 0; +} + +/** + * @brief set_muxconf_regs Setting up the configuration Mux registers + * specific to the hardware. Many pins need to be moved from protect + * to primary mode. + */ +void set_muxconf_regs(void) +{ + /* platform specific muxes */ + MUX_SDP3430(); +} diff --git a/board/ti/sdp3430/sdp.h b/board/ti/sdp3430/sdp.h new file mode 100644 index 0000000..3526e94 --- /dev/null +++ b/board/ti/sdp3430/sdp.h @@ -0,0 +1,417 @@ +/* + * (C) Copyright 2004-2009 + * Texas Instruments Incorporated + * Richard Woodruff r-woodruff2@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _BOARD_SDP_H_ +#define _BOARD_SDP_H_ + +#define OFF_IN_PD 0 +#define OFF_OUT_PD 0 + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_SDP3430()\ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0))\ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A3), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A4), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A5), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A6), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A7), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A8), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A9), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_A10), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D0), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D1), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D3), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D4), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D5), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D6), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D7), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D8), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D9), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D10), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D11), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D12), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D13), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D14), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_D15), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NCS0), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS1), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS2), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS3), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS4), (OFF_IN_PD | IEN | PTU | EN | M4)) /*G55-F_DIS*/\ + MUX_VAL(CP(GPMC_NCS5), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G56T_EN*/\ + MUX_VAL(CP(GPMC_NCS6), (OFF_IN_PD | IEN | PTD | DIS | M4))/*G57-AGPSP*/\ + MUX_VAL(CP(GPMC_NCS7), (OFF_IN_PD | IEN | PTU | EN | M4))/*G58-WLNIQ*/\ + MUX_VAL(CP(GPMC_CLK), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NADV_ALE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NOE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NWE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NBE0_CLE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NBE1), (OFF_IN_PD | IEN | PTD | DIS | M4)) /*G61-BTST*/\ + MUX_VAL(CP(GPMC_NWP), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_WAIT0), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_WAIT1), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_WAIT2), (OFF_IN_PD | IEN | PTU | EN | M4)) /*GPIO_64*/\ + MUX_VAL(CP(GPMC_WAIT3), (OFF_IN_PD | IEN | PTU | EN | M4)) /*GPIO_65*/\ + /*DSS*/\ + MUX_VAL(CP(DSS_PCLK), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_HSYNC), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_VSYNC), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_ACBIAS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA0), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA1), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA3), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA4), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA5), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA6), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA7), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA8), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA9), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA10), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA11), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA12), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA13), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA14), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA15), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA16), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA17), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA18), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA19), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA20), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA21), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA22), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA23), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + /*CAMERA*/\ + MUX_VAL(CP(CAM_HS), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(CAM_VS), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(CAM_XCLKA), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_PCLK), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(CAM_FLD), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G98-C_RST*/\ + MUX_VAL(CP(CAM_D0), (OFF_IN_PD | IEN | PTD | DIS | M2)) /*CAM_D0 */\ + MUX_VAL(CP(CAM_D1), (OFF_IN_PD | IEN | PTD | DIS | M2)) /*CAM_D1 */\ + MUX_VAL(CP(CAM_D2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D3), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D4), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D5), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D6), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D7), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D8), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D9), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D10), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_D11), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_XCLKB), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(CAM_WEN), (OFF_IN_PD | IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(CSI2_DX0), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CSI2_DY0), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CSI2_DX1), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CSI2_DY1), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + /*Audio InterfACe */\ + MUX_VAL(CP(MCBSP2_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP2_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP2_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP2_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + /*Expansion Card */\ + MUX_VAL(CP(MMC1_CLK), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_CMD), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT0), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT1), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT2), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT3), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT4), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT5), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT6), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_DAT7), (OFF_IN_PD | IEN | PTU | EN | M0))\ + /*Wireless LAN */\ + MUX_VAL(CP(MMC2_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_CMD), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC2_DAT0), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC2_DAT1), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC2_DAT2), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC2_DAT3), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC2_DAT4), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DRD0*/\ + MUX_VAL(CP(MMC2_DAT5), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DRD1*/\ + MUX_VAL(CP(MMC2_DAT6), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DCMD*/\ + MUX_VAL(CP(MMC2_DAT7), (OFF_IN_PD | IEN | PTU | EN | M1))/*CLKIN*/\ + /*Bluetooth*/\ + MUX_VAL(CP(MCBSP3_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(UART2_CTS), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(UART2_RTS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART2_TX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART2_RX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + /*Modem Interface */\ + MUX_VAL(CP(UART1_TX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART1_RTS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART1_CTS), (OFF_IN_PD | IEN | PTU | DIS | M0))\ + MUX_VAL(CP(UART1_RX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP4_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1DRX*/\ + MUX_VAL(CP(MCBSP4_DR), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1FLGRX*/\ + MUX_VAL(CP(MCBSP4_DX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1RDYRX*/\ + MUX_VAL(CP(MCBSP4_FSX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1WAKE*/\ + MUX_VAL(CP(MCBSP1_CLKR), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_FSR), (OFF_OUT_PD | IDIS | PTU | EN | M4))/*G157BWP*/\ + MUX_VAL(CP(MCBSP1_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP_CLKS), (OFF_IN_PD | IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MCBSP1_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + /*Serial Interface*/\ + MUX_VAL(CP(UART3_CTS_RCTX), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(UART3_RTS_SD), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART3_RX_IRRX), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(UART3_TX_IRTX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_STP), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(HSUSB0_DIR), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_NXT), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA0), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA1), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA3), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA4), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA5), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA6), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(HSUSB0_DATA7), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + /* NOTE db: removed off-mode from I2C 1/2/3 ... external pullups!! */\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(HDQ_SIO), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(MCSPI1_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI1_SIMO), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI1_SOMI), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI1_CS0), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(MCSPI1_CS1), (OFF_OUT_PD | IDIS | PTD | EN | M0))\ + MUX_VAL(CP(MCSPI1_CS2), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G176*/\ + MUX_VAL(CP(MCSPI1_CS3), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(MCSPI2_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI2_SIMO), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI2_SOMI), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCSPI2_CS0), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(MCSPI2_CS1), (OFF_IN_PD | IEN | PTD | EN | M0))\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_NIRQ), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(SYS_BOOT0), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G2PENIRQ*/\ + MUX_VAL(CP(SYS_BOOT1), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G4MMC1WP*/\ + MUX_VAL(CP(SYS_BOOT3), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G5LCDENV*/\ + MUX_VAL(CP(SYS_BOOT4), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G6LANINT*/\ + MUX_VAL(CP(SYS_BOOT5), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G7MMC2WP*/\ + MUX_VAL(CP(SYS_BOOT6), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G8ENBKL*/\ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_CLKOUT2), (OFF_IN_PD | IEN | PTU | EN | M4))/*GPIO_186*/\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_EMU0), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_EMU1), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_CLK_ES2), (OFF_OUT_PD | IDIS | PTU | EN | M0))\ + MUX_VAL(CP(ETK_CTL_ES2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D0_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*USB1TLD0*/\ + MUX_VAL(CP(ETK_D1_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SPI3_CS0*/\ + MUX_VAL(CP(ETK_D2_ES2), (OFF_IN_PD | IEN | PTD | EN | M1))/*USB1TLD2*/\ + MUX_VAL(CP(ETK_D3_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*USB1TLD7*/\ + MUX_VAL(CP(ETK_D4_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D5_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D6_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D7_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D8_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D9_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D10_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D11_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D12_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D13_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D14_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(ETK_D15_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + /*Die to Die */\ + MUX_VAL(CP(D2D_MCAD0), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD1), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD2), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD3), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD4), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD5), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD6), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD7), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD8), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD9), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD10), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD11), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD12), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD13), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD14), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD15), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD16), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD17), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD18), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD19), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD20), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD21), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD22), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD23), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD24), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD25), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD26), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD27), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD28), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD29), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD30), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD31), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD32), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD33), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD34), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD35), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD36), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_CLK26MI), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_NRESPWRON), (OFF_OUT_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_NRESWARM), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_ARM9NIRQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SPINT), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_FRINT), (OFF_IN_PD | IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_DMAREQ0), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ1), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ2), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ3), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTRST), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTDI), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTDO), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTMS), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTCK), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GRTCK), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MSTDBY), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_IDLEREQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_IDLEACK), (OFF_IN_PD | IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_MWRITE), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SWRITE), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MREAD), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SREAD), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MBUSFLAG), (OFF_IN_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SBUSFLAG), (OFF_OUT_PD | IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0))\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*SDRC_CKE1 NOT USED*/ + +/* + * GPMC Timing definitions for SDP3430 + * at L3 = 166Mhz + */ + +/* Timing definitions for GPMC controller for Sibley NOR */ +#define SDP3430_NOR_GPMC_CONF1 0x00001200 +#define SDP3430_NOR_GPMC_CONF2 0x001F1F00 +#define SDP3430_NOR_GPMC_CONF3 0x00080802 +#define SDP3430_NOR_GPMC_CONF4 0x1C091C09 +#define SDP3430_NOR_GPMC_CONF5 0x01131F1F +#define SDP3430_NOR_GPMC_CONF6 0x1F0F03C2 + +/* + * Timing definitions for GPMC controller for Debug Board + * Debug board contains access to ethernet and DIP Switch setting + * information etc. + */ +#define SDP3430_DEBUG_GPMC_CONF1 0x00611200 +#define SDP3430_DEBUG_GPMC_CONF2 0x001F1F01 +#define SDP3430_DEBUG_GPMC_CONF3 0x00080803 +#define SDP3430_DEBUG_GPMC_CONF4 0x1D091D09 +#define SDP3430_DEBUG_GPMC_CONF5 0x041D1F1F +#define SDP3430_DEBUG_GPMC_CONF6 0x1D0904C4 + +/* Timing defintions for GPMC OneNAND */ +#define SDP3430_ONENAND_GPMC_CONF1 0x00001200 +#define SDP3430_ONENAND_GPMC_CONF2 0x000F0F01 +#define SDP3430_ONENAND_GPMC_CONF3 0x00030301 +#define SDP3430_ONENAND_GPMC_CONF4 0x0F040F04 +#define SDP3430_ONENAND_GPMC_CONF5 0x010F1010 +#define SDP3430_ONENAND_GPMC_CONF6 0x1F060000 + +/* GPMC definitions for GPMC NAND */ +#define SDP3430_NAND_GPMC_CONF1 0x00000800 +#define SDP3430_NAND_GPMC_CONF2 0x00141400 +#define SDP3430_NAND_GPMC_CONF3 0x00141400 +#define SDP3430_NAND_GPMC_CONF4 0x0F010F01 +#define SDP3430_NAND_GPMC_CONF5 0x010C1414 +#define SDP3430_NAND_GPMC_CONF6 0x1F040A80 + +#endif /* _BOARD_SDP_H_ */ diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h new file mode 100644 index 0000000..229dc5e --- /dev/null +++ b/include/configs/omap3_sdp3430.h @@ -0,0 +1,369 @@ +/* + * (C) Copyright 2006-2009 + * Texas Instruments Incorporated. + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * Nishanth Menon nm@ti.com + * + * Configuration settings for the 3430 TI SDP3430 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* TODO: REMOVE THE FOLLOWING + * Retained the following till size.h is removed in u-boot + */ +#include <asm/sizes.h> +/* + * High Level Configuration Options + */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_3430SDP 1 /* working with SDP Rev2 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * NOTE: these #defines presume standard SDP jumper settings. + * In particular: + * - 26 MHz clock (not 19.2 or 38.4 MHz) + * - Boot from 128MB NOR, not NAND or OneNAND + * + * At this writing, OMAP3 U-Boot support doesn't permit concurrent + * support for all the flash types the board supports. + */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Size of malloc() pool + * Total Size Environment - 256k + * Malloc - add 256k + */ +#define CONFIG_ENV_SIZE (256 << 10) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (256 << 10)) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ + /* initial data */ + +/*--------------------------------------------------------------------------*/ + +/* + * Hardware drivers + */ + +/* + * TWL4030 + */ +#define CONFIG_TWL4030_POWER 1 + +/* + * serial port - NS16550 compatible + */ +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* Original SDP u-boot used UART1 and thus J8 (innermost); that can be + * swapped with UART2 via jumpering. Downsides of using J8: it doesn't + * support UART boot (that's only for UART3); it prevents sharing a Linux + * kernel (LL_DEBUG_UART3) or filesystem (getty ttyS2) with most boards. + * + * UART boot uses UART3 on J9, and the SDP user's guide says to use + * that for console. Downsides of using J9: you can't use IRDA too; + * since UART3 isn't in the CORE power domain, it may be a bit less + * usable in certain PM-sensitive debug scenarios. + */ +#undef CONSOLE_J9 /* else J8/UART1 (innermost) */ + +#ifdef CONSOLE_J9 +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 /* UART3 */ +#else +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 +#define CONFIG_SERIAL1 1 /* UART1 */ +#endif + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} + +/* + * I2C for power management setup + */ +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* OMITTED: single 1 Gbit MT29F1G NAND flash */ + +/* + * NOR boot support - single 1 Gbit PF48F6000M0 Strataflash + */ +#define CONFIG_SYS_FLASH_BASE 0x10000000 +#define CONFIG_FLASH_CFI_DRIVER 1 /* Use drivers/cfi_flash.c */ +#define CONFIG_SYS_FLASH_CFI 1 /* use CFI geometry data */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* ~10x faster writes */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* hardware sector protection */ +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 /* flinfo 'E' for empty */ +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE} +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of flash banks */ + +#define CONFIG_SYS_FLASH_CFI_WIDTH 2 +#define PHYS_FLASH_SIZE (128 << 20) +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max sectors on one chip */ + +/* timeout values are in milliseconds */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) + +/* OMITTED: single 2 Gbit KFM2G16 OneNAND flash */ + +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_SYS_ENV_SECT_SIZE (256 << 10) +#define CONFIG_ENV_OFFSET CONFIG_SYS_ENV_SECT_SIZE +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_ENV_SECT_SIZE) +/*--------------------------------------------------------------------------*/ + +/* commands to include */ +#include <config_cmd_default.h> + +/* Enabled commands */ +#define CONFIG_CMD_DHCP /* DHCP Support */ +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NET + +/* Disabled commands */ +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +/*--------------------------------------------------------------------------*/ +/* + * MMC boot support + */ + +#if defined(CONFIG_CMD_MMC) +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 +#endif + +/*---------------------------------------------------------------------------- + * SMSC9115 Ethernet from SMSC9118 family + *---------------------------------------------------------------------------- + */ +#if defined(CONFIG_CMD_NET) + +#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_LAN91C96_BASE DEBUG_BASE +#define CONFIG_LAN91C96_EXT_PHY + +#define CONFIG_BOOTP_SEND_HOSTNAME +/* + * BOOTP fields + */ +#define CONFIG_BOOTP_SUBNETMASK 0x00000001 +#define CONFIG_BOOTP_GATEWAY 0x00000002 +#define CONFIG_BOOTP_HOSTNAME 0x00000004 +#define CONFIG_BOOTP_BOOTPATH 0x00000010 +#endif /* (CONFIG_CMD_NET) */ + +/* + * Environment setup + * + * Default boot order: mmc bootscript, MMC uImage, NOR image. + * Network booting environment must be configured at site. + */ + +/* allow overwriting serial config and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS0,115200n8\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "norargs=setenv bootargs console=${console} " \ + "root=/dev/mtdblock3 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from MMC/SD ...; " \ + "autoscr ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from MMC/SD ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "norboot=echo Booting from NOR ...; " \ + "run norargs; " \ + "bootm 0x80000\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmcinit; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run norboot; " \ + "fi; " \ + "fi; " \ + "else run norboot; fi" + +#define CONFIG_AUTO_COMPLETE 1 + +/*--------------------------------------------------------------------------*/ + +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "OMAP34XX SDP # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +/* SDRAM Test range - start at 16 meg boundary -ends at 32Meg - + * a basic sanity check ONLY + * IF you would like to increase coverage, increase the end address + * or run the test with custom options + */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0 + 0x01000000) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + (32 << 20)) + +/* Default load address */ +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) + +/*--------------------------------------------------------------------------*/ + +/* + * 3430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by + * 32KHz clk, or from external sig. This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* Regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack */ +#endif + +/* + * SDRAM Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/*--------------------------------------------------------------------------*/ + +/* + * NOR FLASH usage ... default nCS0: + * - one 256KB sector for U-Boot + * - one 256KB sector for its parameters (not all used) + * - eight sectors (2 MB) for kernel + * - rest for JFFS2 + */ + +/* Monitor at start of flash */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +/* + * NAND FLASH usage ... default nCS1: + * - four 128KB sectors for X-Loader + * - four 128KB sectors for U-Boot + * - two 128KB sector for its parameters + * - 32 sectors (4 MB) for kernel + * - rest for filesystem + */ + +/* + * OneNAND FLASH usage ... default nCS2: + * - four 128KB sectors for X-Loader + * - two 128KB sectors for U-Boot + * - one 128KB sector for its parameters + * - sixteen sectors (2 MB) for kernel + * - rest for filesystem + */ + +/*--------------------------------------------------------------------------*/ + +#ifndef __ASSEMBLY__ +extern struct gpmc *gpmc_cfg; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +#endif /* __CONFIG_H */
Highlights of this platform are: Flash Memory devices: Sibley NOR, Micron 8bit NAND and OneNAND Connectivity: 3 UARTs and expanded 4 UART ports + IrDA Ethernet, USB Other peripherals: TWL5030 PMIC+Audio+Keypad VGA display Expansion ports: Memory devices plugin boards (PISMO) Connectivity board for GPS,WLAN etc.. Completely configurable boot sequence and device mapping etc.. For more details, please refer: http://focus.ti.com/general/docs/wtbu/wtbugencontent.tsp?templateId=6123&... avigationId=12013&contentId=28741
- Ethernet
- mmc0
- NOR boot
TODO:
- mmc1
Thanks
Pushed to u-boot-ti next
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=commit;h=b5b03ec30b2f4496db05c1...
Sandeep
Having this in u-boot-ti/next and building omap3_sdp3430 gives
eth.c:497:2: warning: #warning Ethernet driver is deprecated. Please update to use CONFIG_NET_MULTI
Please fix.
Thanks
Dirk
- Ethernet
- mmc0
- NOR boot
TODO:
- mmc1
- omap3_sdp3430 ARM CORTEX-A8 (OMAP3xx SoC) omap3_zoom1 ARM CORTEX-A8 (OMAP3xx SoC)
- omap3_sdp3430 \ omap3_zoom1 \ omap3_zoom2 \
- @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 sdp3430 ti omap3
+COBJS := sdp.o
- $(AR) $(ARFLAGS) $@ $(OBJS)
+clean:
- rm -f $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- (C) Copyright 2004-2009
- Texas Instruments Incorporated, <www.ti.com>
- Richard Woodruff r-woodruff2@ti.com
- project.
- MA 02111-1307 USA
- DDR_DISCRETE,
- "OMAP3 SDP3430 board",
- "OneNAND",
- "NAND",
+#else
- "NOR",
+#endif +};
- SDP3430_NOR_GPMC_CONF1,
- SDP3430_NOR_GPMC_CONF2,
- SDP3430_NOR_GPMC_CONF3,
- SDP3430_NOR_GPMC_CONF4,
- SDP3430_NOR_GPMC_CONF5,
- SDP3430_NOR_GPMC_CONF6,
- /*CONF7- computed as params */
- Timing definitions for GPMC controller for Debug Board
- Debug board contains access to ethernet and DIP Switch setting
- information etc.
- SDP3430_DEBUG_GPMC_CONF1,
- SDP3430_DEBUG_GPMC_CONF2,
- SDP3430_DEBUG_GPMC_CONF3,
- SDP3430_DEBUG_GPMC_CONF4,
- SDP3430_DEBUG_GPMC_CONF5,
- SDP3430_DEBUG_GPMC_CONF6,
- SDP3430_ONENAND_GPMC_CONF1,
- SDP3430_ONENAND_GPMC_CONF2,
- SDP3430_ONENAND_GPMC_CONF3,
- SDP3430_ONENAND_GPMC_CONF4,
- SDP3430_ONENAND_GPMC_CONF5,
- SDP3430_ONENAND_GPMC_CONF6,
- SDP3430_NAND_GPMC_CONF1,
- SDP3430_NAND_GPMC_CONF2,
- SDP3430_NAND_GPMC_CONF3,
- SDP3430_NAND_GPMC_CONF4,
- SDP3430_NAND_GPMC_CONF5,
- SDP3430_NAND_GPMC_CONF6,
- @brief board_init - gpmc and basic setup as phase1 of boot sequence
- @return 0
- DECLARE_GLOBAL_DATA_PTR;
- gpmc_init(); /* in SRAM or SDRAM, finish GPMC */
- /* TODO: Dynamically pop out CS mapping and program accordingly */
- /* Configure devices for default ON ON ON settings */
- enable_gpmc_cs_config(gpmc_sdp_nor, &gpmc_cfg->cs[0],
- enable_gpmc_cs_config(gpmc_sdp_nand, &gpmc_cfg->cs[1], 0x28000000,
GPMC_SIZE_16M);
- enable_gpmc_cs_config(gpmc_sdp_onenand, &gpmc_cfg->cs[2], 0x20000000,
GPMC_SIZE_16M);
- enable_gpmc_cs_config(gpmc_sdp_debug, &gpmc_cfg->cs[3], DEBUG_BASE,
GPMC_SIZE_16M);
- /* board id for Linux */
- gd->bd->bi_arch_number = MACH_TYPE_OMAP_3430SDP;
- /* boot param addr */
- gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
- @brief ether_init Take the Ethernet controller out of reset and wait
- for the EEPROM load to complete.
- int cnt = 20;
- writew(0x0, LAN_RESET_REGISTER);
- do {
udelay(100);
if (cnt == 0)
goto reset_err_out;
--cnt;
- } while (readw(LAN_RESET_REGISTER) != 0x1);
- cnt = 20;
- do {
udelay(100);
if (cnt == 0)
goto reset_err_out;
--cnt;
- } while (readw(LAN_RESET_REGISTER) != 0x0000);
- udelay(1000);
- writeb(readb(ETH_CONTROL_REG) & ~0x1, ETH_CONTROL_REG);
- udelay(1000);
+reset_err_out:
- return;
+#endif +}
- @brief misc_init_r - Configure SDP board specific configurations
- such as power configurations, ethernet initialization as phase2 of
- boot sequence
- @return 0
- /* Partial setup:
* VPLL1 - 1.8V
* VDAC - 1.8V
- twl4030_power_init();
- /* FIXME finish setup:
* VPLL2 - 1.8V
- ether_init();
- @brief set_muxconf_regs Setting up the configuration Mux registers
- specific to the hardware. Many pins need to be moved from protect
- to primary mode.
- /* platform specific muxes */
- MUX_SDP3430();
- project.
- MA 02111-1307 USA
- IEN - Input Enable
- IDIS - Input Disable
- PTD - Pull type Down
- PTU - Pull type Up
- DIS - Pull type selection is inactive
- EN - Pull type selection is active
- M0 - Mode 0
- The commented string gives the final mux configuration for that pin
- /*SDRC*/\
- MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0))\
- /*GPMC*/\
- MUX_VAL(CP(GPMC_A1), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A3), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A4), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A5), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A6), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A7), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A8), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A9), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_A10), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D0), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D1), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D3), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D4), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D5), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D6), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D7), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D8), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D9), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D10), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D11), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D12), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D13), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D14), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_D15), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NCS0), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_NCS1), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_NCS2), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_NCS3), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_NCS4), (OFF_IN_PD | IEN | PTU | EN | M4)) /*G55-F_DIS*/\
- MUX_VAL(CP(GPMC_NCS5), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G56T_EN*/\
- MUX_VAL(CP(GPMC_NCS6), (OFF_IN_PD | IEN | PTD | DIS | M4))/*G57-AGPSP*/\
- MUX_VAL(CP(GPMC_NCS7), (OFF_IN_PD | IEN | PTU | EN | M4))/*G58-WLNIQ*/\
- MUX_VAL(CP(GPMC_CLK), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NADV_ALE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NOE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NWE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NBE0_CLE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NBE1), (OFF_IN_PD | IEN | PTD | DIS | M4)) /*G61-BTST*/\
- MUX_VAL(CP(GPMC_NWP), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_WAIT0), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_WAIT1), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_WAIT2), (OFF_IN_PD | IEN | PTU | EN | M4)) /*GPIO_64*/\
- MUX_VAL(CP(GPMC_WAIT3), (OFF_IN_PD | IEN | PTU | EN | M4)) /*GPIO_65*/\
- /*DSS*/\
- MUX_VAL(CP(DSS_PCLK), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_HSYNC), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_VSYNC), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_ACBIAS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA0), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA1), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA3), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA4), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA5), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA6), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA7), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA8), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA9), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA10), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA11), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA12), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA13), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA14), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA15), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA16), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA17), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA18), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA19), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA20), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA21), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA22), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(DSS_DATA23), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- /*CAMERA*/\
- MUX_VAL(CP(CAM_HS), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(CAM_VS), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(CAM_XCLKA), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_PCLK), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(CAM_FLD), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G98-C_RST*/\
- MUX_VAL(CP(CAM_D0), (OFF_IN_PD | IEN | PTD | DIS | M2)) /*CAM_D0 */\
- MUX_VAL(CP(CAM_D1), (OFF_IN_PD | IEN | PTD | DIS | M2)) /*CAM_D1 */\
- MUX_VAL(CP(CAM_D2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D3), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D4), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D5), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D6), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D7), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D8), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D9), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D10), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_D11), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_XCLKB), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(CAM_WEN), (OFF_IN_PD | IEN | PTD | DIS | M4)) /*GPIO_167*/\
- MUX_VAL(CP(CAM_STROBE), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(CSI2_DX0), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CSI2_DY0), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CSI2_DX1), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(CSI2_DY1), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- /*Audio InterfACe */\
- MUX_VAL(CP(MCBSP2_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP2_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP2_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP2_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- /*Expansion Card */\
- MUX_VAL(CP(MMC1_CLK), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_CMD), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT0), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT1), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT2), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT3), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT4), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT5), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT6), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC1_DAT7), (OFF_IN_PD | IEN | PTU | EN | M0))\
- /*Wireless LAN */\
- MUX_VAL(CP(MMC2_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MMC2_CMD), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC2_DAT0), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC2_DAT1), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC2_DAT2), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC2_DAT3), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MMC2_DAT4), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DRD0*/\
- MUX_VAL(CP(MMC2_DAT5), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DRD1*/\
- MUX_VAL(CP(MMC2_DAT6), (OFF_OUT_PD | IDIS | PTD | DIS | M1))/*DCMD*/\
- MUX_VAL(CP(MMC2_DAT7), (OFF_IN_PD | IEN | PTU | EN | M1))/*CLKIN*/\
- /*Bluetooth*/\
- MUX_VAL(CP(MCBSP3_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP3_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP3_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP3_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(UART2_CTS), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(UART2_RTS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(UART2_TX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(UART2_RX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- /*Modem Interface */\
- MUX_VAL(CP(UART1_TX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(UART1_RTS), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(UART1_CTS), (OFF_IN_PD | IEN | PTU | DIS | M0))\
- MUX_VAL(CP(UART1_RX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP4_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1DRX*/\
- MUX_VAL(CP(MCBSP4_DR), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1FLGRX*/\
- MUX_VAL(CP(MCBSP4_DX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1RDYRX*/\
- MUX_VAL(CP(MCBSP4_FSX), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SSI1WAKE*/\
- MUX_VAL(CP(MCBSP1_CLKR), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP1_FSR), (OFF_OUT_PD | IDIS | PTU | EN | M4))/*G157BWP*/\
- MUX_VAL(CP(MCBSP1_DX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP1_DR), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP_CLKS), (OFF_IN_PD | IEN | PTU | DIS | M0))\
- MUX_VAL(CP(MCBSP1_FSX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCBSP1_CLKX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- /*Serial Interface*/\
- MUX_VAL(CP(UART3_CTS_RCTX), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(UART3_RTS_SD), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(UART3_RX_IRRX), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(UART3_TX_IRTX), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_STP), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(HSUSB0_DIR), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_NXT), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA0), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA1), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA3), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA4), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA5), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA6), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(HSUSB0_DATA7), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- /* NOTE db: removed off-mode from I2C 1/2/3 ... external pullups!! */\
- MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(HDQ_SIO), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(MCSPI1_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI1_SIMO), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI1_SOMI), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI1_CS0), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(MCSPI1_CS1), (OFF_OUT_PD | IDIS | PTD | EN | M0))\
- MUX_VAL(CP(MCSPI1_CS2), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G176*/\
- MUX_VAL(CP(MCSPI1_CS3), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(MCSPI2_CLK), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI2_SIMO), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI2_SOMI), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(MCSPI2_CS0), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(MCSPI2_CS1), (OFF_IN_PD | IEN | PTD | EN | M0))\
- /*Control and debug */\
- MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SYS_NIRQ), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(SYS_BOOT0), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G2PENIRQ*/\
- MUX_VAL(CP(SYS_BOOT1), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*GPIO_3 */\
- MUX_VAL(CP(SYS_BOOT2), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G4MMC1WP*/\
- MUX_VAL(CP(SYS_BOOT3), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G5LCDENV*/\
- MUX_VAL(CP(SYS_BOOT4), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G6LANINT*/\
- MUX_VAL(CP(SYS_BOOT5), (OFF_OUT_PD | IEN | PTD | DIS | M4))/*G7MMC2WP*/\
- MUX_VAL(CP(SYS_BOOT6), (OFF_OUT_PD | IDIS | PTD | DIS | M4))/*G8ENBKL*/\
- MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SYS_CLKOUT2), (OFF_IN_PD | IEN | PTU | EN | M4))/*GPIO_186*/\
- MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(JTAG_EMU0), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(JTAG_EMU1), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_CLK_ES2), (OFF_OUT_PD | IDIS | PTU | EN | M0))\
- MUX_VAL(CP(ETK_CTL_ES2), (OFF_OUT_PD | IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D0_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*USB1TLD0*/\
- MUX_VAL(CP(ETK_D1_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*SPI3_CS0*/\
- MUX_VAL(CP(ETK_D2_ES2), (OFF_IN_PD | IEN | PTD | EN | M1))/*USB1TLD2*/\
- MUX_VAL(CP(ETK_D3_ES2), (OFF_IN_PD | IEN | PTD | DIS | M1))/*USB1TLD7*/\
- MUX_VAL(CP(ETK_D4_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D5_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D6_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D7_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D8_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D9_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D10_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D11_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D12_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D13_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D14_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(ETK_D15_ES2), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- /*Die to Die */\
- MUX_VAL(CP(D2D_MCAD0), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD1), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD2), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD3), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD4), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD5), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD6), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD7), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD8), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD9), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD10), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD11), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD12), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD13), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD14), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD15), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD16), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD17), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD18), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD19), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD20), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD21), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD22), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD23), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD24), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD25), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD26), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD27), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD28), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD29), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD30), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD31), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD32), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD33), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD34), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD35), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_MCAD36), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_CLK26MI), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_NRESPWRON), (OFF_OUT_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_NRESWARM), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(D2D_ARM9NIRQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_UMA2P6FIQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_SPINT), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_FRINT), (OFF_IN_PD | IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_DMAREQ0), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_DMAREQ1), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_DMAREQ2), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_DMAREQ3), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GTRST), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GTDI), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GTDO), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GTMS), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GTCK), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_N3GRTCK), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_MSTDBY), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0))\
- MUX_VAL(CP(D2D_IDLEREQ), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_IDLEACK), (OFF_IN_PD | IEN | PTU | EN | M0))\
- MUX_VAL(CP(D2D_MWRITE), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_SWRITE), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_MREAD), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_SREAD), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_MBUSFLAG), (OFF_IN_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(D2D_SBUSFLAG), (OFF_OUT_PD | IEN | PTD | DIS | M0))\
- MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0))\
- MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*SDRC_CKE1 NOT USED*/
- GPMC Timing definitions for SDP3430
- at L3 = 166Mhz
- information etc.
- (C) Copyright 2006-2009
- Texas Instruments Incorporated.
- Syed Mohammed Khasim x0khasim@ti.com
- Nishanth Menon nm@ti.com
- Configuration settings for the 3430 TI SDP3430 board.
- project.
- MA 02111-1307 USA
- Retained the following till size.h is removed in u-boot
- High Level Configuration Options
- NOTE: these #defines presume standard SDP jumper settings.
- In particular:
- At this writing, OMAP3 U-Boot support doesn't permit concurrent
- support for all the flash types the board supports.
- Size of malloc() pool
- Total Size Environment - 256k
- Malloc - add 256k
/* initial data */
- Hardware drivers
- TWL4030
- serial port - NS16550 compatible
- swapped with UART2 via jumpering. Downsides of using J8: it doesn't
- support UART boot (that's only for UART3); it prevents sharing a Linux
- kernel (LL_DEBUG_UART3) or filesystem (getty ttyS2) with most boards.
- UART boot uses UART3 on J9, and the SDP user's guide says to use
- that for console. Downsides of using J9: you can't use IRDA too;
- since UART3 isn't in the CORE power domain, it may be a bit less
- usable in certain PM-sensitive debug scenarios.
115200}
- I2C for power management setup
- NOR boot support - single 1 Gbit PF48F6000M0 Strataflash
- MMC boot support
- SMSC9115 Ethernet from SMSC9118 family
- BOOTP fields
- Environment setup
- Default boot order: mmc bootscript, MMC uImage, NOR image.
- Network booting environment must be configured at site.
- "loadaddr=0x82000000\0" \
- "console=ttyS0,115200n8\0" \
- "mmcargs=setenv bootargs console=${console} " \
- "norargs=setenv bootargs console=${console} " \
- "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \
- "bootscript=echo Running bootscript from MMC/SD ...; " \
- "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \
- "mmcboot=echo Booting from MMC/SD ...; " \
"run mmcargs; " \
- "norboot=echo Booting from NOR ...; " \
"run norargs; " \
"bootm 0x80000\0" \
- "if mmcinit; then " \
"else " \
"run mmcboot; " \
"fi; " \
"fi; " \
- "else run norboot; fi"
- Miscellaneous configurable options
- a basic sanity check ONLY
- IF you would like to increase coverage, increase the end address
- or run the test with custom options
- 3430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by
- 32KHz clk, or from external sig. This rate is divided by a local divisor.
- Stack sizes
- The stack sizes are set up in start.S using the settings below
- SDRAM Memory Map
- NOR FLASH usage ... default nCS0:
- rest for JFFS2
- NAND FLASH usage ... default nCS1:
- OneNAND FLASH usage ... default nCS2:
Dirk Behme
Nishanth Menon
Paulraj, Sandeep
