[U-Boot] relocation problem (again)
Dear Marcel, Dear Reinhard,
sorry I forgot to mention, that this is in reply to http://lists.denx.de/pipermail/u-boot/2011-January/084499.html
I have the same problem with my board and the actual u-boot-atmel (git from 5th Aug. 2011). It even looks like I am using the same board. It is a in-circuit ICnova SAM9G45 OEM on a ADB1000 with a 5" display.
Actually I use the u-boot from in-circuit, which is a patched version basing on u-boot from 2009. I would like to upgrade this old version to the actual u-boot version. Some time ago somebody tried to get the in-circuit patch into the u-boot mainstream, but the patch was rejected because of not meeting the coding rules.
Marcel, can you give me a hint what you changed to get your configuration running ? I used the latest code for the at91sam9m10g45ek as reference and added/changed it.
Starting the old u-boot version with patches from in-circuit: -------------------------------------------------------------
Start AT91Bootstrap
U-Boot 2009.11 (Jun 18 2011 - 19:57:09)
DRAM: 128 MB Flash: 1 MB NAND: 256 MiB In: serial Out: serial Err: serial MMC: Atmel MCI: 0 Net: macb0 Hit any key to stop autoboot: 0 ICnova>
Starting u-boot-atmel (git) from 5th Aug. 2011: ------------------------------------------------
Start AT91Bootstrap
U-Boot 2011.06 (Aug 10 2011 - 20:49:32)
U-Boot code: 73F00000 -> 73F45494 BSS: -> 73F87110 CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz monitor len: 00087110 ramsize: 08000000 TLB table at: 77ff0000 Top of RAM usable for U-Boot at: 77ff0000 Reserving 540k for U-Boot at: 77f68000 Reserving 384k for malloc() at: 77f08000 Reserving 24 Bytes for Board Info at: 77f07fe8 Reserving 144 Bytes for Global Data at: 77f07f58 New Stack Pointer is: 77f07f48 RAM Configuration: Bank #0: 70000000 128 MiB relocation Offset is: 04068000
no more output, it seems the relocation fails. I have a #DEBUG in lib/board.c to get the above output.
Here is my configuration:
/* * Configuation settings for the ICNOVA ADB1000 with SAM9G45 OEM and 5" TFT. * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */
#ifndef __CONFIG_H #define __CONFIG_H
#include <asm/hardware.h>
#define CONFIG_AT91_LEGACY #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
/* ARM asynchronous clock */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */ #define CONFIG_SYS_HZ 1000
#define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */
#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DISPLAY_CPUINFO
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ #define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
/* * This needs to be defined for the OHCI code to work but it is defined as * ATMEL_ID_UHPHS in the CPU specific header files. */ #define ATMEL_ID_UHP ATMEL_ID_UHPHS
/* * Specify the clock enable bit in the PMC_SCER register. */ #define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* LCD */ #define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN #define CONFIG_LCD_INFO #define CONFIG_LCD_INFO_BELOW_LOGO #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_ICNOVA_LCD_BASE 0x73E00000
#define CONFIG_BOOTDELAY 3
/* * Command line configuration. */ #include <config_cmd_default.h> #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DHCP #define CONFIG_CMD_USB #define CONFIG_CMD_NAND #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define CONFIG_MTD_NAND_ECC_JFFS2 //#define CONFIG_CMD_UBIFS #define CONFIG_CMD_PING #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_FLASH #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION 1 #undef CONFIG_CMD_FPGA
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x70000000 #define CONFIG_SYS_SDRAM_SIZE 0x08000000 /* 128 megs */
/* NOR flash */ #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_SYS_FLASH_SIZE 0x00100000 #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_SECT 8 #define CONFIG_SYS_MAX_FLASH_SECT (CONFIG_SYS_FLASH_SECT+1) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_FLASH_CFI_WIDTH FLASH_CFI_16BIT
/* NAND flash */ #define CONFIG_JFFS2_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_MAX_CHIPS 1 #define CONFIG_NAND_ATMEL #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_DBW_8 #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* our ALE is AD21 */ #define CONFIG_SYS_NAND_MASK_CLE (1 << 22) /* our CLE is AD22 */ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC8 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC11
#define MTDIDS_DEFAULT "nand0=nand.0" #define MTDPARTS_DEFAULT "mtdparts=nand.0:2M(kernel),16M(root),-(Data)"
/* MCI */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC #define CONFIG_GENERIC_ATMEL_MCI #define MMCI_BASE 0xFFF80000
/* Ethernet */ #define CONFIG_MACB #define CONFIG_NET_MULTI
/* USB */ #define CONFIG_USB_ATMEL #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91SAM9G45_UHP_OHCI_BASE */ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "adb1000" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE
#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x00400000) /* Allow 4MB for the kernel run-time image */
#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + CONFIG_SYS_SDRAM_SIZE)
/* bootstrap + u-boot + env in norflash */ #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SIZE (CONFIG_SYS_FLASH_SIZE / CONFIG_SYS_FLASH_SECT) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_SIZE - CONFIG_ENV_SIZE)
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 }
#define CONFIG_SYS_PROMPT "u-boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (256*1024)
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000)
#ifdef CONFIG_USE_IRQ #error CONFIG_USE_IRQ not supported #endif
#endif
and this is my board file:
/* * (C) Copyright 2007-2008 * Stelian Pop stelian.pop@leadtechdesign.com * Lead Tech Design <www.leadtechdesign.com> * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */
#include <common.h> #include <asm/io.h> #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> #include <mmc.h> #include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif #include <netdev.h>
DECLARE_GLOBAL_DATA_PTR;
/* ------------------------------------------------------------------------- */ /* * Miscelaneous platform dependent initialisations */
#ifdef CONFIG_CMD_NAND void icnova_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ csa = readl(&matrix->ebicsa); csa |= AT91_MATRIX_EBI_CS3A_SMC_SMARTMEDIA; writel(csa, &matrix->ebicsa);
/* Configure SMC CS3 for NAND/SmartMedia */ writel(AT91_SMC_SETUP_NWE(8) | AT91_SMC_SETUP_NCS_WR(0) | AT91_SMC_SETUP_NRD(8) | AT91_SMC_SETUP_NCS_RD(0), &smc->cs[3].setup); writel(AT91_SMC_PULSE_NWE(28) | AT91_SMC_PULSE_NCS_WR(20) | AT91_SMC_PULSE_NRD(28) | AT91_SMC_PULSE_NCS_RD(20), &smc->cs[3].pulse); writel(AT91_SMC_CYCLE_NWE(36) | AT91_SMC_CYCLE_NRD(36), &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE | #ifdef CONFIG_SYS_NAND_DBW_16 AT91_SMC_MODE_DBW_16 | #else /* CONFIG_SYS_NAND_DBW_8 */ AT91_SMC_MODE_DBW_8 | #endif AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
writel(1 << ATMEL_ID_PIOC, &pmc->pcer);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
/* Enable NandFlash */ at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); } #endif
#ifdef CONFIG_CMD_USB static void icnova_usb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
writel(1 << ATMEL_ID_PIODE, &pmc->pcer);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); } #endif
#ifdef CONFIG_MACB static void icnova_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* * Disable pull-up on: * RXDV (PA15) => PHY normal mode (not Test mode) * ERX0 (PA12) => PHY ADDR0 * ERX1 (PA13) => PHY ADDR1 * ERX2 (PA8) => PHY ADDR2 * ERX3 (PA9) => PHY ADDR3 * ECRS (PA29) => PHY ADDR4 => PHYADDR = 0x0 * ECOL (PA30) => full MII interface * ERXER (PA16) => no repeater * ETXCLK (PA17) => no isolate */ unsigned long phy_mask = 0; /* Reset and pdwn-pins */ unsigned long rst = pin_to_mask(AT91_PIN_PA27); unsigned long pdwn = 0;
phy_mask = pin_to_mask(AT91_PIN_PA15) | pin_to_mask(AT91_PIN_PA8) | pin_to_mask(AT91_PIN_PA9) | pin_to_mask(AT91_PIN_PA12) | pin_to_mask(AT91_PIN_PA13) | pin_to_mask(AT91_PIN_PA29) | pin_to_mask(AT91_PIN_PA30) | pin_to_mask(AT91_PIN_PA16) | pin_to_mask(AT91_PIN_PA17); rst = pin_to_mask(AT91_PIN_PA26); pdwn = pin_to_mask(AT91_PIN_PA25);
/* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
/* * Set up Pins */ writel(rst | pdwn | phy_mask, pin_to_controller(AT91_PIN_PA0) + PIO_PER); writel(rst | pdwn | phy_mask, pin_to_controller(AT91_PIN_PA0) + PIO_OER); writel(rst | pdwn | phy_mask, pin_to_controller(AT91_PIN_PA0) + PIO_CODR); udelay(1000); writel(rst, pin_to_controller(AT91_PIN_PA0) + PIO_SODR); udelay(500000); // phy-mask will be resetted by internal hardware
/* And the pins. */ at91_macb_hw_init(); } #endif
#ifdef CONFIG_LCD
vidinfo_t panel_info = { vl_col: 800, vl_row: 480, vl_clk: 33260000, vl_sync: ATMEL_LCDC_INVLINE_NORMAL | ATMEL_LCDC_INVFRAME_NORMAL, vl_bpix: 3, vl_tft: 1, vl_hsync_len: 40, vl_left_margin: 176, vl_right_margin:38, vl_vsync_len: 2, vl_upper_margin:35, vl_lower_margin:8, mmio : ATMEL_BASE_LCDC, };
void lcd_enable(void) { at91_set_A_periph(AT91_PIN_PE6, 1); /* power up */ }
void lcd_disable(void) { at91_set_A_periph(AT91_PIN_PE6, 0); /* power down */ }
static void icnova_lcd_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */ at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */ at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */ at91_set_A_periph(AT91_PIN_PE4, 0); /* LCDHSYNC */ at91_set_A_periph(AT91_PIN_PE5, 0); /* LCDDOTCK */
at91_set_A_periph(AT91_PIN_PE7, 0); /* LCDD0 */ at91_set_A_periph(AT91_PIN_PE8, 0); /* LCDD1 */ at91_set_A_periph(AT91_PIN_PE9, 0); /* LCDD2 */ at91_set_A_periph(AT91_PIN_PE10, 0); /* LCDD3 */ at91_set_A_periph(AT91_PIN_PE11, 0); /* LCDD4 */ at91_set_A_periph(AT91_PIN_PE12, 0); /* LCDD5 */ at91_set_A_periph(AT91_PIN_PE13, 0); /* LCDD6 */ at91_set_A_periph(AT91_PIN_PE14, 0); /* LCDD7 */ at91_set_A_periph(AT91_PIN_PE15, 0); /* LCDD8 */ at91_set_A_periph(AT91_PIN_PE16, 0); /* LCDD9 */ at91_set_A_periph(AT91_PIN_PE17, 0); /* LCDD10 */ at91_set_A_periph(AT91_PIN_PE18, 0); /* LCDD11 */ at91_set_A_periph(AT91_PIN_PE19, 0); /* LCDD12 */ at91_set_B_periph(AT91_PIN_PE20, 0); /* LCDD13 */ at91_set_A_periph(AT91_PIN_PE21, 0); /* LCDD14 */ at91_set_A_periph(AT91_PIN_PE22, 0); /* LCDD15 */ at91_set_A_periph(AT91_PIN_PE23, 0); /* LCDD16 */ at91_set_A_periph(AT91_PIN_PE24, 0); /* LCDD17 */ at91_set_A_periph(AT91_PIN_PE25, 0); /* LCDD18 */ at91_set_A_periph(AT91_PIN_PE26, 0); /* LCDD19 */ at91_set_A_periph(AT91_PIN_PE27, 0); /* LCDD20 */ at91_set_B_periph(AT91_PIN_PE28, 0); /* LCDD21 */ at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
writel(1 << ATMEL_ID_LCDC, &pmc->pcer);
gd->fb_base = CONFIG_ICNOVA_LCD_BASE; }
#ifdef CONFIG_LCD_INFO #include <nand.h> #include <version.h>
void lcd_show_board_info(void) { ulong dram_size, nand_size; int i; char temp[32];
lcd_printf ("%s\n", U_BOOT_VERSION); lcd_printf ("(C) 2008 ATMEL Corp\n"); lcd_printf ("at91support@atmel.com\n"); lcd_printf ("%s CPU at %s MHz\n", ATMEL_CPU_NAME, strmhz(temp, get_cpu_clk_rate()));
dram_size = 0; for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) dram_size += gd->bd->bi_dram[i].size; nand_size = 0; for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) nand_size += nand_info[i].size; lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", dram_size >> 20, nand_size >> 20 ); } #endif /* CONFIG_LCD_INFO */ #endif
int board_early_init_f(void) { at91_seriald_hw_init(); return 0; }
#ifdef CONFIG_MMC static void icnova_mmc_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
at91_set_A_periph(AT91_PIN_PA0, 0); at91_set_A_periph(AT91_PIN_PA1, 1); at91_set_A_periph(AT91_PIN_PA2, 1); at91_set_A_periph(AT91_PIN_PA3, 1); at91_set_A_periph(AT91_PIN_PA4, 1); at91_set_A_periph(AT91_PIN_PA5, 1);
writel(1 << ATMEL_ID_MCI0, &pmc->pcer); }
int board_mmc_init(bd_t *bd) { icnova_mmc_init(); return atmel_mci_init(bd); } #endif
int board_init(void) { /* Enable Ctrlc */ console_init_f();
gd->bd->bi_arch_number = MACH_TYPE_AT91SAM9G45EKES;
/* adress of boot parameters */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
#ifdef CONFIG_CMD_NAND icnova_nand_hw_init(); #endif
#ifdef CONFIG_CMD_USB icnova_usb_hw_init(); #endif
#ifdef CONFIG_MACB icnova_macb_hw_init(); #endif #ifdef CONFIG_LCD icnova_lcd_hw_init(); #endif return 0; }
int dram_init(void) { gd->ram_size = get_ram_size((void *) CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE); return 0; }
#ifdef CONFIG_RESET_PHY_R void reset_phy(void) { #ifdef CONFIG_MACB /* * Initialize ethernet HW addr prior to starting Linux, * needed for nfsroot */ eth_init(gd->bd); #endif } #endif
int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB rc = macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC, 0x00); #endif return rc; }
Can you see anything that could cause the relocation problem?
I would also like to get rid of the AT91Bootstrap. Marcel, did you manage to include the NOR boot code into u-boot?
I am using the ELDK-4.2 as toolchain, could this cause the problem?
Cajus
Dear Cajus Hahn,
I suppose you have not followed the steps I pointed out then?
I have the same problem with my board and the actual u-boot-atmel (git ...
Please do not repeat the same message.
Best Regards, Reinhard
Hi Reinhard,
Dear Cajus Hahn,
I have to admit that I'm responsible for this repetition. The copy of Cajus' mail that I received missed your address in the CC header, so I told Cajus off-list to explicitely CC you to increase chances of you reading the mail. Of course this misleading instruction by myself led to confusion and the repeated message.
So I take the blame for this, sorry. Detlev
Cajus Hahn
Detlev Zundel
Reinhard Meyer
