[U-Boot] [PATCH v3 1/3] rockchip: rk3399: derive ethaddr from cpuid
Generate a MAC address based on the cpuid available in the efuse block: Use the first 6 byte of the cpuid's SHA256 hash and set the locally administered bits. Also ensure that the multicast bit is cleared.
The MAC address is only generated and set if there is no ethaddr present in the saved environment.
This is based off of Klaus Goger's work in 8adc9d
Signed-off-by: Rohan Garg rohan.garg@collabora.com
arch/arm/include/asm/arch-rockchip/misc.h | 13 +++ arch/arm/mach-rockchip/Makefile | 4 + arch/arm/mach-rockchip/misc.c | 112 ++++++++++++++++++++++ arch/arm/mach-rockchip/rk3399-board.c | 21 ++++ 4 files changed, 150 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/misc.h create mode 100644 arch/arm/mach-rockchip/misc.c
diff --git a/arch/arm/include/asm/arch-rockchip/misc.h b/arch/arm/include/asm/arch-rockchip/misc.h new file mode 100644 index 0000000000..b6b03c934e --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/misc.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * RK3399: Architecture common definitions + * + * Copyright (C) 2019 Collabora Inc - https://www.collabora.com/ + * Rohan Garg rohan.garg@collabora.com + */ + +int rockchip_cpuid_from_efuse(const u32 cpuid_offset, + const u32 cpuid_length, + u8 *cpuid); +int rockchip_cpuid_set(const u8 *cpuid, const u32 cpuid_length); +int rockchip_setup_macaddr(void); diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index a12b8d4434..b32c4d6143 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -37,6 +37,10 @@ endif
obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
+ifdef CONFIG_MISC_INIT_R +obj-y += misc.o +endif + obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ ifndef CONFIG_TPL_BUILD diff --git a/arch/arm/mach-rockchip/misc.c b/arch/arm/mach-rockchip/misc.c new file mode 100644 index 0000000000..7b6ec18551 --- /dev/null +++ b/arch/arm/mach-rockchip/misc.c @@ -0,0 +1,112 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * RK3399: Architecture common definitions + * + * Copyright (C) 2019 Collabora Inc - https://www.collabora.com/ + * Rohan Garg rohan.garg@collabora.com + * + * Based on puma-rk3399.c: + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + */ + +#include <common.h> +#include <u-boot/sha256.h> +#include <dm/uclass-internal.h> +#include <environment.h> + +#include <asm/arch-rockchip/misc.h> + +int rockchip_setup_macaddr(void) +{ +#if CONFIG_IS_ENABLED(CMD_NET) + int ret; + const char *cpuid = env_get("cpuid#"); + u8 hash[SHA256_SUM_LEN]; + int size = sizeof(hash); + u8 mac_addr[6]; + + /* Only generate a MAC address, if none is set in the environment */ + if (env_get("ethaddr")) + return -1; + + if (!cpuid) { + debug("%s: could not retrieve 'cpuid#'\n", __func__); + return -1; + } + + ret = hash_block("sha256", (void *)cpuid, strlen(cpuid), hash, &size); + if (ret) { + debug("%s: failed to calculate SHA256\n", __func__); + return -1; + } + + /* Copy 6 bytes of the hash to base the MAC address on */ + memcpy(mac_addr, hash, 6); + + /* Make this a valid MAC address and set it */ + mac_addr[0] &= 0xfe; /* clear multicast bit */ + mac_addr[0] |= 0x02; /* set local assignment bit (IEEE802) */ + eth_env_set_enetaddr("ethaddr", mac_addr); +#endif + return 0; +} + +int rockchip_cpuid_from_efuse(const u32 cpuid_offset, + const u32 cpuid_length, + u8 *cpuid) +{ +#if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) + struct udevice *dev; + int ret; + + /* retrieve the device */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(rockchip_efuse), &dev); + if (ret) { + debug("%s: could not find efuse device\n", __func__); + return -1; + } + + /* read the cpu_id range from the efuses */ + ret = misc_read(dev, cpuid_offset, cpuid, sizeof(cpuid)); + if (ret) { + debug("%s: reading cpuid from the efuses failed\n", + __func__); + return -1; + } +#endif + return 0; +} + +int rockchip_cpuid_set(const u8 *cpuid, const u32 cpuid_length) +{ + u8 low[cpuid_length / 2], high[cpuid_length / 2]; + char cpuid_str[cpuid_length * 2 + 1]; + u64 serialno; + char serialno_str[17]; + int i; + + memset(cpuid_str, 0, sizeof(cpuid_str)); + for (i = 0; i < 16; i++) + sprintf(&cpuid_str[i * 2], "%02x", cpuid[i]); + + debug("cpuid: %s\n", cpuid_str); + + /* + * Mix the cpuid bytes using the same rules as in + * ${linux}/drivers/soc/rockchip/rockchip-cpuinfo.c + */ + for (i = 0; i < 8; i++) { + low[i] = cpuid[1 + (i << 1)]; + high[i] = cpuid[i << 1]; + } + + serialno = crc32_no_comp(0, low, 8); + serialno |= (u64)crc32_no_comp(serialno, high, 8) << 32; + snprintf(serialno_str, sizeof(serialno_str), "%016llx", serialno); + + env_set("cpuid#", cpuid_str); + env_set("serial#", serialno_str); + + return 0; +} diff --git a/arch/arm/mach-rockchip/rk3399-board.c b/arch/arm/mach-rockchip/rk3399-board.c index 443c87cccc..3ffaaceab6 100644 --- a/arch/arm/mach-rockchip/rk3399-board.c +++ b/arch/arm/mach-rockchip/rk3399-board.c @@ -5,9 +5,30 @@
#include <common.h> #include <asm/arch-rockchip/boot_mode.h> +#include <asm/arch-rockchip/misc.h>
int board_late_init(void) { setup_boot_mode(); return 0; } + +int misc_init_r(void) +{ + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + ret = rockchip_setup_macaddr(); + + return ret; +}
This enables us to set a static MAC address
Signed-off-by: Rohan Garg rohan.garg@collabora.com ---
configs/rock-pi-4-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 14ae39a561..602be5a928 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -56,3 +56,4 @@ CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USE_TINY_PRINTF=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y +CONFIG_MISC_INIT_R=y
We should use the shared helpers to setup the necessary parts
.../puma_rk3399/puma-rk3399.c | 108 +++--------------- 1 file changed, 18 insertions(+), 90 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 251cd2d566..fb6c7c1f0a 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -17,6 +17,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/grf_rk3399.h> +#include <asm/arch-rockchip/misc.h> #include <asm/arch-rockchip/periph.h> #include <power/regulator.h> #include <u-boot/sha256.h> @@ -36,94 +37,6 @@ int board_init(void) return 0; }
-static void setup_macaddr(void) -{ -#if CONFIG_IS_ENABLED(CMD_NET) - int ret; - const char *cpuid = env_get("cpuid#"); - u8 hash[SHA256_SUM_LEN]; - int size = sizeof(hash); - u8 mac_addr[6]; - - /* Only generate a MAC address, if none is set in the environment */ - if (env_get("ethaddr")) - return; - - if (!cpuid) { - debug("%s: could not retrieve 'cpuid#'\n", __func__); - return; - } - - ret = hash_block("sha256", (void *)cpuid, strlen(cpuid), hash, &size); - if (ret) { - debug("%s: failed to calculate SHA256\n", __func__); - return; - } - - /* Copy 6 bytes of the hash to base the MAC address on */ - memcpy(mac_addr, hash, 6); - - /* Make this a valid MAC address and set it */ - mac_addr[0] &= 0xfe; /* clear multicast bit */ - mac_addr[0] |= 0x02; /* set local assignment bit (IEEE802) */ - eth_env_set_enetaddr("ethaddr", mac_addr); -#endif -} - -static void setup_serial(void) -{ -#if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) - const u32 cpuid_offset = 0x7; - const u32 cpuid_length = 0x10; - - struct udevice *dev; - int ret, i; - u8 cpuid[cpuid_length]; - u8 low[cpuid_length/2], high[cpuid_length/2]; - char cpuid_str[cpuid_length * 2 + 1]; - u64 serialno; - char serialno_str[17]; - - /* retrieve the device */ - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_GET_DRIVER(rockchip_efuse), &dev); - if (ret) { - debug("%s: could not find efuse device\n", __func__); - return; - } - - /* read the cpu_id range from the efuses */ - ret = misc_read(dev, cpuid_offset, &cpuid, sizeof(cpuid)); - if (ret) { - debug("%s: reading cpuid from the efuses failed\n", - __func__); - return; - } - - memset(cpuid_str, 0, sizeof(cpuid_str)); - for (i = 0; i < 16; i++) - sprintf(&cpuid_str[i * 2], "%02x", cpuid[i]); - - debug("cpuid: %s\n", cpuid_str); - - /* - * Mix the cpuid bytes using the same rules as in - * ${linux}/drivers/soc/rockchip/rockchip-cpuinfo.c - */ - for (i = 0; i < 8; i++) { - low[i] = cpuid[1 + (i << 1)]; - high[i] = cpuid[i << 1]; - } - - serialno = crc32_no_comp(0, low, 8); - serialno |= (u64)crc32_no_comp(serialno, high, 8) << 32; - snprintf(serialno_str, sizeof(serialno_str), "%016llx", serialno); - - env_set("cpuid#", cpuid_str); - env_set("serial#", serialno_str); -#endif -} - static void setup_iodomain(void) { const u32 GRF_IO_VSEL_GPIO4CD_SHIFT = 3; @@ -213,8 +126,23 @@ static int setup_boottargets(void)
int misc_init_r(void) { - setup_serial(); - setup_macaddr(); + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + ret = rockchip_setup_macaddr(); + if (ret) + return ret; + setup_iodomain(); setup_boottargets();
Hi Rohan,
- int ret;
- u8 mac_addr[6];
return;
- if (!cpuid) {
return;
- if (ret) {
return;
-#endif -}
- int ret, i;
- u64 serialno;
- if (ret) {
return;
- if (ret) {
__func__);
return;
-#endif -}
After misc_init_r has add into rk3399_board, then this misc_init_r() here will be multi-defined?
In this case, maybe we need to remove the misc_init_r() from rk3399_board.c first? :(
Thanks,
- Kever
- setup_serial();
- setup_macaddr();
- int ret;
- ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid);
- if (ret)
return ret;
- ret = rockchip_cpuid_set(cpuid, cpuid_length);
- if (ret)
return ret;
- ret = rockchip_setup_macaddr();
- if (ret)
return ret;
- setup_iodomain(); setup_boottargets();
Hey On Wednesday, 24 July 2019 14:26:44 CEST Kever Yang wrote:
Hi Rohan,
- int ret;
- u8 mac_addr[6];
return;
- if (!cpuid) {
return;
&size);
- if (ret) {
return;
-#endif -}
- int ret, i;
- u64 serialno;
- if (ret) {
return;
- if (ret) {
__func__);
return;
-#endif -}
I'm a bit confused. I thought the idea was to hoist this code up into rk3399- board.c?
On a separate note, perhaps setup_iodomain should move into a more generic helper for the rk3399 boards.
I'm also not sure why setup_boottargets fiddles around with boot order, but perhaps we shouldn't be doing that? None of the other boards seem to do that ( or at least none that I could find anyway ).
Cheers Rohan Garg
Hi Rohan,
- int ret;
- u8 mac_addr[6];
return;
- if (!cpuid) {
return;
&size);
- if (ret) {
return;
-#endif -}
- int ret, i;
- u64 serialno;
- if (ret) {
return;
- if (ret) {
__func__);
return;
-#endif -}
Please refer to the comment above setup_boottargets() in board/theobroma-systems/puma_rk3399/puma-rk3399.c for details on why the bootorder is modified for distroboot.
Please make sure that this is left in place, as it will otherwise break the expected and documented behaviour (i.e. how the “BIOS_DISABLE” signal is expected to work) for the RK3399-Q7.
Thanks, Philipp.
Hi Kever, Rohan,
On Wed, 2019-07-24 at 20:26 +0800, Kever Yang wrote:
Hi Rohan,
- int ret;
- u8 mac_addr[6];
return;
- if (!cpuid) {
return;
- if (ret) {
return;
-#endif -}
- int ret, i;
- u64 serialno;
- if (ret) {
return;
- if (ret) {
__func__);
return;
-#endif -}
Good catch. Indeed, with the first patch applied the build would fail.
Does this mean we should let each board introduce its own misc_init_r, or instead provide a common weak misc_init_r?
Thanks, Ezequiel
Ezequiel Garcia
Kever Yang
Philipp Tomsich
Rohan Garg
