[U-Boot] [PATCH 0/7] dm: Introduce driver model for Atmel at91
This series adds driver model support for serial and GPIO for the Atmel AT91 series. The at91sam9260-based Snapper 9260 is converted over as an example.
For both drivers the old behaviour is retained, so driver model becomes option, not mandatory.
This series is available at u-boot-dm/atmel-working.
Simon Glass (7): dm: at91: Correct text base for snapper9260 dm: at91: Move snapper9260 to generic baord dm: at91: Add driver model support for atmel GPIO driver dm: at91: Add platform data for GPIO on at91sam9260-based boards dm: at91: Refactor serial driver slightly for driver model dm: at91: Add driver model support for the serial driver dm: at91: Convert snapper9260 to use driver model
arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 14 ++ arch/arm/include/asm/arch-at91/at91_serial.h | 15 ++ arch/arm/include/asm/arch-at91/at91sam9260.h | 4 +- arch/arm/include/asm/arch-at91/gpio.h | 6 + board/bluewater/snapper9260/snapper9260.c | 18 +- drivers/gpio/at91_gpio.c | 221 +++++++++++++++++----- drivers/serial/atmel_usart.c | 117 +++++++++++- include/configs/snapper9260.h | 12 +- 8 files changed, 349 insertions(+), 58 deletions(-) create mode 100644 arch/arm/include/asm/arch-at91/at91_serial.h
The value should be 0x23f00000. Fix it.
include/configs/snapper9260.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 1ebee71..adb09c2 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -15,7 +15,7 @@ #include <asm/hardware.h> #include <linux/sizes.h>
-#define CONFIG_SYS_TEXT_BASE 0x20000000 +#define CONFIG_SYS_TEXT_BASE 0x23f00000
/* ARM asynchronous clock */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* External Crystal, in Hz */
Dear Simon,
I wonder why this is required. It depends on the first stage loader snapper9260 uses and I guess the first value is the right one used in the factory programmed loader. Nevertheless other at91 boards use 0x21f00000 due to relocation issues on boards with less RAM. It seems the snapper9260 has just 64MiB of RAM, this means just 1MiB of space for relocated u-boot, malloc arena, ... This was exactly the reason for other at91 boards to switch to 0x21f00000 as base address.
Best regards
Andreas Bießmann
It also seems the maintainer of snapper9260 is not reachable. Simon, do you own such a board?
Best regards
Andreas Bießmann
On 23.10.14 07:07, Andreas Bießmann wrote:
Dear Simon,
Best regards
Andreas Bießmann
On Oct 22, 2014 11:10 PM, "Andreas Bießmann" andreas.devel@googlemail.com wrote:
Yes I have one. The base address is to make the maximum amount of room for loading the kernel, etc.
Best regards
Andreas Bießmann
Dear Simon,
Best regards
Andreas Bießmann
On 23.10.14 07:12, Simon Glass wrote:
On Oct 22, 2014 11:10 PM, "Andreas Bießmann" <andreas.devel@googlemail.com mailto:andreas.devel@googlemail.com> wrote:
Yes I have one.
so would you take maintainer-ship?
Well, the base address is just used for the temporary copy of u-boot inside RAM. After copy from media to RAM we will relocate to a runtime defined address. This address depends on some variable parameters which may also be defined at runtime. We had the problem that in some cases the calculated relocation address collates with running u-boot in RAM. The chance to hit this issue is high when you just have room of 1 MiB (which must hold two copies of u-boot!)
Best regards
Andreas Bießmann
Hi Andreas,
On 22 October 2014 23:21, Andreas Bießmann andreas.devel@googlemail.com wrote:
Yes I have one.
OK.
Ah yes of course :-) I'm not sure about the pre-boot but will see if I can change it.
This works correctly, so switch it over before the deadline.
include/configs/snapper9260.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index adb09c2..fdb6cca 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -20,6 +20,7 @@ /* ARM asynchronous clock */ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* External Crystal, in Hz */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_GENERIC_BOARD
/* CPU */ #define CONFIG_ARCH_CPU_INIT
Modify this driver to support driver model, with platform data required to determine the GPIOs that it controls.
arch/arm/include/asm/arch-at91/gpio.h | 6 + drivers/gpio/at91_gpio.c | 221 +++++++++++++++++++++++++++------- 2 files changed, 183 insertions(+), 44 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/gpio.h b/arch/arm/include/asm/arch-at91/gpio.h index 7121388..6d2a7b7 100644 --- a/arch/arm/include/asm/arch-at91/gpio.h +++ b/arch/arm/include/asm/arch-at91/gpio.h @@ -253,4 +253,10 @@ static inline unsigned at91_gpio_to_pin(unsigned gpio) return gpio % 32; }
+/* Platform data for each GPIO port */ +struct at91_port_platdata { + uint32_t base_addr; + const char *bank_name; +}; + #endif /* __ASM_ARCH_AT91_GPIO_H */ diff --git a/drivers/gpio/at91_gpio.c b/drivers/gpio/at91_gpio.c index 6517af1..822ba8c 100644 --- a/drivers/gpio/at91_gpio.c +++ b/drivers/gpio/at91_gpio.c @@ -10,11 +10,14 @@
#include <config.h> #include <common.h> +#include <dm.h> #include <asm/io.h> #include <linux/sizes.h> +#include <asm/gpio.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> -#include <asm/arch/gpio.h> + +#define GPIO_PER_BANK 32
static struct at91_port *at91_pio_get_port(unsigned port) { @@ -39,19 +42,25 @@ static struct at91_port *at91_pio_get_port(unsigned port) } }
+static void at91_set_port_pullup(struct at91_port *at91_port, unsigned offset, + int use_pullup) +{ + u32 mask; + + mask = 1 << offset; + if (use_pullup) + writel(mask, &at91_port->puer); + else + writel(mask, &at91_port->pudr); + writel(mask, &at91_port->per); +} + int at91_set_pio_pullup(unsigned port, unsigned pin, int use_pullup) { struct at91_port *at91_port = at91_pio_get_port(port); - u32 mask;
- if (at91_port && (pin < 32)) { - mask = 1 << pin; - if (use_pullup) - writel(1 << pin, &at91_port->puer); - else - writel(1 << pin, &at91_port->pudr); - writel(mask, &at91_port->per); - } + if (at91_port && (pin < 32)) + at91_set_port_pullup(at91_port, pin, use_pullup);
return 0; } @@ -172,6 +181,29 @@ int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup) } #endif
+#ifdef CONFIG_DM_GPIO +static bool at91_get_port_output(struct at91_port *at91_port, int offset) +{ + u32 mask, val; + + mask = 1 << offset; + val = readl(&at91_port->osr); + return val & mask ? true : false; +} +#endif + +static void at91_set_port_input(struct at91_port *at91_port, int offset, + int use_pullup) +{ + u32 mask; + + mask = 1 << offset; + writel(mask, &at91_port->idr); + at91_set_port_pullup(at91_port, offset, use_pullup); + writel(mask, &at91_port->odr); + writel(mask, &at91_port->per); +} + /* * mux the pin to the gpio controller (instead of "A" or "B" peripheral), and * configure it for an input. @@ -179,19 +211,29 @@ int at91_set_d_periph(unsigned port, unsigned pin, int use_pullup) int at91_set_pio_input(unsigned port, u32 pin, int use_pullup) { struct at91_port *at91_port = at91_pio_get_port(port); - u32 mask;
- if (at91_port && (pin < 32)) { - mask = 1 << pin; - writel(mask, &at91_port->idr); - at91_set_pio_pullup(port, pin, use_pullup); - writel(mask, &at91_port->odr); - writel(mask, &at91_port->per); - } + if (at91_port && (pin < 32)) + at91_set_port_input(at91_port, pin, use_pullup);
return 0; }
+static void at91_set_port_output(struct at91_port *at91_port, int offset, + int value) +{ + u32 mask; + + mask = 1 << offset; + writel(mask, &at91_port->idr); + writel(mask, &at91_port->pudr); + if (value) + writel(mask, &at91_port->sodr); + else + writel(mask, &at91_port->codr); + writel(mask, &at91_port->oer); + writel(mask, &at91_port->per); +} + /* * mux the pin to the gpio controller (instead of "A" or "B" peripheral), * and configure it for an output. @@ -199,19 +241,9 @@ int at91_set_pio_input(unsigned port, u32 pin, int use_pullup) int at91_set_pio_output(unsigned port, u32 pin, int value) { struct at91_port *at91_port = at91_pio_get_port(port); - u32 mask;
- if (at91_port && (port < ATMEL_PIO_PORTS) && (pin < 32)) { - mask = 1 << pin; - writel(mask, &at91_port->idr); - writel(mask, &at91_port->pudr); - if (value) - writel(mask, &at91_port->sodr); - else - writel(mask, &at91_port->codr); - writel(mask, &at91_port->oer); - writel(mask, &at91_port->per); - } + if (at91_port && (port < ATMEL_PIO_PORTS) && (pin < 32)) + at91_set_port_output(at91_port, pin, value);
return 0; } @@ -321,41 +353,54 @@ int at91_set_pio_multi_drive(unsigned port, unsigned pin, int is_on) return 0; }
+static void at91_set_port_value(struct at91_port *at91_port, int offset, + int value) +{ + u32 mask; + + mask = 1 << offset; + if (value) + writel(mask, &at91_port->sodr); + else + writel(mask, &at91_port->codr); +} + /* * assuming the pin is muxed as a gpio output, set its value. */ int at91_set_pio_value(unsigned port, unsigned pin, int value) { struct at91_port *at91_port = at91_pio_get_port(port); - u32 mask;
- if (at91_port && (pin < 32)) { - mask = 1 << pin; - if (value) - writel(mask, &at91_port->sodr); - else - writel(mask, &at91_port->codr); - } + if (at91_port && (pin < 32)) + at91_set_port_value(at91_port, pin, value);
return 0; }
+static int at91_get_port_value(struct at91_port *at91_port, int offset) +{ + u32 pdsr = 0, mask; + + mask = 1 << offset; + pdsr = readl(&at91_port->pdsr) & mask; + + return pdsr != 0; +} /* * read the pin's value (works even if it's not muxed as a gpio). */ int at91_get_pio_value(unsigned port, unsigned pin) { struct at91_port *at91_port = at91_pio_get_port(port); - u32 pdsr = 0, mask;
- if (at91_port && (pin < 32)) { - mask = 1 << pin; - pdsr = readl(&at91_port->pdsr) & mask; - } + if (at91_port && (pin < 32)) + return at91_get_port_value(at91_port, pin);
- return pdsr != 0; + return 0; }
+#ifndef CONFIG_DM_GPIO /* Common GPIO API */
int gpio_request(unsigned gpio, const char *label) @@ -395,3 +440,91 @@ int gpio_set_value(unsigned gpio, int value)
return 0; } +#endif + +#ifdef CONFIG_DM_GPIO + +struct at91_port_priv { + struct at91_port *regs; +}; + +/* set GPIO pin 'gpio' as an input */ +static int at91_gpio_direction_input(struct udevice *dev, unsigned offset) +{ + struct at91_port_priv *port = dev_get_platdata(dev); + + at91_set_port_input(port->regs, offset, 0); + + return 0; +} + +/* set GPIO pin 'gpio' as an output, with polarity 'value' */ +static int at91_gpio_direction_output(struct udevice *dev, unsigned offset, + int value) +{ + struct at91_port_priv *port = dev_get_platdata(dev); + + at91_set_port_output(port->regs, offset, value); + + return 0; +} + +/* read GPIO IN value of pin 'gpio' */ +static int at91_gpio_get_value(struct udevice *dev, unsigned offset) +{ + struct at91_port_priv *port = dev_get_platdata(dev); + + return at91_get_port_value(port->regs, offset); +} + +/* write GPIO OUT value to pin 'gpio' */ +static int at91_gpio_set_value(struct udevice *dev, unsigned offset, + int value) +{ + struct at91_port_priv *port = dev_get_platdata(dev); + + at91_set_port_value(port->regs, offset, value); + + return 0; +} + +static int at91_gpio_get_function(struct udevice *dev, unsigned offset) +{ + struct at91_port_priv *port = dev_get_platdata(dev); + + /* GPIOF_FUNC is not implemented yet */ + if (at91_get_port_output(port->regs, offset)) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static const struct dm_gpio_ops gpio_at91_ops = { + .direction_input = at91_gpio_direction_input, + .direction_output = at91_gpio_direction_output, + .get_value = at91_gpio_get_value, + .set_value = at91_gpio_set_value, + .get_function = at91_gpio_get_function, +}; + +static int at91_gpio_probe(struct udevice *dev) +{ + struct at91_port_priv *port = dev_get_priv(dev); + struct at91_port_platdata *plat = dev_get_platdata(dev); + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + + uc_priv->bank_name = plat->bank_name; + uc_priv->gpio_count = GPIO_PER_BANK; + port->regs = (struct at91_port *)plat->base_addr; + + return 0; +} + +U_BOOT_DRIVER(gpio_at91) = { + .name = "gpio_at91", + .id = UCLASS_GPIO, + .ops = &gpio_at91_ops, + .probe = at91_gpio_probe, + .priv_auto_alloc_size = sizeof(struct at91_port_priv), +}; +#endif
Dear Simon,
- uint32_t base_addr;
- const char *bank_name;
int use_pullup)
- u32 mask;
- mask = 1 << offset;
- if (use_pullup)
- else
u32 mask;
mask = 1 << pin;
if (use_pullup)
else
could we please use the newly defined GPIO_PER_BANK here and elsewhere?
- u32 mask, val;
- val = readl(&at91_port->osr);
- return val & mask ? true : false;
Nitpick, wouldn't just 'return val & mask' work here? It would be implicit conversion, but isn't the construct here also implicit conversion?
+} +#endif
int use_pullup)
- u32 mask;
- at91_set_port_pullup(at91_port, offset, use_pullup);
- mux the pin to the gpio controller (instead of "A" or "B" peripheral), and
- configure it for an input.
u32 mask;
mask = 1 << pin;
int value)
- u32 mask;
- if (value)
- else
- and configure it for an output.
u32 mask;
mask = 1 << pin;
if (value)
else
I think the port check here is a leftover. It should be handled correctly inside at91_pio_get_port() and therefore could be removed here.
int value)
- u32 mask;
- if (value)
- else
- assuming the pin is muxed as a gpio output, set its value.
u32 mask;
mask = 1 << pin;
if (value)
else
- return pdsr != 0;
- read the pin's value (works even if it's not muxed as a gpio).
u32 pdsr = 0, mask;
mask = 1 << pin;
- return pdsr != 0;
return 0; } +#endif
- struct at91_port *regs;
- struct at91_port_priv *port = dev_get_platdata(dev);
- at91_set_port_input(port->regs, offset, 0);
int value)
- at91_set_port_output(port->regs, offset, value);
- return at91_get_port_value(port->regs, offset);
int value)
- at91_set_port_value(port->regs, offset, value);
- /* GPIOF_FUNC is not implemented yet */
- if (at91_get_port_output(port->regs, offset))
- else
return GPIOF_INPUT;
- .direction_input = at91_gpio_direction_input,
- .direction_output = at91_gpio_direction_output,
- .get_value = at91_gpio_get_value,
- .set_value = at91_gpio_set_value,
- .get_function = at91_gpio_get_function,
- struct at91_port_priv *port = dev_get_priv(dev);
- struct at91_port_platdata *plat = dev_get_platdata(dev);
- struct gpio_dev_priv *uc_priv = dev->uclass_priv;
- uc_priv->bank_name = plat->bank_name;
- uc_priv->gpio_count = GPIO_PER_BANK;
- port->regs = (struct at91_port *)plat->base_addr;
- .name = "gpio_at91",
- .id = UCLASS_GPIO,
- .ops = &gpio_at91_ops,
- .probe = at91_gpio_probe,
- .priv_auto_alloc_size = sizeof(struct at91_port_priv),
+}; +#endif
Best regards
Andreas Bießmann
These boards all have the same GPIO arrangement, so add some common platform data that can be used by all boards. Remove the configs which are no longer required.
arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 14 ++++++++++++++ arch/arm/include/asm/arch-at91/at91sam9260.h | 4 +++- 2 files changed, 17 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c index cae4abc..5edcfc2 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <dm.h> #include <asm/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> @@ -207,3 +208,16 @@ void at91_mci_hw_init(void) #endif } #endif + +/* Platform data for the GPIOs */ +static const struct at91_port_platdata at91sam9260_plat[] = { + { ATMEL_BASE_PIOA, "A" }, + { ATMEL_BASE_PIOB, "B" }, + { ATMEL_BASE_PIOC, "C" }, +}; + +U_BOOT_DEVICES(at91sam9260_gpios) = { + { "gpio_at91", &at91sam9260_plat[0] }, + { "gpio_at91", &at91sam9260_plat[1] }, + { "gpio_at91", &at91sam9260_plat[2] }, +}; diff --git a/arch/arm/include/asm/arch-at91/at91sam9260.h b/arch/arm/include/asm/arch-at91/at91sam9260.h index 2e902ee..4d46def 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9260.h +++ b/arch/arm/include/asm/arch-at91/at91sam9260.h @@ -136,9 +136,11 @@ /* * Other misc defines */ +#ifndef CONFIG_DM_GPIO #define ATMEL_PIO_PORTS 3 /* these SoCs have 3 PIO */ -#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP #define ATMEL_BASE_PIO ATMEL_BASE_PIOA +#endif +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* * SoC specific defines
Hi Simon,
- { ATMEL_BASE_PIOA, "A" },
- { ATMEL_BASE_PIOB, "B" },
- { ATMEL_BASE_PIOC, "C" },
data sheet call the parts 'Px', sam9260 has PA0..PA31, PB0..PB31 and PC0..PC31, shouldn't we use that name here too?
- { "gpio_at91", &at91sam9260_plat[0] },
- { "gpio_at91", &at91sam9260_plat[1] },
- { "gpio_at91", &at91sam9260_plat[2] },
- Other misc defines
- SoC specific defines
Best regards
Andreas Bießmann
Before adding driver model support, split out a few of the functions so that they can be used by the driver model code.
drivers/serial/atmel_usart.c | 32 +++++++++++++++++++++++--------- 1 file changed, 23 insertions(+), 9 deletions(-)
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index 8f0e348..ce36e99 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -19,9 +19,9 @@
DECLARE_GLOBAL_DATA_PTR;
-static void atmel_serial_setbrg(void) +static void atmel_serial_setbrg_internal(atmel_usart3_t *usart, int id, + int baudrate) { - atmel_usart3_t *usart = (atmel_usart3_t *)CONFIG_USART_BASE; unsigned long divisor; unsigned long usart_hz;
@@ -30,15 +30,13 @@ static void atmel_serial_setbrg(void) * Baud Rate = -------------- * 16 * CD */ - usart_hz = get_usart_clk_rate(CONFIG_USART_ID); - divisor = (usart_hz / 16 + gd->baudrate / 2) / gd->baudrate; + usart_hz = get_usart_clk_rate(id); + divisor = (usart_hz / 16 + baudrate / 2) / baudrate; writel(USART3_BF(CD, divisor), &usart->brgr); }
-static int atmel_serial_init(void) +static void atmel_serial_init_internal(atmel_usart3_t *usart) { - atmel_usart3_t *usart = (atmel_usart3_t *)CONFIG_USART_BASE; - /* * Just in case: drain transmitter register * 1000us is enough for baudrate >= 9600 @@ -47,9 +45,10 @@ static int atmel_serial_init(void) __udelay(1000);
writel(USART3_BIT(RSTRX) | USART3_BIT(RSTTX), &usart->cr); +}
- serial_setbrg(); - +static void atmel_serial_activate(atmel_usart3_t *usart) +{ writel((USART3_BF(USART_MODE, USART3_USART_MODE_NORMAL) | USART3_BF(USCLKS, USART3_USCLKS_MCK) | USART3_BF(CHRL, USART3_CHRL_8) @@ -59,6 +58,21 @@ static int atmel_serial_init(void) writel(USART3_BIT(RXEN) | USART3_BIT(TXEN), &usart->cr); /* 100us is enough for the new settings to be settled */ __udelay(100); +} + +static void atmel_serial_setbrg(void) +{ + atmel_serial_setbrg_internal((atmel_usart3_t *)CONFIG_USART_BASE, + CONFIG_USART_ID, gd->baudrate); +} + +static int atmel_serial_init(void) +{ + atmel_usart3_t *usart = (atmel_usart3_t *)CONFIG_USART_BASE; + + atmel_serial_init_internal(usart); + serial_setbrg(); + atmel_serial_activate(usart);
return 0; }
Acked-by: Andreas Bießmann andreas.devel@googlemail.com
Add driver model support while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
arch/arm/include/asm/arch-at91/at91_serial.h | 15 +++++ drivers/serial/atmel_usart.c | 85 ++++++++++++++++++++++++++++ 2 files changed, 100 insertions(+) create mode 100644 arch/arm/include/asm/arch-at91/at91_serial.h
diff --git a/arch/arm/include/asm/arch-at91/at91_serial.h b/arch/arm/include/asm/arch-at91/at91_serial.h new file mode 100644 index 0000000..9f78ed4 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91_serial.h @@ -0,0 +1,15 @@ +/* + * Copyright (c) 2014 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _AT91_SERIAL_H +#define _AT91_SERIAL_H + +/* Information about a serial port */ +struct at91_serial_platdata { + uint32_t base_addr; +}; + +#endif diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index ce36e99..d3e2ade 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -7,11 +7,17 @@ * SPDX-License-Identifier: GPL-2.0+ */ #include <common.h> +#include <dm.h> +#include <errno.h> #include <watchdog.h> #include <serial.h> #include <linux/compiler.h>
#include <asm/io.h> +#ifdef CONFIG_DM_SERIAL +/* Should this be made common with avr32? */ +#include <asm/arch/at91_serial.h> +#endif #include <asm/arch/clk.h> #include <asm/arch/hardware.h>
@@ -60,6 +66,7 @@ static void atmel_serial_activate(atmel_usart3_t *usart) __udelay(100); }
+#ifndef CONFIG_DM_SERIAL static void atmel_serial_setbrg(void) { atmel_serial_setbrg_internal((atmel_usart3_t *)CONFIG_USART_BASE, @@ -123,3 +130,81 @@ __weak struct serial_device *default_serial_console(void) { return &atmel_serial_drv; } +#endif + +#ifdef CONFIG_DM_SERIAL + +struct at91_serial_priv { + atmel_usart3_t *usart; +}; + +int at91_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct at91_serial_priv *priv = dev_get_priv(dev); + + atmel_serial_setbrg_internal(priv->usart, 0 /* ignored */, baudrate); + atmel_serial_activate(priv->usart); + + return 0; +} + +static int at91_serial_getc(struct udevice *dev) +{ + struct at91_serial_priv *priv = dev_get_priv(dev); + + if (!(readl(&priv->usart->csr) & USART3_BIT(RXRDY))) + return -EAGAIN; + + return readl(&priv->usart->rhr); +} + +static int at91_serial_putc(struct udevice *dev, const char ch) +{ + struct at91_serial_priv *priv = dev_get_priv(dev); + + if (!(readl(&priv->usart->csr) & USART3_BIT(TXRDY))) + return -EAGAIN; + + writel(ch, &priv->usart->thr); + + return 0; +} + +static int at91_serial_pending(struct udevice *dev, bool input) +{ + struct at91_serial_priv *priv = dev_get_priv(dev); + uint32_t csr = readl(&priv->usart->csr); + + if (input) + return csr & USART3_BIT(RXRDY) ? 1 : 0; + else + return csr & USART3_BIT(TXEMPTY) ? 0 : 1; +} + +static const struct dm_serial_ops at91_serial_ops = { + .putc = at91_serial_putc, + .pending = at91_serial_pending, + .getc = at91_serial_getc, + .setbrg = at91_serial_setbrg, +}; + +static int at91_serial_probe(struct udevice *dev) +{ + struct at91_serial_platdata *plat = dev->platdata; + struct at91_serial_priv *priv = dev_get_priv(dev); + + priv->usart = (atmel_usart3_t *)plat->base_addr; + atmel_serial_init_internal(priv->usart); + + return 0; +} + +U_BOOT_DRIVER(serial_at91) = { + .name = "serial_at91", + .id = UCLASS_SERIAL, + .probe = at91_serial_probe, + .ops = &at91_serial_ops, + .flags = DM_FLAG_PRE_RELOC, + .priv_auto_alloc_size = sizeof(struct at91_serial_priv), +}; +#endif
Hi Simon,
- Copyright (c) 2014 Google, Inc
yes, we should do so. Therefore I vote for atmel_serial.h.
- atmel_usart3_t *usart;
- struct at91_serial_priv *priv = dev_get_priv(dev);
- atmel_serial_setbrg_internal(priv->usart, 0 /* ignored */, baudrate);
- atmel_serial_activate(priv->usart);
- if (!(readl(&priv->usart->csr) & USART3_BIT(RXRDY)))
return -EAGAIN;
- return readl(&priv->usart->rhr);
- if (!(readl(&priv->usart->csr) & USART3_BIT(TXRDY)))
return -EAGAIN;
- writel(ch, &priv->usart->thr);
- uint32_t csr = readl(&priv->usart->csr);
- if (input)
- else
- .putc = at91_serial_putc,
- .pending = at91_serial_pending,
- .getc = at91_serial_getc,
- .setbrg = at91_serial_setbrg,
- struct at91_serial_platdata *plat = dev->platdata;
- priv->usart = (atmel_usart3_t *)plat->base_addr;
- atmel_serial_init_internal(priv->usart);
Please name it 'atmel' rather than 'at91' at91 is just one (legacy) product family, there is also avr32 (ok, outdated) but new and growing 'sama5'.
- .name = "serial_at91",
- .id = UCLASS_SERIAL,
- .probe = at91_serial_probe,
- .ops = &at91_serial_ops,
- .flags = DM_FLAG_PRE_RELOC,
- .priv_auto_alloc_size = sizeof(struct at91_serial_priv),
+}; +#endif
The patch looks good to me, but I wonder if changing the baudrate is working as expected. Did you test this?
Best regards
Andreas Bießmann
Convert this at91sam9260-based board to use driver model. This should serve as an example for other similar boards. Serial and GPIO are supported so far.
board/bluewater/snapper9260/snapper9260.c | 18 ++++++++++++++++-- include/configs/snapper9260.h | 9 ++++++++- 2 files changed, 24 insertions(+), 3 deletions(-)
diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index bfde129..b98359f 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -9,12 +9,15 @@ */
#include <common.h> +#include <dm.h> #include <asm/io.h> +#include <asm/gpio.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> +#include <asm/arch/at91_serial.h> #include <net.h> #include <netdev.h> #include <i2c.h> @@ -95,10 +98,12 @@ static void nand_hw_init(void) &smc->cs[3].mode);
/* Configure RDY/BSY */ - at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + gpio_request(CONFIG_SYS_NAND_READY_PIN, "nand_rdy"); + gpio_direction_input(CONFIG_SYS_NAND_READY_PIN);
/* Enable NandFlash */ - at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); + gpio_request(CONFIG_SYS_NAND_ENABLE_PIN, "nand_ce"); + gpio_direction_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); }
int board_init(void) @@ -140,3 +145,12 @@ int dram_init(void) void reset_phy(void) { } + +static struct at91_serial_platdata at91sam9260_serial_plat = { + .base_addr = ATMEL_BASE_DBGU, +}; + +U_BOOT_DEVICE(at91sam9260_serial) = { + .name = "serial_at91", + .platdata = &at91sam9260_serial_plat, +}; diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index fdb6cca..251ef07 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -21,6 +21,11 @@ #define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* External Crystal, in Hz */ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DM +#define CONFIG_CMD_DM +#define CONFIG_DM_GPIO +#define CONFIG_DM_SERIAL +#define CONFIG_SYS_MALLOC_F_LEN (1 << 10)
/* CPU */ #define CONFIG_ARCH_CPU_INIT @@ -85,8 +90,10 @@
/* UARTs/Serial console */ #define CONFIG_ATMEL_USART +#ifndef CONFIG_DM_SERIAL #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS +#endif #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_PROMPT "Snapper> "
@@ -160,7 +167,7 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_FAT #define CONFIG_CMD_I2C -#undef CONFIG_CMD_GPIO +#define CONFIG_CMD_GPIO #define CONFIG_CMD_USB #define CONFIG_CMD_MII #define CONFIG_CMD_NAND
Are there any comments on this series please?
-- 2.1.0.rc2.206.gedb03e5
Hi Simon,
done ;)
Regards
Andreas Bießmann
Andreas Bießmann
