[U-Boot] [PATCH] command: constify _do_help input tables
The _do_help func does not need to write to the command tables passed to it, so constify the input args.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/command.c | 8 ++++---- include/command.h | 4 ++-- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/common/command.c b/common/command.c index ddaed68..6ed12e5 100644 --- a/common/command.c +++ b/common/command.c @@ -33,14 +33,14 @@ * for long help messages */
-int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int - flag, int argc, char * const argv[]) +int _do_help(const cmd_tbl_t *cmd_start, int cmd_items, const cmd_tbl_t *cmdtp, + int flag, int argc, char * const argv[]) { int i; int rcode = 0;
if (argc == 1) { /*show list of commands */ - cmd_tbl_t *cmd_array[cmd_items]; + const cmd_tbl_t *cmd_array[cmd_items]; int i, j, swaps;
/* Make array of commands from .uboot_cmd section */ @@ -55,7 +55,7 @@ int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int for (j = 0; j < i; ++j) { if (strcmp (cmd_array[j]->name, cmd_array[j + 1]->name) > 0) { - cmd_tbl_t *tmp; + const cmd_tbl_t *tmp; tmp = cmd_array[j]; cmd_array[j] = cmd_array[j + 1]; cmd_array[j + 1] = tmp; diff --git a/include/command.h b/include/command.h index cab9651..54b1996 100644 --- a/include/command.h +++ b/include/command.h @@ -66,8 +66,8 @@ extern cmd_tbl_t __u_boot_cmd_end;
/* common/command.c */ -int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int - flag, int argc, char * const argv[]); +int _do_help(const cmd_tbl_t *cmd_start, int cmd_items, const cmd_tbl_t *cmdtp, + int flag, int argc, char * const argv[]); cmd_tbl_t *find_cmd(const char *cmd); cmd_tbl_t *find_cmd_tbl (const char *cmd, cmd_tbl_t *table, int table_len);
err, forgot this one for now. it requires tinkering in other internal command funcs to avoid compiler warnings, and changes in those requires tinkering in all command code. i'll have to split up my old patch to make this work. -mike
Mike Frysinger
