[U-Boot] [PATCH] rockchip: firefly-rk3399: enable SPL_SYSRESET config
After the patch below, we need to add SPL_SYSRESET for do_reset() in SPL: 87c16d4 drivers: spl: consistently use the $(SPL_TPL_) macro
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
configs/firefly-rk3399_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index d8ea4cb..eead166 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -9,7 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_FIT_GENERATOR="board/rockchip/evb_rk3399/mk_fit_atf.sh" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y @@ -36,6 +35,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y @@ -70,6 +70,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y
Kever,
I’ll try to get this in for the current release (i.e get it applied and send out a pull later this week), as it’s a defconfig-only bugfix for a regression introduced in the current release.
Regards, Philipp.
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index d8ea4cb..eead166 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -9,7 +9,6 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_FIT_GENERATOR="board/rockchip/evb_rk3399/mk_fit_atf.sh" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y @@ -36,6 +35,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y @@ -70,6 +70,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -- 1.9.1
Hi Philipp,
I think this patch is not enough, pls drop this.
I have send another patch to add SPL_SYSRESET for all Rockchip SoCs,
because all of them need this, eg. rk3288 have many boards, all have this issue.
Thanks, - Kever On 09/07/2017 04:53 PM, Dr. Philipp Tomsich wrote:
Kever,
Regards, Philipp.
Dr. Philipp Tomsich
Kever Yang
