[PATCH] ARM: zynq: Align qspi node name with Linux kernel
Nodes should follow generic rules where compatible and reg properties should be listed on the top of node. That's why sync it up.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynq-7000.dtsi | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index b4aa09d149b0..11fa0ef2bfed 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -235,13 +235,13 @@ };
qspi: spi@e000d000 { - clock-names = "ref_clk", "pclk"; - clocks = <&clkc 10>, <&clkc 43>; compatible = "xlnx,zynq-qspi-1.0"; - status = "disabled"; + reg = <0xe000d000 0x1000>; interrupt-parent = <&intc>; interrupts = <0 19 4>; - reg = <0xe000d000 0x1000>; + clocks = <&clkc 10>, <&clkc 43>; + clock-names = "ref_clk", "pclk"; + status = "disabled"; #address-cells = <1>; #size-cells = <0>; }; @@ -378,9 +378,9 @@
devcfg: devcfg@f8007000 { compatible = "xlnx,zynq-devcfg-1.0"; + reg = <0xf8007000 0x100>; interrupt-parent = <&intc>; interrupts = <0 8 4>; - reg = <0xf8007000 0x100>; clocks = <&clkc 12>, <&clkc 15>, <&clkc 16>, <&clkc 17>, <&clkc 18>; clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3"; syscon = <&slcr>;
Ășt 6. 9. 2022 v 12:36 odesĂlatel Michal Simek michal.simek@amd.com napsal:
@@ -378,9 +378,9 @@
-- 2.36.1
Applied. M
Michal Simek
Michal Simek
