[PATCH v2 0/9] Bug-fixes for a few boards
This series includes fixes to get some rockchip and nvidia boards working again. It also drops the broken Beaglebone Black config and provides a devicetree fix for coral (x86).
Changes in v2: - Put the conditions under EFI_TCG2_PROTOCOL - Consider MEASURED_BOOT too - Remove the superfluous if() and drop the debug() as well - Use 'phase' instead of 'stage' - Add new patch to correct memory size in SPL - Drop patch "regulator: rk8xx: Fix incorrect parameter" - Rewrite boneblack patch to onstead drop the target and update docs
Simon Glass (9): nvidia: nyan-big: Disable debug UART tpm: Avoid code bloat when not using EFI_TCG2_PROTOCOL rockchip: veyron: Add logging for power init power: regulator: Handle autoset in regulators_enable_boot_on() fdt: Correct condition for bloblist existing spl: Allow ATF to work when dcache is disabled rockchip: Ensure memory size is available in RK3399 SPL rockchip: bob: kevin: Disable dcache in SPL Drop the special am335x_boneblack_vboot target
board/google/veyron/veyron.c | 30 +++---- board/ti/am335x/MAINTAINERS | 1 - boot/Kconfig | 4 + common/spl/spl_atf.c | 3 +- configs/am335x_boneblack_vboot_defconfig | 94 ---------------------- configs/am335x_evm_defconfig | 3 +- configs/chromebook_bob_defconfig | 1 + configs/chromebook_kevin_defconfig | 1 + configs/nyan-big_defconfig | 1 - doc/usage/fit/beaglebone_vboot.rst | 21 +++-- drivers/power/regulator/regulator-uclass.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 49 ++++++----- lib/Kconfig | 4 - lib/fdtdec.c | 12 ++- 14 files changed, 70 insertions(+), 156 deletions(-) delete mode 100644 configs/am335x_boneblack_vboot_defconfig
This cannot be enabled early in boot since some other init is needed. At this point it is unclear exactly what init is needed, so disable the debug UART to avoid a hang.
(no changes since v1)
configs/nyan-big_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 1483d17d975..4dec710cf8d 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -17,7 +17,6 @@ CONFIG_TEGRA124=y CONFIG_TARGET_NYAN_BIG=y CONFIG_TEGRA_GPU=y CONFIG_SYS_LOAD_ADDR=0x82408000 -CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_BOOTSTAGE=y
It does not make sense to enable all SHA algorithms unless they are needed. It bloats the code and in this case, causes chromebook_link to fail to build. That board does use the TPM, but not with measured boot, nor EFI.
Since EFI_TCG2_PROTOCOL already selects these options, we just need to add them to MEASURED_BOOT as well.
Note that the original commit combines refactoring and new features, which makes it hard to see what is going on.
Fixes: 97707f12fda tpm: Support boot measurements Signed-off-by: Simon Glass sjg@chromium.org ---
boot/Kconfig | 4 ++++ lib/Kconfig | 4 ---- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 6f3096c15a6..b061891e109 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT config MEASURED_BOOT bool "Measure boot images and configuration when booting without EFI" depends on HASH && TPM_V2 + select SHA1 + select SHA256 + select SHA384 + select SHA512 help This option enables measurement of the boot process when booting without UEFI . Measurement involves creating cryptographic hashes diff --git a/lib/Kconfig b/lib/Kconfig index 189e6eb31aa..568892fce44 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -438,10 +438,6 @@ config TPM bool "Trusted Platform Module (TPM) Support" depends on DM imply DM_RNG - select SHA1 - select SHA256 - select SHA384 - select SHA512 help This enables support for TPMs which can be used to provide security features for your board. The TPM can be connected via LPC or I2C
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
I am not sure this is the right way to deal with your problem. The TPM main functionality is to measure and extend PCRs, so shaXXXX is really required. To make things even worse, you don't know the PCR banks that are enabled beforehand. This is a runtime config of the TPM.
So this would make the TPM pretty useless. Can't you remove something that doesn't break functionality?
Thanks /Ilias
-- 2.34.1
On 6/14/24 08:03, Ilias Apalodimas wrote:
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot cannot extend PCRs. So it seems fine to let these two select the complete set of hashing algorithms. As Simon pointed out for EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig.
Even if U-Boot does not support measured boot (EFI or non-EFI) we might still be using the TPMs RNG.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Thanks /Ilias
-- 2.34.1
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 0xb0000000
Regards /Ilias
Thanks /Ilias
-- 2.34.1
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1.
TPM v1 only needs SHA-1.
In cmd/tpm-v2.c do_tpm2_pcr_extend() and do_tpm_pcr_read() assume SHA256. Function tpm_pcr_extend() shows the same limitation. This bug should be fixed. But as is CMD_TPM_V2 seems only to require CONFIG_SHA256.
Best regards
Heinrich
Regards /Ilias
Thanks /Ilias
-- 2.34.1
Hi Heinrich,
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
I still prefer to leave the TPM in a working state tbh.
Best regards
Heinrich
Regards /Ilias
Thanks /Ilias
-- 2.34.1
Hi Heinrich
resending the reply, I accidentally sent half of the message...
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
I still prefer to imply all algos.
Isn't [0] fixing this?
[0] https://source.denx.de/u-boot/u-boot/-/commit/89aa8463cdf3919ca4f04fc24ec8b1... Thanks /Ilias
Best regards
Heinrich
Regards /Ilias
Thanks /Ilias
-- 2.34.1
On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Heinrich
Hi Simon,
Changes in v2:
select SHA1
select SHA256
select SHA384
select SHA1
select SHA256
select SHA384
select SHA512
That's pretty normal for U-Boot though, since we want to avoid lots of growth for things people might want control over. We can enable or disable the SHA for the board, if this functionality is used outside of measured boot and tcg2, but someone is enabling the tpm command.
'imply' would be OK in this case as I can disable it for that board. I don't think it is in the spirit of U-Boot though.
isn't someone checking the growth in U-Boot? Or do so few boards have TPMs that it didn't register? The size growth was 3.2KB on chromebook_link.
Best regards
Heinrich
Regards /Ilias
Thanks /Ilias
-- 2.34.1
Hi Heinrich
Hi Simon,
On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > It does not make sense to enable all SHA algorithms unless they are > needed. It bloats the code and in this case, causes chromebook_link to > fail to build. That board does use the TPM, but not with measured boot, > nor EFI. > > Since EFI_TCG2_PROTOCOL already selects these options, we just need to > add them to MEASURED_BOOT as well. > > Note that the original commit combines refactoring and new features, > which makes it hard to see what is going on. > > Fixes: 97707f12fda tpm: Support boot measurements > Signed-off-by: Simon Glass sjg@chromium.org > --- > > Changes in v2: > - Put the conditions under EFI_TCG2_PROTOCOL > - Consider MEASURED_BOOT too > > boot/Kconfig | 4 ++++ > lib/Kconfig | 4 ---- > 2 files changed, 4 insertions(+), 4 deletions(-) > > diff --git a/boot/Kconfig b/boot/Kconfig > index 6f3096c15a6..b061891e109 100644 > --- a/boot/Kconfig > +++ b/boot/Kconfig > @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > config MEASURED_BOOT > bool "Measure boot images and configuration when booting without EFI" > depends on HASH && TPM_V2 > + select SHA1 > + select SHA256 > + select SHA384 > + select SHA512 > help > This option enables measurement of the boot process when booting > without UEFI . Measurement involves creating cryptographic hashes > diff --git a/lib/Kconfig b/lib/Kconfig > index 189e6eb31aa..568892fce44 100644 > --- a/lib/Kconfig > +++ b/lib/Kconfig > @@ -438,10 +438,6 @@ config TPM > bool "Trusted Platform Module (TPM) Support" > depends on DM > imply DM_RNG > - select SHA1 > - select SHA256 > - select SHA384 > - select SHA512
As always, yes, nearly every PR (I don't check the ones that touch just a single board for example) gets a world build before/after. In this case I likely assumed that it was acceptable growth for enabling features. It sounds like some of the chromebook boards need to be setting the features to cause link failure if a size is exceeded?
Hi Tom,
Hi Heinrich
On 6/14/24 08:03, Ilias Apalodimas wrote: > Hi Simon, > > On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: >> >> It does not make sense to enable all SHA algorithms unless they are >> needed. It bloats the code and in this case, causes chromebook_link to >> fail to build. That board does use the TPM, but not with measured boot, >> nor EFI. >> >> Since EFI_TCG2_PROTOCOL already selects these options, we just need to >> add them to MEASURED_BOOT as well. >> >> Note that the original commit combines refactoring and new features, >> which makes it hard to see what is going on. >> >> Fixes: 97707f12fda tpm: Support boot measurements >> Signed-off-by: Simon Glass sjg@chromium.org >> --- >> >> Changes in v2: >> - Put the conditions under EFI_TCG2_PROTOCOL >> - Consider MEASURED_BOOT too >> >> boot/Kconfig | 4 ++++ >> lib/Kconfig | 4 ---- >> 2 files changed, 4 insertions(+), 4 deletions(-) >> >> diff --git a/boot/Kconfig b/boot/Kconfig >> index 6f3096c15a6..b061891e109 100644 >> --- a/boot/Kconfig >> +++ b/boot/Kconfig >> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT >> config MEASURED_BOOT >> bool "Measure boot images and configuration when booting without EFI" >> depends on HASH && TPM_V2 >> + select SHA1 >> + select SHA256 >> + select SHA384 >> + select SHA512 >> help >> This option enables measurement of the boot process when booting >> without UEFI . Measurement involves creating cryptographic hashes >> diff --git a/lib/Kconfig b/lib/Kconfig >> index 189e6eb31aa..568892fce44 100644 >> --- a/lib/Kconfig >> +++ b/lib/Kconfig >> @@ -438,10 +438,6 @@ config TPM >> bool "Trusted Platform Module (TPM) Support" >> depends on DM >> imply DM_RNG >> - select SHA1 >> - select SHA256 >> - select SHA384 >> - select SHA512 > > I am not sure this is the right way to deal with your problem. > The TPM main functionality is to measure and extend PCRs, so shaXXXX > is really required. To make things even worse, you don't know the PCR > banks that are enabled beforehand. This is a runtime config of the > TPM.
The problem is that some Intel platforms have binary blobs, so the size isn't known unless you have a real blob.
-- Tom
On Tue, Jun 18, 2024 at 06:43:51AM -0600, Simon Glass wrote:
Hi Tom,
Hi Heinrich
On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > On 6/14/24 08:03, Ilias Apalodimas wrote: >> Hi Simon, >> >> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: >>> >>> It does not make sense to enable all SHA algorithms unless they are >>> needed. It bloats the code and in this case, causes chromebook_link to >>> fail to build. That board does use the TPM, but not with measured boot, >>> nor EFI. >>> >>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to >>> add them to MEASURED_BOOT as well. >>> >>> Note that the original commit combines refactoring and new features, >>> which makes it hard to see what is going on. >>> >>> Fixes: 97707f12fda tpm: Support boot measurements >>> Signed-off-by: Simon Glass sjg@chromium.org >>> --- >>> >>> Changes in v2: >>> - Put the conditions under EFI_TCG2_PROTOCOL >>> - Consider MEASURED_BOOT too >>> >>> boot/Kconfig | 4 ++++ >>> lib/Kconfig | 4 ---- >>> 2 files changed, 4 insertions(+), 4 deletions(-) >>> >>> diff --git a/boot/Kconfig b/boot/Kconfig >>> index 6f3096c15a6..b061891e109 100644 >>> --- a/boot/Kconfig >>> +++ b/boot/Kconfig >>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT >>> config MEASURED_BOOT >>> bool "Measure boot images and configuration when booting without EFI" >>> depends on HASH && TPM_V2 >>> + select SHA1 >>> + select SHA256 >>> + select SHA384 >>> + select SHA512 >>> help >>> This option enables measurement of the boot process when booting >>> without UEFI . Measurement involves creating cryptographic hashes >>> diff --git a/lib/Kconfig b/lib/Kconfig >>> index 189e6eb31aa..568892fce44 100644 >>> --- a/lib/Kconfig >>> +++ b/lib/Kconfig >>> @@ -438,10 +438,6 @@ config TPM >>> bool "Trusted Platform Module (TPM) Support" >>> depends on DM >>> imply DM_RNG >>> - select SHA1 >>> - select SHA256 >>> - select SHA384 >>> - select SHA512 >> >> I am not sure this is the right way to deal with your problem. >> The TPM main functionality is to measure and extend PCRs, so shaXXXX >> is really required. To make things even worse, you don't know the PCR >> banks that are enabled beforehand. This is a runtime config of the >> TPM. > > If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > cannot extend PCRs. So it seems fine to let these two select the > complete set of hashing algorithms. As Simon pointed out for > EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig.
Alright, but can't we put in some limit based on what the current blobs are, or look at the last few blob releases and see if they change much in size and put something in? Other platforms have blobs and size limits...
Hi Tom,
Hi Tom,
Hi Heinrich
On 14.06.24 09:01, Ilias Apalodimas wrote: > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: >> >> On 6/14/24 08:03, Ilias Apalodimas wrote: >>> Hi Simon, >>> >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: >>>> >>>> It does not make sense to enable all SHA algorithms unless they are >>>> needed. It bloats the code and in this case, causes chromebook_link to >>>> fail to build. That board does use the TPM, but not with measured boot, >>>> nor EFI. >>>> >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to >>>> add them to MEASURED_BOOT as well. >>>> >>>> Note that the original commit combines refactoring and new features, >>>> which makes it hard to see what is going on. >>>> >>>> Fixes: 97707f12fda tpm: Support boot measurements >>>> Signed-off-by: Simon Glass sjg@chromium.org >>>> --- >>>> >>>> Changes in v2: >>>> - Put the conditions under EFI_TCG2_PROTOCOL >>>> - Consider MEASURED_BOOT too >>>> >>>> boot/Kconfig | 4 ++++ >>>> lib/Kconfig | 4 ---- >>>> 2 files changed, 4 insertions(+), 4 deletions(-) >>>> >>>> diff --git a/boot/Kconfig b/boot/Kconfig >>>> index 6f3096c15a6..b061891e109 100644 >>>> --- a/boot/Kconfig >>>> +++ b/boot/Kconfig >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT >>>> config MEASURED_BOOT >>>> bool "Measure boot images and configuration when booting without EFI" >>>> depends on HASH && TPM_V2 >>>> + select SHA1 >>>> + select SHA256 >>>> + select SHA384 >>>> + select SHA512 >>>> help >>>> This option enables measurement of the boot process when booting >>>> without UEFI . Measurement involves creating cryptographic hashes >>>> diff --git a/lib/Kconfig b/lib/Kconfig >>>> index 189e6eb31aa..568892fce44 100644 >>>> --- a/lib/Kconfig >>>> +++ b/lib/Kconfig >>>> @@ -438,10 +438,6 @@ config TPM >>>> bool "Trusted Platform Module (TPM) Support" >>>> depends on DM >>>> imply DM_RNG >>>> - select SHA1 >>>> - select SHA256 >>>> - select SHA384 >>>> - select SHA512 >>> >>> I am not sure this is the right way to deal with your problem. >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX >>> is really required. To make things even worse, you don't know the PCR >>> banks that are enabled beforehand. This is a runtime config of the >>> TPM. >> >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot >> cannot extend PCRs. So it seems fine to let these two select the >> complete set of hashing algorithms. As Simon pointed out for >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > 0xb0000000
Yes we can duplicate the entry sizes from binman into Kconfig options. But I am not a fan of that...two variables controlling the same thing and both can break, with nothing to connect them other than the poor user.
I wonder if some magic could solve this, inferring limits from the binman image. But that is getting into yet another domain...
On Tue, Jun 18, 2024 at 09:03:37PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Heinrich
On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > >> > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > >>> Hi Simon, > >>> > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > >>>> > >>>> It does not make sense to enable all SHA algorithms unless they are > >>>> needed. It bloats the code and in this case, causes chromebook_link to > >>>> fail to build. That board does use the TPM, but not with measured boot, > >>>> nor EFI. > >>>> > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > >>>> add them to MEASURED_BOOT as well. > >>>> > >>>> Note that the original commit combines refactoring and new features, > >>>> which makes it hard to see what is going on. > >>>> > >>>> Fixes: 97707f12fda tpm: Support boot measurements > >>>> Signed-off-by: Simon Glass sjg@chromium.org > >>>> --- > >>>> > >>>> Changes in v2: > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > >>>> - Consider MEASURED_BOOT too > >>>> > >>>> boot/Kconfig | 4 ++++ > >>>> lib/Kconfig | 4 ---- > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > >>>> > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > >>>> index 6f3096c15a6..b061891e109 100644 > >>>> --- a/boot/Kconfig > >>>> +++ b/boot/Kconfig > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > >>>> config MEASURED_BOOT > >>>> bool "Measure boot images and configuration when booting without EFI" > >>>> depends on HASH && TPM_V2 > >>>> + select SHA1 > >>>> + select SHA256 > >>>> + select SHA384 > >>>> + select SHA512 > >>>> help > >>>> This option enables measurement of the boot process when booting > >>>> without UEFI . Measurement involves creating cryptographic hashes > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > >>>> index 189e6eb31aa..568892fce44 100644 > >>>> --- a/lib/Kconfig > >>>> +++ b/lib/Kconfig > >>>> @@ -438,10 +438,6 @@ config TPM > >>>> bool "Trusted Platform Module (TPM) Support" > >>>> depends on DM > >>>> imply DM_RNG > >>>> - select SHA1 > >>>> - select SHA256 > >>>> - select SHA384 > >>>> - select SHA512 > >>> > >>> I am not sure this is the right way to deal with your problem. > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > >>> is really required. To make things even worse, you don't know the PCR > >>> banks that are enabled beforehand. This is a runtime config of the > >>> TPM. > >> > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > >> cannot extend PCRs. So it seems fine to let these two select the > >> complete set of hashing algorithms. As Simon pointed out for > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > 0xb0000000
> > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > TPM v1 only needs SHA-1.
I'm sorry, I just don't see what makes this case different from all of the other cases where we have to include blobs. We know there's X amount of flash available, blobs tend to take up Y and so we set BOARD_SIZE_LIMIT to Z where there's some room for growth in U-Boot but it takes in to account whatever limits the blobs place on us.
Hi Tom,
Hi Tom,
Hi Tom,
On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas ilias.apalodimas@linaro.org wrote: > > Hi Heinrich > > resending the reply, I accidentally sent half of the message... > > On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > >> > > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > > >>> Hi Simon, > > >>> > > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > >>>> > > >>>> It does not make sense to enable all SHA algorithms unless they are > > >>>> needed. It bloats the code and in this case, causes chromebook_link to > > >>>> fail to build. That board does use the TPM, but not with measured boot, > > >>>> nor EFI. > > >>>> > > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > > >>>> add them to MEASURED_BOOT as well. > > >>>> > > >>>> Note that the original commit combines refactoring and new features, > > >>>> which makes it hard to see what is going on. > > >>>> > > >>>> Fixes: 97707f12fda tpm: Support boot measurements > > >>>> Signed-off-by: Simon Glass sjg@chromium.org > > >>>> --- > > >>>> > > >>>> Changes in v2: > > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > > >>>> - Consider MEASURED_BOOT too > > >>>> > > >>>> boot/Kconfig | 4 ++++ > > >>>> lib/Kconfig | 4 ---- > > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > > >>>> > > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > > >>>> index 6f3096c15a6..b061891e109 100644 > > >>>> --- a/boot/Kconfig > > >>>> +++ b/boot/Kconfig > > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > > >>>> config MEASURED_BOOT > > >>>> bool "Measure boot images and configuration when booting without EFI" > > >>>> depends on HASH && TPM_V2 > > >>>> + select SHA1 > > >>>> + select SHA256 > > >>>> + select SHA384 > > >>>> + select SHA512 > > >>>> help > > >>>> This option enables measurement of the boot process when booting > > >>>> without UEFI . Measurement involves creating cryptographic hashes > > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > > >>>> index 189e6eb31aa..568892fce44 100644 > > >>>> --- a/lib/Kconfig > > >>>> +++ b/lib/Kconfig > > >>>> @@ -438,10 +438,6 @@ config TPM > > >>>> bool "Trusted Platform Module (TPM) Support" > > >>>> depends on DM > > >>>> imply DM_RNG > > >>>> - select SHA1 > > >>>> - select SHA256 > > >>>> - select SHA384 > > >>>> - select SHA512 > > >>> > > >>> I am not sure this is the right way to deal with your problem. > > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > > >>> is really required. To make things even worse, you don't know the PCR > > >>> banks that are enabled beforehand. This is a runtime config of the > > >>> TPM. > > >> > > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > > >> cannot extend PCRs. So it seems fine to let these two select the > > >> complete set of hashing algorithms. As Simon pointed out for > > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > > 0xb0000000
> > > > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > > > TPM v1 only needs SHA-1. > > I still prefer to imply all algos.
The difference is that now we are using Binman, we have the limit in the image description, so adding it to Kconfig a) involves calculations and perhaps guesswork and b) results in two limits stored in different places which may conflict.
I thought of a way to handle this in Binman, so will send that in the next version.
On Thu, Jun 20, 2024 at 05:05:29PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Mon, Jun 17, 2024 at 07:53:22AM -0600, Simon Glass wrote: > Hi, > > On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas > ilias.apalodimas@linaro.org wrote: > > > > Hi Heinrich > > > > resending the reply, I accidentally sent half of the message... > > > > On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > >> > > > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > > > >>> Hi Simon, > > > >>> > > > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > > >>>> > > > >>>> It does not make sense to enable all SHA algorithms unless they are > > > >>>> needed. It bloats the code and in this case, causes chromebook_link to > > > >>>> fail to build. That board does use the TPM, but not with measured boot, > > > >>>> nor EFI. > > > >>>> > > > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > > > >>>> add them to MEASURED_BOOT as well. > > > >>>> > > > >>>> Note that the original commit combines refactoring and new features, > > > >>>> which makes it hard to see what is going on. > > > >>>> > > > >>>> Fixes: 97707f12fda tpm: Support boot measurements > > > >>>> Signed-off-by: Simon Glass sjg@chromium.org > > > >>>> --- > > > >>>> > > > >>>> Changes in v2: > > > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > > > >>>> - Consider MEASURED_BOOT too > > > >>>> > > > >>>> boot/Kconfig | 4 ++++ > > > >>>> lib/Kconfig | 4 ---- > > > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > > > >>>> > > > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > > > >>>> index 6f3096c15a6..b061891e109 100644 > > > >>>> --- a/boot/Kconfig > > > >>>> +++ b/boot/Kconfig > > > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > > > >>>> config MEASURED_BOOT > > > >>>> bool "Measure boot images and configuration when booting without EFI" > > > >>>> depends on HASH && TPM_V2 > > > >>>> + select SHA1 > > > >>>> + select SHA256 > > > >>>> + select SHA384 > > > >>>> + select SHA512 > > > >>>> help > > > >>>> This option enables measurement of the boot process when booting > > > >>>> without UEFI . Measurement involves creating cryptographic hashes > > > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > > > >>>> index 189e6eb31aa..568892fce44 100644 > > > >>>> --- a/lib/Kconfig > > > >>>> +++ b/lib/Kconfig > > > >>>> @@ -438,10 +438,6 @@ config TPM > > > >>>> bool "Trusted Platform Module (TPM) Support" > > > >>>> depends on DM > > > >>>> imply DM_RNG > > > >>>> - select SHA1 > > > >>>> - select SHA256 > > > >>>> - select SHA384 > > > >>>> - select SHA512 > > > >>> > > > >>> I am not sure this is the right way to deal with your problem. > > > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > > > >>> is really required. To make things even worse, you don't know the PCR > > > >>> banks that are enabled beforehand. This is a runtime config of the > > > >>> TPM. > > > >> > > > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > > > >> cannot extend PCRs. So it seems fine to let these two select the > > > >> complete set of hashing algorithms. As Simon pointed out for > > > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > > > 0xb0000000 > > That's pretty normal for U-Boot though, since we want to avoid lots of > growth for things people might want control over. We can enable or > disable the SHA for the board, if this functionality is used outside > of measured boot and tcg2, but someone is enabling the tpm command. > > > > > > > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > > > > > TPM v1 only needs SHA-1. > > > > I still prefer to imply all algos. > > 'imply' would be OK in this case as I can disable it for that board. I > don't think it is in the spirit of U-Boot though. > > isn't someone checking the growth in U-Boot? Or do so few boards have > TPMs that it didn't register? The size growth was 3.2KB on > chromebook_link.
I'm still confused, sorry. This sounds like a whole lot more work than setting BOARD_SIZE_LIMIT reasonably so that we fail to link and CI errors out, before we get to buildman and needing to make this case still fail but with fake blobs.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Mon, 17 Jun 2024 at 11:16, Tom Rini trini@konsulko.com wrote: > > On Mon, Jun 17, 2024 at 07:53:22AM -0600, Simon Glass wrote: > > Hi, > > > > On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas > > ilias.apalodimas@linaro.org wrote: > > > > > > Hi Heinrich > > > > > > resending the reply, I accidentally sent half of the message... > > > > > > On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > > > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > > > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > >> > > > > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > > > > >>> Hi Simon, > > > > >>> > > > > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > > > >>>> > > > > >>>> It does not make sense to enable all SHA algorithms unless they are > > > > >>>> needed. It bloats the code and in this case, causes chromebook_link to > > > > >>>> fail to build. That board does use the TPM, but not with measured boot, > > > > >>>> nor EFI. > > > > >>>> > > > > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > > > > >>>> add them to MEASURED_BOOT as well. > > > > >>>> > > > > >>>> Note that the original commit combines refactoring and new features, > > > > >>>> which makes it hard to see what is going on. > > > > >>>> > > > > >>>> Fixes: 97707f12fda tpm: Support boot measurements > > > > >>>> Signed-off-by: Simon Glass sjg@chromium.org > > > > >>>> --- > > > > >>>> > > > > >>>> Changes in v2: > > > > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > > > > >>>> - Consider MEASURED_BOOT too > > > > >>>> > > > > >>>> boot/Kconfig | 4 ++++ > > > > >>>> lib/Kconfig | 4 ---- > > > > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > > > > >>>> > > > > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > > > > >>>> index 6f3096c15a6..b061891e109 100644 > > > > >>>> --- a/boot/Kconfig > > > > >>>> +++ b/boot/Kconfig > > > > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > > > > >>>> config MEASURED_BOOT > > > > >>>> bool "Measure boot images and configuration when booting without EFI" > > > > >>>> depends on HASH && TPM_V2 > > > > >>>> + select SHA1 > > > > >>>> + select SHA256 > > > > >>>> + select SHA384 > > > > >>>> + select SHA512 > > > > >>>> help > > > > >>>> This option enables measurement of the boot process when booting > > > > >>>> without UEFI . Measurement involves creating cryptographic hashes > > > > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > > > > >>>> index 189e6eb31aa..568892fce44 100644 > > > > >>>> --- a/lib/Kconfig > > > > >>>> +++ b/lib/Kconfig > > > > >>>> @@ -438,10 +438,6 @@ config TPM > > > > >>>> bool "Trusted Platform Module (TPM) Support" > > > > >>>> depends on DM > > > > >>>> imply DM_RNG > > > > >>>> - select SHA1 > > > > >>>> - select SHA256 > > > > >>>> - select SHA384 > > > > >>>> - select SHA512 > > > > >>> > > > > >>> I am not sure this is the right way to deal with your problem. > > > > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > > > > >>> is really required. To make things even worse, you don't know the PCR > > > > >>> banks that are enabled beforehand. This is a runtime config of the > > > > >>> TPM. > > > > >> > > > > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > > > > >> cannot extend PCRs. So it seems fine to let these two select the > > > > >> complete set of hashing algorithms. As Simon pointed out for > > > > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > > > > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > > > > 0xb0000000 > > > > That's pretty normal for U-Boot though, since we want to avoid lots of > > growth for things people might want control over. We can enable or > > disable the SHA for the board, if this functionality is used outside > > of measured boot and tcg2, but someone is enabling the tpm command. > > > > > > > > > > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > > > > > > > TPM v1 only needs SHA-1. > > > > > > I still prefer to imply all algos. > > > > 'imply' would be OK in this case as I can disable it for that board. I > > don't think it is in the spirit of U-Boot though. > > > > isn't someone checking the growth in U-Boot? Or do so few boards have > > TPMs that it didn't register? The size growth was 3.2KB on > > chromebook_link. > > As always, yes, nearly every PR (I don't check the ones that touch just > a single board for example) gets a world build before/after. In this > case I likely assumed that it was acceptable growth for enabling > features. It sounds like some of the chromebook boards need to be > setting the features to cause link failure if a size is exceeded?
It is simpler for me, since I don't need to reverse-engineer the space requirement for each board. With the patch I sent, I can just add some reasonable numbers to each entry and it will do the right thing.
On Fri, Jun 21, 2024 at 08:57:51AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Tue, Jun 18, 2024 at 06:43:51AM -0600, Simon Glass wrote: > Hi Tom, > > On Mon, 17 Jun 2024 at 11:16, Tom Rini trini@konsulko.com wrote: > > > > On Mon, Jun 17, 2024 at 07:53:22AM -0600, Simon Glass wrote: > > > Hi, > > > > > > On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas > > > ilias.apalodimas@linaro.org wrote: > > > > > > > > Hi Heinrich > > > > > > > > resending the reply, I accidentally sent half of the message... > > > > > > > > On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > > > > > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > > > > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > >> > > > > > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > > > > > >>> Hi Simon, > > > > > >>> > > > > > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > > > > >>>> > > > > > >>>> It does not make sense to enable all SHA algorithms unless they are > > > > > >>>> needed. It bloats the code and in this case, causes chromebook_link to > > > > > >>>> fail to build. That board does use the TPM, but not with measured boot, > > > > > >>>> nor EFI. > > > > > >>>> > > > > > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > > > > > >>>> add them to MEASURED_BOOT as well. > > > > > >>>> > > > > > >>>> Note that the original commit combines refactoring and new features, > > > > > >>>> which makes it hard to see what is going on. > > > > > >>>> > > > > > >>>> Fixes: 97707f12fda tpm: Support boot measurements > > > > > >>>> Signed-off-by: Simon Glass sjg@chromium.org > > > > > >>>> --- > > > > > >>>> > > > > > >>>> Changes in v2: > > > > > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > > > > > >>>> - Consider MEASURED_BOOT too > > > > > >>>> > > > > > >>>> boot/Kconfig | 4 ++++ > > > > > >>>> lib/Kconfig | 4 ---- > > > > > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > > > > > >>>> > > > > > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > > > > > >>>> index 6f3096c15a6..b061891e109 100644 > > > > > >>>> --- a/boot/Kconfig > > > > > >>>> +++ b/boot/Kconfig > > > > > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > > > > > >>>> config MEASURED_BOOT > > > > > >>>> bool "Measure boot images and configuration when booting without EFI" > > > > > >>>> depends on HASH && TPM_V2 > > > > > >>>> + select SHA1 > > > > > >>>> + select SHA256 > > > > > >>>> + select SHA384 > > > > > >>>> + select SHA512 > > > > > >>>> help > > > > > >>>> This option enables measurement of the boot process when booting > > > > > >>>> without UEFI . Measurement involves creating cryptographic hashes > > > > > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > > > > > >>>> index 189e6eb31aa..568892fce44 100644 > > > > > >>>> --- a/lib/Kconfig > > > > > >>>> +++ b/lib/Kconfig > > > > > >>>> @@ -438,10 +438,6 @@ config TPM > > > > > >>>> bool "Trusted Platform Module (TPM) Support" > > > > > >>>> depends on DM > > > > > >>>> imply DM_RNG > > > > > >>>> - select SHA1 > > > > > >>>> - select SHA256 > > > > > >>>> - select SHA384 > > > > > >>>> - select SHA512 > > > > > >>> > > > > > >>> I am not sure this is the right way to deal with your problem. > > > > > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > > > > > >>> is really required. To make things even worse, you don't know the PCR > > > > > >>> banks that are enabled beforehand. This is a runtime config of the > > > > > >>> TPM. > > > > > >> > > > > > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > > > > > >> cannot extend PCRs. So it seems fine to let these two select the > > > > > >> complete set of hashing algorithms. As Simon pointed out for > > > > > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > > > > > > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > > > > > 0xb0000000 > > > > > > That's pretty normal for U-Boot though, since we want to avoid lots of > > > growth for things people might want control over. We can enable or > > > disable the SHA for the board, if this functionality is used outside > > > of measured boot and tcg2, but someone is enabling the tpm command. > > > > > > > > > > > > > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > > > > > > > > > TPM v1 only needs SHA-1. > > > > > > > > I still prefer to imply all algos. > > > > > > 'imply' would be OK in this case as I can disable it for that board. I > > > don't think it is in the spirit of U-Boot though. > > > > > > isn't someone checking the growth in U-Boot? Or do so few boards have > > > TPMs that it didn't register? The size growth was 3.2KB on > > > chromebook_link. > > > > As always, yes, nearly every PR (I don't check the ones that touch just > > a single board for example) gets a world build before/after. In this > > case I likely assumed that it was acceptable growth for enabling > > features. It sounds like some of the chromebook boards need to be > > setting the features to cause link failure if a size is exceeded? > > The problem is that some Intel platforms have binary blobs, so the > size isn't known unless you have a real blob.
Yes, I very much do not like guessing about 3 numbers instead of guessing about 1 number and using the standard mechanism we already have. Please use BOARD_SIZE_LIMIT as this is the standard mechanism to enforce size limits on U-Boot itself.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Tue, 18 Jun 2024 at 08:15, Tom Rini trini@konsulko.com wrote: > > On Tue, Jun 18, 2024 at 06:43:51AM -0600, Simon Glass wrote: > > Hi Tom, > > > > On Mon, 17 Jun 2024 at 11:16, Tom Rini trini@konsulko.com wrote: > > > > > > On Mon, Jun 17, 2024 at 07:53:22AM -0600, Simon Glass wrote: > > > > Hi, > > > > > > > > On Sat, 15 Jun 2024 at 01:03, Ilias Apalodimas > > > > ilias.apalodimas@linaro.org wrote: > > > > > > > > > > Hi Heinrich > > > > > > > > > > resending the reply, I accidentally sent half of the message... > > > > > > > > > > On Fri, 14 Jun 2024 at 12:04, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > > > > > > > > On 14.06.24 09:01, Ilias Apalodimas wrote: > > > > > > > On Fri, 14 Jun 2024 at 09:59, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > > > > > >> > > > > > > >> On 6/14/24 08:03, Ilias Apalodimas wrote: > > > > > > >>> Hi Simon, > > > > > > >>> > > > > > > >>> On Mon, 10 Jun 2024 at 17:59, Simon Glass sjg@chromium.org wrote: > > > > > > >>>> > > > > > > >>>> It does not make sense to enable all SHA algorithms unless they are > > > > > > >>>> needed. It bloats the code and in this case, causes chromebook_link to > > > > > > >>>> fail to build. That board does use the TPM, but not with measured boot, > > > > > > >>>> nor EFI. > > > > > > >>>> > > > > > > >>>> Since EFI_TCG2_PROTOCOL already selects these options, we just need to > > > > > > >>>> add them to MEASURED_BOOT as well. > > > > > > >>>> > > > > > > >>>> Note that the original commit combines refactoring and new features, > > > > > > >>>> which makes it hard to see what is going on. > > > > > > >>>> > > > > > > >>>> Fixes: 97707f12fda tpm: Support boot measurements > > > > > > >>>> Signed-off-by: Simon Glass sjg@chromium.org > > > > > > >>>> --- > > > > > > >>>> > > > > > > >>>> Changes in v2: > > > > > > >>>> - Put the conditions under EFI_TCG2_PROTOCOL > > > > > > >>>> - Consider MEASURED_BOOT too > > > > > > >>>> > > > > > > >>>> boot/Kconfig | 4 ++++ > > > > > > >>>> lib/Kconfig | 4 ---- > > > > > > >>>> 2 files changed, 4 insertions(+), 4 deletions(-) > > > > > > >>>> > > > > > > >>>> diff --git a/boot/Kconfig b/boot/Kconfig > > > > > > >>>> index 6f3096c15a6..b061891e109 100644 > > > > > > >>>> --- a/boot/Kconfig > > > > > > >>>> +++ b/boot/Kconfig > > > > > > >>>> @@ -734,6 +734,10 @@ config LEGACY_IMAGE_FORMAT > > > > > > >>>> config MEASURED_BOOT > > > > > > >>>> bool "Measure boot images and configuration when booting without EFI" > > > > > > >>>> depends on HASH && TPM_V2 > > > > > > >>>> + select SHA1 > > > > > > >>>> + select SHA256 > > > > > > >>>> + select SHA384 > > > > > > >>>> + select SHA512 > > > > > > >>>> help > > > > > > >>>> This option enables measurement of the boot process when booting > > > > > > >>>> without UEFI . Measurement involves creating cryptographic hashes > > > > > > >>>> diff --git a/lib/Kconfig b/lib/Kconfig > > > > > > >>>> index 189e6eb31aa..568892fce44 100644 > > > > > > >>>> --- a/lib/Kconfig > > > > > > >>>> +++ b/lib/Kconfig > > > > > > >>>> @@ -438,10 +438,6 @@ config TPM > > > > > > >>>> bool "Trusted Platform Module (TPM) Support" > > > > > > >>>> depends on DM > > > > > > >>>> imply DM_RNG > > > > > > >>>> - select SHA1 > > > > > > >>>> - select SHA256 > > > > > > >>>> - select SHA384 > > > > > > >>>> - select SHA512 > > > > > > >>> > > > > > > >>> I am not sure this is the right way to deal with your problem. > > > > > > >>> The TPM main functionality is to measure and extend PCRs, so shaXXXX > > > > > > >>> is really required. To make things even worse, you don't know the PCR > > > > > > >>> banks that are enabled beforehand. This is a runtime config of the > > > > > > >>> TPM. > > > > > > >> > > > > > > >> If neither MEASURED_BOOT nor EFI_TCG2_PROTOCOL is selected, U-Boot > > > > > > >> cannot extend PCRs. So it seems fine to let these two select the > > > > > > >> complete set of hashing algorithms. As Simon pointed out for > > > > > > >> EFI_TCG2_PROTOCOL this is already done in lib/efi_loader/Kconfig. > > > > > > > > > > > > > > It can. The cmd we have can extend those pcrs -- e.g tpm2 pcr_extend 8 > > > > > > > 0xb0000000 > > > > > > > > That's pretty normal for U-Boot though, since we want to avoid lots of > > > > growth for things people might want control over. We can enable or > > > > disable the SHA for the board, if this functionality is used outside > > > > of measured boot and tcg2, but someone is enabling the tpm command. > > > > > > > > > > > > > > > > So this patch should also consider CMD_TPM_V2 and CMD_TPM_V1. > > > > > > > > > > > > TPM v1 only needs SHA-1. > > > > > > > > > > I still prefer to imply all algos. > > > > > > > > 'imply' would be OK in this case as I can disable it for that board. I > > > > don't think it is in the spirit of U-Boot though. > > > > > > > > isn't someone checking the growth in U-Boot? Or do so few boards have > > > > TPMs that it didn't register? The size growth was 3.2KB on > > > > chromebook_link. > > > > > > As always, yes, nearly every PR (I don't check the ones that touch just > > > a single board for example) gets a world build before/after. In this > > > case I likely assumed that it was acceptable growth for enabling > > > features. It sounds like some of the chromebook boards need to be > > > setting the features to cause link failure if a size is exceeded? > > > > The problem is that some Intel platforms have binary blobs, so the > > size isn't known unless you have a real blob. > > Alright, but can't we put in some limit based on what the current blobs > are, or look at the last few blob releases and see if they change much > in size and put something in? Other platforms have blobs and size > limits...
If it were that easy I would have sent a patch :-)
Here is the map for this board:
ImagePos Offset Size Name 00000000 00000000 00800000 rom ff800000 ff800000 00001000 intel-descriptor ff801000 ff801000 001ff000 intel-me ffef0000 ffef0000 000999f0 u-boot-with-ucode-ptr fff899f0 fff899f0 00005554 u-boot-dtb-with-ucode fff8ef50 fff8ef50 00000000 u-boot-ucode fff8ef50 fff8ef50 00000571 fdtmap fff90000 fff90000 00010000 intel-vga fffa0000 fffa0000 0002fc94 intel-mrc fffcfc94 fffcfc94 00000000 private-files fffff800 fffff800 00000070 x86-start16 fffffff0 fffffff0 00000005 x86-reset16 fffffff8 fffffff8 00000008 image-header
What limit should I set on what?
- the U-Boot is the thing you are wanting to limit - the dtb has microcode added - the ucode is empty in this case - the fdtmap is variable in size
So this all seems a bit backwards. The actual limit is that (u-boot-with-ucode-ptr + u-boot-dtb-with-ucode + u-boot-ucode + fdtmap) fits in the space available. Note that some boards don't have intel-vga or intel-mrc.
With the other patch I sent I can have a sensible limit for all x86 boards.
On Fri, Jun 21, 2024 at 11:55:42AM -0600, Simon Glass wrote:
Hi Tom,
[snip]
Is this a trick question? $ printf %d\n $(( 0xfff90000 - 0xffef0000)) 655360
Of course since we're less than that today, you can reduce it by whatever other magic numbers I'm not seeing but are part of your assumed sizes.
And you can set the same sensible limit with the existing mechanism with the bonus of it not making x86 different from the rest?
Hi Tom,
Hi Tom,
[snip]
That limit is on u-boot-nodtb.bin. Even with a size (for that file) of 634816 it doesn't fit. I need to calculate a size based on the size of the dtb and the microcode...which of course can change.
Did you miss the comments above?
I understand that it is possible to set a limit for u-boot-nodtb.bin but that is not accurate nor sufficient in the presence of blobs. The solution belongs in Binman.
On Fri, Jun 21, 2024 at 01:38:07PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
[snip]
Yes, and you're able to assume some size for them, which is what you put in the dts file?
No, I saw them. They're similar constraints to other systems.
Your series puts reasonable estimates on the size of the blobs and then will give a failure such as: binman: Node '/binman/rom/intel-vga': Offset 0xfff90000 (4294508544) overlaps with previous entry '/binman/rom/fdtmap' ending at 0xfff902e1 (4294509281) Which is not as nice as (I just threw in a limit): u-boot-nodtb.bin exceeds file size limit: limit: 0x927c0 bytes actual: 0x9a810 bytes excess: 0x8050 bytes make[1]: *** [/home/trini/work/u-boot/u-boot/Makefile:1359: u-boot-nodtb.bin] Error 1
And tells us how much we need to get back size wise. Aside from when using the actual blobs (and in which case a real error will be shown when trying to use them), it's always about making an estimate on the part of the system that we control.
Hi Tom,
Hi Tom,
Hi Tom,
[snip]
I just put in a limit for the blobs, whose sizes are known.
Thanks for digging into this.
I wasn't aware that the limit was just an estimate. Since it produces a build error it seems to be enforced as a hard requirement. But I can set a limit and we'll see how things go.
I still like the binman block-size thing though. The error message binman provides actually tells you what to do (reduce the space of the things that are overflowing into intel-vga). So I'd like to add that too.
On Sun, Jun 23, 2024 at 03:52:12PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
[snip]
I think this is a reasonable compromise, thank you.
Add better logging for power init so that CONFIG_LOG_ERROR_RETURN can be enabled.
Changes in v2: - Remove the superfluous if() and drop the debug() as well
board/google/veyron/veyron.c | 30 ++++++++++++------------------ 1 file changed, 12 insertions(+), 18 deletions(-)
diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index 32dbcdc4d10..6d4c9debdee 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -29,44 +29,38 @@ static int veyron_init(void) int ret;
ret = regulator_get_by_platname("vdd_arm", &dev); - if (ret) { - debug("Cannot set regulator name\n"); - return ret; - } + if (ret) + return log_msg_ret("vdd", ret);
/* Slowly raise to max CPU voltage to prevent overshoot */ ret = regulator_set_value(dev, 1200000); if (ret) - return ret; + return log_msg_ret("s12", ret); udelay(175); /* Must wait for voltage to stabilize, 2mV/us */ ret = regulator_set_value(dev, 1400000); if (ret) - return ret; + return log_msg_ret("s14", ret); udelay(100); /* Must wait for voltage to stabilize, 2mV/us */
ret = rockchip_get_clk(&clk.dev); if (ret) - return ret; + return log_msg_ret("clk", ret); clk.id = PLL_APLL; ret = clk_set_rate(&clk, 1800000000); if (IS_ERR_VALUE(ret)) - return ret; + return log_msg_ret("s18", ret);
ret = regulator_get_by_platname("vcc33_sd", &dev); - if (ret) { - debug("Cannot get regulator name\n"); - return ret; - } + if (ret) + return log_msg_ret("vcc", ret);
ret = regulator_set_value(dev, 3300000); if (ret) - return ret; + return log_msg_ret("s33", ret);
ret = regulators_enable_boot_on(false); - if (ret) { - debug("%s: Cannot enable boot on regulators\n", __func__); - return ret; - } + if (ret) + return log_msg_ret("boo", ret);
return 0; } @@ -81,7 +75,7 @@ int board_early_init_r(void) if (!fdt_node_check_compatible(gd->fdt_blob, 0, "google,veyron")) { ret = veyron_init(); if (ret) - return ret; + return log_msg_ret("vey", ret); } #endif /*
Hi Simon,
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
With a recent change, regulators_enable_boot_on() returns an error if a regulator is already set. Check for and handle this situation.
Fixes: d99fb64a98a power: regulator: Only run autoset once for each regulator Reviewed-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
drivers/power/regulator/regulator-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 77d101f262e..d9e1fb68295 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -518,7 +518,7 @@ int regulators_enable_boot_on(bool verbose) dev; uclass_next_device(&dev)) { ret = regulator_autoset(dev); - if (ret == -EMEDIUMTYPE) { + if (ret == -EMEDIUMTYPE || ret == -EALREADY) { ret = 0; continue; }
On some boards, the bloblist is created in SPL once SDRAM is ready. It cannot be accessed until that point, so is not available early in SPL.
Add a condition to avoid a hang in this case.
This fixes a hang in chromebook_coral
Fixes: 70fe2385943 ("fdt: Allow the devicetree to come from a bloblist")
Changes in v2: - Use 'phase' instead of 'stage'
lib/fdtdec.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index b2c59ab3818..79eaa56ea39 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1669,8 +1669,16 @@ int fdtdec_setup(void) { int ret = -ENOENT;
- /* If allowing a bloblist, check that first */ - if (CONFIG_IS_ENABLED(BLOBLIST)) { + /* + * If allowing a bloblist, check that first. This would be better + * handled with an OF_BLOBLIST Kconfig, but that caused far too much + * argument, so add a hack here, used e.g. by chromebook_coral + * The necessary test is whether the previous phase passed a bloblist, + * not whether this phase creates one. + */ + if (CONFIG_IS_ENABLED(OF_BLOBLIST) && + (spl_prev_phase() != PHASE_TPL || + !IS_ENABLED(CONFIG_TPL_BLOBLIST))) { ret = bloblist_maybe_init(); if (!ret) { gd->fdt_blob = bloblist_find(BLOBLISTT_CONTROL_FDT, 0);
The dcache may not be enabled in SPL. Add a check to avoid trying to use an undefined function.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
common/spl/spl_atf.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_atf.c b/common/spl/spl_atf.c index 3bdd013a35f..9afe6456bc4 100644 --- a/common/spl/spl_atf.c +++ b/common/spl/spl_atf.c @@ -204,7 +204,8 @@ static void __noreturn bl31_entry(uintptr_t bl31_entry, uintptr_t bl32_entry, fdt_addr);
raw_write_daif(SPSR_EXCEPTION_MASK); - dcache_disable(); + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) + dcache_disable();
atf_entry(bl31_params, (void *)fdt_addr); }
At present gd->ram_size is 0 in SPL, meaning that it is not possible to enable the cache. Correct this by always populating the RAM size correctly.
Part of the confusion here comes from the large blocks of code which are #ifdefed out. Add a function phase_sdram_init() which returns whether SDRAM init should happen in the current phase, using that as needed to control the code flow.
This increases code size by about 500 bytes in SPL when the cache is on, since it must call the rather large rockchip_sdram_size() function.
Changes in v2: - Add new patch to correct memory size in SPL
drivers/ram/rockchip/sdram_rk3399.c | 49 ++++++++++++++++------------- 1 file changed, 27 insertions(+), 22 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 02cc4a38cf0..2f37dd712e7 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -13,6 +13,7 @@ #include <log.h> #include <ram.h> #include <regmap.h> +#include <spl.h> #include <syscon.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru.h> @@ -63,8 +64,6 @@ struct chan_info { };
struct dram_info { -#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) u32 pwrup_srefresh_exit[2]; struct chan_info chan[2]; struct clk ddr_clk; @@ -75,7 +74,6 @@ struct dram_info { struct rk3399_pmusgrf_regs *pmusgrf; struct rk3399_ddr_cic_regs *cic; const struct sdram_rk3399_ops *ops; -#endif struct ram_info info; struct rk3399_pmugrf_regs *pmugrf; }; @@ -92,9 +90,6 @@ struct sdram_rk3399_ops { struct rk3399_sdram_params *params); };
-#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) - struct rockchip_dmc_plat { #if CONFIG_IS_ENABLED(OF_PLATDATA) struct dtd_rockchip_rk3399_dmc dtplat; @@ -191,6 +186,17 @@ struct io_setting { }, };
+/** + * phase_sdram_init() - Check if this is the phase where SDRAM init happens + * + * Returns: true to do SDRAM init in this phase, false to not + */ +static bool phase_sdram_init(void) +{ + return spl_phase() == PHASE_TPL || + (!IS_ENABLED(CONFIG_TPL) && !spl_in_proper()); +} + static struct io_setting * lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) { @@ -3024,7 +3030,7 @@ static int rk3399_dmc_of_to_plat(struct udevice *dev) struct rockchip_dmc_plat *plat = dev_get_plat(dev); int ret;
- if (!CONFIG_IS_ENABLED(OF_REAL)) + if (!CONFIG_IS_ENABLED(OF_REAL) || !phase_sdram_init()) return 0;
ret = dev_read_u32_array(dev, "rockchip,sdram-params", @@ -3138,23 +3144,25 @@ static int rk3399_dmc_init(struct udevice *dev)
return 0; } -#endif
static int rk3399_dmc_probe(struct udevice *dev) { -#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) - if (rk3399_dmc_init(dev)) - return 0; -#else struct dram_info *priv = dev_get_priv(dev);
- priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); - debug("%s: pmugrf = %p\n", __func__, priv->pmugrf); - priv->info.base = CFG_SYS_SDRAM_BASE; - priv->info.size = - rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg2); -#endif + if (phase_sdram_init()) { + if (rk3399_dmc_init(dev)) + return 0; + } else { + priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + debug("%s: pmugrf = %p\n", __func__, priv->pmugrf); + } + + if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) { + priv->info.base = CFG_SYS_SDRAM_BASE; + priv->info.size = + rockchip_sdram_size((ulong)&priv->pmugrf->os_reg2); + } + return 0; }
@@ -3181,10 +3189,7 @@ U_BOOT_DRIVER(dmc_rk3399) = { .id = UCLASS_RAM, .of_match = rk3399_dmc_ids, .ops = &rk3399_dmc_ops, -#if defined(CONFIG_TPL_BUILD) || \ - (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) .of_to_plat = rk3399_dmc_of_to_plat, -#endif .probe = rk3399_dmc_probe, .priv_auto = sizeof(struct dram_info), #if defined(CONFIG_TPL_BUILD) || \
Hi Simon,
Changes in v2:
- phase_sdram_init() - Check if this is the phase where SDRAM init happens
- Returns: true to do SDRAM init in this phase, false to not
- return spl_phase() == PHASE_TPL ||
- static struct io_setting * lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) {
return 0; } -#endif
- priv->info.size =
-#endif
- if (phase_sdram_init()) {
- } else {
- if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) {
priv->info.size =
Isn't the whole change summarized to making sure that priv->info.base and priv->info.size are set when DCACHE is enabled AND we're in the first stage BL (TPL or SPL if no TPL)?
i.e., shouldn't the following code be enough:
""" static int rk3399_dmc_probe(struct udevice *dev) { #if defined(CONFIG_TPL_BUILD) || \ (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) if (rk3399_dmc_init(dev)) return 0; #else struct dram_info *priv = dev_get_priv(dev);
priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); debug("%s: pmugrf = %p\n", __func__, priv->pmugrf); #endif priv->info.base = CFG_SYS_SDRAM_BASE; priv->info.size = rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg2);
return 0; } """ ?
Then what's after the endif could be guarded by if (!CONFIG_IS_ENABLED(SYS_DCACHE_OFF)) { if we need to but it's not clear to me why that is needed?
Basically, I'm not sure the migration from ifdefs to the phase_sdram_init() function is necessary. I'm not against it, but it makes the whole thing much harder to read and hides the actual changes.
Additionally, why was the cast to phys_addr_t changed to a ulong? The function actually expects a phys_addr_t.
Finally, can you please explain why gd->ram_size being 0 is an issue for the caches, where is this checked? I'm not too familiar with the caches in general :)
Cheers, Quentin
Hi Simon and Quentin,
On 2024-06-11 13:27, Quentin Schulz wrote:
Hi Simon,
Changes in v2:
return 0; } -#endif
- priv->info.size =
-#endif
- } else {
priv->info.size =
return 0; } """ ?
Agree, this look strange to me too and your diff much cleaner :-)
My best guess is that enabling of caches in SPL cause issue for bob/kevin because they only use SPL not TPL+SPL like (if I am not mistaken) all other Rockchip arm64 targets.
Using SPL-only was not something I tested when caches was enabled in SPL.
Maybe bob/kevin can be changed to also use TPL+SPL similar to all other RK3399 boards?
How U-Boot works on these chromebooks is still a mystery to me. If I understand correctly SPL is only involved for bare metal boot, if this is the case then using TPL + back-to-brom to load SPL should probably work fine?, and would align all RK3399 boards to work in a similar way.
Regards, Jonas
Cheers, Quentin
Hi Jonas,
Hi Simon,
Changes in v2:
} -#endif
- priv->info.size =
-#endif
- } else {
priv->info.size =
return 0; } """ ?
Once I repair my Gru Bob, I'll be able to finally migrate it to Linux but broken power and volume rocker buttons make it impossible to disable some of the EC security stuff :)
Anyway, my understanding is that coreboot is started by the BootROM, then it loads U-Boot as its payload (I assume SPL???) which allows to boot UEFI systems (coreboot doesn't).
I assume no TPL because we don't want to back-to-brom as coreboot's payload wouldn't be loaded by the BootROM so it wouldn't know what to do with it.
I'll let Simon answer and will religiously listen :)
Cheers, Quentin
Hi Quentin,
On Tue, 11 Jun 2024 at 05:27, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Changes in v2:
if (!CONFIG_IS_ENABLED(OF_REAL) || !phase_sdram_init()) return 0; ret = dev_read_u32_array(dev, "rockchip,sdram-params",
} -#endif
priv->info.size =
-#endif
} else {
priv->info.size =
Yes, that's the nub of it. Of course, it doesn't actually fix the problem. I presume the SRAM appears in the page tables?
Just to avoid increasing code size when the cache is off.
Yes well it would have been a lot better if I had put it in a separate patch, which I forgot to do.
Hmm that is something that we brought in for 32-bit machines. For 64-bit I don't really see why we are using it. It makes printf() hard.
But anyway, I should have left it alone :-)
It puts the MMU table just below the top of RAM which is currently base + size (0 + 0) = somewhere like (4GB - 64KB).
This causes a hang, so disable it. Unfortunately the RAM-size fix does not resolve the problem and I am unsure what is wrong. As soon as the cache is enabled the board appears to hang.
Fixes: 6d8cdfd1536 ("rockchip: spl: Enable caches to speed up checksum validation")
(no changes since v1)
configs/chromebook_bob_defconfig | 1 + configs/chromebook_kevin_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index acfe3934104..b2ecfa6050c 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_TEXT_BASE=0x00200000 diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index 95fdb418d82..da748e4f022 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1
Now that am335x_evm boots OK on the Beaglebone black, drop the latter and update the docs to cover the change.
Also add a few updates about 'make fit' and drop the note about the security review, as U-Boot's verified boot has had quite extensive review now.
Changes in v2: - Drop patch "regulator: rk8xx: Fix incorrect parameter" - Rewrite boneblack patch to onstead drop the target and update docs
board/ti/am335x/MAINTAINERS | 1 - configs/am335x_boneblack_vboot_defconfig | 94 ------------------------ configs/am335x_evm_defconfig | 3 +- doc/usage/fit/beaglebone_vboot.rst | 21 +++--- 4 files changed, 12 insertions(+), 107 deletions(-) delete mode 100644 configs/am335x_boneblack_vboot_defconfig
diff --git a/board/ti/am335x/MAINTAINERS b/board/ti/am335x/MAINTAINERS index 219c8715bf1..ed8800a2663 100644 --- a/board/ti/am335x/MAINTAINERS +++ b/board/ti/am335x/MAINTAINERS @@ -3,6 +3,5 @@ M: Tom Rini trini@konsulko.com S: Maintained F: board/ti/am335x/ F: include/configs/am335x_evm.h -F: configs/am335x_boneblack_vboot_defconfig F: configs/am335x_evm_defconfig F: configs/am335x_evm_spiboot_defconfig diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig deleted file mode 100644 index d473a1a793b..00000000000 --- a/configs/am335x_boneblack_vboot_defconfig +++ /dev/null @@ -1,94 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_CPU_INIT=y -# CONFIG_SPL_USE_ARCH_MEMCPY is not set -# CONFIG_SPL_USE_ARCH_MEMSET is not set -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" -CONFIG_AM33XX=y -CONFIG_CLOCK_SYNTHESIZER=y -CONFIG_SPL=y -CONFIG_ENV_OFFSET_REDUND=0x280000 -CONFIG_TIMESTAMP=y -CONFIG_FIT_SIGNATURE=y -CONFIG_FIT_VERBOSE=y -CONFIG_SYS_BOOTM_LEN=0x1000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -CONFIG_SPL_MUSB_NEW=y -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_NET=y -CONFIG_SPL_NET_VCI_STRING="AM33xx U-Boot SPL" -CONFIG_SPL_OS_BOOT=y -CONFIG_SPL_FALCON_BOOT_MMCSD=y -CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR=0x1700 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR=0x1500 -CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS=0x200 -CONFIG_CMD_SPL=y -CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 -# CONFIG_CMD_SETEXPR is not set -CONFIG_BOOTP_DNS2=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_DEV=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RETRY_COUNT=10 -CONFIG_BOOTP_SEND_HOSTNAME=y -# CONFIG_SPL_BLK is not set -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_SYS_BOOTCOUNT_BE=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_DM_I2C=y -CONFIG_MISC=y -CONFIG_SYS_I2C_EEPROM_ADDR=0x50 -# CONFIG_SPL_DM_MMC is not set -CONFIG_MMC_OMAP_HS=y -CONFIG_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_SMSC=y -CONFIG_PHY_GIGE=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_DM_PMIC=y -# CONFIG_SPL_DM_PMIC is not set -CONFIG_PMIC_TPS65217=y -CONFIG_SPL_POWER_TPS65910=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_TI=y -CONFIG_USB_GADGET=y -CONFIG_SPL_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_SPL_USB_ETHER=y -CONFIG_LZO=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index d243cb16e72..cabc181460a 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -13,6 +13,8 @@ CONFIG_AM335X_USB0_PERIPHERAL=y CONFIG_AM335X_USB1=y CONFIG_SPL=y CONFIG_TIMESTAMP=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_BOOTM_LEN=0x1000000 CONFIG_DISTRO_DEFAULTS=y @@ -119,5 +121,4 @@ CONFIG_SPL_USB_ETHER=y CONFIG_WDT=y # CONFIG_SPL_WDT is not set CONFIG_DYNAMIC_CRC_TABLE=y -CONFIG_RSA=y CONFIG_LZO=y diff --git a/doc/usage/fit/beaglebone_vboot.rst b/doc/usage/fit/beaglebone_vboot.rst index cd6bb141910..1360c71803c 100644 --- a/doc/usage/fit/beaglebone_vboot.rst +++ b/doc/usage/fit/beaglebone_vboot.rst @@ -67,18 +67,20 @@ a. Set up the environment variable to point to your toolchain. You will need
export CROSS_COMPILE=arm-linux-gnueabi-
-b. Configure and build U-Boot with verified boot enabled:: +b. Configure and build U-Boot with verified boot enabled. Note that we use the +am335x_evm target since it covers all boards based on the AM335x evaluation +board::
export UBOOT=/path/to/u-boot cd $UBOOT # You can add -j10 if you have 10 CPUs to make it faster - make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all - export UOUT=$UBOOT/b/am335x_boneblack_vboot + make O=b/am335x_evm am335x_evm_config all + export UOUT=$UBOOT/b/am335x_evm
c. You will now have a U-Boot image::
- file b/am335x_boneblack_vboot/u-boot-dtb.img - b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, + file b/am335x_evm/u-boot-dtb.img + b/am335x_evm/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, @@ -466,7 +468,7 @@ the private key that you signed with so that it can verify any kernels that you sign::
cd $UBOOT - make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb + make O=b/am335x_evm EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb
Here we are overriding the normal device tree file with our one, which contains the public key. @@ -597,14 +599,11 @@ Further Improvements
Several of the steps here can be easily automated. In particular it would be capital if signing and packaging a kernel were easy, perhaps a simple make -target in the kernel. +target in the kernel. A stating point for this is the 'make image.fit' target +for ARM64 in Linux from v6.9 onwards.
Some mention of how to use multiple .dtb files in a FIT might be useful.
-U-Boot's verified boot mechanism has not had a robust and independent security -review. Such a review should look at the implementation and its resistance to -attacks. - Perhaps the verified boot feature could be integrated into the Amstrom distribution.
participants (6)
Ilias Apalodimas
Jonas Karlman
Quentin Schulz
