[U-Boot] [PATCH V2] powerpc/85xx: Add workaround for errata USB-14 (enable on P204x/P3041/P50x0)
On P204x/P304x/P50x0 Rev1.0, USB transmit will result in false internal multi-bit ECC errors, which has impact on performance, so software should disable all ECC reporting from USB1 and USB2.
In formal release document, the errata number should be USB14 instead of USB138.
Signed-off-by: xulei Lei.Xu@freescale.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: xulei B33228@freescale.com --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 14 ++++++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 5 ++++- arch/powerpc/include/asm/immap_85xx.h | 9 +++++++++ 4 files changed, 30 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 5d72f4c..422782c 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -255,6 +255,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_P4080_ERRATUM_PCIE_A003 puts("Work-around for Erratum PCIe-A003 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_USB14 + puts("Work-around for Erratum USB14 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index de9d916..ab633d0 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -623,6 +623,20 @@ skip_l2: } #endif
+#ifdef CONFIG_SYS_FSL_ERRATUM_USB14 + /* On P204x/P304x/P50x0 Rev1.0, USB transmit will result internal + * multi-bit ECC errors which has impact on performance, so software + * should disable all ECC reporting from USB1 and USB2. + */ + if (IS_SVR_REV(get_svr(), 1, 0)) { + struct dcsr_dcfg_regs *dcfg = (struct dcsr_dcfg_regs *) + (CONFIG_SYS_DCSRBAR + CONFIG_SYS_DCSR_DCFG_OFFSET); + setbits_be32(&dcfg->ecccr1, + (DCSR_DCFG_ECC_DISABLE_USB1 | + DCSR_DCFG_ECC_DISABLE_USB2)); + } +#endif + #ifdef CONFIG_FMAN_ENET fman_enet_init(); #endif diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d57c178..4236835 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -333,6 +333,7 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 +#define CONFIG_SYS_FSL_ERRATUM_USB14 #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER @@ -365,6 +366,7 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 +#define CONFIG_SYS_FSL_ERRATUM_USB14 #define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER @@ -442,6 +444,7 @@ #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#define CONFIG_SYS_FSL_ERRATUM_USB14 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 @@ -473,7 +476,7 @@ #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 -#define CONFIG_SYS_FSL_ERRATUM_USB138 +#define CONFIG_SYS_FSL_ERRATUM_USB14 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003 #define CONFIG_SYS_FSL_ERRATUM_DDR_A003474 #define CONFIG_SYS_FSL_ERRATUM_A004699 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 4eb3f79..a94f748 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -3160,4 +3160,13 @@ struct ccsr_cluster_l2 { #define CONFIG_SYS_FSL_CLUSTER_1_L2 \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CLUSTER_1_L2_OFFSET) #endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + +#define CONFIG_SYS_DCSR_DCFG_OFFSET 0X20000 +struct dcsr_dcfg_regs { + u8 res_0[0x520]; + u32 ecccr1; +#define DCSR_DCFG_ECC_DISABLE_USB1 0x00008000 +#define DCSR_DCFG_ECC_DISABLE_USB2 0x00004000 + u8 res_524[0x1000 - 0x524]; /* 0x524 - 0x1000 */ +}; #endif /*__IMMAP_85xx__*/
xulei
