[U-Boot] [PATCH 4/7] driver: net: ldpaa: Report back only error frames for tx
Management Complex FW 9.0 puts a new requirement to provide Tx confirmation and error queue configuration by calling dpni_set_tx_conf API.
Configure report of only error frames for a tx frame.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- drivers/net/ldpaa_eth/ldpaa_eth.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 85eb2c4..a2e455f 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -783,6 +783,7 @@ static int ldpaa_dpni_bind(struct ldpaa_eth_priv *priv) { struct dpni_pools_cfg pools_params; struct dpni_tx_flow_cfg dflt_tx_flow; + struct dpni_tx_conf_cfg tx_conf_cfg; int err = 0;
pools_params.num_dpbp = 1; @@ -807,6 +808,17 @@ static int ldpaa_dpni_bind(struct ldpaa_eth_priv *priv) return err; }
+ memset(&tx_conf_cfg, 0, sizeof(struct dpni_tx_conf_cfg)); + tx_conf_cfg.errors_only = true; + /*Set tx-conf and error configuration*/ + err = dpni_set_tx_conf(dflt_mc_io, MC_CMD_NO_FLAGS, + dflt_dpni->dpni_handle, + priv->tx_flow_id, &tx_conf_cfg); + if (err) { + printf("dpni_set_tx_conf() failed\n"); + return err; + } + return 0; }
Slightly reformat commit message. Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Prabhakar Kushwaha
york sun
