[U-Boot] OMAP3 move declaration of gpmc_cfg
This is cleanup of omap3 board config files.
This is the link to the thread on the list http://lists.denx.de/pipermail/u-boot/2009-November/064351.html
This was regression tested with MAKEALL arm and runtested on Zoom2
Tom
Every omap3 board config file declared the global variable gpmc_cfg. This changes moves the declaration to a better location in the arch dependent header file cpu.h.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/asm-arm/arch-omap3/cpu.h | 4 ++++ include/configs/devkit8000.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_sdp3430.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap3_zoom2.h | 1 - 9 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/include/asm-arm/arch-omap3/cpu.h b/include/asm-arm/arch-omap3/cpu.h index e51c4f3..aa8de32 100644 --- a/include/asm-arm/arch-omap3/cpu.h +++ b/include/asm-arm/arch-omap3/cpu.h @@ -136,6 +136,10 @@ struct gpmc { u32 ecc8_result; /* 0x21C */ u32 ecc9_result; /* 0x220 */ }; + +/* Used for board specific gpmc initialization */ +extern struct gpmc *gpmc_cfg; + #else /* __ASSEMBLY__ */ #define GPMC_CONFIG1 0x00 #define GPMC_CONFIG2 0x04 diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 1011770..7487bb7 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -299,7 +299,6 @@ #define CONFIG_ENV_OFFSET boot_flash_off
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 024b9b8..70186ce 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -314,7 +314,6 @@ #define CONFIG_SYS_JFFS2_NUM_BANKS 1
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 6709edc..162bfea 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -295,7 +295,6 @@ #define CONFIG_SYS_JFFS2_NUM_BANKS 1
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 0f812a7..ff25aba 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -299,7 +299,6 @@ #define CONFIG_SYS_JFFS2_NUM_BANKS 1
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 0cafeb8..838b1ad 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -292,7 +292,6 @@ #define CONFIG_SYS_JFFS2_NUM_BANKS 1
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index d91c8ff..a2a4b8a 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -361,7 +361,6 @@ /*--------------------------------------------------------------------------*/
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 2aef973..62a6340 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -300,7 +300,6 @@ #define CONFIG_SYS_JFFS2_NUM_BANKS 1
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index 5b03fb6..5296630 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -255,7 +255,6 @@ #define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ)
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Tom Rix Sent: Tuesday, November 17, 2009 2:20 AM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] OMAP3 Move declaration of gpmc_cfg.
Hi Tom,
Wouldn't omap_gpmc.h be a better place for this?
Sorry, I had missed this post earlier; but found after implementing the change for omap3evm and am3517evm; Came across this port while following the trail for removing other externs from the config files.
Best regards, Sanjeev
#ifndef __ASSEMBLY__ -extern struct gpmc *gpmc_cfg; extern unsigned int boot_flash_base; extern volatile unsigned int boot_flash_env_addr; extern unsigned int boot_flash_off; -- 1.6.0.6
Pushed to u-boot-ti
Thanks, Sandeep
Paulraj, Sandeep
Premi, Sanjeev
Tom Rix
